[U-Boot] [PATCH v4 0/6] MX31: NAND boot for PDK boards.
Hi all,
This is the latest set of patches that introduces NAND boot support for the i.MX31 CPU in general and the PDK board especially.
The patches apply on u-boot/next. For u-boot-arm/next I get an error from StGit when applying the CONFIG_PRELOADER patch but that's because the u-boot-arm/next is not update (as of this email). Don't know if git resolves the problem (it's the file onenand_ipl/board/apollon/Makefile that causes the problem), however after fixing that manually the u-boot-arm/next also builds fine with these patches.
This update takes of the comments received from Wolfgang Denk.
The code boots on i.MX31 PDK board using large page NAND, it should work for small page NAND as well but that has not been tested.
Regards, Magnus Lilja
Jean-Christophe PLAGNIOL-VILLARD (1): ARM: Add macros.h to be used in assembler file.
Magnus Lilja (5): ARM1136: Introduce CONFIG_PRELOADER macro. MX31: Add NAND SPL for i.MX31. i.MX31: Create a common device file. MX31: Add basic support for Freescale i.MX31 PDK board. MX31: Add NAND SPL boot support to i.MX31 PDK board.
MAINTAINERS | 4 + MAKEALL | 2 + Makefile | 13 ++- README | 5 + board/freescale/mx31pdk/Makefile | 52 ++++++ board/freescale/mx31pdk/config.mk | 5 + board/freescale/mx31pdk/lowlevel_init.S | 114 ++++++++++++ board/freescale/mx31pdk/mx31pdk.c | 63 +++++++ cpu/arm1136/mx31/Makefile | 1 + cpu/arm1136/mx31/devices.c | 56 ++++++ cpu/arm1136/start.S | 33 ++-- include/asm-arm/arch-mx31/mx31-regs.h | 61 +++++++ include/asm-arm/arch-mx31/mx31.h | 3 + include/asm-arm/macro.h | 74 ++++++++ include/configs/mx31pdk.h | 177 ++++++++++++++++++ include/fsl_nfc.h | 109 +++++++++++ nand_spl/board/freescale/mx31pdk/Makefile | 54 ++++++ nand_spl/board/freescale/mx31pdk/config.mk | 5 + nand_spl/board/freescale/mx31pdk/u-boot.lds | 36 ++++ nand_spl/nand_boot_fsl_nfc.c | 259 +++++++++++++++++++++++++++ onenand_ipl/board/apollon/Makefile | 4 +- 21 files changed, 1113 insertions(+), 17 deletions(-) create mode 100644 board/freescale/mx31pdk/Makefile create mode 100644 board/freescale/mx31pdk/config.mk create mode 100644 board/freescale/mx31pdk/lowlevel_init.S create mode 100644 board/freescale/mx31pdk/mx31pdk.c create mode 100644 cpu/arm1136/mx31/devices.c create mode 100644 include/asm-arm/macro.h create mode 100644 include/configs/mx31pdk.h create mode 100644 include/fsl_nfc.h create mode 100644 nand_spl/board/freescale/mx31pdk/Makefile create mode 100644 nand_spl/board/freescale/mx31pdk/config.mk create mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds create mode 100644 nand_spl/nand_boot_fsl_nfc.c
Currently CONFIG_ONENAND_IPL is used in a number of #ifdef's in start.S. In preparation for adding support for NAND SPL the macro CONFIG_PRELOADER is introducted and replaces the CONFIG_ONENAND_IPL in start.S.
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com ---
NOTE: This patch applies to u-boot/next but not u-boot-arm/next since the OBJCFLAGS spelling error is corrected in u-boot/next. Atleast StGit had problems applying the patch to u-boot-arm/next, don't know what git thinks about.
README | 5 +++++ cpu/arm1136/start.S | 24 ++++++++++++------------ onenand_ipl/board/apollon/Makefile | 4 ++-- 3 files changed, 19 insertions(+), 14 deletions(-)
diff --git a/README b/README index 561c100..0e84337 100644 --- a/README +++ b/README @@ -2702,6 +2702,11 @@ Low Level (hardware related) configuration options: some other boot loader or by a debugger which performs these initializations itself.
+- CONFIG_PRELOADER + + Modifies the behaviour of start.S when compiling a loader + that is executed before the actual U-Boot. E.g. when + compiling a NAND SPL.
Building the Software: ====================== diff --git a/cpu/arm1136/start.S b/cpu/arm1136/start.S index 999b184..28cb5fd 100644 --- a/cpu/arm1136/start.S +++ b/cpu/arm1136/start.S @@ -32,7 +32,7 @@ #include <version.h> .globl _start _start: b reset -#ifdef CONFIG_ONENAND_IPL +#ifdef CONFIG_PRELOADER ldr pc, _hang ldr pc, _hang ldr pc, _hang @@ -67,7 +67,7 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_PRELOADER */ .global _end_vect _end_vect:
@@ -156,9 +156,9 @@ relocate: /* relocate U-Boot to RAM */ adr r0, _start /* r0 <- current position of code */ ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ cmp r0, r1 /* don't reloc during debug */ -#ifndef CONFIG_ONENAND_IPL +#ifndef CONFIG_PRELOADER beq stack_setup -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_PRELOADER */
ldr r2, _armboot_start ldr r3, _bss_start @@ -175,7 +175,7 @@ copy_loop: /* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ -#ifdef CONFIG_ONENAND_IPL +#ifdef CONFIG_PRELOADER sub sp, r0, #128 /* leave 32 words for abort-stack */ #else sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ @@ -184,14 +184,14 @@ stack_setup: sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif sub sp, r0, #12 /* leave 3 words for abort-stack */ -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_PRELOADER */
clear_bss: ldr r0, _bss_start /* find start of bss segment */ ldr r1, _bss_end /* stop here */ mov r2, #0x00000000 /* clear */
-#ifndef CONFIG_ONENAND_IPL +#ifndef CONFIG_PRELOADER clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 @@ -244,7 +244,7 @@ cpu_init_crit: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */
-#ifndef CONFIG_ONENAND_IPL +#ifndef CONFIG_PRELOADER /* ************************************************************************* * @@ -357,17 +357,17 @@ cpu_init_crit: .macro get_fiq_stack @ setup FIQ stack ldr sp, FIQ_STACK_START .endm -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_PRELOADER */
/* * exception handlers */ -#ifdef CONFIG_ONENAND_IPL +#ifdef CONFIG_PRELOADER .align 5 do_hang: ldr sp, _TEXT_BASE /* use 32 words about stack */ bl hang /* hang and never return */ -#else /* !CONFIG_ONENAND IPL */ +#else /* !CONFIG_PRELOADER */ .align 5 undefined_instruction: get_bad_stack @@ -435,4 +435,4 @@ fiq: arm1136_cache_flush: mcr p15, 0, r1, c7, c5, 0 @ invalidate I cache mov pc, lr @ back to caller -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_PRELOADER */ diff --git a/onenand_ipl/board/apollon/Makefile b/onenand_ipl/board/apollon/Makefile index f6c36ec..49a8e90 100644 --- a/onenand_ipl/board/apollon/Makefile +++ b/onenand_ipl/board/apollon/Makefile @@ -4,8 +4,8 @@ include $(TOPDIR)/onenand_ipl/board/$(BOARDDIR)/config.mk
LDSCRIPT= $(TOPDIR)/onenand_ipl/board/$(BOARDDIR)/u-boot.onenand.lds LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) -AFLAGS += -DCONFIG_ONENAND_IPL -CFLAGS += -DCONFIG_ONENAND_IPL +AFLAGS += -DCONFIG_PRELOADER -DCONFIG_ONENAND_IPL +CFLAGS += -DCONFIG_PRELOADER -DCONFIG_ONENAND_IPL OBJCFLAGS += --gap-fill=0x00
SOBJS := low_levelinit.o
This patch adds the NAND SPL framework needed to boot i.MX31 boards from NAND.
