[U-Boot] [PATCH] mtd: nand: Remove jz4740 driver
This driver is not used by anyone, remove it.
Signed-off-by: Marek Vasut marex@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Paul Burton paul.burton@imgtec.com Cc: Scott Wood oss@buserror.net --- drivers/mtd/nand/Makefile | 1 - drivers/mtd/nand/jz4740_nand.c | 258 ----------------------------------------- 2 files changed, 259 deletions(-) delete mode 100644 drivers/mtd/nand/jz4740_nand.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 6fb3718..aea6a93 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -50,7 +50,6 @@ obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o obj-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o obj-$(CONFIG_NAND_FSMC) += fsmc_nand.o -obj-$(CONFIG_NAND_JZ4740) += jz4740_nand.o obj-$(CONFIG_NAND_KB9202) += kb9202_nand.o obj-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o obj-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o diff --git a/drivers/mtd/nand/jz4740_nand.c b/drivers/mtd/nand/jz4740_nand.c deleted file mode 100644 index abcedc2..0000000 --- a/drivers/mtd/nand/jz4740_nand.c +++ /dev/null @@ -1,258 +0,0 @@ -/* - * Platform independend driver for JZ4740. - * - * Copyright (c) 2007 Ingenic Semiconductor Inc. - * Author: jlwei@ingenic.cn - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#include <common.h> - -#include <nand.h> -#include <asm/io.h> -#include <asm/jz4740.h> - -#define JZ_NAND_DATA_ADDR ((void __iomem *)0xB8000000) -#define JZ_NAND_CMD_ADDR (JZ_NAND_DATA_ADDR + 0x8000) -#define JZ_NAND_ADDR_ADDR (JZ_NAND_DATA_ADDR + 0x10000) - -#define JZ_NAND_ECC_CTRL_ENCODING BIT(3) -#define JZ_NAND_ECC_CTRL_RS BIT(2) -#define JZ_NAND_ECC_CTRL_RESET BIT(1) -#define JZ_NAND_ECC_CTRL_ENABLE BIT(0) - -#define EMC_SMCR1_OPT_NAND 0x094c4400 -/* Optimize the timing of nand */ - -static struct jz4740_emc * emc = (struct jz4740_emc *)JZ4740_EMC_BASE; - -static struct nand_ecclayout qi_lb60_ecclayout_2gb = { - .eccbytes = 72, - .eccpos = { - 12, 13, 14, 15, 16, 17, 18, 19, - 20, 21, 22, 23, 24, 25, 26, 27, - 28, 29, 30, 31, 32, 33, 34, 35, - 36, 37, 38, 39, 40, 41, 42, 43, - 44, 45, 46, 47, 48, 49, 50, 51, - 52, 53, 54, 55, 56, 57, 58, 59, - 60, 61, 62, 63, 64, 65, 66, 67, - 68, 69, 70, 71, 72, 73, 74, 75, - 76, 77, 78, 79, 80, 81, 82, 83 }, - .oobfree = { - {.offset = 2, - .length = 10 }, - {.offset = 84, - .length = 44 } } -}; - -static int is_reading; - -static void jz_nand_cmd_ctrl(struct mtd_info *mtd, int cmd, unsigned int ctrl) -{ - struct nand_chip *this = mtd->priv; - uint32_t reg; - - if (ctrl & NAND_CTRL_CHANGE) { - if (ctrl & NAND_ALE) - this->IO_ADDR_W = JZ_NAND_ADDR_ADDR; - else if (ctrl & NAND_CLE) - this->IO_ADDR_W = JZ_NAND_CMD_ADDR; - else - this->IO_ADDR_W = JZ_NAND_DATA_ADDR; - - reg = readl(&emc->nfcsr); - if (ctrl & NAND_NCE) - reg |= EMC_NFCSR_NFCE1; - else - reg &= ~EMC_NFCSR_NFCE1; - writel(reg, &emc->nfcsr); - } - - if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -} - -static int jz_nand_device_ready(struct mtd_info *mtd) -{ - return (readl(GPIO_PXPIN(2)) & 0x40000000) ? 1 : 0; -} - -void board_nand_select_device(struct nand_chip *nand, int chip) -{ - /* - * Don't use "chip" to address the NAND device, - * generate the cs from the address where it is encoded. - */ -} - -static int jz_nand_rs_calculate_ecc(struct mtd_info *mtd, const u_char *dat, - u_char *ecc_code) -{ - uint32_t status; - int i; - - if (is_reading) - return 0; - - do { - status = readl(&emc->nfints); - } while (!