[U-Boot] [PATCH v2 1/2] mmc: sdhci: remove the unused argument for sdhci_setup_cfg
buswidth isn't used anywhere in sdhci_setup_cfg.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Minkyu Kang mk7.kang@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for V2: - None
drivers/mmc/msm_sdhci.c | 4 ++-- drivers/mmc/sdhci.c | 4 ++-- drivers/mmc/zynq_sdhci.c | 2 +- include/sdhci.h | 3 +-- 4 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index 70a8d96..e90a044 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -144,8 +144,8 @@ static int msm_sdc_probe(struct udevice *dev) host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
caps = sdhci_readl(host, SDHCI_CAPABILITIES); - ret = sdhci_setup_cfg(&plat->cfg, dev->name, host->bus_width, - caps, 0, 0, host->version, host->quirks, 0); + ret = sdhci_setup_cfg(&plat->cfg, dev->name, caps, + 0, 0, host->version, host->quirks, 0); host->mmc = &plat->mmc; if (ret) return ret; diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 4112223..c275314 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -511,7 +511,7 @@ static const struct mmc_ops sdhci_ops = { }; #endif
-int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth, +int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, uint caps, u32 max_clk, u32 min_clk, uint version, uint quirks, uint host_caps) { @@ -582,7 +582,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) } #endif
- if (sdhci_setup_cfg(&host->cfg, host->name, host->bus_width, caps, + if (sdhci_setup_cfg(&host->cfg, host->name, caps, max_clk, min_clk, SDHCI_GET_VERSION(host), host->quirks, host->host_caps)) { printf("%s: Hardware doesn't specify base clock frequency\n", diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index bcd154a..69d6151 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -40,7 +40,7 @@ static int arasan_sdhci_probe(struct udevice *dev) host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
caps = sdhci_readl(host, SDHCI_CAPABILITIES); - ret = sdhci_setup_cfg(&plat->cfg, dev->name, host->bus_width, + ret = sdhci_setup_cfg(&plat->cfg, dev->name, caps, CONFIG_ZYNQ_SDHCI_MAX_FREQ, CONFIG_ZYNQ_SDHCI_MIN_FREQ, host->version, host->quirks, 0); diff --git a/include/sdhci.h b/include/sdhci.h index c4d3b55..693ecc1 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -368,7 +368,6 @@ static inline u8 sdhci_readb(struct sdhci_host *host, int reg) * * @cfg: Configuration structure to fill in (generally &plat->mmc) * @name: Device name (normally dev->name) - * @buswidth: Bus width (in bits, such as 4 or 8) * @caps: Host capabilities (MMC_MODE_...) * @max_clk: Maximum supported clock speed in HZ (0 for default) * @min_clk: Minimum supported clock speed in HZ (0 for default) @@ -377,7 +376,7 @@ static inline u8 sdhci_readb(struct sdhci_host *host, int reg) * @quirks: Quick flags (SDHCI_QUIRK_...) * @host_caps: Additional host capabilities (0 if none) */ -int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth, +int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, uint caps, u32 max_clk, u32 min_clk, uint version, uint quirks, uint host_caps);
Some arguments don't need to pass to sdhci_setup_cfg. Generic variable can be used in sdhci_setup_cfg, and some arguments are already included in sdhci_host struct.
It's enough that just pass the board specific things to sdhci_setup_cfg(). After removing the unnecessary arguments, it's more simpler than before. It doesn't consider "Version" and "Capabilities" anymore in each SoC driver.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for V2: - Add the rockchip_sdhci host controller. - Fix typo.