It has been tested on a i.MX31 PDK board with large page NAND. Small page NANDs should work as well, but this has not been tested.
Note: The i.MX31 NFC uses a non-standard layout for large page NANDs, whether this is compatible with a particular setup depends on how the NAND device is programmed by the flash programmer (e.g. JTAG debugger).
The patch is based on the work by Maxim Artamonov.
Signed-off-by: Maxim Artamonov scn1874@yandex.ru Signed-off-by: Magnus Lilja lilja.magnus@gmail.com ---
Changes from last version: Fixed comments received from Wolfang Denk.
cpu/arm1136/start.S | 9 +- include/asm-arm/arch-mx31/mx31-regs.h | 5 + include/fsl_nfc.h | 109 ++++++++++++++ nand_spl/nand_boot_fsl_nfc.c | 259 +++++++++++++++++++++++++++++++++ 4 files changed, 380 insertions(+), 2 deletions(-) create mode 100644 include/fsl_nfc.h create mode 100644 nand_spl/nand_boot_fsl_nfc.c
diff --git a/cpu/arm1136/start.S b/cpu/arm1136/start.S index 28cb5fd..957f438 100644 --- a/cpu/arm1136/start.S +++ b/cpu/arm1136/start.S @@ -200,12 +200,15 @@ clbss_l:str r2, [r0] /* clear loop... */
ldr pc, _start_armboot
+#ifdef CONFIG_NAND_SPL +_start_armboot: .word nand_boot +#else #ifdef CONFIG_ONENAND_IPL _start_armboot: .word start_oneboot #else _start_armboot: .word start_armboot -#endif - +#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_NAND_SPL */
/* ************************************************************************* @@ -217,6 +220,7 @@ _start_armboot: .word start_armboot * ************************************************************************* */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT cpu_init_crit: /* * flush v4 I/D caches @@ -243,6 +247,7 @@ cpu_init_crit: bl lowlevel_init /* go setup pll,mux,memory */ mov lr, ip /* restore link */ mov pc, lr /* back to my caller */ +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
#ifndef CONFIG_PRELOADER /* diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index a8a05c8..c2e7dcf 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -194,4 +194,9 @@ #define CS5_BASE 0xB6000000 #define PCMCIA_MEM_BASE 0xC0000000
+/* + * NAND controller + */ +#define NFC_BASE_ADDR 0xB8000000 + #endif /* __ASM_ARCH_MX31_REGS_H */ diff --git a/include/fsl_nfc.h b/include/fsl_nfc.h new file mode 100644 index 0000000..da5be37 --- /dev/null +++ b/include/fsl_nfc.h @@ -0,0 +1,109 @@ +/* + * + * (c) 2009 Magnus Lilja lilja.magnus@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSL_NFC_H +#define __FSL_NFC_H + +/* + * Register map and bit definitions for the Freescale NAND Flash + * Controller present in i.MX31 and other devices. + */ + +struct fsl_nfc_regs { + u32 main_area0[128]; /* @0x000 */ + u32 main_area1[128]; + u32 main_area2[128]; + u32 main_area3[128]; + u32 spare_area0[4]; + u32 spare_area1[4]; + u32 spare_area2[4]; + u32 spare_area3[4]; + u32 reserved1[64 - 16 + 64 * 5]; + u16 bufsiz; /* @ 0xe00 */ + u16 reserved2; + u16 buffer_address; + u16 flash_add; + u16 flash_cmd; + u16 configuration; + u16 ecc_status_result; + u16 ecc_rslt_main_area; + u16 ecc_rslt_spare_area; + u16 nf_wr_prot; + u16 unlock_start_blk_add; + u16 unlock_end_blk_add; + u16 nand_flash_wr_pr_st; + u16 nand_flash_config1; + u16 nand_flash_config2; +}; + +/* + * Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command + * operation + */ +#define NFC_CMD 0x1 + +/* + * Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address + * operation + */ +#define NFC_ADDR 0x2 + +/* + * Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input + * operation + */ +#define NFC_INPUT 0x4 + +/* + * Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data + * Output operation + */ +#define NFC_OUTPUT 0x8 + +/* + * Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID + * operation + */ +#define NFC_ID 0x10 + +/* + * Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read + * Status operation + */ +#define NFC_STATUS 0x20 + +/* + * Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status + * operation + */ +#define NFC_INT 0x8000 + +#define NFC_SP_EN (1 << 2) +#define NFC_ECC_EN (1 << 3) +#define NFC_INT_MSK (1 << 4) +#define NFC_BIG (1 << 5) +#define NFC_RST (1 << 6) +#define NFC_CE (1 << 7) +#define NFC_ONE_CYCLE (1 << 8) + +#endif /* __FSL_NFC_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c new file mode 100644 index 0000000..a9df2a8 --- /dev/null +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -0,0 +1,259 @@ +/* + * (C) Copyright 2009 + * Magnus Lilja lilja.magnus@gmail.com + * + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * + * (C) Copyright 2006-2008 + * Stefan Roese, DENX Software Engineering, sr at denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> +#include <asm-arm/arch/mx31-regs.h> +#include <asm/io.h> +#include <fsl_nfc.h> + +static struct fsl_nfc_regs *nfc; + +static void nfc_wait_ready(void) +{ + uint32_t tmp; + + while (!(readw(&nfc->nand_flash_config2) & NFC_INT)) + ; + + /* Reset interrupt flag */ + tmp = readw(&nfc->nand_flash_config2); + tmp &= ~NFC_INT; + writew(tmp, &nfc->nand_flash_config2); +} + +static void nfc_nand_init(void) +{ + /* unlocking RAM Buff */ + writew(0x2, &nfc->configuration); + + /* hardware ECC checking and correct */ + writew(NFC_ECC_EN, &nfc->nand_flash_config1); +} + +static void nfc_nand_command(unsigned short command) +{ + writew(command, &nfc->flash_cmd); + writew(NFC_CMD, &nfc->nand_flash_config2); + nfc_wait_ready(); +} + +static void nfc_nand_page_address(unsigned int page_address) +{ + unsigned int page_count; + + writew(0x00, &nfc->flash_cmd); + writew(NFC_ADDR, &nfc->nand_flash_config2); + nfc_wait_ready(); + + /* code only for 2kb flash */ + if (CONFIG_SYS_NAND_PAGE_SIZE == 0x800) { + writew(0x00, &nfc->flash_add); + writew(NFC_ADDR, &nfc->nand_flash_config2); + nfc_wait_ready(); + } + + page_count = CONFIG_SYS_NAND_SIZE / CONFIG_SYS_NAND_PAGE_SIZE; + + if (page_address <= page_count) { + page_count--; /* transform 0x01000000 to 0x00ffffff */ + do { + writew(page_address & 0xff, &nfc->flash_add); + writew(NFC_ADDR, &nfc->nand_flash_config2); + nfc_wait_ready(); + page_address = page_address >> 8; + page_count = page_count >> 8; + } while (page_count); + } +} + +static void nfc_nand_data_output(void) +{ + int i; + + /* + * The NAND controller requires four output commands for + * large page devices. + */ + for (i = 0; i < (CONFIG_SYS_NAND_PAGE_SIZE / 512); i++) { + writew(NFC_ECC_EN, &nfc->nand_flash_config1); + writew(i, &nfc->buffer_address); /* read in i:th buffer */ + writew(NFC_OUTPUT, &nfc->nand_flash_config2); + nfc_wait_ready(); + } +} + +static int nfc_nand_check_ecc(void) +{ + return readw(&nfc->ecc_status_result); +} + +static int nfc_read_page(unsigned int page_address, unsigned char *buf) +{ + int i; + u32 *src; + u32 *dst; + + writew(0, &nfc->buffer_address); /* read in first 0 buffer */ + nfc_nand_command(NAND_CMD_READ0); + nfc_nand_page_address(page_address); + + if (CONFIG_SYS_NAND_PAGE_SIZE == 