[PATCH u-boot-net 00/14] u-boot-net refactors, fixes, cleanups
So I wanted to solve a problem regarding MDIO bus within mvneta driver, to make it use the mvmdio DM driver instead of the non-DM MDIO bus registered during mvneta probe, and improve some other things there, and it seems like I opened a small bag from hell, which resulted in this series of refactors, fixes and cleanups in the network subsystem.
The series applies on Tom's master branch. It won't apply to u-boot-next's master nor net, those are too old.
This series was CI tested (https://github.com/u-boot/u-boot/pull/142).
Marek Behún (14): net: mdio-uclass: fix type for phy_mode_str and phy_handle_str net: mdio-uclass: use ARRAY_SIZE() net: introduce helpers to get PHY ofnode from MAC net: mdio-uclass: add wrappers for read/write/reset operations treewide: use dm_mdio_read/write/reset() wrappers net: phy: fix parsing wrong property net: introduce helpers to get PHY interface mode from a device/ofnode treewide: Rename PHY_INTERFACE_MODE_COUNT to PHY_INTERFACE_MODE_MAX treewide: Rename PHY_INTERFACE_MODE_NONE to PHY_INTERFACE_MODE_NA phy: Move PHY_INTERFACE_MODE_NA to the beginning of the enum definition net: phy: xilinx: Check interface type in ->config(), not ->probe() net: phy: use ->is_c45 instead of is_10g_interface() bcmgenet, sun8i_emac: Don't connect PHY two times net: phy: don't require PHY interface mode during PHY creation
board/CZ.NIC/turris_mox/turris_mox.c | 2 +- board/boundary/nitrogen6x/nitrogen6x.c | 2 +- board/freescale/corenet_ds/eth_hydra.c | 2 +- board/freescale/corenet_ds/eth_superhydra.c | 4 +- board/freescale/t104xrdb/eth.c | 4 +- board/gdsys/a38x/controlcenterdc.c | 7 +- board/gdsys/a38x/ihs_phys.c | 6 +- board/st/stm32f746-disco/stm32f746-disco.c | 13 +-- drivers/core/ofnode.c | 44 ++++++++ drivers/core/read.c | 10 ++ drivers/net/ag7xxx.c | 9 +- drivers/net/altera_tse.c | 17 +-- drivers/net/bcm6348-eth.c | 8 +- drivers/net/bcmgenet.c | 12 +- drivers/net/designware.c | 10 +- drivers/net/dwc_eth_qos.c | 40 +------ drivers/net/ethoc.c | 4 +- drivers/net/fec_mxc.c | 15 +-- drivers/net/fm/b4860.c | 8 +- drivers/net/fm/eth.c | 13 +-- drivers/net/fm/init.c | 8 +- drivers/net/fm/ls1043.c | 6 +- drivers/net/fm/ls1046.c | 8 +- drivers/net/fm/p1023.c | 4 +- drivers/net/fm/p4080.c | 6 +- drivers/net/fm/p5020.c | 6 +- drivers/net/fm/p5040.c | 6 +- drivers/net/fm/t1024.c | 4 +- drivers/net/fm/t1040.c | 4 +- drivers/net/fm/t2080.c | 6 +- drivers/net/fm/t4240.c | 6 +- drivers/net/fsl_enetc.c | 13 +-- drivers/net/ftgmac100.c | 11 +- drivers/net/higmacv300.c | 9 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 28 +---- drivers/net/ldpaa_eth/ldpaa_wriop.c | 10 +- drivers/net/ldpaa_eth/ls1088a.c | 4 +- drivers/net/ldpaa_eth/ls2080a.c | 4 +- drivers/net/ldpaa_eth/lx2160a.c | 4 +- drivers/net/macb.c | 10 +- drivers/net/mdio_mux_sandbox.c | 6 +- drivers/net/mscc_eswitch/jr2_switch.c | 2 +- drivers/net/mscc_eswitch/luton_switch.c | 2 +- drivers/net/mscc_eswitch/ocelot_switch.c | 2 +- drivers/net/mscc_eswitch/serval_switch.c | 2 +- drivers/net/mscc_eswitch/servalt_switch.c | 2 +- drivers/net/mt7620-eth.c | 45 +++----- drivers/net/mtk_eth.c | 8 +- drivers/net/mvgbe.c | 7 +- drivers/net/mvneta.c | 11 +- drivers/net/mvpp2.c | 9 +- drivers/net/pch_gbe.c | 4 +- drivers/net/phy/aquantia.c | 2 +- drivers/net/phy/phy.c | 115 +++++++------------- drivers/net/phy/xilinx_gmii2rgmii.c | 14 +-- drivers/net/pic32_eth.c | 11 +- drivers/net/qe/dm_qe_uec.c | 11 +- drivers/net/ravb.c | 19 +--- drivers/net/sh_eth.c | 19 +--- drivers/net/sni_ave.c | 16 +-- drivers/net/sni_netsec.c | 10 +- drivers/net/sun8i_emac.c | 13 +-- drivers/net/sunxi_emac.c | 5 +- drivers/net/ti/am65-cpsw-nuss.c | 15 +-- drivers/net/ti/cpsw.c | 10 +- drivers/net/ti/keystone_net.c | 24 ++-- drivers/net/tsec.c | 9 +- drivers/net/xilinx_axi_emac.c | 10 +- drivers/net/zynq_gem.c | 9 +- include/_exports.h | 3 +- include/dm/ofnode.h | 27 +++++ include/dm/read.h | 36 ++++++ include/exports.h | 3 +- include/fm_eth.h | 2 +- include/miiphy.h | 31 ++++++ include/phy.h | 32 ++---- include/phy_interface.h | 11 +- include/vsc9953.h | 2 +- net/mdio-mux-uclass.c | 16 +-- net/mdio-uclass.c | 96 ++++++++-------- test/dm/mdio.c | 18 +-- test/dm/mdio_mux.c | 16 +-- 82 files changed, 469 insertions(+), 623 deletions(-)
These global variables should both have type static const char * const
Signed-off-by: Marek Behún marek.behun@nic.cz --- net/mdio-uclass.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index e74e34f78f..5735afe49e 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -17,13 +17,14 @@
/* DT node properties for MAC-PHY interface */ #define PHY_MODE_STR_CNT 2 -static const char *phy_mode_str[PHY_MODE_STR_CNT] = { "phy-mode", - "phy-connection-type" }; +static const char * const phy_mode_str[PHY_MODE_STR_CNT] = { + "phy-mode", "phy-connection-type" +}; /* DT node properties that reference a PHY node */ #define PHY_HANDLE_STR_CNT 3 -const char *phy_handle_str[PHY_HANDLE_STR_CNT] = { "phy-handle", - "phy", - "phy-device" }; +static const char * const phy_handle_str[PHY_HANDLE_STR_CNT] = { + "phy-handle", "phy", "phy-device" +};
void dm_mdio_probe_devices(void) {
"phy",
"phy-device" };
void dm_mdio_probe_devices(void) { -- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Use the ARRAY_SIZE() macro instead of hardcoding sizes of arrays in macors.
Signed-off-by: Marek Behún marek.behun@nic.cz --- net/mdio-uclass.c | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 5735afe49e..649dc60f73 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -16,13 +16,12 @@ #include <linux/compat.h>
/* DT node properties for MAC-PHY interface */ -#define PHY_MODE_STR_CNT 2 -static const char * const phy_mode_str[PHY_MODE_STR_CNT] = { +static const char * const phy_mode_str[] = { "phy-mode", "phy-connection-type" }; + /* DT node properties that reference a PHY node */ -#define PHY_HANDLE_STR_CNT 3 -static const char * const phy_handle_str[PHY_HANDLE_STR_CNT] = { +static const char * const phy_handle_str[] = { "phy-handle", "phy", "phy-device" };
@@ -149,7 +148,7 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, goto out; }
- for (i = 0; i < PHY_HANDLE_STR_CNT; i++) + for (i = 0; i < ARRAY_SIZE(phy_handle_str); i++) if (!dev_read_phandle_with_args(ethdev, phy_handle_str[i], NULL, 0, 0, &phandle)) break; @@ -199,7 +198,7 @@ struct phy_device *dm_eth_phy_connect(struct udevice *ethdev) }
interface = PHY_INTERFACE_MODE_NONE; - for (i = 0; i < PHY_MODE_STR_CNT; i++) { + for (i = 0; i < ARRAY_SIZE(phy_mode_str); i++) { if_str = dev_read_string(ethdev, phy_mode_str[i]); if (if_str) { interface = phy_get_interface_by_name(if_str);
macros.
-- 2.34.1
Add helpers ofnode_get_phy_node() and dev_get_phy_node() and use it in net/mdio-uclass.c function dm_eth_connect_phy_handle().
This is useful because other part's of U-Boot may want to get PHY ofnode without connecting a PHY.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/core/ofnode.c | 21 +++++++++++++++++++++ drivers/core/read.c | 5 +++++ include/dm/ofnode.h | 14 ++++++++++++++ include/dm/read.h | 19 +++++++++++++++++++ net/mdio-uclass.c | 24 ++++++------------------ 5 files changed, 65 insertions(+), 18 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 709bea272a..eaad2c989b 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1162,3 +1162,24 @@ const char *ofnode_conf_read_str(const char *prop_name)
return ofnode_read_string(node, prop_name); } + +ofnode ofnode_get_phy_node(ofnode node) +{ + /* DT node properties that reference a PHY node */ + static const char * const phy_handle_str[] = { + "phy-handle", "phy", "phy-device", + }; + struct ofnode_phandle_args args = { + .node = ofnode_null() + }; + int i; + + assert(ofnode_valid(node)); + + for (i = 0; i < ARRAY_SIZE(phy_handle_str); i++) + if (!ofnode_parse_phandle_with_args(node, phy_handle_str[i], + NULL, 0, 0, &args)) + break; + + return args.node; +} diff --git a/drivers/core/read.c b/drivers/core/read.c index 31f9e78a06..7ff100218d 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -398,3 +398,8 @@ int dev_decode_display_timing(const struct udevice *dev, int index, { return ofnode_decode_display_timing(dev_ofnode(dev), index, config); } + +ofnode dev_get_phy_node(const struct udevice *dev) +{ + return ofnode_get_phy_node(dev_ofnode(dev)); +} diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 0cb324c8b0..8164386043 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1204,4 +1204,18 @@ int ofnode_conf_read_int(const char *prop_name, int default_val); */ const char *ofnode_conf_read_str(const char *prop_name);
+/** + * ofnode_get_phy_node() - Get PHY node for a MAC (if not fixed-link) + * + * This function parses PHY handle from the Ethernet controller's ofnode + * (trying all possible PHY handle property names), and returns the PHY ofnode. + * + * Before this is used, ofnode_phy_is_fixed_link() should be checked first, and + * if the result to that is true, this function should not be called. + * + * @eth_node: ofnode belonging to the Ethernet controller + * Return: ofnode of the PHY, if it exists, otherwise an invalid ofnode + */ +ofnode ofnode_get_phy_node(ofnode eth_node); + #endif diff --git a/include/dm/read.h b/include/dm/read.h index 233af3c063..899eb813fd 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -743,6 +743,20 @@ int dev_read_pci_bus_range(const struct udevice *dev, struct resource *res); int dev_decode_display_timing(const struct udevice *dev, int index, struct display_timing *config);
+/** + * dev_get_phy_node() - Get PHY node for a MAC (if not fixed-link) + * + * This function parses PHY handle from the Ethernet controller's ofnode + * (trying all possible PHY handle property names), and returns the PHY ofnode. + * + * Before this is used, ofnode_phy_is_fixed_link() should be checked first, and + * if the result to that is true, this function should not be called. + * + * @dev: device representing the MAC + * Return: ofnode of the PHY, if it exists, otherwise an invalid ofnode + */ +ofnode dev_get_phy_node(const struct udevice *dev); + #else /* CONFIG_DM_DEV_READ_INLINE is enabled */ #include <asm/global_data.h>
@@ -1092,6 +1106,11 @@ static inline int dev_decode_display_timing(const struct udevice *dev, return ofnode_decode_display_timing(dev_ofnode(dev), index, config); }
+static inline ofnode dev_get_phy_node(const struct udevice *dev) +{ + return ofnode_get_phy_node(dev_ofnode(dev)); +} + #endif /* CONFIG_DM_DEV_READ_INLINE */
/** diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 649dc60f73..233b70171b 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -20,11 +20,6 @@ static const char * const phy_mode_str[] = { "phy-mode", "phy-connection-type" };
-/* DT node properties that reference a PHY node */ -static const char * const phy_handle_str[] = { - "phy-handle", "phy", "phy-device" -}; - void dm_mdio_probe_devices(void) { struct udevice *it; @@ -137,23 +132,16 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, u32 phy_addr; struct udevice *mdiodev; struct phy_device *phy; - struct ofnode_phandle_args phandle = {.node = ofnode_null()}; ofnode phynode; - int i;
if (CONFIG_IS_ENABLED(PHY_FIXED) && ofnode_phy_is_fixed_link(dev_ofnode(ethdev), &phynode)) { phy = phy_connect(NULL, 0, ethdev, interface); - phandle.node = phynode; goto out; }
- for (i = 0; i < ARRAY_SIZE(phy_handle_str); i++) - if (!dev_read_phandle_with_args(ethdev, phy_handle_str[i], NULL, - 0, 0, &phandle)) - break; - - if (!ofnode_valid(phandle.node)) { + phynode = dev_get_phy_node(ethdev); + if (!ofnode_valid(phynode)) { dev_dbg(ethdev, "can't find PHY node\n"); return NULL; } @@ -162,16 +150,16 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, * reading 'reg' directly should be fine. This is a PHY node, the * address is always size 1 and requires no translation */ - if (ofnode_read_u32(phandle.node, "reg", &phy_addr)) { + if (ofnode_read_u32(phynode, "reg", &phy_addr)) { dev_dbg(ethdev, "missing reg property in phy node\n"); return NULL; }
if (uclass_get_device_by_ofnode(UCLASS_MDIO, - ofnode_get_parent(phandle.node), + ofnode_get_parent(phynode), &mdiodev)) { dev_dbg(ethdev, "can't find MDIO bus for node %s\n", - ofnode_get_name(ofnode_get_parent(phandle.node))); + ofnode_get_name(ofnode_get_parent(phynode))); return NULL; }
@@ -179,7 +167,7 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev,
out: if (phy) - phy->node = phandle.node; + phy->node = phynode;
return phy; }
int i;
NULL, 0, 0, &args))
break;
return args.node;
- ofnode_get_phy_node() - Get PHY node for a MAC (if not fixed-link)
- This function parses PHY handle from the Ethernet controller's ofnode
- (trying all possible PHY handle property names), and returns the PHY ofnode.
- Before this is used, ofnode_phy_is_fixed_link() should be checked first, and
- if the result to that is true, this function should not be called.
- @eth_node: ofnode belonging to the Ethernet controller
- Return: ofnode of the PHY, if it exists, otherwise an invalid ofnode
- dev_get_phy_node() - Get PHY node for a MAC (if not fixed-link)
- @dev: device representing the MAC
int i; if (CONFIG_IS_ENABLED(PHY_FIXED) && ofnode_phy_is_fixed_link(dev_ofnode(ethdev), &phynode)) { phy = phy_connect(NULL, 0, ethdev, interface);
0, 0, &phandle))
break;
if (ofnode_read_u32(phynode, "reg", &phy_addr)) { dev_dbg(ethdev, "missing reg property in phy node\n"); return NULL; } if (uclass_get_device_by_ofnode(UCLASS_MDIO,
out: if (phy)
phy->node = phynode; return phy;
2.34.1
Hi Marek,
Please add a test for your new function. With that:
On Mon, 28 Mar 2022 00:35:00 -0600 Simon Glass sjg@chromium.org wrote:
Hi Marek,
Dear Simon,
OK, I added test for ofnode_get_phy_node(). Should I also add one for dev_get_phy_node() ? That one is implemented in drivers/core/read.c or include/dm/read.h, and it just calls ofnode_get_phy_node()...
Also adding test for ofnode_get_phy_mode() (node -> mode) which is implemented in patch 07/14. Can I add your reviewde-by for that patch also? That patch is rather big, touches many files treewide...
Marek
Add wrappers dm_mdio_read(), dm_mdio_write() and dm_mdio_reset() for DM MDIO's .read(), .write() and .reset() operations.
Signed-off-by: Marek Behún marek.behun@nic.cz --- include/miiphy.h | 31 +++++++++++++++++++++++++++++++ net/mdio-uclass.c | 31 +++++++++++++++++++++++++++++++ 2 files changed, 62 insertions(+)
diff --git a/include/miiphy.h b/include/miiphy.h index 235ae066dd..110921f20d 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -157,6 +157,37 @@ struct mdio_ops { */ void dm_mdio_probe_devices(void);
+/** + * dm_mdio_read - Wrapper over .read() operation for DM MDIO + * + * @mdiodev: mdio device + * @addr: PHY address on MDIO bus + * @devad: device address on PHY if C45; should be MDIO_DEVAD_NONE if C22 + * @reg: register address + * Return: register value if non-negative, -error code otherwise + */ +int dm_mdio_read(struct udevice *mdio_dev, int addr, int devad, int reg); + +/** + * dm_mdio_write - Wrapper over .write() operation for DM MDIO + * + * @mdiodev: mdio device + * @addr: PHY address on MDIO bus + * @devad: device address on PHY if C45; should be MDIO_DEVAD_NONE if C22 + * @reg: register address + * @val: value to write + * Return: 0 on success, -error code otherwise + */ +int dm_mdio_write(struct udevice *mdio_dev, int addr, int devad, int reg, u16 val); + +/** + * dm_mdio_reset - Wrapper over .reset() operation for DM MDIO + * + * @mdiodev: mdio device + * Return: 0 on success, -error code otherwise + */ +int dm_mdio_reset(struct udevice *mdio_dev); + /** * dm_mdio_phy_connect - Wrapper over phy_connect for DM MDIO * diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 233b70171b..887c228167 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -57,6 +57,37 @@ static int dm_mdio_post_bind(struct udevice *dev) return 0; }
+int dm_mdio_read(struct udevice *mdio_dev, int addr, int devad, int reg) +{ + struct mdio_ops *ops = mdio_get_ops(mdio_dev); + + if (!ops->read) + return -ENOSYS; + + return ops->read(mdio_dev, addr, devad, reg); +} + +int dm_mdio_write(struct udevice *mdio_dev, int addr, int devad, int reg, + u16 val) +{ + struct mdio_ops *ops = mdio_get_ops(mdio_dev); + + if (!ops->write) + return -ENOSYS; + + return ops->write(mdio_dev, addr, devad, reg, val); +} + +int dm_mdio_reset(struct udevice *mdio_dev) +{ + struct mdio_ops *ops = mdio_get_ops(mdio_dev); + + if (!ops->reset) + return 0; + + return ops->reset(mdio_dev); +} + /* * Following read/write/reset functions are registered with legacy MII code. * These are called for PHY operations by upper layers and we further call the
- dm_mdio_read - Wrapper over .read() operation for DM MDIO
- @mdiodev: mdio device
- @addr: PHY address on MDIO bus
- @devad: device address on PHY if C45; should be MDIO_DEVAD_NONE if C22
- @reg: register address
- Return: register value if non-negative, -error code otherwise
- dm_mdio_write - Wrapper over .write() operation for DM MDIO
- @val: value to write
- Return: 0 on success, -error code otherwise
- dm_mdio_reset - Wrapper over .reset() operation for DM MDIO
- dm_mdio_phy_connect - Wrapper over phy_connect for DM MDIO
if (!ops->read)
return -ENOSYS;
u16 val)
if (!ops->write)
return -ENOSYS;
if (!ops->reset)
- Following read/write/reset functions are registered with legacy MII code.
