[U-Boot] [PATCH] ARM: meson: display Amlogic SoC Information
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family.
This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing.
Signed-off-by: Julien Masson jmasson@baylibre.com --- arch/arm/mach-meson/board-common.c | 140 +++++++++++++++++++++++++++++++++++++ configs/khadas-vim_defconfig | 2 +- configs/libretech-cc_defconfig | 2 +- configs/odroid-c2_defconfig | 2 +- configs/p212_defconfig | 2 +- 5 files changed, 144 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-meson/board-common.c b/arch/arm/mach-meson/board-common.c index 8c41301..e766ebc 100644 --- a/arch/arm/mach-meson/board-common.c +++ b/arch/arm/mach-meson/board-common.c @@ -7,11 +7,59 @@ #include <asm/arch/boot.h> #include <linux/libfdt.h> #include <linux/err.h> +#include <linux/bitfield.h> #include <asm/arch/mem.h> #include <asm/arch/sm.h> #include <asm/armv8/mmu.h> +#include <asm/io.h> #include <asm/unaligned.h> #include <efi_loader.h> +#include <dm.h> +#include <syscon.h> +#include <regmap.h> + +#define AO_SEC_SD_CFG8 0xe0 +#define AO_SEC_SOCINFO_OFFSET AO_SEC_SD_CFG8 + +#define SOCINFO_MAJOR GENMASK(31, 24) +#define SOCINFO_PACK GENMASK(23, 16) +#define SOCINFO_MINOR GENMASK(15, 8) +#define SOCINFO_MISC GENMASK(7, 0) + +static const struct meson_gx_soc_id { + const char *name; + unsigned int id; +} soc_ids[] = { + { "GXBB", 0x1f }, + { "GXTVBB", 0x20 }, + { "GXL", 0x21 }, + { "GXM", 0x22 }, + { "TXL", 0x23 }, + { "TXLX", 0x24 }, + { "AXG", 0x25 }, + { "GXLX", 0x26 }, + { "TXHD", 0x27 }, +}; + +static const struct meson_gx_package_id { + const char *name; + unsigned int major_id; + unsigned int pack_id; +} soc_packages[] = { + { "S905", 0x1f, 0 }, + { "S905H", 0x1f, 0x13 }, + { "S905M", 0x1f, 0x20 }, + { "S905D", 0x21, 0 }, + { "S905X", 0x21, 0x80 }, + { "S905W", 0x21, 0xa0 }, + { "S905L", 0x21, 0xc0 }, + { "S905M2", 0x21, 0xe0 }, + { "S912", 0x22, 0 }, + { "962X", 0x24, 0x10 }, + { "962E", 0x24, 0x20 }, + { "A113X", 0x25, 0x37 }, + { "A113D", 0x25, 0x22 }, +};
DECLARE_GLOBAL_DATA_PTR;
@@ -115,3 +163,95 @@ void reset_cpu(ulong addr) { psci_system_reset(); } + +static inline unsigned int socinfo_to_major(u32 socinfo) +{ + return FIELD_GET(SOCINFO_MAJOR, socinfo); +} + +static inline unsigned int socinfo_to_minor(u32 socinfo) +{ + return FIELD_GET(SOCINFO_MINOR, socinfo); +} + +static inline unsigned int socinfo_to_pack(u32 socinfo) +{ + return FIELD_GET(SOCINFO_PACK, socinfo); +} + +static inline unsigned int socinfo_to_misc(u32 socinfo) +{ + return FIELD_GET(SOCINFO_MISC, socinfo); +} + +static const char *socinfo_to_package_id(u32 socinfo) +{ + unsigned int pack = socinfo_to_pack(socinfo) & 0xf0; + unsigned int major = socinfo_to_major(socinfo); + int i; + + for (i = 0 ; i < ARRAY_SIZE(soc_packages) ; ++i) { + if (soc_packages[i].major_id == major && + soc_packages[i].pack_id == pack) + return soc_packages[i].name; + } + + return "Unknown"; +} + +static const char *socinfo_to_soc_id(u32 socinfo) +{ + unsigned int id = socinfo_to_major(socinfo); + int i; + + for (i = 0 ; i < ARRAY_SIZE(soc_ids) ; ++i) { + if (soc_ids[i].id == id) + return soc_ids[i].name; + } + + return "Unknown"; +} + +int show_board_info(void) +{ + struct regmap *regmap; + int nodeoffset, ret; + ofnode node; + unsigned int socinfo; + + /* find the offset of compatible node */ + nodeoffset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, + "amlogic,meson-gx-ao-secure"); + if (nodeoffset < 0) + return 0; + + /* check if chip-id is available */ + if (!fdt_getprop(gd->fdt_blob, nodeoffset, "amlogic,has-chip-id", NULL)) + return 0; + + /* get regmap from the syscon node */ + node = offset_to_ofnode(nodeoffset); + regmap = syscon_node_to_regmap(node); + if (IS_ERR(regmap)) { + printf("%s: failed