0x800) + nfc_nand_command(NAND_CMD_READSTART); + + nfc_nand_data_output(); /* fill the main buffer 0 */ + + if (nfc_nand_check_ecc()) + return -1; + + src = &nfc->main_area0[0]; + dst = (u32 *)buf; + + /* main copy loop from NAND-buffer to SDRAM memory */ + for (i = 0; i < (CONFIG_SYS_NAND_PAGE_SIZE / 4); i++) { + writel(readl(src), dst); + src++; + dst++; + } + + return 0; +} + +static int is_badblock(int pagenumber) +{ + int page = pagenumber; + u32 badblock; + u32 *src; + + /* Check the first two pages for bad block markers */ + for (page = pagenumber; page < pagenumber + 2; page++) { + writew(0, &nfc->buffer_address); /* read in first 0 buffer */ + nfc_nand_command(NAND_CMD_READ0); + nfc_nand_page_address(page); + + if (CONFIG_SYS_NAND_PAGE_SIZE == 0x800) + nfc_nand_command(NAND_CMD_READSTART); + + nfc_nand_data_output(); /* fill the main buffer 0 */ + + src = &nfc->spare_area0[0]; + + /* + * IMPORTANT NOTE: The nand flash controller uses a non- + * standard layout for large page devices. This can + * affect the position of the bad block marker. + */ + /* Get the bad block marker */ + badblock = readl(&src[CONFIG_SYS_NAND_BAD_BLOCK_POS / 4]); + badblock >>= 8 * (CONFIG_SYS_NAND_BAD_BLOCK_POS % 4); + badblock &= 0xff; + + /* bad block marker verify */ + if (badblock != 0xff) + return 1; /* potential bad block */ + } + + return 0; +} + +static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) +{ + int i; + unsigned int page; + unsigned int maxpages = CONFIG_SYS_NAND_SIZE / + CONFIG_SYS_NAND_PAGE_SIZE; + + nfc = (void *)NFC_BASE_ADDR; + + nfc_nand_init(); + + /* Convert to page number */ + page = from / CONFIG_SYS_NAND_PAGE_SIZE; + i = 0; + + while (i < (size / CONFIG_SYS_NAND_PAGE_SIZE)) { + if (nfc_read_page(page, buf) < 0) + return -1; + + page++; + i++; + buf = buf + CONFIG_SYS_NAND_PAGE_SIZE; + + /* + * Check if we have crossed a block boundary, and if so + * check for bad block. + */ + if (!(page % CONFIG_SYS_NAND_PAGE_COUNT)) { + /* + * Yes, new block. See if this block is good. If not, + * loop until we find i good block. + */ + while (is_badblock(page)) { + page = page + CONFIG_SYS_NAND_PAGE_COUNT; + /* Check i we've reached the end of flash. */ + if (page >= maxpages) + return -1; + } + } + } + + return 0; +} + +/* + * The main entry for NAND booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from NAND into SDRAM and starts it from there. + */ +void nand_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + + nfc = (void *)NFC_BASE_ADDR; + + /* + * CONFIG_SYS_NAND_U_BOOT_OFFS and CONFIG_SYS_NAND_U_BOOT_SIZE must + * be aligned to full pages + */ + if (!nand_load(CONFIG_SYS_NAND_U_BOOT_OFFS, CONFIG_SYS_NAND_U_BOOT_SIZE, + (uchar *)CONFIG_SYS_NAND_U_BOOT_DST)) { + /* Copy from NAND successful, start U-boot */ + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; + uboot(); + } else { + /* Unrecoverable error when copying from NAND */ + hang(); + } +} + +/* + * Called in case of an exception. + */ +void hang(void) +{ + /* Loop forever */ + while (1) ; +}
From: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com ---
Changes from last version: Added documentation for the macros.
include/asm-arm/macro.h | 74 +++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 74 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/macro.h
diff --git a/include/asm-arm/macro.h b/include/asm-arm/macro.h new file mode 100644 index 0000000..57b5260 --- /dev/null +++ b/include/asm-arm/macro.h @@ -0,0 +1,74 @@ +/* + * include/asm-arm/macro.h + * + * Copyright (C) 2009 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARM_MACRO_H__ +#define __ASM_ARM_MACRO_H__ +#ifdef __ASSEMBLY__ + +/* + * These macros provide a convenient way to write 8, 16 and 32 bit data + * to any address. + * Registers r4 and r5 are used, any data in these registers are + * overwritten by the macros. + * The macros are valid for any ARM architecture, they do not implement + * any memory barriers so caution is recommended when using these when the + * caches are enabled or on a multi-core system. + */ + +.macro write32, addr, data + ldr r4, =\addr + ldr r5, =\data + str r5, [r4] +.endm + +.macro write16, addr, data + ldr r4, =\addr + ldrh r5, =\data + strh r5, [r4] +.endm + +.macro write8, addr, data + ldr r4, =\addr + ldrb r5, =\data + strb r5, [r4] +.endm + +/* + * This macro generates a loop that can be used for delays in the code. + * Register r4 is used, any data in this register is overwritten by the + * macro. + * The macro is valid for any ARM architeture. The actual time spent in the + * loop will vary from CPU to CPU though. + */ + +.macro wait_timer, time + ldr r4, =\time +1: + nop + subs r4, r4, #1 + bcs 1b +.endm + +#endif /* __ASSEMBLY__ */ +#endif /* __ASM_ARM_MACRO_H__ */
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- cpu/arm1136/mx31/Makefile | 1 + cpu/arm1136/mx31/devices.c | 56 ++++++++++++++++++++++++++++++++++++++ include/asm-arm/arch-mx31/mx31.h | 3 ++ 3 files changed, 60 insertions(+), 0 deletions(-) create mode 100644 cpu/arm1136/mx31/devices.c
diff --git a/cpu/arm1136/mx31/Makefile b/cpu/arm1136/mx31/Makefile index 1e49e8d..c8e18f7 100644 --- a/cpu/arm1136/mx31/Makefile +++ b/cpu/arm1136/mx31/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(SOC).a
COBJS += generic.o COBJS += timer.o +COBJS += devices.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/arm1136/mx31/devices.c b/cpu/arm1136/mx31/devices.c new file mode 100644 index 0000000..1f4ca7e --- /dev/null +++ b/cpu/arm1136/mx31/devices.c @@ -0,0 +1,56 @@ +/* + * + * (C) Copyright 2009 Magnus Lilja lilja.magnus@gmail.com + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/mx31-regs.h> +#include <asm/arch/mx31.h> + +#ifdef CONFIG_SYS_MX31_UART1 +void mx31_uart1_hw_init(void) +{ + /* setup pins for UART1 */ + mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX); + mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX); + mx31_gpio_mux(MUX_RTS1__UART1_RTS_B); + mx31_gpio_mux(MUX_CTS1__UART1_CTS_B); +} +#endif + +#ifdef CONFIG_MXC_SPI +void mx31_spi2_hw_init(void) +{ + /* SPI2 */ + mx31_gpio_mux(MUX_CSPI2_SS2__CSPI2_SS2_B); + mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); + mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B); + mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI); + mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO); + mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B); + mx31_gpio_mux(MUX_CSPI2_SS1__CSPI2_SS1_B); + + /* start SPI2 clock */ + __REG(CCM_CGR2) = __REG(CCM_CGR2) | (3 << 4); +} +#endif diff --git a/include/asm-arm/arch-mx31/mx31.h b/include/asm-arm/arch-mx31/mx31.h index 1d475dd..53b9f27 100644 --- a/include/asm-arm/arch-mx31/mx31.h +++ b/include/asm-arm/arch-mx31/mx31.h @@ -47,4 +47,7 @@ static inline void mx31_gpio_set(unsigned int gpio, unsigned int value) } #endif
+void mx31_uart1_hw_init(void); +void mx31_spi2_hw_init(void); + #endif /* __ASM_ARCH_MX31_H */
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board).