- These are called for PHY operations by upper layers and we further call the
-- 2.34.1
Use the new dm_mdio_read/write/reset() wrappers treewide, instead of always getting and dereferencing MDIO operations structure pointer.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/net/mdio_mux_sandbox.c | 6 ++---- net/mdio-mux-uclass.c | 16 ++++------------ net/mdio-uclass.c | 19 ++++--------------- test/dm/mdio.c | 18 +++++++++--------- test/dm/mdio_mux.c | 16 ++++++++-------- 5 files changed, 27 insertions(+), 48 deletions(-)
diff --git a/drivers/net/mdio_mux_sandbox.c b/drivers/net/mdio_mux_sandbox.c index fff6ddb2f1..e1801c1426 100644 --- a/drivers/net/mdio_mux_sandbox.c +++ b/drivers/net/mdio_mux_sandbox.c @@ -20,7 +20,6 @@ struct mdio_mux_sandbox_priv { static int mdio_mux_sandbox_mark_selection(struct udevice *dev, int sel) { struct udevice *mdio; - struct mdio_ops *ops; int err;
/* @@ -30,9 +29,8 @@ static int mdio_mux_sandbox_mark_selection(struct udevice *dev, int sel) err = uclass_get_device_by_name(UCLASS_MDIO, "mdio-test", &mdio); if (err) return err; - ops = mdio_get_ops(mdio); - return ops->write(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG_CNT - 1, (u16)sel); + return dm_mdio_write(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG_CNT - 1, (u16)sel); }
static int mdio_mux_sandbox_select(struct udevice *dev, int cur, int sel) diff --git a/net/mdio-mux-uclass.c b/net/mdio-mux-uclass.c index 780526c19e..94b90e0657 100644 --- a/net/mdio-mux-uclass.c +++ b/net/mdio-mux-uclass.c @@ -54,11 +54,6 @@ static struct udevice *mmux_get_parent_mdio(struct udevice *mux) return pdata->mdio_parent; }
-static struct mdio_ops *mmux_get_mdio_parent_ops(struct udevice *mux) -{ - return mdio_get_ops(mmux_get_parent_mdio(mux)); -} - /* call driver select function before performing MDIO r/w */ static int mmux_change_sel(struct udevice *ch, bool sel) { @@ -90,14 +85,13 @@ static int mmux_read(struct udevice *ch, int addr, int devad, { struct udevice *mux = ch->parent; struct udevice *parent_mdio = mmux_get_parent_mdio(mux); - struct mdio_ops *parent_ops = mmux_get_mdio_parent_ops(mux); int err;
err = mmux_change_sel(ch, true); if (err) return err;
- err = parent_ops->read(parent_mdio, addr, devad, reg); + err = dm_mdio_read(parent_mdio, addr, devad, reg); mmux_change_sel(ch, false);
return err; @@ -109,14 +103,13 @@ static int mmux_write(struct udevice *ch, int addr, int devad, { struct udevice *mux = ch->parent; struct udevice *parent_mdio = mmux_get_parent_mdio(mux); - struct mdio_ops *parent_ops = mmux_get_mdio_parent_ops(mux); int err;
- err = parent_ops->write(parent_mdio, addr, devad, reg, val); + err = dm_mdio_write(parent_mdio, addr, devad, reg, val); mmux_change_sel(ch, false);
return err; @@ -127,18 +120,17 @@ static int mmux_reset(struct udevice *ch) { struct udevice *mux = ch->parent; struct udevice *parent_mdio = mmux_get_parent_mdio(mux); - struct mdio_ops *parent_ops = mmux_get_mdio_parent_ops(mux); int err;
/* reset is optional, if it's not implemented just exit */ - if (!parent_ops->reset) + if (!mdio_get_ops(parent_mdio)->reset) return 0;
- err = parent_ops->reset(parent_mdio); + err = dm_mdio_reset(parent_mdio); mmux_change_sel(ch, false);
return err; diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 887c228167..bef8280e21 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -95,27 +95,18 @@ int dm_mdio_reset(struct udevice *mdio_dev) */ static int mdio_read(struct mii_dev *mii_bus, int addr, int devad, int reg) { - struct udevice *dev = mii_bus->priv; - - return mdio_get_ops(dev)->read(dev, addr, devad, reg); + return dm_mdio_read(mii_bus->priv, addr, devad, reg); }
static int mdio_write(struct mii_dev *mii_bus, int addr, int devad, int reg, u16 val) { - struct udevice *dev = mii_bus->priv; - - return mdio_get_ops(dev)->write(dev, addr, devad, reg, val); + return dm_mdio_write(mii_bus->priv, addr, devad, reg, val); }
static int mdio_reset(struct mii_dev *mii_bus) { - struct udevice *dev = mii_bus->priv; - - if (mdio_get_ops(dev)->reset) - return mdio_get_ops(dev)->reset(dev); - else - return 0; + return dm_mdio_reset(mii_bus->priv); }
static int dm_mdio_post_probe(struct udevice *dev) @@ -135,10 +126,8 @@ static int dm_mdio_post_probe(struct udevice *dev) static int dm_mdio_pre_remove(struct udevice *dev) { struct mdio_perdev_priv *pdata = dev_get_uclass_priv(dev); - struct mdio_ops *ops = mdio_get_ops(dev);
- if (ops->reset) - ops->reset(dev); + dm_mdio_reset(dev); mdio_unregister(pdata->mii_bus); mdio_free(pdata->mii_bus);
diff --git a/test/dm/mdio.c b/test/dm/mdio.c index 64347e1275..f863c52645 100644 --- a/test/dm/mdio.c +++ b/test/dm/mdio.c @@ -38,18 +38,18 @@ static int dm_test_mdio(struct unit_test_state *uts) ut_assertnonnull(ops->read); ut_assertnonnull(ops->write);
- ut_assertok(ops->write(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG, TEST_REG_VALUE)); - reg = ops->read(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG); + ut_assertok(dm_mdio_write(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG, TEST_REG_VALUE)); + reg = dm_mdio_read(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG); ut_asserteq(reg, TEST_REG_VALUE);
- ut_assert(ops->read(dev, SANDBOX_PHY_ADDR + 1, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG) != 0); + ut_assert(dm_mdio_read(dev, SANDBOX_PHY_ADDR + 1, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG) != 0);
- ut_assertok(ops->reset(dev)); - reg = ops->read(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG); + ut_assertok(dm_mdio_reset(dev)); + reg = dm_mdio_read(dev, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG); ut_asserteq(reg, 0);
return 0; diff --git a/test/dm/mdio_mux.c b/test/dm/mdio_mux.c index 950f385d17..bfe3518221 100644 --- a/test/dm/mdio_mux.c +++ b/test/dm/mdio_mux.c @@ -57,22 +57,22 @@ static int dm_test_mdio_mux(struct unit_test_state *uts) * is selected to the selection #. Just reading that register from * either of the child buses should return the id of the child bus */ - reg = ops->read(mdio_ch0, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG_CNT - 1); + reg = dm_mdio_read(mdio_ch0, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, 0);
- reg = ops->read(mdio_ch1, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG_CNT - 1); + reg = dm_mdio_read(mdio_ch1, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, 1);
mmops->select(mux, MDIO_MUX_SELECT_NONE, 5); - reg = ops_parent->read(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG_CNT - 1); + reg = dm_mdio_read(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, 5);
mmops->deselect(mux, 5); - reg = ops_parent->read(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, - SANDBOX_PHY_REG_CNT - 1); + reg = dm_mdio_read(mdio, SANDBOX_PHY_ADDR, MDIO_DEVAD_NONE, + SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, (u16)MDIO_MUX_SELECT_NONE);
struct mdio_ops *ops; int err; /*
struct mdio_ops *parent_ops = mmux_get_mdio_parent_ops(mux); int err; err = mmux_change_sel(ch, true); if (err) return err;
err = dm_mdio_read(parent_mdio, addr, devad, reg); mmux_change_sel(ch, false); return err;
err = dm_mdio_write(parent_mdio, addr, devad, reg, val); mmux_change_sel(ch, false); return err;
struct mdio_ops *parent_ops = mmux_get_mdio_parent_ops(mux); int err; /* reset is optional, if it's not implemented just exit */
if (!mdio_get_ops(parent_mdio)->reset) return 0; err = mmux_change_sel(ch, true); if (err) return err;
err = dm_mdio_reset(parent_mdio); mmux_change_sel(ch, false); return err;
else
if (ops->reset)
ops->reset(dev);
SANDBOX_PHY_REG);
SANDBOX_PHY_REG);
SANDBOX_PHY_REG); ut_asserteq(reg, 0); return 0;
SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, 1); mmops->select(mux, MDIO_MUX_SELECT_NONE, 5);
SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, 5); mmops->deselect(mux, 5);
SANDBOX_PHY_REG_CNT - 1); ut_asserteq(reg, (u16)MDIO_MUX_SELECT_NONE); return 0;
-- 2.34.1
The "phy-interface-type" property should be "phy-connection-type".
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/net/phy/phy.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index c9fc20855b..fe6dbdaee4 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -989,7 +989,7 @@ struct phy_device *fixed_phy_create(ofnode node)
if_str = ofnode_read_string(node, "phy-mode"); if (!if_str) { - if_str = ofnode_read_string(node, "phy-interface-type"); + if_str = ofnode_read_string(node, "phy-connection-type"); } if (if_str) { interface = phy_get_interface_by_name(if_str);
-- 2.34.1
Add helpers ofnode_read_phy_mode() and dev_read_phy_mode() to parse the "phy-mode" / "phy-connection-type" property.
Use them treewide.
This allows us to inline the phy_get_interface_by_name() into ofnode_read_phy_mode(), since the former is not used anymore.
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/st/stm32f746-disco/stm32f746-disco.c | 13 +++----- drivers/core/ofnode.c | 23 ++++++++++++++ drivers/core/read.c | 5 +++ drivers/net/ag7xxx.c | 9 ++---- drivers/net/altera_tse.c | 13 ++------ drivers/net/bcm6348-eth.c | 6 +--- drivers/net/bcmgenet.c | 10 ++---- drivers/net/designware.c | 10 ++---- drivers/net/dwc_eth_qos.c | 36 +++------------------- drivers/net/fec_mxc.c | 11 ++----- drivers/net/fm/eth.c | 13 +------- drivers/net/fsl_enetc.c | 13 +++----- drivers/net/ftgmac100.c | 11 ++----- drivers/net/higmacv300.c | 9 ++---- drivers/net/ldpaa_eth/ldpaa_eth.c | 28 +++-------------- drivers/net/macb.c | 10 ++---- drivers/net/mt7620-eth.c | 35 +++++++-------------- drivers/net/mtk_eth.c | 8 ++--- drivers/net/mvgbe.c | 7 ++--- drivers/net/mvneta.c | 11 ++----- drivers/net/mvpp2.c | 9 ++---- drivers/net/phy/phy.c | 25 ++------------- drivers/net/pic32_eth.c | 11 ++----- drivers/net/qe/dm_qe_uec.c | 11 ++----- drivers/net/ravb.c | 15 +++------ drivers/net/sh_eth.c | 15 +++------ drivers/net/sni_ave.c | 12 ++------ drivers/net/sni_netsec.c | 10 ++---- drivers/net/sun8i_emac.c | 11 ++----- drivers/net/ti/am65-cpsw-nuss.c | 15 +++------ drivers/net/ti/cpsw.c | 10 ++---- drivers/net/ti/keystone_net.c | 24 +++++++-------- drivers/net/tsec.c | 9 ++---- drivers/net/xilinx_axi_emac.c | 10 ++---- drivers/net/zynq_gem.c | 9 ++---- include/dm/ofnode.h | 13 ++++++++ include/dm/read.h | 17 ++++++++++ include/phy.h | 8 ----- net/mdio-uclass.c | 18 +---------- 39 files changed, 161 insertions(+), 372 deletions(-)
diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 95d83e73ee..69f657c54b 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -117,16 +117,13 @@ int board_late_init(void) int board_init(void) { #ifdef CONFIG_ETH_DESIGNWARE - const char *phy_mode; - int node; + ofnode node;
- node = fdt_node_offset_by_compatible(gd->fdt_blob, 0, "st,stm32-dwmac"); - if (node < 0) + node = ofnode_by_compatible(ofnode_null(), "st,stm32-dwmac"); + if (!ofnode_valid(node)) return -1;
- phy_mode = fdt_getprop(gd->fdt_blob, node, "phy-mode", NULL); - - switch (phy_get_interface_by_name(phy_mode)) { + switch (ofnode_read_phy_mode(node)) { case PHY_INTERFACE_MODE_RMII: STM32_SYSCFG->pmc |= SYSCFG_PMC_MII_RMII_SEL; break; @@ -134,7 +131,7 @@ int board_init(void) STM32_SYSCFG->pmc &= ~SYSCFG_PMC_MII_RMII_SEL; break; default: - printf("PHY interface %s not supported !\n", phy_mode); + printf("Unsupported PHY interface!\n"); } #endif
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index eaad2c989b..191ab63a5d 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1183,3 +1183,26 @@ ofnode ofnode_get_phy_node(ofnode node)
return args.node; } + +phy_interface_t ofnode_read_phy_mode(ofnode node) +{ + const char *mode; + int i; + + assert(ofnode_valid(node)); + + mode = ofnode_read_string(node, "phy-mode"); + if (!mode) + mode = ofnode_read_string(node, "phy-connection-type"); + + if (!mode) + return PHY_INTERFACE_MODE_NONE; + + for (i = 0; i < PHY_INTERFACE_MODE_COUNT; i++) + if (!strcmp(mode, phy_interface_strings[i])) + return i; + + debug("%s: Invalid PHY interface '%s'\n", __func__, mode); + + return PHY_INTERFACE_MODE_NONE; +} diff --git a/drivers/core/read.c b/drivers/core/read.c index 7ff100218d..c73508d276 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -403,3 +403,8 @@ ofnode dev_get_phy_node(const struct udevice *dev) { return ofnode_get_phy_node(dev_ofnode(dev)); } + +phy_interface_t dev_read_phy_mode(const struct udevice *dev) +{ + return ofnode_read_phy_mode(dev_ofnode(dev)); +} diff --git a/drivers/net/ag7xxx.c b/drivers/net/ag7xxx.c index 632ab3c1e5..f24a917bd4 100644 --- a/drivers/net/ag7xxx.c +++ b/drivers/net/ag7xxx.c @@ -1254,7 +1254,6 @@ static const struct eth_ops ag7xxx_eth_ops = { static int ag7xxx_eth_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode; int ret;
pdata->iobase = dev_read_addr(dev); @@ -1265,13 +1264,9 @@ static int ag7xxx_eth_of_to_plat(struct udevice *dev) if (ret <= 0) return ret;
- phy_mode = fdt_getprop(gd->fdt_blob, ret, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
return 0; } diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index eb4cd96763..25247472b0 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -676,17 +676,10 @@ static int altera_tse_probe(struct udevice *dev) static int altera_tse_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode; - - pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
return 0; } diff --git a/drivers/net/bcm6348-eth.c b/drivers/net/bcm6348-eth.c index aad7b61213..75b24136fd 100644 --- a/drivers/net/bcm6348-eth.c +++ b/drivers/net/bcm6348-eth.c @@ -415,7 +415,6 @@ static int bcm6348_eth_probe(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct bcm6348_eth_priv *priv = dev_get_priv(dev); struct ofnode_phandle_args phy; - const char *phy_mode; int ret, i;
/* get base address */ @@ -425,10 +424,7 @@ static int bcm6348_eth_probe(struct udevice *dev) pdata->iobase = (phys_addr_t) priv->base;
/* get phy mode */ - pdata->phy_interface = PHY_INTERFACE_MODE_NONE; - phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -ENODEV;
diff --git a/drivers/net/bcmgenet.c b/drivers/net/bcmgenet.c index 67839563db..c6acb4932b 100644 --- a/drivers/net/bcmgenet.c +++ b/drivers/net/bcmgenet.c @@ -690,20 +690,14 @@ static int bcmgenet_eth_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct bcmgenet_eth_priv *priv = dev_get_priv(dev); struct ofnode_phandle_args phy_node; - const char *phy_mode; int ret;
/* Get phy mode from DT */ - pdata->phy_interface = -1; - phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
ret = dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phy_node); diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 5aaac603a0..7b7b0f6578 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -914,21 +914,15 @@ int designware_eth_of_to_plat(struct udevice *dev) struct dw_eth_dev *priv = dev_get_priv(dev); #endif struct eth_pdata *pdata = &dw_pdata->eth_pdata; - const char *phy_mode; #if CONFIG_IS_ENABLED(DM_GPIO) int reset_flags = GPIOD_IS_OUT; #endif int ret = 0;
pdata->iobase = dev_read_addr(dev); - pdata->phy_interface = -1; - phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
pdata->max_speed = dev_read_u32_default(dev, "max-speed", 0);
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 22dad5b203..9777f6cb9c 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -270,7 +270,7 @@ struct eqos_config { int config_mac; int config_mac_mdio; unsigned int axi_bus_width; - phy_interface_t (*interface)(struct udevice *dev); + phy_interface_t (*interface)(const struct udevice *dev); struct eqos_ops *ops; };
@@ -1729,21 +1729,7 @@ err_probe: return ret; }
-static phy_interface_t eqos_get_interface_stm32(struct udevice *dev) -{ - const char *phy_mode; - phy_interface_t interface = PHY_INTERFACE_MODE_NONE; - - debug("%s(dev=%p):\n", __func__, dev); - - phy_mode = dev_read_prop(dev, "phy-mode", NULL); - if (phy_mode) - interface = phy_get_interface_by_name(phy_mode); - - return interface; -} - -static phy_interface_t eqos_get_interface_tegra186(struct udevice *dev) +static phy_interface_t eqos_get_interface_tegra186(const struct udevice *dev) { return PHY_INTERFACE_MODE_MII; } @@ -1766,20 +1752,6 @@ static int eqos_probe_resources_imx(struct udevice *dev) return 0; }
-static phy_interface_t eqos_get_interface_imx(struct udevice *dev) -{ - const char *phy_mode; - phy_interface_t interface = PHY_INTERFACE_MODE_NONE; - - debug("%s(dev=%p):\n", __func__, dev); - - phy_mode = dev_read_prop(dev, "phy-mode", NULL); - if (phy_mode) - interface = phy_get_interface_by_name(phy_mode); - - return interface; -} - static int eqos_remove_resources_tegra186(struct udevice *dev) { struct eqos_priv *eqos = dev_get_priv(dev); @@ -1985,7 +1957,7 @@ static const struct eqos_config __maybe_unused eqos_stm32_config = { .config_mac = EQOS_MAC_RXQ_CTRL0_RXQ0EN_ENABLED_AV, .config_mac_mdio = EQOS_MAC_MDIO_ADDRESS_CR_250_300, .axi_bus_width = EQOS_AXI_WIDTH_64, - .interface = eqos_get_interface_stm32, + .interface = dev_read_phy_mode, .ops = &eqos_stm32_ops };
