[U-Boot] [PATCH] ARM: am3517_evm: Enable SPL_OF_CONTROL and SPL_OF_PLATDATA
The SPL doesn't have much room, so in order to support OF_CONTROL in SPL, we need the extra functionality of SPL_OF_PLATDATA.
Adding these features allows us to remove a small part of code without losing the serial port during SPL.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index bcd3588818..da8be22085 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -37,20 +37,6 @@ DECLARE_GLOBAL_DATA_PTR; #define CPGMACSS_SW_RST (1 << 1) #define PHY_GPIO 30
-/* This is only needed until SPL gets OF support */ -#ifdef CONFIG_SPL_BUILD -static const struct ns16550_platdata am3517_serial = { - .base = OMAP34XX_UART3, - .reg_shift = 2, - .clock = V_NS16550_CLK, - .fcr = UART_FCR_DEFVAL, -}; - -U_BOOT_DEVICE(am3517_uart) = { - "ns16550_serial", - &am3517_serial -}; -#endif
/* * Routine: board_init diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 6643f93e33..3b8e2900eb 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -30,6 +30,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1920k(u-boot),256k(u-boot-env),8m(kernel),512k(dtb),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_OF_PLATDATA=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y @@ -43,3 +45,4 @@ CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_AM35X=y CONFIG_BCH=y +# CONFIG_SPL_OF_LIBFDT is not set
Adam Ford