This patch assumes that some other program performs the actual NAND boot.
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/freescale/mx31pdk/Makefile | 52 +++++++++++ board/freescale/mx31pdk/config.mk | 1 + board/freescale/mx31pdk/mx31pdk.c | 63 +++++++++++++ include/asm-arm/arch-mx31/mx31-regs.h | 2 + include/configs/mx31pdk.h | 162 +++++++++++++++++++++++++++++++++ 8 files changed, 288 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx31pdk/Makefile create mode 100644 board/freescale/mx31pdk/config.mk create mode 100644 board/freescale/mx31pdk/mx31pdk.c create mode 100644 include/configs/mx31pdk.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1f6008f..8eb54e1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -528,6 +528,10 @@ Thomas Elste info@elste.org
modnet50 ARM720T (NET+50)
+Fabio Estevam Fabio.Estevam@freescale.com + + mx31pdk i.MX31 + Peter Figuli peposh@etc.sk
wepep250 xscale diff --git a/MAKEALL b/MAKEALL index f48a08e..0757064 100755 --- a/MAKEALL +++ b/MAKEALL @@ -552,6 +552,7 @@ LIST_ARM11=" \ imx31_phycore \ imx31_phycore_eet \ mx31ads \ + mx31pdk \ qong \ smdk6400 \ " diff --git a/Makefile b/Makefile index aa4646f..e445e51 100644 --- a/Makefile +++ b/Makefile @@ -3115,6 +3115,9 @@ imx31_phycore_config : unconfig mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
+mx31pdk_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm1136 mx31pdk freescale mx31 + omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx
diff --git a/board/freescale/mx31pdk/Makefile b/board/freescale/mx31pdk/Makefile new file mode 100644 index 0000000..d5d8f04 --- /dev/null +++ b/board/freescale/mx31pdk/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := mx31pdk.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk new file mode 100644 index 0000000..d34dc02 --- /dev/null +++ b/board/freescale/mx31pdk/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x87f00000 diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c new file mode 100644 index 0000000..6b60c17 --- /dev/null +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -0,0 +1,63 @@ +/* + * + * (C) Copyright 2009 Magnus Lilja lilja.magnus@gmail.com + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include <common.h> +#include <asm/arch/mx31.h> +#include <asm/arch/mx31-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init(void) +{ + /* CS5: CPLD incl. network controller */ + __REG(CSCR_U(5)) = 0x0000d843; + __REG(CSCR_L(5)) = 0x22252521; + __REG(CSCR_A(5)) = 0x22220a00; + + /* Setup UART1 and SPI2 pins */ + mx31_uart1_hw_init(); + mx31_spi2_hw_init(); + + gd->bd->bi_arch_number = MACH_TYPE_MX31_3DS; /* board id for linux */ + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +int checkboard(void) +{ + printf("Board: i.MX31 MAX PDK (3DS)\n"); + return 0; +} diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index c2e7dcf..76f4d53 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -84,6 +84,8 @@ #define IPU_CONF_IC_EN (1<<1) #define IPU_CONF_SCI_EN (1<<0)
+#define ARM_PPMRR 0x40000015 + #define WDOG_BASE 0x53FDC000
/* diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h new file mode 100644 index 0000000..ca7b960 --- /dev/null +++ b/include/configs/mx31pdk.h @@ -0,0 +1,162 @@ +/* + * (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com + * + * (C) Copyright 2004 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Kshitij Gupta kshitij@ti.com + * + * Configuration settings for the Freescale i.MX31 PDK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ +#define CONFIG_MX31 1 /* in a mx31 */ +#define CONFIG_MX31_HCLK_FREQ 26000000 +#define CONFIG_MX31_CLK32 32768 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* No support for NAND boot for i.MX31 PDK yet, so we rely on some other + * program to initialize the SDRAM. + */ +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) +/* Bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Hardware drivers + */ + +#define CONFIG_MX31_UART 1 +#define CONFIG_SYS_MX31_UART1 1 + +#define CONFIG_HARD_SPI 1 +#define CONFIG_MXC_SPI 1 +#define CONFIG_DEFAULT_SPI_BUS 1 +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) + +#define CONFIG_RTC_MC13783 1 + +/* MC13783 connected to CSPI2 and SS2 */ +#define CONFIG_MC13783_SPI_BUS 1 +#define CONFIG_MC13783_SPI_CS 2 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SPI +#define CONFIG_CMD_DATE + +/* + * Disabled due to compilation errors in cmd_bootm.c (IMLS seems to require + * that CFG_NO_FLASH is undefined). + */ +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs " \ + "ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp\0" \ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; " \ + "tftpboot 0x81000000 uImage-mx31; bootm\0" + +#define CONFIG_DRIVER_SMC911X 1 +#define CONFIG_DRIVER_SMC911X_BASE 0xB6000000 +#define CONFIG_DRIVER_SMC911X_32_BIT 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "uboot> " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT)+16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x10000 + +/* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0x81000000 + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING 1 + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE +#define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +/* No NOR flash present */ +#define CONFIG_SYS_NO_FLASH 1 + +#define CONFIG_ENV_IS_NOWHERE 1 + +#define CONFIG_ENV_SIZE (128 * 1024) + +#endif /* __CONFIG_H */