@@ -2013,7 +1985,7 @@ struct eqos_config __maybe_unused eqos_imx_config = { .config_mac = EQOS_MAC_RXQ_CTRL0_RXQ0EN_ENABLED_DCB, .config_mac_mdio = EQOS_MAC_MDIO_ADDRESS_CR_250_300, .axi_bus_width = EQOS_AXI_WIDTH_64, - .interface = eqos_get_interface_imx, + .interface = dev_read_phy_mode, .ops = &eqos_imx_ops };
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 985b038447..de1d06f0f1 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1558,20 +1558,13 @@ static int fecmxc_of_to_plat(struct udevice *dev) int ret = 0; struct eth_pdata *pdata = dev_get_plat(dev); struct fec_priv *priv = dev_get_priv(dev); - const char *phy_mode;
pdata->iobase = dev_read_addr(dev); priv->eth = (struct ethernet_regs *)pdata->iobase;
- pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
#ifdef CONFIG_DM_REGULATOR device_get_supply_regulator(dev, "phy-supply", &priv->phy_supply); diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 5e0d0bca9b..1ffe9e2b7a 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -954,17 +954,6 @@ int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info) return 0; } #else /* CONFIG_DM_ETH */ -#ifdef CONFIG_PHYLIB -phy_interface_t fman_read_sys_if(struct udevice *dev) -{ - const char *if_str; - - if_str = ofnode_read_string(dev_ofnode(dev), "phy-connection-type"); - debug("MAC system interface mode %s\n", if_str); - - return phy_get_interface_by_name(if_str); -} -#endif
static int fm_eth_bind(struct udevice *dev) { @@ -1038,7 +1027,7 @@ static int fm_eth_probe(struct udevice *dev) reg = (void *)(uintptr_t)dev_read_addr(dev); fm_eth->mac_type = dev_get_driver_data(dev); #ifdef CONFIG_PHYLIB - fm_eth->enet_if = fman_read_sys_if(dev); + fm_eth->enet_if = dev_read_phy_mode(dev); #else fm_eth->enet_if = PHY_INTERFACE_MODE_SGMII; printf("%s: warning - unable to determine interface type\n", __func__); diff --git a/drivers/net/fsl_enetc.c b/drivers/net/fsl_enetc.c index 915c7c8025..8f5af1dbc0 100644 --- a/drivers/net/fsl_enetc.c +++ b/drivers/net/fsl_enetc.c @@ -260,9 +260,6 @@ static int enetc_init_sxgmii(struct udevice *dev) static void enetc_start_pcs(struct udevice *dev) { struct enetc_priv *priv = dev_get_priv(dev); - const char *if_str; - - priv->if_type = PHY_INTERFACE_MODE_NONE;
/* register internal MDIO for debug purposes */ if (enetc_read_port(priv, ENETC_PCAPR0) & ENETC_PCAPRO_MDIO) { @@ -279,14 +276,12 @@ static void enetc_start_pcs(struct udevice *dev) return; }
- if_str = ofnode_read_string(dev_ofnode(dev), "phy-mode"); - if (if_str) - priv->if_type = phy_get_interface_by_name(if_str); - else + priv->if_type = dev_read_phy_mode(dev); + if (priv->if_type == PHY_INTERFACE_MODE_NONE) { enetc_dbg(dev, "phy-mode property not found, defaulting to SGMII\n"); - if (priv->if_type < 0) - priv->if_type = PHY_INTERFACE_MODE_NONE; + priv->if_type = PHY_INTERFACE_MODE_SGMII; + }
switch (priv->if_type) { case PHY_INTERFACE_MODE_SGMII: diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index aa719d295f..626c27d7bf 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -549,17 +549,12 @@ static int ftgmac100_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); struct ftgmac100_data *priv = dev_get_priv(dev); - const char *phy_mode;
pdata->iobase = dev_read_addr(dev); - pdata->phy_interface = -1; - phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - dev_err(dev, "Invalid PHY interface '%s'\n", phy_mode); + + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
diff --git a/drivers/net/higmacv300.c b/drivers/net/higmacv300.c index aa79d6eda8..ce8f2dfd09 100644 --- a/drivers/net/higmacv300.c +++ b/drivers/net/higmacv300.c @@ -561,19 +561,14 @@ static int higmac_remove(struct udevice *dev) static int higmac_of_to_plat(struct udevice *dev) { struct higmac_priv *priv = dev_get_priv(dev); - int phyintf = PHY_INTERFACE_MODE_NONE; - const char *phy_mode; ofnode phy_node;
priv->base = dev_remap_addr_index(dev, 0); priv->macif_ctrl = dev_remap_addr_index(dev, 1);
- phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) - phyintf = phy_get_interface_by_name(phy_mode); - if (phyintf == PHY_INTERFACE_MODE_NONE) + priv->phyintf = dev_read_phy_mode(dev); + if (priv->phyintf == PHY_INTERFACE_MODE_NONE) return -ENODEV; - priv->phyintf = phyintf;
phy_node = dev_read_subnode(dev, "phy"); if (!ofnode_valid(phy_node)) { diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 725173f627..c775598b91 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -1120,31 +1120,14 @@ static uint32_t ldpaa_eth_get_dpmac_id(struct udevice *dev) return fdtdec_get_uint(gd->fdt_blob, port_node, "reg", -1); }
-static const char *ldpaa_eth_get_phy_mode_str(struct udevice *dev) -{ - int port_node = dev_of_offset(dev); - const char *phy_mode_str; - - phy_mode_str = fdt_getprop(gd->fdt_blob, port_node, - "phy-connection-type", NULL); - if (phy_mode_str) - return phy_mode_str; - - phy_mode_str = fdt_getprop(gd->fdt_blob, port_node, "phy-mode", NULL); - return phy_mode_str; -} - static int ldpaa_eth_bind(struct udevice *dev) { - const char *phy_mode_str = NULL; uint32_t dpmac_id; char eth_name[16]; int phy_mode = -1;
- phy_mode_str = ldpaa_eth_get_phy_mode_str(dev); - if (phy_mode_str) - phy_mode = phy_get_interface_by_name(phy_mode_str); - if (phy_mode == -1) { + phy_mode = dev_read_phy_mode(dev); + if (phy_mode == PHY_INTERFACE_MODE_NONE) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; } @@ -1155,7 +1138,8 @@ static int ldpaa_eth_bind(struct udevice *dev) return -EINVAL; }
- sprintf(eth_name, "DPMAC%d@%s", dpmac_id, phy_mode_str); + sprintf(eth_name, "DPMAC%d@%s", dpmac_id, + phy_string_for_interface(phy_mode)); device_set_name(dev, eth_name);
return 0; @@ -1164,11 +1148,9 @@ static int ldpaa_eth_bind(struct udevice *dev) static int ldpaa_eth_of_to_plat(struct udevice *dev) { struct ldpaa_eth_priv *priv = dev_get_priv(dev); - const char *phy_mode_str;
priv->dpmac_id = ldpaa_eth_get_dpmac_id(dev); - phy_mode_str = ldpaa_eth_get_phy_mode_str(dev); - priv->phy_mode = phy_get_interface_by_name(phy_mode_str); + priv->phy_mode = dev_read_phy_mode(dev);
return 0; } diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 37eed59a69..317b380e8f 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -1360,17 +1360,11 @@ static int macb_eth_probe(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct macb_device *macb = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; - const char *phy_mode; int ret;
- phy_mode = dev_read_prop(dev, "phy-mode", NULL); - - if (phy_mode) - macb->phy_interface = phy_get_interface_by_name(phy_mode); - if (macb->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + macb->phy_interface = dev_read_phy_mode(dev); + if (macb->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
/* Read phyaddr from DT */ if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, diff --git a/drivers/net/mt7620-eth.c b/drivers/net/mt7620-eth.c index 222250d52a..24fcb9373f 100644 --- a/drivers/net/mt7620-eth.c +++ b/drivers/net/mt7620-eth.c @@ -1048,33 +1048,20 @@ static int mt7620_eth_parse_gsw_port(struct mt7620_eth_priv *priv, u32 idx, ofnode node) { ofnode subnode; - const char *str; - int mode, speed, ret; + int speed, ret; u32 phy_addr;
- str = ofnode_read_string(node, "phy-mode"); - if (str) { - mode = phy_get_interface_by_name(str); - if (mode < 0) { - dev_err(priv->dev, "mt7620_eth: invalid phy-mode\n"); - return -EINVAL; - } - - switch (mode) { - case PHY_INTERFACE_MODE_MII: - case PHY_INTERFACE_MODE_RMII: - case PHY_INTERFACE_MODE_RGMII: - case PHY_INTERFACE_MODE_NONE: - break; - default: - dev_err(priv->dev, - "mt7620_eth: unsupported phy-mode\n"); - return -ENOTSUPP; - } + priv->port_cfg[idx].mode = ofnode_read_phy_mode(node);
- priv->port_cfg[idx].mode = mode; - } else { - priv->port_cfg[idx].mode = PHY_INTERFACE_MODE_NONE; + switch (priv->port_cfg[idx].mode) { + case PHY_INTERFACE_MODE_MII: + case PHY_INTERFACE_MODE_RMII: + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_NONE: + break; + default: + dev_err(priv->dev, "mt7620_eth: unsupported phy-mode\n"); + return -ENOTSUPP; }
subnode = ofnode_find_subnode(node, "fixed-link"); diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index 26f02847a2..d6065db5fb 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -1447,11 +1447,9 @@ static int mtk_eth_of_to_plat(struct udevice *dev) priv->gmac_id = dev_read_u32_default(dev, "mediatek,gmac-id", 0);
/* Interface mode is required */ - str = dev_read_string(dev, "phy-mode"); - if (str) { - pdata->phy_interface = phy_get_interface_by_name(str); - priv->phy_interface = pdata->phy_interface; - } else { + pdata->phy_interface = dev_read_phy_mode(dev); + priv->phy_interface = pdata->phy_interface; + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) { printf("error: phy-mode is not set\n"); return -EINVAL; } diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 954bf86121..32ec0b437d 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -993,7 +993,6 @@ static int mvgbe_of_to_plat(struct udevice *dev) struct mvgbe_device *dmvgbe = dev_get_priv(dev); void *blob = (void *)gd->fdt_blob; int node = dev_of_offset(dev); - const char *phy_mode; int fl_node; int pnode; unsigned long addr; @@ -1005,10 +1004,8 @@ static int mvgbe_of_to_plat(struct udevice *dev) "marvell,kirkwood-eth-port");
/* Get phy-mode / phy_interface from DT */ - phy_mode = fdt_getprop(gd->fdt_blob, pnode, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - else + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) pdata->phy_interface = PHY_INTERFACE_MODE_GMII;
dmvgbe->phy_interface = pdata->phy_interface; diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index 4a4268c2b2..d31b96a9d8 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -1799,20 +1799,13 @@ static const struct eth_ops mvneta_ops = { static int mvneta_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode;
/* Get phy-mode / phy_interface from DT */ - pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
return 0; } diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 4c0a7b0a9f..dfddac180f 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -4786,11 +4786,9 @@ static int mvpp2_port_init(struct udevice *dev, struct mvpp2_port *port) static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) { int port_node = dev_of_offset(dev); - const char *phy_mode_str; int phy_node; u32 id; u32 phyaddr = 0; - int phy_mode = -1; int fixed_link = 0; int ret;
@@ -4821,10 +4819,8 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) phyaddr = PHY_MAX_ADDR; }
- phy_mode_str = fdt_getprop(gd->fdt_blob, port_node, "phy-mode", NULL); - if (phy_mode_str) - phy_mode = phy_get_interface_by_name(phy_mode_str); - if (phy_mode == -1) { + port->phy_interface = dev_read_phy_mode(dev); + if (port->phy_interface == PHY_INTERFACE_MODE_NONE) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; } @@ -4847,7 +4843,6 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) port->first_rxq = port->id * rxq_number; else port->first_rxq = port->id * port->priv->max_port_rxqs; - port->phy_interface = phy_mode; port->phyaddr = phyaddr;
return 0; diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index fe6dbdaee4..4109676a51 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -982,25 +982,16 @@ static struct phy_device *phy_connect_gmii2rgmii(struct mii_dev *bus, */ struct phy_device *fixed_phy_create(ofnode node) { - phy_interface_t interface = PHY_INTERFACE_MODE_NONE; struct phy_device *phydev; - const char *if_str; ofnode subnode;
- if_str = ofnode_read_string(node, "phy-mode"); - if (!if_str) { - if_str = ofnode_read_string(node, "phy-connection-type"); - } - if (if_str) { - interface = phy_get_interface_by_name(if_str); - } - subnode = ofnode_find_subnode(node, "fixed-link"); if (!ofnode_valid(subnode)) { return NULL; }
- phydev = phy_device_create(NULL, 0, PHY_FIXED_ID, false, interface); + phydev = phy_device_create(NULL, 0, PHY_FIXED_ID, false, + ofnode_read_phy_mode(node)); if (phydev) phydev->node = subnode;
@@ -1093,15 +1084,3 @@ int phy_shutdown(struct phy_device *phydev)
return 0; } - -int phy_get_interface_by_name(const char *str) -{ - int i; - - for (i = 0; i < PHY_INTERFACE_MODE_COUNT; i++) { - if (!strcmp(str, phy_interface_strings[i])) - return i; - } - - return -1; -} diff --git a/drivers/net/pic32_eth.c b/drivers/net/pic32_eth.c index 5a678d1cf9..03eb51e51d 100644 --- a/drivers/net/pic32_eth.c +++ b/drivers/net/pic32_eth.c @@ -534,7 +534,6 @@ static int pic32_eth_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); struct pic32eth_dev *priv = dev_get_priv(dev); - const char *phy_mode; void __iomem *iobase; fdt_addr_t addr; fdt_size_t size; @@ -550,15 +549,9 @@ static int pic32_eth_probe(struct udevice *dev) pdata->iobase = (phys_addr_t)addr;
/* get phy mode */ - pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
/* get phy addr */ offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), diff --git a/drivers/net/qe/dm_qe_uec.c b/drivers/net/qe/dm_qe_uec.c index a12c8cd2ac..5a66d726cd 100644 --- a/drivers/net/qe/dm_qe_uec.c +++ b/drivers/net/qe/dm_qe_uec.c @@ -1133,19 +1133,12 @@ static int qe_uec_remove(struct udevice *dev) static int qe_uec_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode;
pdata->iobase = (phys_addr_t)devfdt_get_addr(dev);
- pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), - "phy-connection-type", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
return 0; } diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 4078d33bb5..f6d386bd6b 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -674,20 +674,13 @@ static const struct eth_ops ravb_ops = { int ravb_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode; const fdt32_t *cell; - int ret = 0;
pdata->iobase = dev_read_addr(dev); - pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
pdata->max_speed = 1000; cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL); @@ -696,7 +689,7 @@ int ravb_of_to_plat(struct udevice *dev)
sprintf(bb_miiphy_buses[0].name, dev->name);
- return ret; + return 0; }
static const struct udevice_id ravb_ids[] = { diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 4055f07b2f..04c9c2d968 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -915,20 +915,13 @@ static const struct eth_ops sh_ether_ops = { int sh_ether_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); - const char *phy_mode; const fdt32_t *cell; - int ret = 0;
pdata->max_speed = 1000; cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL); @@ -937,7 +930,7 @@ int sh_ether_of_to_plat(struct udevice *dev)
static const struct udevice_id sh_ether_ids[] = { diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index ab51552ed8..0a368c6d03 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -738,7 +738,6 @@ static int ave_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct ave_private *priv = dev_get_priv(dev); struct ofnode_phandle_args args; - const char *phy_mode; const u32 *valp; int ret, nc, nr; const char *name; @@ -748,15 +747,10 @@ static int ave_of_to_plat(struct udevice *dev) return -EINVAL;
pdata->iobase = dev_read_addr(dev); - pdata->phy_interface = -1; - phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", - NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - dev_err(dev, "Invalid PHY interface '%s'\n", phy_mode); + + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
pdata->max_speed = 0; valp = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", diff --git a/drivers/net/sni_netsec.c b/drivers/net/sni_netsec.c index 4901321d0c..693fd3a35d 100644 --- a/drivers/net/sni_netsec.c +++ b/drivers/net/sni_netsec.c @@ -1029,19 +1029,13 @@ static int netsec_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct netsec_priv *priv = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; - const char *phy_mode;
pdata->iobase = dev_read_addr_index(dev, 0); priv->eeprom_base = dev_read_addr_index(dev, 1) - EERPROM_MAP_OFFSET;
- pdata->phy_interface = -1; - phy_mode = dev_read_prop(dev, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - pr_err("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phandle_args)) diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 2e24d12214..5654a3430e 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -882,7 +882,6 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) struct sun8i_eth_pdata *sun8i_pdata = dev_get_plat(dev); struct eth_pdata *pdata = &sun8i_pdata->eth_pdata; struct emac_eth_dev *priv = dev_get_priv(dev); - const char *phy_mode; const fdt32_t *reg; int node = dev_of_offset(dev); int offset = 0; @@ -946,16 +945,10 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) } priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1);