to get regmap\n", __func__); + return 0; + } + + /* read soc info */ + ret = regmap_read(regmap, AO_SEC_SOCINFO_OFFSET, &socinfo); + if (ret && !socinfo) { + printf("%s: invalid chipid value\n", __func__); + return 0; + } + + /* print board information */ + printf("Amlogic Meson %s (%s) Revision %x:%x (%x:%x)\n", + socinfo_to_soc_id(socinfo), + socinfo_to_package_id(socinfo), + socinfo_to_major(socinfo), + socinfo_to_minor(socinfo), + socinfo_to_pack(socinfo), + socinfo_to_misc(socinfo)); + + return 0; +} diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index 6f1ad0e..aeec2be 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -11,7 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_ADC=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index d28c7ab..a1b9fd9 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -10,7 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_OF_BOARD_SETUP=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_ADC=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 747da18..04904c2 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -10,7 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_GPIO=y diff --git a/configs/p212_defconfig b/configs/p212_defconfig index b048863..0422740 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -11,7 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_GPIO=y
Hi Julien,
First, please also CC to u-boot-amlogic@groups.io !
Please add to all the Amlogic boards, including nanopi-k2, khadas-vim2 and s400
- const char *name;
- unsigned int id;
+} soc_ids[] = {
- { "GXBB", 0x1f },
- { "GXTVBB", 0x20 },
- { "GXL", 0x21 },
- { "GXM", 0x22 },
- { "TXL", 0x23 },
- { "TXLX", 0x24 },
- { "AXG", 0x25 },
- { "GXLX", 0x26 },
- { "TXHD", 0x27 },
- const char *name;
- unsigned int major_id;
- unsigned int pack_id;
- { "S905", 0x1f, 0 },
- { "S905H", 0x1f, 0x13 },
- { "S905M", 0x1f, 0x20 },
- { "S905D", 0x21, 0 },
- { "S905X", 0x21, 0x80 },
- { "S905W", 0x21, 0xa0 },
- { "S905L", 0x21, 0xc0 },
- { "S905M2", 0x21, 0xe0 },
- { "S912", 0x22, 0 },
- { "962X", 0x24, 0x10 },
- { "962E", 0x24, 0x20 },
- { "A113X", 0x25, 0x37 },
- { "A113D", 0x25, 0x22 },
Can you handle the mask into this struct aswell like https://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic.git/co... ?
You should also add the new IDs like in : https://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic.git/co...
- return FIELD_GET(SOCINFO_MAJOR, socinfo);
- return FIELD_GET(SOCINFO_MINOR, socinfo);
- return FIELD_GET(SOCINFO_PACK, socinfo);
- return FIELD_GET(SOCINFO_MISC, socinfo);
- unsigned int pack = socinfo_to_pack(socinfo) & 0xf0;
- unsigned int major = socinfo_to_major(socinfo);
- int i;
- for (i = 0 ; i < ARRAY_SIZE(soc_packages) ; ++i) {
- return "Unknown";
- unsigned int id = socinfo_to_major(socinfo);
- int i;
- for (i = 0 ; i < ARRAY_SIZE(soc_ids) ; ++i) {
- return "Unknown";
- struct regmap *regmap;
- int nodeoffset, ret;
- ofnode node;
- unsigned int socinfo;
- /* find the offset of compatible node */
- nodeoffset = fdt_node_offset_by_compatible(gd->fdt_blob, -1,
- if (nodeoffset < 0)
- /* check if chip-id is available */
- if (!fdt_getprop(gd->fdt_blob, nodeoffset, "amlogic,has-chip-id", NULL))
- /* get regmap from the syscon node */
- node = offset_to_ofnode(nodeoffset);
- regmap = syscon_node_to_regmap(node);
- if (IS_ERR(regmap)) {
- /* read soc info */
- ret = regmap_read(regmap, AO_SEC_SOCINFO_OFFSET, &socinfo);
- if (ret && !socinfo) {
- /* print board information */
- printf("Amlogic Meson %s (%s) Revision %x:%x (%x:%x)\n",
Can you also show the board model from DT like the original show_board_info() ?
Looks good, but can you move this code to a separate C file, like board-info.c ?
Thanks !!
Neil
Julien Masson
Neil Armstrong