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- MAKEALL | 1 + Makefile | 14 +++- board/freescale/mx31pdk/config.mk | 4 + board/freescale/mx31pdk/lowlevel_init.S | 114 +++++++++++++++++++++++++++ include/asm-arm/arch-mx31/mx31-regs.h | 54 +++++++++++++ include/configs/mx31pdk.h | 21 ++++- nand_spl/board/freescale/mx31pdk/Makefile | 54 +++++++++++++ nand_spl/board/freescale/mx31pdk/config.mk | 5 + nand_spl/board/freescale/mx31pdk/u-boot.lds | 36 +++++++++ 9 files changed, 297 insertions(+), 6 deletions(-) create mode 100644 board/freescale/mx31pdk/lowlevel_init.S create mode 100644 nand_spl/board/freescale/mx31pdk/Makefile create mode 100644 nand_spl/board/freescale/mx31pdk/config.mk create mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds
diff --git a/MAKEALL b/MAKEALL index 0757064..1f7cab4 100755 --- a/MAKEALL +++ b/MAKEALL @@ -553,6 +553,7 @@ LIST_ARM11=" \ imx31_phycore_eet \ mx31ads \ mx31pdk \ + mx31pdk_nand \ qong \ smdk6400 \ " diff --git a/Makefile b/Makefile index e445e51..29d1f22 100644 --- a/Makefile +++ b/Makefile @@ -376,7 +376,7 @@ $(LDSCRIPT): depend $(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C nand_spl/board/$(BOARDDIR) all
-$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin +$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin $(obj)include/autoconf.mk cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
$(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk @@ -3115,8 +3115,16 @@ imx31_phycore_config : unconfig mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
-mx31pdk_config : unconfig - @$(MKCONFIG) $(@:_config=) arm arm1136 mx31pdk freescale mx31 +mx31pdk_config \ +mx31pdk_nand_config : unconfig + @mkdir -p $(obj)include + @if [ -n "$(findstring _nand_,$@)" ]; then \ + echo "#define CONFIG_NAND_U_BOOT" >> $(obj)include/config.h; \ + else \ + echo "#define CONFIG_SKIP_LOWLEVEL_INIT" >> $(obj)include/config.h; \ + echo "#define CONFIG_SKIP_RELOCATE_UBOOT" >> $(obj)include/config.h; \ + fi + @$(MKCONFIG) -a mx31pdk arm arm1136 mx31pdk freescale mx31
omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk index d34dc02..dcaa09f 100644 --- a/board/freescale/mx31pdk/config.mk +++ b/board/freescale/mx31pdk/config.mk @@ -1 +1,5 @@ +ifdef CONFIG_NAND_SPL +TEXT_BASE = 0x87ec0000 +else TEXT_BASE = 0x87f00000 +endif diff --git a/board/freescale/mx31pdk/lowlevel_init.S b/board/freescale/mx31pdk/lowlevel_init.S new file mode 100644 index 0000000..f913f90 --- /dev/null +++ b/board/freescale/mx31pdk/lowlevel_init.S @@ -0,0 +1,114 @@ +/* + * (C) Copyright 2009 Magnus Lilja lilja.magnus@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +.globl lowlevel_init + +#include <asm/arch/mx31-regs.h> +#include <asm/macro.h> + +#define CCM_CCMR_SETUP 0x074B0BF5 +#define CCM_PDR0_SETUP_532MHZ (PDR0_CSI_PODF(0x1ff) | PDR0_PER_PODF(7) | \ + PDR0_HSP_PODF(3) | PDR0_NFC_PODF(5) | \ + PDR0_IPG_PODF(1) | PDR0_MAX_PODF(3) | \ + PDR0_MCU_PODF(0)) +#define CCM_MPCTL_SETUP_532MHZ (PLL_PD(0) | PLL_MFD(51) | PLL_MFI(10) | \ + PLL_MFN(12)) + +#define ESDMISC_MDDR_SETUP 0x00000004 +#define ESDMISC_MDDR_RESET_DL 0x0000000c +#define ESDCFG0_MDDR_SETUP 0x006ac73a + +#define ESDCTL_ROW_COL (ESDCTL_SDE | ESDCTL_ROW(2) | ESDCTL_COL(2)) +#define ESDCTL_SETTINGS (ESDCTL_ROW_COL | ESDCTL_SREFR(3) | \ + ESDCTL_DSIZ(2) | ESDCTL_BL(1)) +#define ESDCTL_PRECHARGE (ESDCTL_ROW_COL | ESDCTL_CMD_PRECHARGE) +#define ESDCTL_AUTOREFRESH (ESDCTL_ROW_COL | ESDCTL_CMD_AUTOREFRESH) +#define ESDCTL_LOADMODEREG (ESDCTL_ROW_COL | ESDCTL_CMD_LOADMODEREG) +#define ESDCTL_RW ESDCTL_SETTINGS + +.globl lowlevel_init +lowlevel_init: + /* Also setup the Peripheral Port Remap register inside the core */ + ldr r0, =ARM_PPMRR /* start from AIPS 2GB region */ + mcr p15, 0, r0, c15, c2, 4 + + write32 IPU_CONF, IPU_CONF_DI_EN + write32 CCM_CCMR, CCM_CCMR_SETUP + + wait_timer 0x40000 + + write32 CCM_CCMR, CCM_CCMR_SETUP | CCMR_MPE + write32 CCM_CCMR, (CCM_CCMR_SETUP | CCMR_MPE) & ~CCMR_MDS + + /* Set up clock to 532MHz */ + write32 CCM_PDR0, CCM_PDR0_SETUP_532MHZ + write32 CCM_MPCTL, CCM_MPCTL_SETUP_532MHZ + + write32 CCM_SPCTL, PLL_PD(1) | PLL_MFD(4) | PLL_MFI(12) | PLL_MFN(1) + + /* Set up MX31 DDR pins */ + write32 IOMUXC_SW_PAD_CTL_SDCKE1_SDCLK_SDCLK_B, 0 + write32 IOMUXC_SW_PAD_CTL_CAS_SDWE_SDCKE0, 0 + write32 IOMUXC_SW_PAD_CTL_BCLK_RW_RAS, 0 + write32 IOMUXC_SW_PAD_CTL_CS2_CS3_CS4, 0x1000 + write32 IOMUXC_SW_PAD_CTL_DQM3_EB0_EB1, 0 + write32 IOMUXC_SW_PAD_CTL_DQM0_DQM1_DQM2, 0 + write32 IOMUXC_SW_PAD_CTL_SD29_SD30_SD31, 0 + write32 IOMUXC_SW_PAD_CTL_SD26_SD27_SD28, 0 + write32 IOMUXC_SW_PAD_CTL_SD23_SD24_SD25, 