- phy_mode = fdt_getprop(gd->fdt_blob, node, "phy-mode", NULL); - - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); printf("phy interface%d\n", pdata->phy_interface); - - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
if (priv->variant == H3_EMAC) { ret = sun8i_handle_internal_phy(dev, priv); diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 87f51b3b99..c1da334739 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -602,21 +602,14 @@ static int am65_cpsw_ofdata_parse_phy(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct am65_cpsw_priv *priv = dev_get_priv(dev); struct ofnode_phandle_args out_args; - const char *phy_mode; int ret = 0;
dev_read_u32(dev, "reg", &priv->port_id);
- phy_mode = dev_read_string(dev, "phy-mode"); - if (phy_mode) { - pdata->phy_interface = - phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - dev_err(dev, "Invalid PHY mode '%s', port %u\n", - phy_mode, priv->port_id); - ret = -EINVAL; - goto out; - } + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) { + dev_err(dev, "Invalid PHY mode, port %u\n", priv->port_id); + return -EINVAL; }
dev_read_u32(dev, "max-speed", (u32 *)&pdata->max_speed); diff --git a/drivers/net/ti/cpsw.c b/drivers/net/ti/cpsw.c index 68f4191fe9..5b7bab734e 100644 --- a/drivers/net/ti/cpsw.c +++ b/drivers/net/ti/cpsw.c @@ -1194,15 +1194,12 @@ static void cpsw_eth_of_parse_slave(struct cpsw_platform_data *data, { struct ofnode_phandle_args out_args; struct cpsw_slave_data *slave_data; - const char *phy_mode; u32 phy_id[2]; int ret;
slave_data = &data->slave_data[slave_index];
- phy_mode = ofnode_read_string(subnode, "phy-mode"); - if (phy_mode) - slave_data->phy_if = phy_get_interface_by_name(phy_mode); + slave_data->phy_if = ofnode_read_phy_mode(subnode);
ret = ofnode_parse_phandle_with_args(subnode, "phy-handle", NULL, 0, 0, &out_args); @@ -1348,11 +1345,8 @@ static int cpsw_eth_of_to_plat(struct udevice *dev) }
pdata->phy_interface = data->slave_data[data->active_slave].phy_if; - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, - phy_string_for_interface(pdata->phy_interface)); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
return 0; } diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index 5e8f683c29..b55e7da4c1 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -687,7 +687,6 @@ static int ks2_eth_parse_slave_interface(int netcp, int slave, int phy; int dma_count; u32 dma_channel[8]; - const char *phy_mode;
priv->slave_port = fdtdec_get_int(fdt, slave, "slave-port", -1); priv->net_rx_buffs.rx_flow = priv->slave_port * 8; @@ -728,20 +727,19 @@ static int ks2_eth_parse_slave_interface(int netcp, int slave, priv->sgmii_link_type = SGMII_LINK_MAC_PHY; priv->has_mdio = true; } else if (priv->link_type == LINK_TYPE_RGMII_LINK_MAC_PHY) { - phy_mode = fdt_getprop(fdt, slave, "phy-mode", NULL); - if (phy_mode) { - priv->phy_if = phy_get_interface_by_name(phy_mode); - if (priv->phy_if != PHY_INTERFACE_MODE_RGMII && - priv->phy_if != PHY_INTERFACE_MODE_RGMII_ID && - priv->phy_if != PHY_INTERFACE_MODE_RGMII_RXID && - priv->phy_if != PHY_INTERFACE_MODE_RGMII_TXID) { - pr_err("invalid phy-mode\n"); - return -EINVAL; - } - } else { + priv->phy_if = ofnode_read_phy_mode(offset_to_ofnode(slave)); + if (priv->phy_if == PHY_INTERFACE_MODE_NONE) priv->phy_if = PHY_INTERFACE_MODE_RGMII; - } pdata->phy_interface = priv->phy_if; + + if (priv->phy_if != PHY_INTERFACE_MODE_RGMII && + priv->phy_if != PHY_INTERFACE_MODE_RGMII_ID && + priv->phy_if != PHY_INTERFACE_MODE_RGMII_RXID && + priv->phy_if != PHY_INTERFACE_MODE_RGMII_TXID) { + pr_err("invalid phy-mode\n"); + return -EINVAL; + } + priv->has_mdio = true; }
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index beca886b25..fec051ebb7 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -834,7 +834,6 @@ int tsec_probe(struct udevice *dev) struct ofnode_phandle_args phandle_args; u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; struct tsec_data *data; - const char *phy_mode; ofnode parent, child; fdt_addr_t reg; u32 max_speed; @@ -894,12 +893,8 @@ int tsec_probe(struct udevice *dev)
priv->tbiaddr = tbiaddr;
- phy_mode = dev_read_prop(dev, "phy-connection-type", NULL); - if (!phy_mode) - phy_mode = dev_read_prop(dev, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) pdata->phy_interface = tsec_get_interface(priv);
priv->interface = pdata->phy_interface; diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index f21addb4d0..02d13c3e0a 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -821,7 +821,6 @@ static int axi_emac_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = &plat->eth_pdata; int node = dev_of_offset(dev); int offset = 0; - const char *phy_mode;
pdata->iobase = dev_read_addr(dev); plat->mactype = dev_get_driver_data(dev); @@ -850,14 +849,9 @@ static int axi_emac_of_to_plat(struct udevice *dev) plat->phy_of_handle = offset; }
- phy_mode = fdt_getprop(gd->fdt_blob, node, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - printf("%s: Invalid PHY interface '%s'\n", __func__, - phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - }
plat->eth_hasnobuf = fdtdec_get_bool(gd->fdt_blob, node, "xlnx,eth-hasnobuf"); diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 3118d14726..0062851134 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -827,7 +827,6 @@ static int zynq_gem_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev); struct zynq_gem_priv *priv = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; - const char *phy_mode;
pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->iobase = (struct zynq_gem_regs *)pdata->iobase; @@ -859,13 +858,9 @@ static int zynq_gem_of_to_plat(struct udevice *dev) } }
- phy_mode = dev_read_prop(dev, "phy-mode", NULL); - if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) return -EINVAL; - } priv->interface = pdata->phy_interface;
priv->int_pcs = dev_read_bool(dev, "is-internal-pcspma"); diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 8164386043..8a38c143f9 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -12,6 +12,7 @@ #include <dm/of.h> #include <dm/of_access.h> #include <log.h> +#include <phy_interface.h>
/* Enable checks to protect against invalid calls */ #undef OF_CHECKS @@ -1218,4 +1219,16 @@ const char *ofnode_conf_read_str(const char *prop_name); */ ofnode ofnode_get_phy_node(ofnode eth_node);
+/** + * ofnode_read_phy_mode() - Read PHY connection type from a MAC node + * + * This function parses the "phy-mode" / "phy-connection-type" property and + * returns the corresponding PHY interface type. + * + * @mac_node: ofnode containing the property + * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NONE on + * error + */ +phy_interface_t ofnode_read_phy_mode(ofnode mac_node); + #endif diff --git a/include/dm/read.h b/include/dm/read.h index 899eb813fd..bfa2645967 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -757,6 +757,18 @@ int dev_decode_display_timing(const struct udevice *dev, int index, */ ofnode dev_get_phy_node(const struct udevice *dev);
+/** + * dev_read_phy_mode() - Read PHY connection type from a MAC + * + * This function parses the "phy-mode" / "phy-connection-type" property and + * returns the corresponding PHY interface type. + * + * @dev: device representing the MAC + * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NONE on + * error + */ +phy_interface_t dev_read_phy_mode(const struct udevice *dev); + #else /* CONFIG_DM_DEV_READ_INLINE is enabled */ #include <asm/global_data.h>
@@ -1111,6 +1123,11 @@ static inline ofnode dev_get_phy_node(const struct udevice *dev) return ofnode_get_phy_node(dev_ofnode(dev)); }
+static inline phy_interface_t dev_read_phy_mode(const struct udevice *dev) +{ + return ofnode_read_phy_mode(dev_ofnode(dev)); +} + #endif /* CONFIG_DM_DEV_READ_INLINE */
/** diff --git a/include/phy.h b/include/phy.h index c66fd43ea8..dee8fb5f2e 100644 --- a/include/phy.h +++ b/include/phy.h @@ -542,14 +542,6 @@ int phy_xilinx_gmii2rgmii_init(void); int board_phy_config(struct phy_device *phydev); int get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id);
-/** - * phy_get_interface_by_name() - Look up a PHY interface name - * - * @str: PHY interface name, e.g. "mii" - * @return: PHY_INTERFACE_MODE_... value, or -1 if not found - */ -int phy_get_interface_by_name(const char *str); - /** * phy_interface_is_rgmii - Convenience function for testing if a PHY interface * is RGMII (all variants) diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index bef8280e21..874f59413a 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -15,11 +15,6 @@ #include <dm/uclass-internal.h> #include <linux/compat.h>
-/* DT node properties for MAC-PHY interface */ -static const char * const phy_mode_str[] = { - "phy-mode", "phy-connection-type" -}; - void dm_mdio_probe_devices(void) { struct udevice *it; @@ -195,26 +190,15 @@ out: /* Connect to a PHY linked in eth DT node */ struct phy_device *dm_eth_phy_connect(struct udevice *ethdev) { - const char *if_str; phy_interface_t interface; struct phy_device *phy; - int i;
if (!dev_has_ofnode(ethdev)) { debug("%s: supplied eth dev has no DT node!\n", ethdev->name); return NULL; }
- interface = PHY_INTERFACE_MODE_NONE; - for (i = 0; i < ARRAY_SIZE(phy_mode_str); i++) { - if_str = dev_read_string(ethdev, phy_mode_str[i]); - if (if_str) { - interface = phy_get_interface_by_name(if_str); - break; - } - } - if (interface < 0) - interface = PHY_INTERFACE_MODE_NONE; + interface = dev_read_phy_mode(ethdev); if (interface == PHY_INTERFACE_MODE_NONE) dev_dbg(ethdev, "can't find interface mode, default to NONE\n");
Use them treewide.
int node;
ofnode node;
if (node < 0)
#endif
return args.node;
const char *mode;
int i;
if (!mode)
if (!mode)
return i;
const char *phy_mode; int ret; pdata->iobase = dev_read_addr(dev);
if (phy_mode)
} return 0;
NULL);
if (phy_mode)
} return 0;
const char *phy_mode; int ret, i; /* get base address */
/* get phy mode */
if (phy_mode)
const char *phy_mode; int ret; pdata->iobase = dev_read_addr(dev); /* Get phy mode from DT */
if (phy_mode)
} ret = dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phy_node);
if (phy_mode)
} pdata->max_speed = dev_read_u32_default(dev, "max-speed", 0);
if (phy_mode)
return interface;
if (phy_mode)
return interface;
const char *phy_mode; pdata->iobase = dev_read_addr(dev); priv->eth = (struct ethernet_regs *)pdata->iobase;
NULL);
if (phy_mode)
const char *if_str;
-} -#endif
const char *if_str;
priv->if_type = PHY_INTERFACE_MODE_NONE; /* register internal MDIO for debug purposes */ if (enetc_read_port(priv, ENETC_PCAPR0) & ENETC_PCAPRO_MDIO) {
if (if_str)
else
} switch (priv->if_type) { case PHY_INTERFACE_MODE_SGMII:
if (phy_mode)
const char *phy_mode; ofnode phy_node; priv->base = dev_remap_addr_index(dev, 0); priv->macif_ctrl = dev_remap_addr_index(dev, 1);
if (phy_mode)
priv->phyintf = phyintf; phy_node = dev_read_subnode(dev, "phy"); if (!ofnode_valid(phy_node)) {
if (phy_mode_str)
if (phy_mode_str)
phy_string_for_interface(phy_mode)); device_set_name(dev, eth_name); return 0;
const char *phy_mode_str; priv->dpmac_id = ldpaa_eth_get_dpmac_id(dev);
priv->phy_mode = dev_read_phy_mode(dev); return 0;
if (phy_mode)
} /* Read phyaddr from DT */ if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0,
const char *str;
if (str) {
if (mode < 0) {
return -EINVAL;
switch (mode) {
break;
default:
dev_err(priv->dev,
return -ENOTSUPP;
} else {
break;
default:
return -ENOTSUPP; } subnode = ofnode_find_subnode(node, "fixed-link");
if (str) {
} else {
if (phy_mode)
else
if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) pdata->phy_interface = PHY_INTERFACE_MODE_GMII; dmvgbe->phy_interface = pdata->phy_interface;
const char *phy_mode; pdata->iobase = dev_read_addr(dev); /* Get phy-mode / phy_interface from DT */
NULL);
if (phy_mode)
} return 0;
if (phy_mode_str)
port->phy_interface = phy_mode; port->phyaddr = phyaddr; return 0;
if (!if_str) {
if (if_str) {
int i;
return i;
return -1;
/* get phy mode */
NULL);
if (phy_mode)
} /* get phy addr */ offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev),
const char *phy_mode; pdata->iobase = (phys_addr_t)devfdt_get_addr(dev);
if (phy_mode)
} return 0;
int ret = 0; pdata->iobase = dev_read_addr(dev);
NULL);
if (phy_mode)
} pdata->max_speed = 1000; cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL);
return ret;
NULL);
if (phy_mode)
return ret;
NULL);
if (phy_mode)
} pdata->max_speed = 0; valp = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed",
const char *phy_mode; pdata->iobase = dev_read_addr_index(dev, 0); priv->eeprom_base = dev_read_addr_index(dev, 1) - EERPROM_MAP_OFFSET;
if (phy_mode)
} if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phandle_args))
if (phy_mode)
} if (priv->variant == H3_EMAC) { ret = sun8i_handle_internal_phy(dev, priv);
const char *phy_mode; int ret = 0; dev_read_u32(dev, "reg", &priv->port_id);
if (phy_mode) {
ret = -EINVAL;
goto out;
return -EINVAL; } dev_read_u32(dev, "max-speed", (u32 *)&pdata->max_speed);
const char *phy_mode; u32 phy_id[2]; int ret; slave_data = &data->slave_data[slave_index];
if (phy_mode)
slave_data->phy_if = ofnode_read_phy_mode(subnode); ret = ofnode_parse_phandle_with_args(subnode, "phy-handle", NULL, 0, 0, &out_args);
} return 0;
const char *phy_mode; priv->slave_port = fdtdec_get_int(fdt, slave, "slave-port", -1); priv->net_rx_buffs.rx_flow = priv->slave_port * 8;
if (phy_mode) {
return -EINVAL;
} else {
return -EINVAL;
if (!phy_mode)
if (phy_mode)
if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) pdata->phy_interface = tsec_get_interface(priv); priv->interface = pdata->phy_interface;
const char *phy_mode; pdata->iobase = dev_read_addr(dev); plat->mactype = dev_get_driver_data(dev);
if (phy_mode)
phy_mode);
} plat->eth_hasnobuf = fdtdec_get_bool(gd->fdt_blob, node, "xlnx,eth-hasnobuf");
const char *phy_mode; pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->iobase = (struct zynq_gem_regs *)pdata->iobase;
if (phy_mode)
} priv->interface = pdata->phy_interface; priv->int_pcs = dev_read_bool(dev, "is-internal-pcspma");
- ofnode_read_phy_mode() - Read PHY connection type from a MAC node
- This function parses the "phy-mode" / "phy-connection-type" property and
- returns the corresponding PHY interface type.
- @mac_node: ofnode containing the property
- Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NONE on
error
- dev_read_phy_mode() - Read PHY connection type from a MAC
error
- phy_get_interface_by_name() - Look up a PHY interface name
- @str: PHY interface name, e.g. "mii"
- @return: PHY_INTERFACE_MODE_... value, or -1 if not found
- phy_interface_is_rgmii - Convenience function for testing if a PHY interface
- is RGMII (all variants)
int i; if (!dev_has_ofnode(ethdev)) { debug("%s: supplied eth dev has no DT node!\n", ethdev->name); return NULL; }
if (if_str) {
break;
if (interface < 0)
-- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Rename constant PHY_INTERFACE_MODE_COUNT to PHY_INTERFACE_MODE_MAX to make it compatible with Linux' naming.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/core/ofnode.c | 2 +- drivers/net/phy/aquantia.c | 2 +- include/phy_interface.h | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 191ab63a5d..b9c334c46d 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1198,7 +1198,7 @@ phy_interface_t ofnode_read_phy_mode(ofnode node) if (!mode) return PHY_INTERFACE_MODE_NONE;
- for (i = 0; i < PHY_INTERFACE_MODE_COUNT; i++) + for (i = 0; i < PHY_INTERFACE_MODE_MAX; i++) if (!strcmp(mode, phy_interface_strings[i])) return i;
diff --git a/drivers/net/phy/aquantia.c b/drivers/net/phy/aquantia.c index 83075f78c9..7e950fe0c2 100644 --- a/drivers/net/phy/aquantia.c +++ b/drivers/net/phy/aquantia.c @@ -305,7 +305,7 @@ struct { u16 syscfg; int cnt; u16 start_rate; -} aquantia_syscfg[PHY_INTERFACE_MODE_COUNT] = { +} aquantia_syscfg[PHY_INTERFACE_MODE_MAX] = { [PHY_INTERFACE_MODE_SGMII] = {0x04b, AQUANTIA_VND1_GSYSCFG_1G, AQUANTIA_VND1_GSTART_RATE_1G}, [PHY_INTERFACE_MODE_2500BASEX] = {0x144, AQUANTIA_VND1_GSYSCFG_2_5G, diff --git a/include/phy_interface.h b/include/phy_interface.h index f075abe9c9..494bc87e67 100644 --- a/include/phy_interface.h +++ b/include/phy_interface.h @@ -41,7 +41,7 @@ typedef enum { PHY_INTERFACE_MODE_USXGMII, PHY_INTERFACE_MODE_NONE, /* Must be last */
- PHY_INTERFACE_MODE_COUNT, + PHY_INTERFACE_MODE_MAX, } phy_interface_t;
static const char * const phy_interface_strings[] = {
Thanks, Stefan
- for (i = 0; i < PHY_INTERFACE_MODE_MAX; i++) if (!strcmp(mode, phy_interface_strings[i])) return i;
Viele Grüße, Stefan Roese
Rename constant PHY_INTERFACE_MODE_NONE to PHY_INTERFACE_MODE_NA to make it compatible with Linux' naming.