(status & EMC_NFINTS_ENCF)); - - /* disable ecc */ - writel(readl(&emc->nfecr) & ~EMC_NFECR_ECCE, &emc->nfecr); - - for (i = 0; i < 9; i++) - ecc_code[i] = readb(&emc->nfpar[i]); - - return 0; -} - -static void jz_nand_hwctl(struct mtd_info *mtd, int mode) -{ - uint32_t reg; - - writel(0, &emc->nfints); - reg = readl(&emc->nfecr); - reg |= JZ_NAND_ECC_CTRL_RESET; - reg |= JZ_NAND_ECC_CTRL_ENABLE; - reg |= JZ_NAND_ECC_CTRL_RS; - - switch (mode) { - case NAND_ECC_READ: - reg &= ~JZ_NAND_ECC_CTRL_ENCODING; - is_reading = 1; - break; - case NAND_ECC_WRITE: - reg |= JZ_NAND_ECC_CTRL_ENCODING; - is_reading = 0; - break; - default: - break; - } - - writel(reg, &emc->nfecr); -} - -/* Correct 1~9-bit errors in 512-bytes data */ -static void jz_rs_correct(unsigned char *dat, int idx, int mask) -{ - int i; - - idx--; - - i = idx + (idx >> 3); - if (i >= 512) - return; - - mask <<= (idx & 0x7); - - dat[i] ^= mask & 0xff; - if (i < 511) - dat[i + 1] ^= (mask >> 8) & 0xff; -} - -static int jz_nand_rs_correct_data(struct mtd_info *mtd, u_char *dat, - u_char *read_ecc, u_char *calc_ecc) -{ - int k; - uint32_t errcnt, index, mask, status; - - /* Set PAR values */ - const uint8_t all_ff_ecc[] = { - 0xcd, 0x9d, 0x90, 0x58, 0xf4, 0x8b, 0xff, 0xb7, 0x6f }; - - if (read_ecc[0] == 0xff && read_ecc[1] == 0xff && - read_ecc[2] == 0xff && read_ecc[3] == 0xff && - read_ecc[4] == 0xff && read_ecc[5] == 0xff && - read_ecc[6] == 0xff && read_ecc[7] == 0xff && - read_ecc[8] == 0xff) { - for (k = 0; k < 9; k++) - writeb(all_ff_ecc[k], &emc->nfpar[k]); - } else { - for (k = 0; k < 9; k++) - writeb(read_ecc[k], &emc->nfpar[k]); - } - /* Set PRDY */ - writel(readl(&emc->nfecr) | EMC_NFECR_PRDY, &emc->nfecr); - - /* Wait for completion */ - do { - status = readl(&emc->nfints); - } while (!(status & EMC_NFINTS_DECF)); - - /* disable ecc */ - writel(readl(&emc->nfecr) & ~EMC_NFECR_ECCE, &emc->nfecr); - - /* Check decoding */ - if (!(status & EMC_NFINTS_ERR)) - return 0; - - if (status & EMC_NFINTS_UNCOR) { - printf("uncorrectable ecc\n"); - return -1; - } - - errcnt = (status & EMC_NFINTS_ERRCNT_MASK) >> EMC_NFINTS_ERRCNT_BIT; - - switch (errcnt) { - case 4: - index = (readl(&emc->nferr[3]) & EMC_NFERR_INDEX_MASK) >> - EMC_NFERR_INDEX_BIT; - mask = (readl(&emc->nferr[3]) & EMC_NFERR_MASK_MASK) >> - EMC_NFERR_MASK_BIT; - jz_rs_correct(dat, index, mask); - case 3: - index = (readl(&emc->nferr[2]) & EMC_NFERR_INDEX_MASK) >> - EMC_NFERR_INDEX_BIT; - mask = (readl(&emc->nferr[2]) & EMC_NFERR_MASK_MASK) >> - EMC_NFERR_MASK_BIT; - jz_rs_correct(dat, index, mask); - case 2: - index = (readl(&emc->nferr[1]) & EMC_NFERR_INDEX_MASK) >> - EMC_NFERR_INDEX_BIT; - mask = (readl(&emc->nferr[1]) & EMC_NFERR_MASK_MASK) >> - EMC_NFERR_MASK_BIT; - jz_rs_correct(dat, index, mask); - case 1: - index = (readl(&emc->nferr[0]) & EMC_NFERR_INDEX_MASK) >> - EMC_NFERR_INDEX_BIT; - mask = (readl(&emc->nferr[0]) & EMC_NFERR_MASK_MASK) >> - EMC_NFERR_MASK_BIT; - jz_rs_correct(dat, index, mask); - default: - break; - } - - return errcnt; -} - -/* - * Main initialization routine - */ -int board_nand_init(struct nand_chip *nand) -{ - uint32_t reg; - - reg = readl(&emc->nfcsr); - reg |= EMC_NFCSR_NFE1; /* EMC setup, Set NFE bit */ - writel(reg, &emc->nfcsr); - - writel(EMC_SMCR1_OPT_NAND, &emc->smcr[1]); - - nand->IO_ADDR_R = JZ_NAND_DATA_ADDR; - nand->IO_ADDR_W = JZ_NAND_DATA_ADDR; - nand->cmd_ctrl = jz_nand_cmd_ctrl; - nand->dev_ready = jz_nand_device_ready; - nand->ecc.hwctl = jz_nand_hwctl; - nand->ecc.correct = jz_nand_rs_correct_data; - nand->ecc.calculate = jz_nand_rs_calculate_ecc; - nand->ecc.mode = NAND_ECC_HW_OOB_FIRST; - nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; - nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; - nand->ecc.strength = 4; - nand->ecc.layout = &qi_lb60_ecclayout_2gb; - nand->chip_delay = 50; - nand->bbt_options |= NAND_BBT_USE_FLASH; - - return 0; -}
Am 25.05.2016 um 02:16 schrieb Marek Vasut:
Acked-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