0 + write32 IOMUXC_SW_PAD_CTL_SD20_SD21_SD22, 0 + write32 IOMUXC_SW_PAD_CTL_SD17_SD18_SD19, 0 + write32 IOMUXC_SW_PAD_CTL_SD14_SD15_SD16, 0 + write32 IOMUXC_SW_PAD_CTL_SD11_SD12_SD13, 0 + write32 IOMUXC_SW_PAD_CTL_SD8_SD9_SD10, 0 + write32 IOMUXC_SW_PAD_CTL_SD5_SD6_SD7, 0 + write32 IOMUXC_SW_PAD_CTL_SD2_SD3_SD4, 0 + write32 IOMUXC_SW_PAD_CTL_SDBA0_SD0_SD1, 0 + write32 IOMUXC_SW_PAD_CTL_A24_A25_SDBA1, 0 + write32 IOMUXC_SW_PAD_CTL_A21_A22_A23, 0 + write32 IOMUXC_SW_PAD_CTL_A18_A19_A20, 0 + write32 IOMUXC_SW_PAD_CTL_A15_A16_A17, 0 + write32 IOMUXC_SW_PAD_CTL_A12_A13_A14, 0 + write32 IOMUXC_SW_PAD_CTL_A10_MA10_A11, 0 + write32 IOMUXC_SW_PAD_CTL_A7_A8_A9, 0 + write32 IOMUXC_SW_PAD_CTL_A4_A5_A6, 0 + write32 IOMUXC_SW_PAD_CTL_A1_A2_A3, 0 + write32 IOMUXC_SW_PAD_CTL_VPG0_VPG1_A0, 0 + + /* Set up MX31 DDR Memory Controller */ + write32 WEIM_ESDMISC, ESDMISC_MDDR_SETUP + write32 WEIM_ESDCFG0, ESDCFG0_MDDR_SETUP + + /* Perform DDR init sequence */ + write32 WEIM_ESDCTL0, ESDCTL_PRECHARGE + write32 CSD0_BASE | 0x0f00, 0x12344321 + write32 WEIM_ESDCTL0, ESDCTL_AUTOREFRESH + write32 CSD0_BASE, 0x12344321 + write32 CSD0_BASE, 0x12344321 + write32 WEIM_ESDCTL0, ESDCTL_LOADMODEREG + write8 CSD0_BASE | 0x00000033, 0xda + write8 CSD0_BASE | 0x01000000, 0xff + write32 WEIM_ESDCTL0, ESDCTL_RW + write32 CSD0_BASE, 0xDEADBEEF + write32 WEIM_ESDMISC, ESDMISC_MDDR_RESET_DL + + mov pc, lr diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index 76f4d53..51b02a2 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -61,6 +61,29 @@ #define PLL_MFI(x) (((x) & 0xf) << 10) #define PLL_MFN(x) (((x) & 0x3ff) << 0)
+#define WEIM_ESDCTL0 0xB8001000 +#define WEIM_ESDCFG0 0xB8001004 +#define WEIM_ESDCTL1 0xB8001008 +#define WEIM_ESDCFG1 0xB800100C +#define WEIM_ESDMISC 0xB8001010 + +#define ESDCTL_SDE (1 << 31) +#define ESDCTL_CMD_RW (0 << 28) +#define ESDCTL_CMD_PRECHARGE (1 << 28) +#define ESDCTL_CMD_AUTOREFRESH (2 << 28) +#define ESDCTL_CMD_LOADMODEREG (3 << 28) +#define ESDCTL_CMD_MANUALREFRESH (4 << 28) +#define ESDCTL_ROW_13 (2 << 24) +#define ESDCTL_ROW(x) ((x) << 24) +#define ESDCTL_COL_9 (1 << 20) +#define ESDCTL_COL(x) ((x) << 20) +#define ESDCTL_DSIZ(x) ((x) << 16) +#define ESDCTL_SREFR(x) ((x) << 13) +#define ESDCTL_PWDT(x) ((x) << 10) +#define ESDCTL_FP(x) ((x) << 8) +#define ESDCTL_BL(x) ((x) << 7) +#define ESDCTL_PRCT(x) ((x) << 0) + #define WEIM_BASE 0xb8002000 #define CSCR_U(x) (WEIM_BASE + (x) * 0x10) #define CSCR_L(x) (WEIM_BASE + 4 + (x) * 0x10) @@ -181,6 +204,37 @@ #define MUX_CSPI2_MOSI__I2C2_SCL IOMUX_MODE(MUX_CTL_CSPI2_MOSI, MUX_CTL_ALT1) #define MUX_CSPI2_MISO__I2C2_SDA IOMUX_MODE(MUX_CTL_CSPI2_MISO, MUX_CTL_ALT1)
+/* PAD control registers for SDR/DDR */ +#define IOMUXC_SW_PAD_CTL_SDCKE1_SDCLK_SDCLK_B (IOMUXC_BASE + 0x26C) +#define IOMUXC_SW_PAD_CTL_CAS_SDWE_SDCKE0 (IOMUXC_BASE + 0x270) +#define IOMUXC_SW_PAD_CTL_BCLK_RW_RAS (IOMUXC_BASE + 0x274) +#define IOMUXC_SW_PAD_CTL_CS5_ECB_LBA (IOMUXC_BASE + 0x278) +#define IOMUXC_SW_PAD_CTL_CS2_CS3_CS4 (IOMUXC_BASE + 0x27C) +#define IOMUXC_SW_PAD_CTL_OE_CS0_CS1 (IOMUXC_BASE + 0x280) +#define IOMUXC_SW_PAD_CTL_DQM3_EB0_EB1 (IOMUXC_BASE + 0x284) +#define IOMUXC_SW_PAD_CTL_DQM0_DQM1_DQM2 (IOMUXC_BASE + 0x288) +#define IOMUXC_SW_PAD_CTL_SD29_SD30_SD31 (IOMUXC_BASE + 0x28C) +#define IOMUXC_SW_PAD_CTL_SD26_SD27_SD28 (IOMUXC_BASE + 0x290) +#define IOMUXC_SW_PAD_CTL_SD23_SD24_SD25 (IOMUXC_BASE + 0x294) +#define IOMUXC_SW_PAD_CTL_SD20_SD21_SD22 (IOMUXC_BASE + 0x298) +#define IOMUXC_SW_PAD_CTL_SD17_SD18_SD19 (IOMUXC_BASE + 0x29C) +#define IOMUXC_SW_PAD_CTL_SD14_SD15_SD16 (IOMUXC_BASE + 0x2A0) +#define IOMUXC_SW_PAD_CTL_SD11_SD12_SD13 (IOMUXC_BASE + 0x2A4) +#define IOMUXC_SW_PAD_CTL_SD8_SD9_SD10 (IOMUXC_BASE + 0x2A8) +#define IOMUXC_SW_PAD_CTL_SD5_SD6_SD7 (IOMUXC_BASE + 0x2AC) +#define IOMUXC_SW_PAD_CTL_SD2_SD3_SD4 (IOMUXC_BASE + 0x2B0) +#define IOMUXC_SW_PAD_CTL_SDBA0_SD0_SD1 (IOMUXC_BASE + 0x2B4) +#define IOMUXC_SW_PAD_CTL_A24_A25_SDBA1 (IOMUXC_BASE + 0x2B8) +#define IOMUXC_SW_PAD_CTL_A21_A22_A23 (IOMUXC_BASE + 0x2BC) +#define IOMUXC_SW_PAD_CTL_A18_A19_A20 (IOMUXC_BASE + 0x2C0) +#define IOMUXC_SW_PAD_CTL_A15_A16_A17 (IOMUXC_BASE + 0x2C4) +#define IOMUXC_SW_PAD_CTL_A12_A13_A14 (IOMUXC_BASE + 0x2C8) +#define IOMUXC_SW_PAD_CTL_A10_MA10_A11 (IOMUXC_BASE + 0x2CC) +#define IOMUXC_SW_PAD_CTL_A7_A8_A9 (IOMUXC_BASE + 0x2D0) +#define IOMUXC_SW_PAD_CTL_A4_A5_A6 (IOMUXC_BASE + 0x2D4) +#define IOMUXC_SW_PAD_CTL_A1_A2_A3 (IOMUXC_BASE + 0x2D8) +#define IOMUXC_SW_PAD_CTL_VPG0_VPG1_A0 (IOMUXC_BASE + 0x2DC) + /* * Memory regions and CS */ diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index ca7b960..1795a7e 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -43,10 +43,10 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-/* No support for NAND boot for i.MX31 PDK yet, so we rely on some other - * program to initialize the SDRAM. - */ +#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) #define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT +#endif