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/freescale/corenet_ds/eth_hydra.c | 2 +- board/freescale/corenet_ds/eth_superhydra.c | 4 ++-- board/freescale/t104xrdb/eth.c | 4 ++-- drivers/core/ofnode.c | 4 ++-- drivers/net/ag7xxx.c | 2 +- drivers/net/altera_tse.c | 2 +- drivers/net/bcm6348-eth.c | 2 +- drivers/net/bcmgenet.c | 2 +- drivers/net/designware.c | 2 +- drivers/net/dwc_eth_qos.c | 4 ++-- drivers/net/fec_mxc.c | 2 +- drivers/net/fm/b4860.c | 8 ++++---- drivers/net/fm/init.c | 8 ++++---- drivers/net/fm/ls1043.c | 6 +++--- drivers/net/fm/ls1046.c | 8 ++++---- drivers/net/fm/p1023.c | 4 ++-- drivers/net/fm/p4080.c | 6 +++--- drivers/net/fm/p5020.c | 6 +++--- drivers/net/fm/p5040.c | 6 +++--- drivers/net/fm/t1024.c | 4 ++-- drivers/net/fm/t1040.c | 4 ++-- drivers/net/fm/t2080.c | 6 +++--- drivers/net/fm/t4240.c | 6 +++--- drivers/net/fsl_enetc.c | 2 +- drivers/net/ftgmac100.c | 2 +- drivers/net/higmacv300.c | 2 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 2 +- drivers/net/ldpaa_eth/ldpaa_wriop.c | 10 +++++----- drivers/net/ldpaa_eth/ls1088a.c | 4 ++-- drivers/net/ldpaa_eth/ls2080a.c | 4 ++-- drivers/net/ldpaa_eth/lx2160a.c | 4 ++-- drivers/net/macb.c | 2 +- drivers/net/mscc_eswitch/jr2_switch.c | 2 +- drivers/net/mscc_eswitch/luton_switch.c | 2 +- drivers/net/mscc_eswitch/ocelot_switch.c | 2 +- drivers/net/mscc_eswitch/serval_switch.c | 2 +- drivers/net/mscc_eswitch/servalt_switch.c | 2 +- drivers/net/mt7620-eth.c | 12 ++++++------ drivers/net/mtk_eth.c | 2 +- drivers/net/mvgbe.c | 2 +- drivers/net/mvneta.c | 2 +- drivers/net/mvpp2.c | 2 +- drivers/net/pic32_eth.c | 2 +- drivers/net/qe/dm_qe_uec.c | 2 +- drivers/net/ravb.c | 2 +- drivers/net/sh_eth.c | 2 +- drivers/net/sni_ave.c | 2 +- drivers/net/sni_netsec.c | 2 +- drivers/net/sun8i_emac.c | 2 +- drivers/net/ti/am65-cpsw-nuss.c | 2 +- drivers/net/ti/cpsw.c | 2 +- drivers/net/ti/keystone_net.c | 2 +- drivers/net/tsec.c | 2 +- drivers/net/xilinx_axi_emac.c | 2 +- drivers/net/zynq_gem.c | 2 +- include/dm/ofnode.h | 2 +- include/dm/read.h | 2 +- include/fm_eth.h | 2 +- include/phy_interface.h | 8 ++++---- include/vsc9953.h | 2 +- net/mdio-uclass.c | 4 ++-- 61 files changed, 105 insertions(+), 105 deletions(-)
diff --git a/board/freescale/corenet_ds/eth_hydra.c b/board/freescale/corenet_ds/eth_hydra.c index 6500c2fcf6..a27e905ace 100644 --- a/board/freescale/corenet_ds/eth_hydra.c +++ b/board/freescale/corenet_ds/eth_hydra.c @@ -471,7 +471,7 @@ int board_eth_init(struct bd_info *bis) fm_info_set_mdio(i, miiphy_get_dev_by_name("HYDRA_RGMII_MDIO")); break; - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: fm_info_set_phy_address(i, 0); break; default: diff --git a/board/freescale/corenet_ds/eth_superhydra.c b/board/freescale/corenet_ds/eth_superhydra.c index de7b692f3f..55bac0f761 100644 --- a/board/freescale/corenet_ds/eth_superhydra.c +++ b/board/freescale/corenet_ds/eth_superhydra.c @@ -583,7 +583,7 @@ int board_eth_init(struct bd_info *bis) fm_info_set_mdio(i, miiphy_get_dev_by_name("SUPER_HYDRA_RGMII_MDIO")); break; - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: fm_info_set_phy_address(i, 0); break; default: @@ -733,7 +733,7 @@ int board_eth_init(struct bd_info *bis) fm_info_set_mdio(i, miiphy_get_dev_by_name("SUPER_HYDRA_RGMII_MDIO")); break; - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: fm_info_set_phy_address(i, 0); break; default: diff --git a/board/freescale/t104xrdb/eth.c b/board/freescale/t104xrdb/eth.c index b034f11d68..3ae5d722aa 100644 --- a/board/freescale/t104xrdb/eth.c +++ b/board/freescale/t104xrdb/eth.c @@ -89,7 +89,7 @@ int board_eth_init(struct bd_info *bis) case PHY_INTERFACE_MODE_QSGMII: fm_info_set_phy_address(i, 0); break; - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: fm_info_set_phy_address(i, 0); break; default: @@ -99,7 +99,7 @@ int board_eth_init(struct bd_info *bis) break; } if (fm_info_get_enet_if(i) == PHY_INTERFACE_MODE_QSGMII || - fm_info_get_enet_if(i) == PHY_INTERFACE_MODE_NONE) + fm_info_get_enet_if(i) == PHY_INTERFACE_MODE_NA) fm_info_set_mdio(i, NULL); else fm_info_set_mdio(i, diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index b9c334c46d..ba8f175ac6 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1196,7 +1196,7 @@ phy_interface_t ofnode_read_phy_mode(ofnode node) mode = ofnode_read_string(node, "phy-connection-type");
if (!mode) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
for (i = 0; i < PHY_INTERFACE_MODE_MAX; i++) if (!strcmp(mode, phy_interface_strings[i])) @@ -1204,5 +1204,5 @@ phy_interface_t ofnode_read_phy_mode(ofnode node)
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/ag7xxx.c b/drivers/net/ag7xxx.c index f24a917bd4..a16c998b2a 100644 --- a/drivers/net/ag7xxx.c +++ b/drivers/net/ag7xxx.c @@ -1265,7 +1265,7 @@ static int ag7xxx_eth_of_to_plat(struct udevice *dev) return ret;
pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
return 0; diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index 25247472b0..b1e5c5890a 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -678,7 +678,7 @@ static int altera_tse_of_to_plat(struct udevice *dev) struct eth_pdata *pdata = dev_get_plat(dev);
return 0; diff --git a/drivers/net/bcm6348-eth.c b/drivers/net/bcm6348-eth.c index 75b24136fd..7a34b8f446 100644 --- a/drivers/net/bcm6348-eth.c +++ b/drivers/net/bcm6348-eth.c @@ -425,7 +425,7 @@ static int bcm6348_eth_probe(struct udevice *dev)
/* get phy mode */ pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -ENODEV;
/* get phy */ diff --git a/drivers/net/bcmgenet.c b/drivers/net/bcmgenet.c index c6acb4932b..ef321f2839 100644 --- a/drivers/net/bcmgenet.c +++ b/drivers/net/bcmgenet.c @@ -696,7 +696,7 @@ static int bcmgenet_eth_of_to_plat(struct udevice *dev)
/* Get phy mode from DT */ pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
ret = dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 7b7b0f6578..1584b9eac1 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -921,7 +921,7 @@ int designware_eth_of_to_plat(struct udevice *dev)
pdata->iobase = dev_read_addr(dev); pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
pdata->max_speed = dev_read_u32_default(dev, "max-speed", 0); diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 9777f6cb9c..39aedc80f4 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1682,7 +1682,7 @@ static int eqos_probe_resources_stm32(struct udevice *dev)
interface = eqos->config->interface(dev);
- if (interface == PHY_INTERFACE_MODE_NONE) { + if (interface == PHY_INTERFACE_MODE_NA) { pr_err("Invalid PHY interface\n"); return -EINVAL; } @@ -1743,7 +1743,7 @@ static int eqos_probe_resources_imx(struct udevice *dev)
- if (interface == PHY_INTERFACE_MODE_NONE) { + if (interface == PHY_INTERFACE_MODE_NA) { pr_err("Invalid PHY interface\n"); return -EINVAL; } diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index de1d06f0f1..318568f256 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1563,7 +1563,7 @@ static int fecmxc_of_to_plat(struct udevice *dev) priv->eth = (struct ethernet_regs *)pdata->iobase;
#ifdef CONFIG_DM_REGULATOR diff --git a/drivers/net/fm/b4860.c b/drivers/net/fm/b4860.c index 6e3d008199..e622d86ba3 100644 --- a/drivers/net/fm/b4860.c +++ b/drivers/net/fm/b4860.c @@ -55,7 +55,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) #endif
if (is_device_disabled(port)) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
/*B4860 has two 10Gig Mac*/ if ((port == FM1_10GEC1 || port == FM1_10GEC2) && @@ -112,7 +112,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) (port == FM1_DTSEC2) || (port == FM1_DTSEC3) || (port == FM1_DTSEC4)) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } } } @@ -131,8 +131,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 2fed64205c..af94dabe29 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -130,7 +130,7 @@ static int fm_port_to_index(enum fm_port port)
/* * Determine if an interface is actually active based on HW config - * we expect fman_port_enet_if() to report PHY_INTERFACE_MODE_NONE if + * we expect fman_port_enet_if() to report PHY_INTERFACE_MODE_NA if * the interface is not active based on HW cfg of the SoC */ void fman_enet_init(void) @@ -141,7 +141,7 @@ void fman_enet_init(void) phy_interface_t enet_if;
enet_if = fman_port_enet_if(fm_info[i].port); - if (enet_if != PHY_INTERFACE_MODE_NONE) { + if (enet_if != PHY_INTERFACE_MODE_NA) { fm_info[i].enabled = 1; fm_info[i].enet_if = enet_if; } else { @@ -221,12 +221,12 @@ phy_interface_t fm_info_get_enet_if(enum fm_port port) int i = fm_port_to_index(port);
if (i == -1) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
if (fm_info[i].enabled) return fm_info[i].enet_if;
static void diff --git a/drivers/net/fm/ls1043.c b/drivers/net/fm/ls1043.c index e1abf8f6bb..cd8376a615 100644 --- a/drivers/net/fm/ls1043.c +++ b/drivers/net/fm/ls1043.c @@ -54,13 +54,13 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr13 = in_be32(&gur->rcwsr[13]);
if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC9))) return PHY_INTERFACE_MODE_XGMII;
if ((port == FM1_DTSEC9) && (is_serdes_configured(XFI_FM1_MAC9))) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
if (port == FM1_DTSEC3) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) == @@ -107,5 +107,5 @@ phy_interface_t fman_port_enet_if(enum fm_port port) break; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/ls1046.c b/drivers/net/fm/ls1046.c index 09df0aa537..876f48b147 100644 --- a/drivers/net/fm/ls1046.c +++ b/drivers/net/fm/ls1046.c @@ -54,19 +54,19 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr13 = in_be32(&gur->rcwsr[13]);
if ((port == FM1_10GEC2) && (is_serdes_configured(XFI_FM1_MAC10))) return PHY_INTERFACE_MODE_XGMII;
if ((port == FM1_DTSEC10) && (is_serdes_configured(XFI_FM1_MAC10))) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
if (port == FM1_DTSEC3) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) == @@ -118,5 +118,5 @@ phy_interface_t fman_port_enet_if(enum fm_port port) break; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/p1023.c b/drivers/net/fm/p1023.c index d4167e4d69..c9b85fc8a8 100644 --- a/drivers/net/fm/p1023.c +++ b/drivers/net/fm/p1023.c @@ -46,7 +46,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 pordevsr = in_be32(&gur->pordevsr);
/* DTSEC1 can be SGMII, RGMII or RMII */ if (port == FM1_DTSEC1) { @@ -68,5 +68,5 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_RGMII; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/p4080.c b/drivers/net/fm/p4080.c index b78b02d828..577ee22cb0 100644 --- a/drivers/net/fm/p4080.c +++ b/drivers/net/fm/p4080.c @@ -54,7 +54,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr11 = in_be32(&gur->rcwsr[11]);
if ((port == FM1_10GEC1) && (is_serdes_configured(XAUI_FM1))) return PHY_INTERFACE_MODE_XGMII; @@ -91,8 +91,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/p5020.c b/drivers/net/fm/p5020.c index 8189531215..8ecc48276a 100644 --- a/drivers/net/fm/p5020.c +++ b/drivers/net/fm/p5020.c @@ -50,7 +50,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr11 = in_be32(&gur->rcwsr[11]);
if ((port == FM1_10GEC1) && (is_serdes_configured(XAUI_FM1))) return PHY_INTERFACE_MODE_XGMII; @@ -82,8 +82,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/p5040.c b/drivers/net/fm/p5040.c index 38744e7b7b..3a1494d131 100644 --- a/drivers/net/fm/p5040.c +++ b/drivers/net/fm/p5040.c @@ -56,7 +56,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr11 = in_be32(&gur->rcwsr[11]);
if ((port == FM1_10GEC1) && (is_serdes_configured(XAUI_FM1))) return PHY_INTERFACE_MODE_XGMII; @@ -99,8 +99,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/t1024.c b/drivers/net/fm/t1024.c index 696e74c9e6..7110fb4fb1 100644 --- a/drivers/net/fm/t1024.c +++ b/drivers/net/fm/t1024.c @@ -39,7 +39,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr13 = in_be32(&gur->rcwsr[13]);
if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC1))) return PHY_INTERFACE_MODE_XGMII; @@ -83,5 +83,5 @@ phy_interface_t fman_port_enet_if(enum fm_port port) break; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/t1040.c b/drivers/net/fm/t1040.c index af4f5c5610..192f1c6c81 100644 --- a/drivers/net/fm/t1040.c +++ b/drivers/net/fm/t1040.c @@ -56,8 +56,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/t2080.c b/drivers/net/fm/t2080.c index f4d8d2d869..bfbd8de9cf 100644 --- a/drivers/net/fm/t2080.c +++ b/drivers/net/fm/t2080.c @@ -47,7 +47,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr13 = in_be32(&gur->rcwsr[13]);
if ((port == FM1_10GEC1 || port == FM1_10GEC2) && ((is_serdes_configured(XAUI_FM1_MAC9)) || @@ -85,8 +85,8 @@ phy_interface_t fman_port_enet_if(enum fm_port port) return PHY_INTERFACE_MODE_SGMII; break; default: - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fm/t4240.c b/drivers/net/fm/t4240.c index f8e63c3d71..ba7b86282f 100644 --- a/drivers/net/fm/t4240.c +++ b/drivers/net/fm/t4240.c @@ -61,7 +61,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) u32 rcwsr13 = in_be32(&gur->rcwsr[13]);
if ((port == FM1_10GEC1 || port == FM1_10GEC2) && ((is_serdes_configured(XAUI_FM1_MAC9)) || @@ -73,7 +73,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) if ((port == FM1_DTSEC9 || port == FM1_DTSEC10) && ((is_serdes_configured(XFI_FM1_MAC9)) || (is_serdes_configured(XFI_FM1_MAC10)))) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
if ((port == FM2_10GEC1 || port == FM2_10GEC2) && ((is_serdes_configured(XAUI_FM2_MAC9)) || @@ -166,5 +166,5 @@ phy_interface_t fman_port_enet_if(enum fm_port port) break; }
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/fsl_enetc.c b/drivers/net/fsl_enetc.c index 8f5af1dbc0..1724f948bc 100644 --- a/drivers/net/fsl_enetc.c +++ b/drivers/net/fsl_enetc.c @@ -277,7 +277,7 @@ static void enetc_start_pcs(struct udevice *dev) }
priv->if_type = dev_read_phy_mode(dev); - if (priv->if_type == PHY_INTERFACE_MODE_NONE) { + if (priv->if_type == PHY_INTERFACE_MODE_NA) { enetc_dbg(dev, "phy-mode property not found, defaulting to SGMII\n"); priv->if_type = PHY_INTERFACE_MODE_SGMII; diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 626c27d7bf..78779d7d60 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -553,7 +553,7 @@ static int ftgmac100_of_to_plat(struct udevice *dev) pdata->iobase = dev_read_addr(dev);
pdata->max_speed = dev_read_u32_default(dev, "max-speed", 0); diff --git a/drivers/net/higmacv300.c b/drivers/net/higmacv300.c index ce8f2dfd09..1862235d0c 100644 --- a/drivers/net/higmacv300.c +++ b/drivers/net/higmacv300.c @@ -567,7 +567,7 @@ static int higmac_of_to_plat(struct udevice *dev) priv->macif_ctrl = dev_remap_addr_index(dev, 1);
priv->phyintf = dev_read_phy_mode(dev); - if (priv->phyintf == PHY_INTERFACE_MODE_NONE) + if (priv->phyintf == PHY_INTERFACE_MODE_NA) return -ENODEV;
phy_node = dev_read_subnode(dev, "phy"); diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index c775598b91..b6f589eb91 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -1127,7 +1127,7 @@ static int ldpaa_eth_bind(struct udevice *dev) int phy_mode = -1;
phy_mode = dev_read_phy_mode(dev); - if (phy_mode == PHY_INTERFACE_MODE_NONE) { + if (phy_mode == PHY_INTERFACE_MODE_NA) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; } diff --git a/drivers/net/ldpaa_eth/ldpaa_wriop.c b/drivers/net/ldpaa_eth/ldpaa_wriop.c index 06a284ad68..adecb81357 100644 --- a/drivers/net/ldpaa_eth/ldpaa_wriop.c +++ b/drivers/net/ldpaa_eth/ldpaa_wriop.c @@ -16,7 +16,7 @@ struct wriop_dpmac_info dpmac_info[NUM_WRIOP_PORTS];
__weak phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtc) { - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; }
void wriop_init_dpmac(int sd, int dpmac_id, int lane_prtcl) @@ -26,10 +26,10 @@ void wriop_init_dpmac(int sd, int dpmac_id, int lane_prtcl)
dpmac_info[dpmac_id].enabled = 0; dpmac_info[dpmac_id].id = 0; - dpmac_info[dpmac_id].enet_if = PHY_INTERFACE_MODE_NONE; + dpmac_info[dpmac_id].enet_if = PHY_INTERFACE_MODE_NA;
enet_if = wriop_dpmac_enet_if(dpmac_id, lane_prtcl); - if (enet_if != PHY_INTERFACE_MODE_NONE) { + if (enet_if != PHY_INTERFACE_MODE_NA) { dpmac_info[dpmac_id].enabled = 1; dpmac_info[dpmac_id].id = dpmac_id; dpmac_info[dpmac_id].enet_if = enet_if; @@ -183,10 +183,10 @@ phy_interface_t wriop_get_enet_if(int dpmac_id) int i = wriop_dpmac_to_index(dpmac_id);
if (dpmac_info[i].enabled) return dpmac_info[i].enet_if;
- return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA; } diff --git a/drivers/net/ldpaa_eth/ls1088a.c b/drivers/net/ldpaa_eth/ls1088a.c index 54cb16e51b..943113b20a 100644 --- a/drivers/net/ldpaa_eth/ls1088a.c +++ b/drivers/net/ldpaa_eth/ls1088a.c @@ -50,7 +50,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) enum srds_prtcl;
if (is_device_disabled(dpmac_id + 1)) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
switch (lane_prtcl) { case SGMII1: @@ -66,7 +66,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) if (lane_prtcl >= QSGMII_A && lane_prtcl <= QSGMII_B) return PHY_INTERFACE_MODE_QSGMII;
void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) diff --git a/drivers/net/ldpaa_eth/ls2080a.c b/drivers/net/ldpaa_eth/ls2080a.c index 49eee044f3..62e1d6b869 100644 --- a/drivers/net/ldpaa_eth/ls2080a.c +++ b/drivers/net/ldpaa_eth/ls2080a.c @@ -62,7 +62,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) enum srds_prtcl;
if (lane_prtcl >= SGMII1 && lane_prtcl <= SGMII16) return PHY_INTERFACE_MODE_SGMII; @@ -76,7 +76,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) if (lane_prtcl >= QSGMII_A && lane_prtcl <= QSGMII_D) return PHY_INTERFACE_MODE_QSGMII;
void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) diff --git a/drivers/net/ldpaa_eth/lx2160a.c b/drivers/net/ldpaa_eth/lx2160a.c index e57f1a19a5..f0f8ee1d4d 100644 --- a/drivers/net/ldpaa_eth/lx2160a.c +++ b/drivers/net/ldpaa_eth/lx2160a.c @@ -58,7 +58,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) enum srds_prtcl;
if (is_device_disabled(dpmac_id)) - return PHY_INTERFACE_MODE_NONE; + return PHY_INTERFACE_MODE_NA;
if (lane_prtcl >= SGMII1 && lane_prtcl <= SGMII18) return PHY_INTERFACE_MODE_SGMII; @@ -78,7 +78,7 @@ phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) if (lane_prtcl >= _100GE1 && lane_prtcl <= _100GE2) return PHY_INTERFACE_MODE_CAUI4;
#ifdef CONFIG_SYS_FSL_HAS_RGMII diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 317b380e8f..e02a57b411 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -1363,7 +1363,7 @@ static int macb_eth_probe(struct udevice *dev) int ret;
macb->phy_interface = dev_read_phy_mode(dev); - if (macb->phy_interface == PHY_INTERFACE_MODE_NONE) + if (macb->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
/* Read phyaddr from DT */ diff --git a/drivers/net/mscc_eswitch/jr2_switch.c b/drivers/net/mscc_eswitch/jr2_switch.c index d1e5b61ea5..1462b8f3bc 100644 --- a/drivers/net/mscc_eswitch/jr2_switch.c +++ b/drivers/net/mscc_eswitch/jr2_switch.c @@ -954,7 +954,7 @@ static int jr2_probe(struct udevice *dev)
phy = phy_connect(priv->ports[i].bus, priv->ports[i].phy_addr, dev, - PHY_INTERFACE_MODE_NONE); + PHY_INTERFACE_MODE_NA); if (phy) board_phy_config(phy); } diff --git a/drivers/net/mscc_eswitch/luton_switch.c b/drivers/net/mscc_eswitch/luton_switch.c index 73c950d118..5e4f00c4f4 100644 --- a/drivers/net/mscc_eswitch/luton_switch.c +++ b/drivers/net/mscc_eswitch/luton_switch.c @@ -685,7 +685,7 @@ static int luton_probe(struct udevice *dev)