drivers/mmc/msm_sdhci.c | 4 +--- drivers/mmc/rockchip_sdhci.c | 8 ++------ drivers/mmc/sdhci.c | 26 ++++++++++++++------------ drivers/mmc/zynq_sdhci.c | 6 ++---- include/sdhci.h | 12 +++--------- 5 files changed, 22 insertions(+), 34 deletions(-)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index e90a044..a8cb9e2 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -143,9 +143,7 @@ static int msm_sdc_probe(struct udevice *dev) /* Set host controller version */ host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
- caps = sdhci_readl(host, SDHCI_CAPABILITIES); - ret = sdhci_setup_cfg(&plat->cfg, dev->name, caps, - 0, 0, host->version, host->quirks, 0); + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0); host->mmc = &plat->mmc; if (ret) return ret; diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 023c29b..624029b 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -33,15 +33,11 @@ static int arasan_sdhci_probe(struct udevice *dev) struct rockchip_sdhc *prv = dev_get_priv(dev); struct sdhci_host *host = &prv->host; int ret; - u32 caps;
- host->version = sdhci_readw(host, SDHCI_HOST_VERSION); host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD;
- caps = sdhci_readl(host, SDHCI_CAPABILITIES); - ret = sdhci_setup_cfg(&plat->cfg, dev->name, host->bus_width, - caps, CONFIG_ROCKCHIP_SDHCI_MAX_FREQ, EMMC_MIN_FREQ, - host->version, host->quirks, 0); + ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ROCKCHIP_SDHCI_MAX_FREQ, + EMMC_MIN_FREQ);
host->mmc = &plat->mmc; if (ret) diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index c275314..60108fd 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -511,18 +511,22 @@ static const struct mmc_ops sdhci_ops = { }; #endif
-int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, - uint caps, u32 max_clk, u32 min_clk, uint version, - uint quirks, uint host_caps) +int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, + u32 max_clk, u32 min_clk) { - cfg->name = name; + u32 caps; + + caps = sdhci_readl(host, SDHCI_CAPABILITIES); + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + cfg->name = host->name; #ifndef CONFIG_DM_MMC_OPS cfg->ops = &sdhci_ops; #endif if (max_clk) cfg->f_max = max_clk; else { - if (version >= SDHCI_SPEC_300) + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) cfg->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; else @@ -535,7 +539,7 @@ int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, if (min_clk) cfg->f_min = min_clk; else { - if (version >= SDHCI_SPEC_300) + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) cfg->f_min = cfg->f_max / SDHCI_MAX_DIV_SPEC_300; else cfg->f_min = cfg->f_max / SDHCI_MAX_DIV_SPEC_200; @@ -549,13 +553,13 @@ int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, cfg->voltages |= MMC_VDD_165_195;
cfg->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; - if (version >= SDHCI_SPEC_300) { + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { if (caps & SDHCI_CAN_DO_8BIT) cfg->host_caps |= MMC_MODE_8BIT; }
- if (host_caps) - cfg->host_caps |= host_caps; + if (host->host_caps) + cfg->host_caps |= host->host_caps;
cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; @@ -582,9 +586,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) } #endif
- if (sdhci_setup_cfg(&host->cfg, host->name, caps, - max_clk, min_clk, SDHCI_GET_VERSION(host), - host->quirks, host->host_caps)) { + if (sdhci_setup_cfg(&host->cfg, host, max_clk, min_clk)) { printf("%s: Hardware doesn't specify base clock frequency\n", __func__); return -EINVAL; diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 69d6151..bf54219 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -40,10 +40,8 @@ static int arasan_sdhci_probe(struct udevice *dev) host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
caps = sdhci_readl(host, SDHCI_CAPABILITIES); - ret = sdhci_setup_cfg(&plat->cfg, dev->name, - caps, CONFIG_ZYNQ_SDHCI_MAX_FREQ, - CONFIG_ZYNQ_SDHCI_MIN_FREQ, host->version, - host->quirks, 0); + ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, + CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret) return ret; diff --git a/include/sdhci.h b/include/sdhci.h index 693ecc1..fcef4dc 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -367,18 +367,12 @@ static inline u8 sdhci_readb(struct sdhci_host *host, int reg) * See msm_sdhci.c for an example. * * @cfg: Configuration structure to fill in (generally &plat->mmc) - * @name: Device name (normally dev->name) - * @caps: Host capabilities (MMC_MODE_...) + * @host: SDHCI host structure * @max_clk: Maximum supported clock speed in HZ (0 for default) * @min_clk: Minimum supported clock speed in HZ (0 for default) - * @version: Host controller version (generally read from the - * SDHCI_HOST_VERSION register) - * @quirks: Quick flags (SDHCI_QUIRK_...) - * @host_caps: Additional host capabilities (0 if none) */ -int sdhci_setup_cfg(struct mmc_config *cfg, const char *name, - uint caps, u32 max_clk, u32 min_clk, uint version, - uint quirks, uint host_caps); +int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, + u32 max_clk, u32 min_clk);
/** * sdhci_bind() - Set up a new MMC block device
Jaehoon Chung