/* * Size of malloc() pool @@ -159,4 +159,19 @@
+/* NAND configuration for the NAND_SPL */ + +/* Start copying real U-boot from the second page */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x800 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x30000 +/* Load U-Boot to this address */ +#define CONFIG_SYS_NAND_U_BOOT_DST 0x87f00000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST + +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 + #endif /* __CONFIG_H */ diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile new file mode 100644 index 0000000..a9572ba --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -0,0 +1,54 @@ +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL + +SOBJS = start.o lowlevel_init.o +COBJS = nand_boot_fsl_nfc.o + +SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c +SRCS += $(SRCTREE)/cpu/arm1136/start.S +SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $@ + +######################################################################### + +$(obj)%.o: $(SRCTREE)/cpu/arm1136/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/nand_spl/%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/freescale/mx31pdk/config.mk b/nand_spl/board/freescale/mx31pdk/config.mk new file mode 100644 index 0000000..198cafc --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/config.mk @@ -0,0 +1,5 @@ +PAD_TO := 2048 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif diff --git a/nand_spl/board/freescale/mx31pdk/u-boot.lds b/nand_spl/board/freescale/mx31pdk/u-boot.lds new file mode 100644 index 0000000..edd8430 --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/u-boot.lds @@ -0,0 +1,36 @@ +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + lowlevel_init.o (.text) + nand_boot_fsl_nfc.o (.text) + *(.text) + . = 2K; + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
Jean-Christpohe,
Seems like you missed the last part in my series, could you apply this one as well?
Regards, Magnus
2009/6/13 Magnus Lilja lilja.magnus@gmail.com:
- mx31pdk_nand \
- @mkdir -p $(obj)include
- @if [ -n "$(findstring _nand_,$@)" ]; then \
- echo "#define CONFIG_NAND_U_BOOT" >> $(obj)include/config.h; \
- else \
- echo "#define CONFIG_SKIP_LOWLEVEL_INIT" >> $(obj)include/config.h; \
- echo "#define CONFIG_SKIP_RELOCATE_UBOOT" >> $(obj)include/config.h; \
- fi
- @$(MKCONFIG) -a mx31pdk arm arm1136 mx31pdk freescale mx31
- (C) Copyright 2009 Magnus Lilja lilja.magnus@gmail.com
- project.
- MA 02111-1307 USA
- PDR0_HSP_PODF(3) | PDR0_NFC_PODF(5) | \
- PDR0_IPG_PODF(1) | PDR0_MAX_PODF(3) | \
- PDR0_MCU_PODF(0))
- PLL_MFN(12))
- ESDCTL_DSIZ(2) | ESDCTL_BL(1))
- /* Also setup the Peripheral Port Remap register inside the core */
- ldr r0, =ARM_PPMRR /* start from AIPS 2GB region */
- mcr p15, 0, r0, c15, c2, 4
- write32 IPU_CONF, IPU_CONF_DI_EN
- write32 CCM_CCMR, CCM_CCMR_SETUP
- wait_timer 0x40000
- write32 CCM_CCMR, CCM_CCMR_SETUP | CCMR_MPE
- write32 CCM_CCMR, (CCM_CCMR_SETUP | CCMR_MPE) & ~CCMR_MDS
- /* Set up clock to 532MHz */
- write32 CCM_PDR0, CCM_PDR0_SETUP_532MHZ
- write32 CCM_MPCTL, CCM_MPCTL_SETUP_532MHZ
- write32 CCM_SPCTL, PLL_PD(1) | PLL_MFD(4) | PLL_MFI(12) | PLL_MFN(1)
- /* Set up MX31 DDR pins */
- write32 IOMUXC_SW_PAD_CTL_SDCKE1_SDCLK_SDCLK_B, 0
- write32 IOMUXC_SW_PAD_CTL_CAS_SDWE_SDCKE0, 0
- write32 IOMUXC_SW_PAD_CTL_BCLK_RW_RAS, 0
- write32 IOMUXC_SW_PAD_CTL_CS2_CS3_CS4, 0x1000
- write32 IOMUXC_SW_PAD_CTL_DQM3_EB0_EB1, 0
- write32 IOMUXC_SW_PAD_CTL_DQM0_DQM1_DQM2, 0
- write32 IOMUXC_SW_PAD_CTL_SD29_SD30_SD31, 0
- write32 IOMUXC_SW_PAD_CTL_SD26_SD27_SD28, 0
- write32 IOMUXC_SW_PAD_CTL_SD23_SD24_SD25, 0
- write32 IOMUXC_SW_PAD_CTL_SD20_SD21_SD22, 0
- write32 IOMUXC_SW_PAD_CTL_SD17_SD18_SD19, 0
- write32 IOMUXC_SW_PAD_CTL_SD14_SD15_SD16, 0
- write32 IOMUXC_SW_PAD_CTL_SD11_SD12_SD13, 0
- write32 IOMUXC_SW_PAD_CTL_SD8_SD9_SD10, 0
- write32 IOMUXC_SW_PAD_CTL_SD5_SD6_SD7, 0
- write32 IOMUXC_SW_PAD_CTL_SD2_SD3_SD4, 0
- write32 IOMUXC_SW_PAD_CTL_SDBA0_SD0_SD1, 0
- write32 IOMUXC_SW_PAD_CTL_A24_A25_SDBA1, 0
- write32 IOMUXC_SW_PAD_CTL_A21_A22_A23, 0
- write32 IOMUXC_SW_PAD_CTL_A18_A19_A20, 0
- write32 IOMUXC_SW_PAD_CTL_A15_A16_A17, 0
- write32 IOMUXC_SW_PAD_CTL_A12_A13_A14, 0
- write32 IOMUXC_SW_PAD_CTL_A10_MA10_A11, 0
- write32 IOMUXC_SW_PAD_CTL_A7_A8_A9, 0
- write32 IOMUXC_SW_PAD_CTL_A4_A5_A6, 0
- write32 IOMUXC_SW_PAD_CTL_A1_A2_A3, 0
- write32 IOMUXC_SW_PAD_CTL_VPG0_VPG1_A0, 0
- /* Set up MX31 DDR Memory Controller */
- write32 WEIM_ESDMISC, ESDMISC_MDDR_SETUP
- write32 WEIM_ESDCFG0, ESDCFG0_MDDR_SETUP
- /* Perform DDR init sequence */
- write32 WEIM_ESDCTL0, ESDCTL_PRECHARGE
- write32 CSD0_BASE | 0x0f00, 0x12344321
- write32 WEIM_ESDCTL0, ESDCTL_AUTOREFRESH
- write32 CSD0_BASE, 0x12344321
- write32 WEIM_ESDCTL0, ESDCTL_LOADMODEREG
- write8 CSD0_BASE | 0x00000033, 0xda
- write8 CSD0_BASE | 0x01000000, 0xff
- write32 WEIM_ESDCTL0, ESDCTL_RW
- write32 CSD0_BASE, 0xDEADBEEF
- write32 WEIM_ESDMISC, ESDMISC_MDDR_RESET_DL
- mov pc, lr
- program to initialize the SDRAM.
