Pull request efi-2023-07-rc5
Dear Tom,
The following changes since commit 2f4664f5c3edc55b18d8906f256a4c8e303243c0:
Merge branch '2023-06-14-assorted-fixes' (2023-06-14 15:50:04 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2023-07-rc5
for you to fetch changes up to 5669591dd8d2b21bc79237b161107300eb7f2b12:
efi_selftests: fix protocol repeated selftesting (2023-06-16 06:48:46 +0200)
Gitlab showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16607
---------------------------------------------------------------- Pull request efi-2023-07-rc5
Documentation:
* man-page for imxtract * correct EVT_DM_POST_INIT_F description
UEFI:
* bootm: don't call booti_setup for EFI images * simplify efi_disk_remove * fix tests that failed when executed repeatedly
---------------------------------------------------------------- Bin Meng (1): doc: event: Correct EVT_DM_POST_INIT_F description
Heinrich Schuchardt (5): doc: man-page for imxtract Makefile: clean lib/efi_loader/helloworld_efi.S efi_selftest: ReinstallProtocolInterface test bootm: don't call booti_setup for EFI images test: correct architecture in EFI FIT test
Ilias Apalodimas (3): efi_selftests: fix controllers repeated selftesting efi_loader: simplify efi_disk_remove efi_selftests: fix protocol repeated selftesting
Makefile | 2 +- boot/bootm.c | 3 +- doc/develop/event.rst | 4 +- doc/usage/cmd/imxtract.rst | 81 ++++++++++++++++++++++ doc/usage/index.rst | 1 + lib/efi_loader/efi_disk.c | 91 +++++++------------------ lib/efi_selftest/efi_selftest_controllers.c | 26 ++++++- lib/efi_selftest/efi_selftest_manageprotocols.c | 2 + lib/efi_selftest/efi_selftest_register_notify.c | 25 +++++++ test/py/tests/test_efi_fit.py | 5 ++ 10 files changed, 170 insertions(+), 70 deletions(-) create mode 100644 doc/usage/cmd/imxtract.rst
On Fri, Jun 16, 2023 at 09:22:30AM +0200, Heinrich Schuchardt wrote:
Dear Tom,