phy = phy_connect(priv->ports[i].bus, priv->ports[i].phy_addr, dev, - PHY_INTERFACE_MODE_NONE); + PHY_INTERFACE_MODE_NA); if (phy && i >= MAX_INT_PORT) board_phy_config(phy); } diff --git a/drivers/net/mscc_eswitch/ocelot_switch.c b/drivers/net/mscc_eswitch/ocelot_switch.c index d1d0a489ab..1bf6c42c0f 100644 --- a/drivers/net/mscc_eswitch/ocelot_switch.c +++ b/drivers/net/mscc_eswitch/ocelot_switch.c @@ -608,7 +608,7 @@ static int ocelot_probe(struct udevice *dev)
phy = phy_connect(priv->ports[i].bus, priv->ports[i].phy_addr, dev, - PHY_INTERFACE_MODE_NONE); + PHY_INTERFACE_MODE_NA); if (phy && external_bus(priv, i)) board_phy_config(phy); } diff --git a/drivers/net/mscc_eswitch/serval_switch.c b/drivers/net/mscc_eswitch/serval_switch.c index c4b81f7529..38ddba12b6 100644 --- a/drivers/net/mscc_eswitch/serval_switch.c +++ b/drivers/net/mscc_eswitch/serval_switch.c @@ -561,7 +561,7 @@ static int serval_probe(struct udevice *dev)
phy = phy_connect(priv->ports[i].bus, priv->ports[i].phy_addr, dev, - PHY_INTERFACE_MODE_NONE); + PHY_INTERFACE_MODE_NA); if (phy) board_phy_config(phy); } diff --git a/drivers/net/mscc_eswitch/servalt_switch.c b/drivers/net/mscc_eswitch/servalt_switch.c index f114086ece..db863c2a9f 100644 --- a/drivers/net/mscc_eswitch/servalt_switch.c +++ b/drivers/net/mscc_eswitch/servalt_switch.c @@ -482,7 +482,7 @@ static int servalt_probe(struct udevice *dev) continue;
phy_connect(priv->ports[i].bus, priv->ports[i].phy_addr, dev, - PHY_INTERFACE_MODE_NONE); + PHY_INTERFACE_MODE_NA); }
return 0; diff --git a/drivers/net/mt7620-eth.c b/drivers/net/mt7620-eth.c index 24fcb9373f..038cba1240 100644 --- a/drivers/net/mt7620-eth.c +++ b/drivers/net/mt7620-eth.c @@ -596,7 +596,7 @@ static int mt7620_setup_gmac_mode(struct mt7620_eth_priv *priv, u32 gmac, case PHY_INTERFACE_MODE_RGMII: ge_mode = MT7620_SYSC_GE_RGMII; break; - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: if (gmac == 2) ge_mode = MT7620_SYSC_GE_ESW_PHY; else @@ -620,7 +620,7 @@ static void mt7620_gsw_setup_port(struct mt7620_eth_priv *priv, u32 port, { u32 pmcr;
- if (port_cfg->mode == PHY_INTERFACE_MODE_NONE) { + if (port_cfg->mode == PHY_INTERFACE_MODE_NA) { if (port == 5) { gsw_write(priv, GSW_PMCR(port), FORCE_MODE); return; @@ -666,7 +666,7 @@ static void mt7620_gsw_setup_phy_polling(struct mt7620_eth_priv *priv) { int phy_addr_st, phy_addr_end;
- if (priv->port_cfg[0].mode == PHY_INTERFACE_MODE_NONE) + if (priv->port_cfg[0].mode == PHY_INTERFACE_MODE_NA) priv->ephy_num = NUM_FE_PHYS; else priv->ephy_num = NUM_FE_PHYS - 1; @@ -1057,7 +1057,7 @@ static int mt7620_eth_parse_gsw_port(struct mt7620_eth_priv *priv, u32 idx, case PHY_INTERFACE_MODE_MII: case PHY_INTERFACE_MODE_RMII: case PHY_INTERFACE_MODE_RGMII: - case PHY_INTERFACE_MODE_NONE: + case PHY_INTERFACE_MODE_NA: break; default: dev_err(priv->dev, "mt7620_eth: unsupported phy-mode\n"); @@ -1128,14 +1128,14 @@ static int mt7620_eth_parse_gsw_cfg(struct udevice *dev) if (ret) return ret; } else { - priv->port_cfg[0].mode = PHY_INTERFACE_MODE_NONE; + priv->port_cfg[0].mode = PHY_INTERFACE_MODE_NA; }
subnode = ofnode_find_subnode(dev_ofnode(dev), "port5"); if (ofnode_valid(subnode)) return mt7620_eth_parse_gsw_port(priv, 1, subnode);
- priv->port_cfg[1].mode = PHY_INTERFACE_MODE_NONE; + priv->port_cfg[1].mode = PHY_INTERFACE_MODE_NA; return 0; }
diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index d6065db5fb..666ddeb10d 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -1449,7 +1449,7 @@ static int mtk_eth_of_to_plat(struct udevice *dev) /* Interface mode is required */ pdata->phy_interface = dev_read_phy_mode(dev); priv->phy_interface = pdata->phy_interface; - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) { + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) { printf("error: phy-mode is not set\n"); return -EINVAL; } diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 32ec0b437d..bf5ed5513b 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -1005,7 +1005,7 @@ static int mvgbe_of_to_plat(struct udevice *dev)
/* Get phy-mode / phy_interface from DT */ pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) pdata->phy_interface = PHY_INTERFACE_MODE_GMII;
dmvgbe->phy_interface = pdata->phy_interface; diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index d31b96a9d8..e2ac4d801d 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -1804,7 +1804,7 @@ static int mvneta_of_to_plat(struct udevice *dev)
/* Get phy-mode / phy_interface from DT */ pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
return 0; diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index dfddac180f..8c9afdf79a 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -4820,7 +4820,7 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) }
port->phy_interface = dev_read_phy_mode(dev); - if (port->phy_interface == PHY_INTERFACE_MODE_NONE) { + if (port->phy_interface == PHY_INTERFACE_MODE_NA) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; } diff --git a/drivers/net/pic32_eth.c b/drivers/net/pic32_eth.c index 03eb51e51d..1333a3aa7e 100644 --- a/drivers/net/pic32_eth.c +++ b/drivers/net/pic32_eth.c @@ -550,7 +550,7 @@ static int pic32_eth_probe(struct udevice *dev)
/* get phy mode */ pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
/* get phy addr */ diff --git a/drivers/net/qe/dm_qe_uec.c b/drivers/net/qe/dm_qe_uec.c index 5a66d726cd..8fec1c21e1 100644 --- a/drivers/net/qe/dm_qe_uec.c +++ b/drivers/net/qe/dm_qe_uec.c @@ -1137,7 +1137,7 @@ static int qe_uec_of_to_plat(struct udevice *dev) pdata->iobase = (phys_addr_t)devfdt_get_addr(dev);
return 0; diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index f6d386bd6b..5c152d6e0a 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -679,7 +679,7 @@ int ravb_of_to_plat(struct udevice *dev) pdata->iobase = dev_read_addr(dev);
pdata->max_speed = 1000; diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 04c9c2d968..5c57e3dfcd 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -920,7 +920,7 @@ int sh_ether_of_to_plat(struct udevice *dev) pdata->iobase = dev_read_addr(dev);
pdata->max_speed = 1000; diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index 0a368c6d03..d684e60e72 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -749,7 +749,7 @@ static int ave_of_to_plat(struct udevice *dev) pdata->iobase = dev_read_addr(dev);
pdata->max_speed = 0; diff --git a/drivers/net/sni_netsec.c b/drivers/net/sni_netsec.c index 693fd3a35d..24caacf847 100644 --- a/drivers/net/sni_netsec.c +++ b/drivers/net/sni_netsec.c @@ -1034,7 +1034,7 @@ static int netsec_of_to_plat(struct udevice *dev) priv->eeprom_base = dev_read_addr_index(dev, 1) - EERPROM_MAP_OFFSET;
if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 5654a3430e..5943a5e3f0 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -947,7 +947,7 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev)
pdata->phy_interface = dev_read_phy_mode(dev); printf("phy interface%d\n", pdata->phy_interface); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
if (priv->variant == H3_EMAC) { diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index c1da334739..9580fa37ea 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -607,7 +607,7 @@ static int am65_cpsw_ofdata_parse_phy(struct udevice *dev) dev_read_u32(dev, "reg", &priv->port_id);
pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) { + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) { dev_err(dev, "Invalid PHY mode, port %u\n", priv->port_id); return -EINVAL; } diff --git a/drivers/net/ti/cpsw.c b/drivers/net/ti/cpsw.c index 5b7bab734e..8988c21e66 100644 --- a/drivers/net/ti/cpsw.c +++ b/drivers/net/ti/cpsw.c @@ -1345,7 +1345,7 @@ static int cpsw_eth_of_to_plat(struct udevice *dev) }
pdata->phy_interface = data->slave_data[data->active_slave].phy_if; - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL;
return 0; diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index b55e7da4c1..16e3f32bb0 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -728,7 +728,7 @@ static int ks2_eth_parse_slave_interface(int netcp, int slave, priv->has_mdio = true; } else if (priv->link_type == LINK_TYPE_RGMII_LINK_MAC_PHY) { priv->phy_if = ofnode_read_phy_mode(offset_to_ofnode(slave)); - if (priv->phy_if == PHY_INTERFACE_MODE_NONE) + if (priv->phy_if == PHY_INTERFACE_MODE_NA) priv->phy_if = PHY_INTERFACE_MODE_RGMII; pdata->phy_interface = priv->phy_if;
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index fec051ebb7..d69a9ff477 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -894,7 +894,7 @@ int tsec_probe(struct udevice *dev) priv->tbiaddr = tbiaddr;
pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) pdata->phy_interface = tsec_get_interface(priv);
priv->interface = pdata->phy_interface; diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 02d13c3e0a..a4715735c3 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -850,7 +850,7 @@ static int axi_emac_of_to_plat(struct udevice *dev) }
plat->eth_hasnobuf = fdtdec_get_bool(gd->fdt_blob, node, diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 0062851134..cf6c53c8af 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -859,7 +859,7 @@ static int zynq_gem_of_to_plat(struct udevice *dev) }
pdata->phy_interface = dev_read_phy_mode(dev); - if (pdata->phy_interface == PHY_INTERFACE_MODE_NONE) + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; priv->interface = pdata->phy_interface;
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 8a38c143f9..56330e691a 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1226,7 +1226,7 @@ ofnode ofnode_get_phy_node(ofnode eth_node); * returns the corresponding PHY interface type. * * @mac_node: ofnode containing the property - * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NONE on + * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NA on * error */ phy_interface_t ofnode_read_phy_mode(ofnode mac_node); diff --git a/include/dm/read.h b/include/dm/read.h index bfa2645967..1b54b69acf 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -764,7 +764,7 @@ ofnode dev_get_phy_node(const struct udevice *dev); * returns the corresponding PHY interface type. * * @dev: device representing the MAC - * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NONE on + * Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NA on * error */ phy_interface_t dev_read_phy_mode(const struct udevice *dev); diff --git a/include/fm_eth.h b/include/fm_eth.h index 44da014c66..bf9570679d 100644 --- a/include/fm_eth.h +++ b/include/fm_eth.h @@ -72,7 +72,7 @@ enum fm_eth_type { #define FM_ETH_INFO_INITIALIZER(idx, pregs) \ .fm = idx, \ .phy_regs = (void *)pregs, \ - .enet_if = PHY_INTERFACE_MODE_NONE, \ + .enet_if = PHY_INTERFACE_MODE_NA, \
#ifdef CONFIG_SYS_FMAN_V3 #define FM_DTSEC_INFO_INITIALIZER(idx, n) \ diff --git a/include/phy_interface.h b/include/phy_interface.h index 494bc87e67..59e119a639 100644 --- a/include/phy_interface.h +++ b/include/phy_interface.h @@ -39,7 +39,7 @@ typedef enum { PHY_INTERFACE_MODE_NCSI, PHY_INTERFACE_MODE_10GBASER, PHY_INTERFACE_MODE_USXGMII, - PHY_INTERFACE_MODE_NONE, /* Must be last */ + PHY_INTERFACE_MODE_NA, /* Must be last */
PHY_INTERFACE_MODE_MAX, } phy_interface_t; @@ -71,7 +71,7 @@ static const char * const phy_interface_strings[] = { [PHY_INTERFACE_MODE_NCSI] = "NC-SI", [PHY_INTERFACE_MODE_10GBASER] = "10gbase-r", [PHY_INTERFACE_MODE_USXGMII] = "usxgmii", - [PHY_INTERFACE_MODE_NONE] = "", + [PHY_INTERFACE_MODE_NA] = "", };
/* Backplane modes: @@ -86,8 +86,8 @@ static const char * const backplane_mode_strings[] = { static inline const char *phy_string_for_interface(phy_interface_t i) { /* Default to unknown */ - if (i > PHY_INTERFACE_MODE_NONE) - i = PHY_INTERFACE_MODE_NONE; + if (i > PHY_INTERFACE_MODE_NA) + i = PHY_INTERFACE_MODE_NA;
return phy_interface_strings[i]; } diff --git a/include/vsc9953.h b/include/vsc9953.h index a9c84b4b50..fd52c93044 100644 --- a/include/vsc9953.h +++ b/include/vsc9953.h @@ -691,7 +691,7 @@ struct vsc9953_vcap { .phyaddr = 0, \ .index = idx, \ .phy_regs = NULL, \ - .enet_if = PHY_INTERFACE_MODE_NONE, \ + .enet_if = PHY_INTERFACE_MODE_NA, \ .bus = NULL, \ .phydev = NULL, \ } diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 874f59413a..7593618d9a 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -199,8 +199,8 @@ struct phy_device *dm_eth_phy_connect(struct udevice *ethdev) }
interface = dev_read_phy_mode(ethdev); - if (interface == PHY_INTERFACE_MODE_NONE) - dev_dbg(ethdev, "can't find interface mode, default to NONE\n"); + if (interface == PHY_INTERFACE_MODE_NA) + dev_dbg(ethdev, "can't find interface mode, default to NA\n");
phy = dm_eth_connect_phy_handle(ethdev, interface);
Thanks, Stefan
default:case PHY_INTERFACE_MODE_NA: fm_info_set_phy_address(i, 0); break;
else fm_info_set_mdio(i,fm_info_get_enet_if(i) == PHY_INTERFACE_MODE_NA) fm_info_set_mdio(i, NULL);
if (!mode)
debug("%s: Invalid PHY interface '%s'\n", __func__, mode);
- return PHY_INTERFACE_MODE_NA; }
/* get phy */
- if (interface == PHY_INTERFACE_MODE_NA) { pr_err("Invalid PHY interface\n"); return -EINVAL; }
} }return PHY_INTERFACE_MODE_NA; }
- Determine if an interface is actually active based on HW config
- we expect fman_port_enet_if() to report PHY_INTERFACE_MODE_NONE if
- we expect fman_port_enet_if() to report PHY_INTERFACE_MODE_NA if
- the interface is not active based on HW cfg of the SoC
} else {if (enet_if != PHY_INTERFACE_MODE_NA) { fm_info[i].enabled = 1; fm_info[i].enet_if = enet_if;
if (i == -1)
static void
- if (priv->if_type == PHY_INTERFACE_MODE_NA) { enetc_dbg(dev, "phy-mode property not found, defaulting to SGMII\n"); priv->if_type = PHY_INTERFACE_MODE_SGMII;
- if (phy_mode == PHY_INTERFACE_MODE_NA) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; }
- if (enet_if != PHY_INTERFACE_MODE_NA) { dpmac_info[dpmac_id].enabled = 1; dpmac_info[dpmac_id].id = dpmac_id; dpmac_info[dpmac_id].enet_if = enet_if;
if (i == -1)
if (phy) board_phy_config(phy); }PHY_INTERFACE_MODE_NA);
if (phy && i >= MAX_INT_PORT) board_phy_config(phy); }PHY_INTERFACE_MODE_NA);
if (phy && external_bus(priv, i)) board_phy_config(phy); }PHY_INTERFACE_MODE_NA);
- case PHY_INTERFACE_MODE_NA: if (gmac == 2) ge_mode = MT7620_SYSC_GE_ESW_PHY; else
- if (port_cfg->mode == PHY_INTERFACE_MODE_NA) { if (port == 5) { gsw_write(priv, GSW_PMCR(port), FORCE_MODE); return;
- if (priv->port_cfg[0].mode == PHY_INTERFACE_MODE_NA) priv->ephy_num = NUM_FE_PHYS; else priv->ephy_num = NUM_FE_PHYS - 1;
- case PHY_INTERFACE_MODE_NA: break; default: dev_err(priv->dev, "mt7620_eth: unsupported phy-mode\n");
- priv->port_cfg[1].mode = PHY_INTERFACE_MODE_NA; return 0; }
- if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) { printf("error: phy-mode is not set\n"); return -EINVAL; }
- if (port->phy_interface == PHY_INTERFACE_MODE_NA) { dev_err(dev, "incorrect phy mode\n"); return -EINVAL; }
/* get phy addr */
- if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) { dev_err(dev, "Invalid PHY mode, port %u\n", priv->port_id); return -EINVAL; }
pdata->phy_interface = priv->phy_if;if (priv->phy_if == PHY_INTERFACE_MODE_NA) priv->phy_if = PHY_INTERFACE_MODE_RGMII;
- if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; priv->interface = pdata->phy_interface;
- Return: one of PHY_INTERFACE_MODE_* constants, PHY_INTERFACE_MODE_NA on
error
- @dev: device representing the MAC
error
/* Backplane modes:
- .enet_if = PHY_INTERFACE_MODE_NA, \ .bus = NULL, \ .phydev = NULL, \ }
if (!mode)
return PHY_INTERFACE_MODE_NA; for (i = 0; i < PHY_INTERFACE_MODE_MAX; i++) if (!strcmp(mode, phy_interface_strings[i]))
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; return 0;
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -ENODEV; /* get phy */
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; ret = dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0,
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; pdata->max_speed = dev_read_u32_default(dev, "max-speed", 0);
return PHY_INTERFACE_MODE_NA; /*B4860 has two 10Gig Mac*/ if ((port == FM1_10GEC1 || port == FM1_10GEC2) &&
if (i == -1)
return PHY_INTERFACE_MODE_NA; if (fm_info[i].enabled) return fm_info[i].enet_if;
return PHY_INTERFACE_MODE_NA; if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC9))) return PHY_INTERFACE_MODE_XGMII; if ((port == FM1_DTSEC9) && (is_serdes_configured(XFI_FM1_MAC9)))
return PHY_INTERFACE_MODE_NA; if (port == FM1_DTSEC3) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) ==
return PHY_INTERFACE_MODE_NA; if ((port == FM1_10GEC2) && (is_serdes_configured(XFI_FM1_MAC10))) return PHY_INTERFACE_MODE_XGMII; if ((port == FM1_DTSEC10) && (is_serdes_configured(XFI_FM1_MAC10)))
return PHY_INTERFACE_MODE_NA; /* DTSEC1 can be SGMII, RGMII or RMII */ if (port == FM1_DTSEC1) {
return PHY_INTERFACE_MODE_NA; if ((port == FM1_10GEC1) && (is_serdes_configured(XAUI_FM1))) return PHY_INTERFACE_MODE_XGMII;
return PHY_INTERFACE_MODE_NA; if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC1))) return PHY_INTERFACE_MODE_XGMII;
return PHY_INTERFACE_MODE_NA; if ((port == FM1_10GEC1 || port == FM1_10GEC2) && ((is_serdes_configured(XAUI_FM1_MAC9)) ||
return PHY_INTERFACE_MODE_NA; if ((port == FM2_10GEC1 || port == FM2_10GEC2) && ((is_serdes_configured(XAUI_FM2_MAC9)) ||
if (priv->phyintf == PHY_INTERFACE_MODE_NA) return -ENODEV; phy_node = dev_read_subnode(dev, "phy");
dpmac_info[dpmac_id].enet_if = PHY_INTERFACE_MODE_NA; enet_if = wriop_dpmac_enet_if(dpmac_id, lane_prtcl);
if (i == -1)
return PHY_INTERFACE_MODE_NA; if (dpmac_info[i].enabled) return dpmac_info[i].enet_if;
return PHY_INTERFACE_MODE_NA; switch (lane_prtcl) { case SGMII1:
return PHY_INTERFACE_MODE_NA; if (lane_prtcl >= SGMII1 && lane_prtcl <= SGMII16) return PHY_INTERFACE_MODE_SGMII;
return PHY_INTERFACE_MODE_NA; if (lane_prtcl >= SGMII1 && lane_prtcl <= SGMII18) return PHY_INTERFACE_MODE_SGMII;
if (macb->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; /* Read phyaddr from DT */
PHY_INTERFACE_MODE_NA); } return 0;
priv->port_cfg[0].mode = PHY_INTERFACE_MODE_NA; } subnode = ofnode_find_subnode(dev_ofnode(dev), "port5"); if (ofnode_valid(subnode)) return mt7620_eth_parse_gsw_port(priv, 1, subnode);
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) pdata->phy_interface = PHY_INTERFACE_MODE_GMII; dmvgbe->phy_interface = pdata->phy_interface;
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; /* get phy addr */
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; pdata->max_speed = 1000;
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; pdata->max_speed = 0;
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; if (!dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0,
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; if (priv->variant == H3_EMAC) {
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) pdata->phy_interface = tsec_get_interface(priv); priv->interface = pdata->phy_interface;
if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; plat->eth_hasnobuf = fdtdec_get_bool(gd->fdt_blob, node,
error
error
PHY_INTERFACE_MODE_NA, /* Must be last */ PHY_INTERFACE_MODE_MAX,
i = PHY_INTERFACE_MODE_NA; return phy_interface_strings[i];
dev_dbg(ethdev, "can't find interface mode, default to NA\n"); phy = dm_eth_connect_phy_handle(ethdev, interface);
-- 2.34.1
Move PHY_INTERFACE_MODE_NA to the beginning of the enum definition to make it have zero value. This makes it possible (although not encouraged) to test for invalid/nonexistent interface mode with !val instead of val == PHY_INTERFACE_MODE_NA.
