[U-Boot] [PATCH v1] fs: do_load: pass device path for efi payload
fatload command can be used to load the EFI payload since EFI system partition is always a FAT partition. Call into EFI code from do_load() to set the device path from which the last binary was loaded. An EFI application like grub2 can’t find its configuration file without the device path set.
Since device path is now set in do_load() there is no need to set it in do_load_wrapper() for the load command.
Signed-off-by: Mian Yousaf Kaukab ykaukab@suse.de --- Changes for v1: - Move efi_set_bootdev() call to do_load() - Rename patch from "cmd: fat: fatload: pass device path for efi payload"
cmd/fs.c | 5 ----- fs/fs.c | 5 +++++ 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cmd/fs.c b/cmd/fs.c index aaafbf9b52..db74767b7b 100644 --- a/cmd/fs.c +++ b/cmd/fs.c @@ -8,7 +8,6 @@ #include <common.h> #include <command.h> #include <fs.h> -#include <efi_loader.h>
static int do_size_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -26,10 +25,6 @@ U_BOOT_CMD( static int do_load_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { -#ifdef CONFIG_CMD_BOOTEFI - efi_set_bootdev(argv[1], (argc > 2) ? argv[2] : "", - (argc > 4) ? argv[4] : ""); -#endif return do_load(cmdtp, flag, argc, argv, FS_TYPE_ANY); }
diff --git a/fs/fs.c b/fs/fs.c index 736ebef4a9..48d8f1f6da 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -17,6 +17,7 @@ #include <asm/io.h> #include <div64.h> #include <linux/math64.h> +#include <efi_loader.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -700,6 +701,10 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], else pos = 0;
+#ifdef CONFIG_CMD_BOOTEFI + efi_set_bootdev(argv[1], (argc > 2) ? argv[2] : "", + (argc > 4) ? argv[4] : ""); +#endif time = get_timer(0); ret = _fs_read(filename, addr, pos, bytes, 1, &len_read); time = get_timer(time);
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Mian Yousaf Kaukab
