[U-Boot] [PATCH 3/4] imx6: spl: Reduce SPL limit size in case CONFIG_SECURE_BOOT is enabled
In case CONFIG_SECURE_BOOT is enabled we need to limit the SPL size to avoid a possible HAB failure event: --------- HAB Event 1 ----------------- event data: 0xdb 0x00 0x14 0x42 0x33 0x22 0x33 0x00 0x00 0x00 0x00 0x0f 0x00 0x90 0x70 0x00 0x00 0x01 0x10 0x00 STS = HAB_FAILURE (0x33) RSN = HAB_INV_ADDRESS (0x22) CTX = HAB_CTX_TARGET (0x33) ENG = HAB_ENG_ANY (0x00) As explained in Commit 23612534fe0f ("spl: imx6: Provide a SPL_SIZE_LIMIT default") the i.MX6 SPL size limit is 68KB. The ROM code is copying the image size defined in boot data to its respective load address, in case we exceed the OCRAM free region a HAB invalid address failure event is generated. The maximum CSF size is defined in CONFIG_CSF_SIZE, reduce SPL size limit based on this configuration. Signed-off-by: Breno Lima breno.lima@nxp.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
sbabic@denx.de