The comment near the definition says "Must be last", because when the constant was introduced in commit 5f184715ecd3 ("Create PHY Lib for U-Boot"), it was used as the maximum value when interating over the constants. But this is no longer true - we use PHY_INTERFACE_MODE_MAX for that now, and so we can move it.
Signed-off-by: Marek Behún marek.behun@nic.cz --- include/phy_interface.h | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/include/phy_interface.h b/include/phy_interface.h index 59e119a639..ce3b5004ec 100644 --- a/include/phy_interface.h +++ b/include/phy_interface.h @@ -13,6 +13,7 @@ #include <string.h>
typedef enum { + PHY_INTERFACE_MODE_NA, /* don't touch */ PHY_INTERFACE_MODE_MII, PHY_INTERFACE_MODE_GMII, PHY_INTERFACE_MODE_SGMII, @@ -39,12 +40,11 @@ typedef enum { PHY_INTERFACE_MODE_NCSI, PHY_INTERFACE_MODE_10GBASER, PHY_INTERFACE_MODE_USXGMII, - PHY_INTERFACE_MODE_NA, /* Must be last */ - PHY_INTERFACE_MODE_MAX, } phy_interface_t;
static const char * const phy_interface_strings[] = { + [PHY_INTERFACE_MODE_NA] = "", [PHY_INTERFACE_MODE_MII] = "mii", [PHY_INTERFACE_MODE_GMII] = "gmii", [PHY_INTERFACE_MODE_SGMII] = "sgmii", @@ -71,7 +71,6 @@ static const char * const phy_interface_strings[] = { [PHY_INTERFACE_MODE_NCSI] = "NC-SI", [PHY_INTERFACE_MODE_10GBASER] = "10gbase-r", [PHY_INTERFACE_MODE_USXGMII] = "usxgmii", - [PHY_INTERFACE_MODE_NA] = "", };
/* Backplane modes:
Thanks, Stefan
typedef enum {
- PHY_INTERFACE_MODE_NA, /* don't touch */ PHY_INTERFACE_MODE_MII, PHY_INTERFACE_MODE_GMII, PHY_INTERFACE_MODE_SGMII,
- [PHY_INTERFACE_MODE_NA] = "", [PHY_INTERFACE_MODE_MII] = "mii", [PHY_INTERFACE_MODE_GMII] = "gmii", [PHY_INTERFACE_MODE_SGMII] = "sgmii",
/* Backplane modes:
typedef enum {
} phy_interface_t;
/* Backplane modes:
2.34.1
We want to be able to have phydev->interface uninitialized during ->probe(). We should assume that phydev->interface is initialized only before ->config().
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/net/phy/xilinx_gmii2rgmii.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/phy/xilinx_gmii2rgmii.c b/drivers/net/phy/xilinx_gmii2rgmii.c index 635c0570ef..d92a364365 100644 --- a/drivers/net/phy/xilinx_gmii2rgmii.c +++ b/drivers/net/phy/xilinx_gmii2rgmii.c @@ -26,6 +26,11 @@ static int xilinxgmiitorgmii_config(struct phy_device *phydev)
debug("%s\n", __func__);
+ if (phydev->interface != PHY_INTERFACE_MODE_GMII) { + printf("Incorrect interface type\n"); + return -EINVAL; + } + if (!ofnode_valid(node)) return -EINVAL;
@@ -114,11 +119,6 @@ static int xilinxgmiitorgmii_probe(struct phy_device *phydev) { debug("%s\n", __func__);
- if (phydev->interface != PHY_INTERFACE_MODE_GMII) { - printf("Incorrect interface type\n"); - return -EINVAL; - } - phydev->flags |= PHY_FLAG_BROKEN_RESET;
return -EINVAL;
return -EINVAL;
phydev->flags |= PHY_FLAG_BROKEN_RESET; return 0;
-- 2.34.1
Use phydev->is_c45 instead of is_10g_interface(phydev->interface) to determine whether clause 45 protocol should be used.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/net/phy/phy.c | 8 ++++---- include/phy.h | 12 ------------ 2 files changed, 4 insertions(+), 16 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 4109676a51..10c724388f 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -632,10 +632,10 @@ static int phy_probe(struct phy_device *phydev) return err; }
-static struct phy_driver *generic_for_interface(phy_interface_t interface) +static struct phy_driver *generic_for_phy(struct phy_device *phydev) { #ifdef CONFIG_PHYLIB_10G - if (is_10g_interface(interface)) + if (phydev->is_c45) return &gen10g_driver; #endif
@@ -656,7 +656,7 @@ static struct phy_driver *get_phy_driver(struct phy_device *phydev, }
/* If we made it here, there's no driver for this PHY */ - return generic_for_interface(interface); + return generic_for_phy(phydev); }
static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, @@ -859,7 +859,7 @@ int phy_reset(struct phy_device *phydev)
#ifdef CONFIG_PHYLIB_10G /* If it's 10G, we need to issue reset through one of the MMDs */ - if (is_10g_interface(phydev->interface)) { + if (phydev->is_c45) { if (!phydev->mmds) gen10g_discover_mmds(phydev);
diff --git a/include/phy.h b/include/phy.h index dee8fb5f2e..9742ce6fe1 100644 --- a/include/phy.h +++ b/include/phy.h @@ -359,18 +359,6 @@ static inline int phy_clear_bits_mmd(struct phy_device *phydev, int devad,
#ifdef CONFIG_PHYLIB_10G extern struct phy_driver gen10g_driver; - -/* - * List all 10G interfaces here, the assumption being that PHYs on these - * interfaces are C45 - */ -static inline int is_10g_interface(phy_interface_t interface) -{ - return interface == PHY_INTERFACE_MODE_XGMII || - interface == PHY_INTERFACE_MODE_USXGMII || - interface == PHY_INTERFACE_MODE_10GBASER; -} - #endif
#endif
- List all 10G interfaces here, the assumption being that PHYs on these
- interfaces are C45
#endif
2.34.1
The bcmgenet and sun8i_emac drivers call phy_connect(), which finds / creates the PHY and also connects it to the eth device via phy_connect_dev(), then set some phydev members (bcmgenet only), and then call phy_connect_dev() explicitly again.
Drop the second phy_connect_dev(), since it is unnecesary.
Signed-off-by: Marek Behún marek.behun@nic.cz --- drivers/net/bcmgenet.c | 2 -- drivers/net/sun8i_emac.c | 2 -- 2 files changed, 4 deletions(-)
diff --git a/drivers/net/bcmgenet.c b/drivers/net/bcmgenet.c index ef321f2839..4e1f8ed7a4 100644 --- a/drivers/net/bcmgenet.c +++ b/drivers/net/bcmgenet.c @@ -526,8 +526,6 @@ static int bcmgenet_phy_init(struct bcmgenet_eth_priv *priv, void *dev) } phydev->advertising = phydev->supported;
- phy_connect_dev(phydev, dev); - priv->phydev = phydev; phy_config(priv->phydev);
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 5943a5e3f0..906a8ec5d0 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -391,8 +391,6 @@ static int sun8i_phy_init(struct emac_eth_dev *priv, void *dev) if (!phydev) return -ENODEV;
-- 2.34.1
Currently we require PHY interface mode to be known when finding/creating the PHY - the functions * phy_device_create() * create_phy_by_mask() * search_for_existing_phy() * get_phy_device_by_mask() * phy_find_by_mask() (this is the only one global) all require the interface parameter, but the only thing done with it is that it is assigned to phydev->interface.
This makes it impossible to find a PHY device without overwriting the set mode.
Since the interface mode is not used during .probe() and should be used at first in .config(), drop the interface parameter from these functions. Make the default value of phydev->interface (in phy_device_create()) to be PHY_INTERFACE_MODE_NA. Move the interface parameter to phy_connect_dev(), where it should be.
Change all occurrences treewide. In occurrences where we don't call phy_connect_dev() for some reason (they only configure the PHY without connecting it to an ethernet controller), set phydev->interface = value from phy_find_by_mask call.
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/CZ.NIC/turris_mox/turris_mox.c | 2 +- board/boundary/nitrogen6x/nitrogen6x.c | 2 +- board/gdsys/a38x/controlcenterdc.c | 7 ++- board/gdsys/a38x/ihs_phys.c | 6 +- drivers/net/altera_tse.c | 4 +- drivers/net/ethoc.c | 4 +- drivers/net/fec_mxc.c | 4 +- drivers/net/pch_gbe.c | 4 +- drivers/net/phy/phy.c | 86 +++++++++++--------------- drivers/net/phy/xilinx_gmii2rgmii.c | 4 +- drivers/net/ravb.c | 4 +- drivers/net/sh_eth.c | 4 +- drivers/net/sni_ave.c | 4 +- drivers/net/sunxi_emac.c | 5 +- include/_exports.h | 3 +- include/exports.h | 3 +- include/phy.h | 12 ++-- 17 files changed, 72 insertions(+), 86 deletions(-)
diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index 8888a2dcab..9702d1fc78 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -396,7 +396,7 @@ static void mox_phy_leds_start_blinking(void) return; }
- phydev = phy_find_by_mask(bus, BIT(1), PHY_INTERFACE_MODE_RGMII); + phydev = phy_find_by_mask(bus, BIT(1)); if (!phydev) { printf("Cannot get ethernet PHY!\n"); return; diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 84e14d1124..47784e9445 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -345,7 +345,7 @@ int board_eth_init(struct bd_info *bis) if (!bus) return -EINVAL; /* scan phy 4,5,6,7 */ - phydev = phy_find_by_mask(bus, (0xf << 4), PHY_INTERFACE_MODE_RGMII); + phydev = phy_find_by_mask(bus, (0xf << 4)); if (!phydev) { ret = -EINVAL; goto free_bus; diff --git a/board/gdsys/a38x/controlcenterdc.c b/board/gdsys/a38x/controlcenterdc.c index 7d65400ccb..ccebba7272 100644 --- a/board/gdsys/a38x/controlcenterdc.c +++ b/board/gdsys/a38x/controlcenterdc.c @@ -194,11 +194,12 @@ void init_host_phys(struct mii_dev *bus) for (k = 0; k < 2; ++k) { struct phy_device *phydev;
- phydev = phy_find_by_mask(bus, 1 << k, - PHY_INTERFACE_MODE_SGMII); + phydev = phy_find_by_mask(bus, 1 << k);
- if (phydev) + if (phydev) { + phydev->interface = PHY_INTERFACE_MODE_SGMII; phy_config(phydev); + } } }
diff --git a/board/gdsys/a38x/ihs_phys.c b/board/gdsys/a38x/ihs_phys.c index e09c0006b7..60a5c37aef 100644 --- a/board/gdsys/a38x/ihs_phys.c +++ b/board/gdsys/a38x/ihs_phys.c @@ -28,6 +28,7 @@ static void ihs_phy_config(struct phy_device *phydev, bool qinpn, bool qoutpn) { u16 reg;
+ phydev->interface = PHY_INTERFACE_MODE_MII; phy_config(phydev);
/* enable QSGMII autonegotiation with flow control */ @@ -142,10 +143,9 @@ struct porttype *get_porttype(uint octo_phy_mask, uint k) int init_single_phy(struct porttype *porttype, struct mii_dev *bus, uint bus_idx, uint m, uint phy_idx) { - struct phy_device *phydev = phy_find_by_mask( - bus, 1 << (m * 8 + phy_idx), - PHY_INTERFACE_MODE_MII); + struct phy_device *phydev;
+ phydev = phy_find_by_mask(bus, BIT(m * 8 + phy_idx)); printf(" %u", bus_idx * 32 + m * 8 + phy_idx);
if (!phydev) diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index b1e5c5890a..912d28fca2 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -435,11 +435,11 @@ static int tse_phy_init(struct altera_tse_priv *priv, void *dev) if (priv->phyaddr) mask = 1 << priv->phyaddr;
- phydev = phy_find_by_mask(priv->bus, mask, priv->interface); + phydev = phy_find_by_mask(priv->bus, mask); if (!phydev) return -ENODEV;
- phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, priv->interface);
phydev->supported &= PHY_GBIT_FEATURES; phydev->advertising = phydev->supported; diff --git a/drivers/net/ethoc.c b/drivers/net/ethoc.c index 7f146d4c8b..a219affb58 100644 --- a/drivers/net/ethoc.c +++ b/drivers/net/ethoc.c @@ -614,11 +614,11 @@ static int ethoc_phy_init(struct ethoc *priv, void *dev) mask = 1 << CONFIG_PHY_ADDR; #endif
- phydev = phy_find_by_mask(priv->bus, mask, PHY_INTERFACE_MODE_MII); + phydev = phy_find_by_mask(priv->bus, mask); if (!phydev) return -ENODEV;
- phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, PHY_INTERFACE_MODE_MII);
phydev->supported &= PHY_BASIC_FEATURES; phydev->advertising = phydev->supported; diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 318568f256..f781e29f42 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1172,7 +1172,7 @@ static int fec_probe(struct bd_info *bd, int dev_id, uint32_t base_addr, fec_mii_setspeed(bus->priv); #ifdef CONFIG_PHYLIB fec->phydev = phydev; - phy_connect_dev(phydev, edev); + phy_connect_dev(phydev, edev, PHY_INTERFACE_MODE_RGMII); /* Configure phy */ phy_config(phydev); #else @@ -1234,7 +1234,7 @@ int fecmxc_initialize_multi(struct bd_info *bd, int dev_id, int phy_id, if (!bus) return -ENOMEM; #ifdef CONFIG_PHYLIB - phydev = phy_find_by_mask(bus, 1 << phy_id, PHY_INTERFACE_MODE_RGMII); + phydev = phy_find_by_mask(bus, 1 << phy_id); if (!phydev) { mdio_unregister(bus); free(bus); diff --git a/drivers/net/pch_gbe.c b/drivers/net/pch_gbe.c index fabcf85c0d..f1895246b9 100644 --- a/drivers/net/pch_gbe.c +++ b/drivers/net/pch_gbe.c @@ -416,13 +416,13 @@ static int pch_gbe_phy_init(struct udevice *dev) struct phy_device *phydev; int mask = 0xffffffff;
- phydev = phy_find_by_mask(priv->bus, mask, plat->phy_interface); + phydev = phy_find_by_mask(priv->bus, mask); if (!phydev) { printf("pch_gbe: cannot find the phy\n"); return -1; }
- phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, plat->phy_interface);
phydev->supported &= PHY_GBIT_FEATURES; phydev->advertising = phydev->supported; diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 10c724388f..b6fcedc955 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -642,8 +642,7 @@ static struct phy_driver *generic_for_phy(struct phy_device *phydev) return &genphy_driver; }
-static struct phy_driver *get_phy_driver(struct phy_device *phydev, - phy_interface_t interface) +static struct phy_driver *get_phy_driver(struct phy_device *phydev) { struct list_head *entry; int phy_id = phydev->phy_id; @@ -660,8 +659,7 @@ static struct phy_driver *get_phy_driver(struct phy_device *phydev, }
static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, - u32 phy_id, bool is_c45, - phy_interface_t interface) + u32 phy_id, bool is_c45) { struct phy_device *dev;
@@ -680,7 +678,7 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr,
dev->duplex = -1; dev->link = 0; - dev->interface = interface; + dev->interface = PHY_INTERFACE_MODE_NA;
#ifdef CONFIG_DM_ETH dev->node = ofnode_null(); @@ -693,7 +691,7 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, dev->is_c45 = is_c45; dev->bus = bus;
- dev->drv = get_phy_driver(dev, interface); + dev->drv = get_phy_driver(dev);
if (phy_probe(dev)) { printf("%s, PHY probe failed\n", __func__); @@ -742,8 +740,7 @@ int __weak get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id) }
static struct phy_device *create_phy_by_mask(struct mii_dev *bus, - uint phy_mask, int devad, - phy_interface_t interface) + uint phy_mask, int devad) { u32 phy_id = 0xffffffff; bool is_c45; @@ -764,8 +761,7 @@ static struct phy_device *create_phy_by_mask(struct mii_dev *bus, /* If the PHY ID is mostly f's, we didn't find anything */ if (r == 0 && (phy_id & 0x1fffffff) != 0x1fffffff) { is_c45 = (devad == MDIO_DEVAD_NONE) ? false : true; - return phy_device_create(bus, addr, phy_id, is_c45, - interface); + return phy_device_create(bus, addr, phy_id, is_c45); } next: phy_mask &= ~(1 << addr); @@ -774,25 +770,22 @@ next: }
static struct phy_device *search_for_existing_phy(struct mii_dev *bus, - uint phy_mask, - phy_interface_t interface) + uint phy_mask) { /* If we have one, return the existing device, with new interface */ while (phy_mask) { int addr = ffs(phy_mask) - 1;
- if (bus->phymap[addr]) { - bus->phymap[addr]->interface = interface; + if (bus->phymap[addr]) return bus->phymap[addr]; - } + phy_mask &= ~(1 << addr); } return NULL; }
static struct phy_device *get_phy_device_by_mask(struct mii_dev *bus, - uint phy_mask, - phy_interface_t interface) + uint phy_mask) { struct phy_device *phydev; int devad[] = { @@ -808,13 +801,12 @@ static struct phy_device *get_phy_device_by_mask(struct mii_dev *bus, int i, devad_cnt;
devad_cnt = sizeof(devad)/sizeof(int); - phydev = search_for_existing_phy(bus, phy_mask, interface); + phydev = search_for_existing_phy(bus, phy_mask); if (phydev) return phydev; /* try different access clauses */ for (i = 0; i < devad_cnt; i++) { - phydev = create_phy_by_mask(bus, phy_mask, - devad[i], interface); + phydev = create_phy_by_mask(bus, phy_mask, devad[i]); if (IS_ERR(phydev)) return NULL; if (phydev) @@ -842,10 +834,9 @@ static struct phy_device *get_phy_device_by_mask(struct mii_dev *bus, * Description: Reads the ID registers of the PHY at @addr on the * @bus, then allocates and returns the phy_device to represent it. */ -static struct phy_device *get_phy_device(struct mii_dev *bus, int addr, - phy_interface_t interface) +static struct phy_device *get_phy_device(struct mii_dev *bus, int addr) { - return get_phy_device_by_mask(bus, 1 << addr, interface); + return get_phy_device_by_mask(bus, 1 << addr); }
