[PATCH v2] atmel_sdhci: Force card-detect if MMC_CAP_NONREMOVABLE.
If the device attached to the MMC bus is not removable, set force card-detect bit to bypass card detection procedure, so card detection pin can be used for other purposes.
It's also a workaround for SAMA5D2 who doesn't drive CMD if using GPIO for card detection.
Signed-off-by: Zixun LI zli@ogga.fr --- drivers/mmc/atmel_sdhci.c | 40 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 37b0beeed4..ae56266f57 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -15,6 +15,9 @@ #define ATMEL_SDHC_MIN_FREQ 400000 #define ATMEL_SDHC_GCK_RATE 240000000
+#define ATMEL_SDHC_MC1R 0x204 +#define ATMEL_SDHC_MC1R_FCD 0x80 + #ifndef CONFIG_DM_MMC int atmel_sdhci_init(void *regbase, u32 id) { @@ -52,11 +55,38 @@ struct atmel_sdhci_plat { struct mmc mmc; };
+static void atmel_sdhci_config_fcd(struct sdhci_host *host) +{ + u8 mc1r; + + /* If nonremovable, assume that the card is always present. + * + * WA: SAMA5D2 doesn't drive CMD if using CD GPIO line. + */ + if ((host->mmc->cfg->host_caps & MMC_CAP_NONREMOVABLE) +#if CONFIG_IS_ENABLED(DM_GPIO) + || dm_gpio_get_value(&host->cd_gpio) >= 0 +#endif + ) + { + sdhci_readb(host, ATMEL_SDHC_MC1R); + mc1r |= ATMEL_SDHC_MC1R_FCD; + sdhci_writeb(host, mc1r, ATMEL_SDHC_MC1R); + } +} + static int atmel_sdhci_deferred_probe(struct sdhci_host *host) { struct udevice *dev = host->mmc->dev; + int ret;
- return sdhci_probe(dev); + ret = sdhci_probe(dev); + if (ret) + return ret; + + atmel_sdhci_config_fcd(host); + + return 0; }
static const struct sdhci_ops atmel_sdhci_ops = { @@ -120,7 +150,13 @@ static int atmel_sdhci_probe(struct udevice *dev)
clk_free(&clk);
static int atmel_sdhci_bind(struct udevice *dev)
Applied to u-boot-at91/master, thanks !
Reviewed-by: Eugen Hristev eugen.hristev@collabora.com
Eugen Hristev
Zixun LI