- $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@
- $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@
- cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \
- -Map $(nandobj)u-boot-spl.map \
- -o $@
- $(CC) $(AFLAGS) -c -o $@ $<
- $(CC) $(CFLAGS) -c -o $@ $<
- . = 0x00000000;
- . = ALIGN(4);
- .text :
- start.o (.text)
- lowlevel_init.o (.text)
- nand_boot_fsl_nfc.o (.text)
- *(.text)
- . = 2K;
- . = ALIGN(4);
- .rodata : { *(.rodata) }
- . = ALIGN(4);
- .data : { *(.data) }
- . = ALIGN(4);
- .got : { *(.got) }
- __u_boot_cmd_start = .;
- .u_boot_cmd : { *(.u_boot_cmd) }
- __u_boot_cmd_end = .;
- . = ALIGN(4);
- __bss_start = .;
- .bss : { *(.bss) }
- _end = .;
1.5.6
On 21:11 Mon 29 Jun , Magnus Lilja wrote:
Jean-Christpohe,
I've not I've ask Fabio ack before continue the review as you put it as board Maintainer
Best Regards, J.
2009/6/29 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
Jean-Christpohe,
Ah, ok. I wouldn't mind if you had continued the review while you were at it, I thought you were just waiting for his ACK before adding the last two patches. I could've fixed any issues in the meantime.
/Magnus
- mx31pdk_nand \ qong \ smdk6400 \
I still does not understand this as NAND_SPL already depend on $(obj)include/autoconf.mk
why twice??
PDR0_MCU_PODF(0))
PLL_MFN(12))
those macro need to move too config.h
<snip>
I do not think it's board specific
Best Regards, J.
Hi
- mx31pdk_nand \
I can remove that, as you say NAND_SPL depends on it already.
why twice??
Obviously because I missed that there was one present already. I'll remove.
- PDR0_MCU_PODF(0))
- PLL_MFN(12))
Why? These are specific to this board and only used within this file.
<snip> > + > +# defines $(obj).depend target > +include $(SRCTREE)/rules.mk > + > +sinclude $(obj).depend > + > +######################################################################### > diff --git a/nand_spl/board/freescale/mx31pdk/config.mk b/nand_spl/board/freescale/mx31pdk/config.mk > new file mode 100644 > index 0000000..198cafc > --- /dev/null > +++ b/nand_spl/board/freescale/mx31pdk/config.mk > @@ -0,0 +1,5 @@ > +PAD_TO := 2048 > + > +ifeq ($(debug),1) > +PLATFORM_CPPFLAGS += -DDEBUG > +endif I do not think it's board specific
And what does that comment mean? Should I remove this, move it to another file or what?
I would've appreciated receiving these comments at the same time you reviewed the other patches in the series, that would give me more time to update this.
Thanks, Magnus
- PDR0_MCU_PODF(0))
- PLL_MFN(12))
yes but they are config so it's make sense to put with config and not in the code as we do everytime and a lot's of time we see that the code can be shared but not the define
Personnaly I'll active it manually in the file not via a CPPFLAGS as it will result to active all bebug
Scott what do you think?
Best Regards, J.
Hi
2009/6/30 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
- PDR0_MCU_PODF(0))
- PLL_MFN(12))
So you mean that it should be placed in include/configs/mx31pdk.h?
Yes, I think I can agree on that. So I'll remove the debug stuff from config.mk.
Regards, Magnus
On 21:29 Tue 30 Jun , Magnus Lilja wrote:
Hi
- PDR0_MCU_PODF(0))
- PLL_MFN(12))
yes
Best Regards, J.
I don't think we should do anything differently from the rest of U-Boot here.
-Scott
Hi
2009/6/30 Scott Wood scottwood@freescale.com:
Well, that's not easy since the rest of U-boot does it in different ways, i.e. some boards have the debug stuff and some don't. As an example all boards in nand_spl/board/{amcc,samsung}/* have that while the rest don't have it.
On 07:48 Wed 01 Jul , Magnus Lilja wrote:
Hi
so we need a common rule IMHO define it manually in each file you want to debug make more sense
Scoot for you?
Best Regards, J.
Scoot for you?
If we want to have something makefile based it should be done consistently throughout u-boot. If we're not going to do that, then I agree, do it manually inside each file you want to debug.
-Scott
- mx31pdk i.MX31
Fabio could you ack it please
- mx31pdk \ qong \ smdk6400 \
- (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de
- project.
- MA 02111-1307 USA
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- /* CS5: CPLD incl. network controller */
- __REG(CSCR_U(5)) = 0x0000d843;
we need to remove this __REG ok for this time but a clean up is really needed
Best Regards, J.
- mx31pdk i.MX31
ping
Best Regards, J.
Applied to u-boot/arm
Best Regards, J.
Applied to u-boot-arm
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
All your postings like these seem to be missing any thread infor- mation - there is neither a "References: " nor any "In-reply-to: " header in them. This means thatit is pretty difficult to find out to which message they actually refer to.
Please make sure to configure your mailer such that it adds such "References: " headers, or use a different MUA.
Best Regards, J.
Dear Magnus Lilja,
In message 6fd22327241accc2efcada8380923c8e9c523790.1244918138.git.lilja.magnus@gmail.com you wrote:
Sorry for the late comment...
- These macros provide a convenient way to write 8, 16 and 32 bit data
- to any address.
I think this comment might be wrong. It should probably read "... to any _memory_ address". Using these macros to access device registers and the like is probably nore recommended?
Please comment...
On 21:33 Tue 07 Jul , Wolfgang Denk wrote:
Dear Magnus Lilja,
- to any address.
you can access cpu register without problem with these macros
Best Regards, J.
- to any address.
Is it guaranteed that none of the existing ARM architectures and all the plethora of their specific implementations of the zillions of SoCs do not require any form of memory barrier instructions when accessing device registers? Even when these are external peripherals on some external bus?
Sorry for such a stupid question about things that are eventually obvious to you, but I don't know ARM processors that well...
- to any address.
you may need it in specific case as cache, tlb, co-processor or smp otherwise you do not need it
so normaly no-need for register access
Best Regards, J.
Best Regards, J.
Best Regards, J.
Hi
Hi all,
Any chance this can be merged soon? It applies on u-boot master and runs fine. u-boot-arm/next is missing an apollon patch that fixes a typo, but with that patch it applies fine on u-boot-arm/next as well.
Regards, Magnus
On 22:09 Thu 18 Jun , Magnus Lilja wrote:
Hi
Hi all,
This is the latest set of patches that introduces NAND boot support for the i.MX31 CPU in general and the PDK board especially.
sorry I no time actually I'll take a llok on it this WE
Best Regards, J.
Magnus Lilja
Scott Wood