int phy_reset(struct phy_device *phydev) @@ -904,18 +895,12 @@ int miiphy_reset(const char *devname, unsigned char addr) struct mii_dev *bus = miiphy_get_dev_by_name(devname); struct phy_device *phydev;
- /* - * miiphy_reset was only used on standard PHYs, so we'll fake it here. - * If later code tries to connect with the right interface, this will - * be corrected by get_phy_device in phy_connect() - */ - phydev = get_phy_device(bus, addr, PHY_INTERFACE_MODE_MII); + phydev = get_phy_device(bus, addr);
return phy_reset(phydev); }
-struct phy_device *phy_find_by_mask(struct mii_dev *bus, uint phy_mask, - phy_interface_t interface) +struct phy_device *phy_find_by_mask(struct mii_dev *bus, uint phy_mask) { /* Reset the bus */ if (bus->reset) { @@ -925,13 +910,15 @@ struct phy_device *phy_find_by_mask(struct mii_dev *bus, uint phy_mask, mdelay(15); }
- return get_phy_device_by_mask(bus, phy_mask, interface); + return get_phy_device_by_mask(bus, phy_mask); }
#ifdef CONFIG_DM_ETH -void phy_connect_dev(struct phy_device *phydev, struct udevice *dev) +void phy_connect_dev(struct phy_device *phydev, struct udevice *dev, + phy_interface_t interface) #else -void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev) +void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev, + phy_interface_t interface) #endif { /* Soft Reset the PHY */ @@ -942,13 +929,14 @@ void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev) phydev->dev->name, dev->name); } phydev->dev = dev; - debug("%s connected to %s\n", dev->name, phydev->drv->name); + phydev->interface = interface; + debug("%s connected to %s mode %s\n", dev->name, phydev->drv->name, + phy_string_for_interface(interface)); }
#ifdef CONFIG_PHY_XILINX_GMII2RGMII static struct phy_device *phy_connect_gmii2rgmii(struct mii_dev *bus, - struct udevice *dev, - phy_interface_t interface) + struct udevice *dev) { struct phy_device *phydev = NULL; ofnode node; @@ -957,8 +945,7 @@ static struct phy_device *phy_connect_gmii2rgmii(struct mii_dev *bus, node = ofnode_by_compatible(node, "xlnx,gmii-to-rgmii-1.0"); if (ofnode_valid(node)) { phydev = phy_device_create(bus, 0, - PHY_GMII2RGMII_ID, false, - interface); + PHY_GMII2RGMII_ID, false); if (phydev) phydev->node = node; break; @@ -990,24 +977,23 @@ struct phy_device *fixed_phy_create(ofnode node) return NULL; }
- phydev = phy_device_create(NULL, 0, PHY_FIXED_ID, false, - ofnode_read_phy_mode(node)); + phydev = phy_device_create(NULL, 0, PHY_FIXED_ID, false); if (phydev) phydev->node = subnode;
+ phydev->interface = ofnode_read_phy_mode(node); + return phydev; }
static struct phy_device *phy_connect_fixed(struct mii_dev *bus, - struct udevice *dev, - phy_interface_t interface) + struct udevice *dev) { ofnode node = dev_ofnode(dev), subnode; struct phy_device *phydev = NULL;
if (ofnode_phy_is_fixed_link(node, &subnode)) { - phydev = phy_device_create(bus, 0, PHY_FIXED_ID, - false, interface); + phydev = phy_device_create(bus, 0, PHY_FIXED_ID, false); if (phydev) phydev->node = subnode; } @@ -1030,24 +1016,24 @@ struct phy_device *phy_connect(struct mii_dev *bus, int addr, uint mask = (addr >= 0) ? (1 << addr) : 0xffffffff;
#ifdef CONFIG_PHY_FIXED - phydev = phy_connect_fixed(bus, dev, interface); + phydev = phy_connect_fixed(bus, dev); #endif
#ifdef CONFIG_PHY_NCSI if (!phydev) - phydev = phy_device_create(bus, 0, PHY_NCSI_ID, false, interface); + phydev = phy_device_create(bus, 0, PHY_NCSI_ID, false); #endif
#ifdef CONFIG_PHY_XILINX_GMII2RGMII if (!phydev) - phydev = phy_connect_gmii2rgmii(bus, dev, interface); + phydev = phy_connect_gmii2rgmii(bus, dev); #endif
if (!phydev) - phydev = phy_find_by_mask(bus, mask, interface); + phydev = phy_find_by_mask(bus, mask);
if (phydev) - phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, interface); else printf("Could not get PHY for %s: addr %d\n", bus->name, addr); return phydev; diff --git a/drivers/net/phy/xilinx_gmii2rgmii.c b/drivers/net/phy/xilinx_gmii2rgmii.c index d92a364365..7376283956 100644 --- a/drivers/net/phy/xilinx_gmii2rgmii.c +++ b/drivers/net/phy/xilinx_gmii2rgmii.c @@ -42,13 +42,13 @@ static int xilinxgmiitorgmii_config(struct phy_device *phydev)
ext_phyaddr = ofnode_read_u32_default(phandle.node, "reg", -1); ext_phydev = phy_find_by_mask(phydev->bus, - 1 << ext_phyaddr, - PHY_INTERFACE_MODE_RGMII); + 1 << ext_phyaddr); if (!ext_phydev) { printf("%s, No external phy device found\n", __func__); return -EINVAL; }
+ ext_phydev->interface = PHY_INTERFACE_MODE_RGMII; ext_phydev->node = phandle.node; phydev->priv = ext_phydev;
diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 5c152d6e0a..c28680565f 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -319,11 +319,11 @@ static int ravb_phy_config(struct udevice *dev) mdelay(1); }
- phydev = phy_find_by_mask(eth->bus, mask, pdata->phy_interface); + phydev = phy_find_by_mask(eth->bus, mask); if (!phydev) return -ENODEV;
- phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, pdata->phy_interface);
eth->phydev = phydev;
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 5c57e3dfcd..1de3ff8add 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -762,11 +762,11 @@ static int sh_eth_phy_config(struct udevice *dev) struct phy_device *phydev; int mask = 0xffffffff;
- phydev = phy_find_by_mask(priv->bus, mask, pdata->phy_interface); + phydev = phy_find_by_mask(priv->bus, mask); if (!phydev) return -ENODEV;
port_info->phydev = phydev; phy_config(phydev); diff --git a/drivers/net/sni_ave.c b/drivers/net/sni_ave.c index d684e60e72..58276a40c7 100644 --- a/drivers/net/sni_ave.c +++ b/drivers/net/sni_ave.c @@ -393,11 +393,11 @@ static int ave_phy_init(struct ave_private *priv, void *dev) struct phy_device *phydev; int mask = GENMASK(31, 0), ret;
- phydev = phy_find_by_mask(priv->bus, mask, priv->phy_mode); + phydev = phy_find_by_mask(priv->bus, mask); if (!phydev) return -ENODEV;
- phy_connect_dev(phydev, dev); + phy_connect_dev(phydev, dev, priv->phy_mode);
phydev->supported &= PHY_GBIT_FEATURES; if (priv->max_speed) { diff --git a/drivers/net/sunxi_emac.c b/drivers/net/sunxi_emac.c index 17ad88e732..4c7ef2525b 100644 --- a/drivers/net/sunxi_emac.c +++ b/drivers/net/sunxi_emac.c @@ -272,12 +272,11 @@ static int sunxi_emac_init_phy(struct emac_eth_dev *priv, void *dev) if (ret) return ret;
- priv->phydev = phy_find_by_mask(priv->bus, mask, - PHY_INTERFACE_MODE_MII); + priv->phydev = phy_find_by_mask(priv->bus, mask); if (!priv->phydev) return -ENODEV;
- phy_connect_dev(priv->phydev, dev); + phy_connect_dev(priv->phydev, dev, PHY_INTERFACE_MODE_MII); phy_config(priv->phydev);
return 0; diff --git a/include/_exports.h b/include/_exports.h index 8030d70c0b..f6df8b6107 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -77,8 +77,7 @@ EXPORT_FUNC(mdio_get_current_dev, struct mii_dev *, mdio_get_current_dev, void) EXPORT_FUNC(phy_find_by_mask, struct phy_device *, phy_find_by_mask, - struct mii_dev *bus, unsigned phy_mask, - phy_interface_t interface) + struct mii_dev *bus, unsigned phy_mask) EXPORT_FUNC(mdio_phydev_for_ethname, struct phy_device *, mdio_phydev_for_ethname, const char *ethname) EXPORT_FUNC(miiphy_set_current_dev, int, miiphy_set_current_dev, diff --git a/include/exports.h b/include/exports.h index 550cafdc7a..6f8c9cf451 100644 --- a/include/exports.h +++ b/include/exports.h @@ -55,8 +55,7 @@ int i2c_read (uchar, uint, int , uchar* , int); #endif #ifdef CONFIG_PHY_AQUANTIA struct mii_dev *mdio_get_current_dev(void); -struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask, - phy_interface_t interface); +struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask); struct phy_device *mdio_phydev_for_ethname(const char *ethname); int miiphy_set_current_dev(const char *devname); #endif diff --git a/include/phy.h b/include/phy.h index 9742ce6fe1..9473e5b694 100644 --- a/include/phy.h +++ b/include/phy.h @@ -388,11 +388,9 @@ int phy_reset(struct phy_device *phydev); * * @bus: MII/MDIO bus to scan * @phy_mask: bitmap of PYH addresses to scan - * @interface: type of MAC-PHY interface * @return: pointer to phy_device if a PHY is found, or NULL otherwise */ -struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask, - phy_interface_t interface); +struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask);
@@ -421,8 +419,10 @@ static inline struct phy_device *fixed_phy_create(ofnode node) * phy_connect_dev() - Associates the given pair of PHY and Ethernet devices * @phydev: PHY device * @dev: Ethernet device + * @interface: type of MAC-PHY interface */ -void phy_connect_dev(struct phy_device *phydev, struct udevice *dev); +void phy_connect_dev(struct phy_device *phydev, struct udevice *dev, + phy_interface_t interface);
/** * phy_connect() - Creates a PHY device for the Ethernet interface @@ -456,8 +456,10 @@ static inline ofnode phy_get_ofnode(struct phy_device *phydev) * phy_connect_dev() - Associates the given pair of PHY and Ethernet devices * @phydev: PHY device * @dev: Ethernet device + * @interface: type of MAC-PHY interface */ -void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev); +void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev, + phy_interface_t interface);
- phy_device_create()
- create_phy_by_mask()
- search_for_existing_phy()
- get_phy_device_by_mask()
- phy_find_by_mask() (this is the only one global)
if (phydev)
if (phydev) {
phydev->interface = PHY_INTERFACE_MODE_MII; phy_config(phydev); /* enable QSGMII autonegotiation with flow control */
phydev = phy_find_by_mask(bus, BIT(m * 8 + phy_idx)); printf(" %u", bus_idx * 32 + m * 8 + phy_idx); if (!phydev)
phy_connect_dev(phydev, dev, priv->interface); phydev->supported &= PHY_GBIT_FEATURES; phydev->advertising = phydev->supported;
phy_connect_dev(phydev, dev, PHY_INTERFACE_MODE_MII); phydev->supported &= PHY_BASIC_FEATURES; phydev->advertising = phydev->supported;
phy_connect_dev(phydev, dev, plat->phy_interface); phydev->supported &= PHY_GBIT_FEATURES; phydev->advertising = phydev->supported;
dev->drv = get_phy_driver(dev); if (phy_probe(dev)) { printf("%s, PHY probe failed\n", __func__);
interface);
uint phy_mask,
uint phy_mask)
uint phy_mask,
uint phy_mask)
- Description: Reads the ID registers of the PHY at @addr on the
- @bus, then allocates and returns the phy_device to represent it.
phydev = get_phy_device(bus, addr); return phy_reset(phydev);
interface);
return phydev;
false, interface);
#endif
#endif
#endif
if (!phydev)
phydev = phy_find_by_mask(bus, mask); if (phydev)
1 << ext_phyaddr,
phy_connect_dev(phydev, dev, pdata->phy_interface); eth->phydev = phydev;
phy_connect_dev(phydev, dev, pdata->phy_interface); port_info->phydev = phydev; phy_config(phydev);
phy_connect_dev(phydev, dev, priv->phy_mode); phydev->supported &= PHY_GBIT_FEATURES; if (priv->max_speed) {
phy_connect_dev(priv->phydev, dev, PHY_INTERFACE_MODE_MII); phy_config(priv->phydev); return 0;
- @bus: MII/MDIO bus to scan
- @phy_mask: bitmap of PYH addresses to scan
- @interface: type of MAC-PHY interface
- @return: pointer to phy_device if a PHY is found, or NULL otherwise
- phy_connect_dev() - Associates the given pair of PHY and Ethernet devices
- @phydev: PHY device
- @dev: Ethernet device
- phy_connect() - Creates a PHY device for the Ethernet interface
-- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
So I wanted to solve a problem regarding MDIO bus within mvneta driver, to make it use the mvmdio DM driver instead of the non-DM MDIO bus registered during mvneta probe, and improve some other things there, and it seems like I opened a small bag from hell, which resulted in this series of refactors, fixes and cleanups in the network subsystem.
The series applies on Tom's master branch. It won't apply to u-boot-next's master nor net, those are too old.
This series was CI tested (https://github.com/u-boot/u-boot/pull/142).
Marek Behún (14): net: mdio-uclass: fix type for phy_mode_str and phy_handle_str net: mdio-uclass: use ARRAY_SIZE() net: introduce helpers to get PHY ofnode from MAC net: mdio-uclass: add wrappers for read/write/reset operations treewide: use dm_mdio_read/write/reset() wrappers net: phy: fix parsing wrong property net: introduce helpers to get PHY interface mode from a device/ofnode treewide: Rename PHY_INTERFACE_MODE_COUNT to PHY_INTERFACE_MODE_MAX treewide: Rename PHY_INTERFACE_MODE_NONE to PHY_INTERFACE_MODE_NA phy: Move PHY_INTERFACE_MODE_NA to the beginning of the enum definition net: phy: xilinx: Check interface type in ->config(), not ->probe() net: phy: use ->is_c45 instead of is_10g_interface() bcmgenet, sun8i_emac: Don't connect PHY two times net: phy: don't require PHY interface mode during PHY creation
board/CZ.NIC/turris_mox/turris_mox.c | 2 +- board/boundary/nitrogen6x/nitrogen6x.c | 2 +- board/freescale/corenet_ds/eth_hydra.c | 2 +- board/freescale/corenet_ds/eth_superhydra.c | 4 +- board/freescale/t104xrdb/eth.c | 4 +- board/gdsys/a38x/controlcenterdc.c | 7 +- board/gdsys/a38x/ihs_phys.c | 6 +- board/st/stm32f746-disco/stm32f746-disco.c | 13 +-- drivers/core/ofnode.c | 44 ++++++++ drivers/core/read.c | 10 ++ drivers/net/ag7xxx.c | 9 +- drivers/net/altera_tse.c | 17 +-- drivers/net/bcm6348-eth.c | 8 +- drivers/net/bcmgenet.c | 12 +- drivers/net/designware.c | 10 +- drivers/net/dwc_eth_qos.c | 40 +------ drivers/net/ethoc.c | 4 +- drivers/net/fec_mxc.c | 15 +-- drivers/net/fm/b4860.c | 8 +- drivers/net/fm/eth.c | 13 +-- drivers/net/fm/init.c | 8 +- drivers/net/fm/ls1043.c | 6 +- drivers/net/fm/ls1046.c | 8 +- drivers/net/fm/p1023.c | 4 +- drivers/net/fm/p4080.c | 6 +- drivers/net/fm/p5020.c | 6 +- drivers/net/fm/p5040.c | 6 +- drivers/net/fm/t1024.c | 4 +- drivers/net/fm/t1040.c | 4 +- drivers/net/fm/t2080.c | 6 +- drivers/net/fm/t4240.c | 6 +- drivers/net/fsl_enetc.c | 13 +-- drivers/net/ftgmac100.c | 11 +- drivers/net/higmacv300.c | 9 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 28 +---- drivers/net/ldpaa_eth/ldpaa_wriop.c | 10 +- drivers/net/ldpaa_eth/ls1088a.c | 4 +- drivers/net/ldpaa_eth/ls2080a.c | 4 +- drivers/net/ldpaa_eth/lx2160a.c | 4 +- drivers/net/macb.c | 10 +- drivers/net/mdio_mux_sandbox.c | 6 +- drivers/net/mscc_eswitch/jr2_switch.c | 2 +- drivers/net/mscc_eswitch/luton_switch.c | 2 +- drivers/net/mscc_eswitch/ocelot_switch.c | 2 +- drivers/net/mscc_eswitch/serval_switch.c | 2 +- drivers/net/mscc_eswitch/servalt_switch.c | 2 +- drivers/net/mt7620-eth.c | 45 +++----- drivers/net/mtk_eth.c | 8 +- drivers/net/mvgbe.c | 7 +- drivers/net/mvneta.c | 11 +- drivers/net/mvpp2.c | 9 +- drivers/net/pch_gbe.c | 4 +- drivers/net/phy/aquantia.c | 2 +- drivers/net/phy/phy.c | 115 +++++++------------- drivers/net/phy/xilinx_gmii2rgmii.c | 14 +-- drivers/net/pic32_eth.c | 11 +- drivers/net/qe/dm_qe_uec.c | 11 +- drivers/net/ravb.c | 19 +--- drivers/net/sh_eth.c | 19 +--- drivers/net/sni_ave.c | 16 +-- drivers/net/sni_netsec.c | 10 +- drivers/net/sun8i_emac.c | 13 +-- drivers/net/sunxi_emac.c | 5 +- drivers/net/ti/am65-cpsw-nuss.c | 15 +-- drivers/net/ti/cpsw.c | 10 +- drivers/net/ti/keystone_net.c | 24 ++-- drivers/net/tsec.c | 9 +- drivers/net/xilinx_axi_emac.c | 10 +- drivers/net/zynq_gem.c | 9 +- include/_exports.h | 3 +- include/dm/ofnode.h | 27 +++++ include/dm/read.h | 36 ++++++ include/exports.h | 3 +- include/fm_eth.h | 2 +- include/miiphy.h | 31 ++++++ include/phy.h | 32 ++---- include/phy_interface.h | 11 +- include/vsc9953.h | 2 +- net/mdio-mux-uclass.c | 16 +-- net/mdio-uclass.c | 96 ++++++++-------- test/dm/mdio.c | 18 +-- test/dm/mdio_mux.c | 16 +-- 82 files changed, 469 insertions(+), 623 deletions(-)
-- 2.34.1
Awesome. Thanks !
Marek Behún
Ramon Fried
Stefan Roese
