[U-Boot] [PATCH v2 1/2] Errata/ARM57: Add basic constructs to handle and apply A57 specific erratas
This patch adds basic constructs in the ARMv8 u-boot code to handle and apply Cortex-A57 specific erratas.
As and example, the framework showcases how erratas 833069, 826974 and 828024 can be handled and applied.
Later on this framework can be extended to include other erratas.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com --- Changes from v1: - Addressed York's comment about x29 usage and calling the core errata fxup function before the lowlevel_init function is called.
arch/arm/cpu/armv8/start.S | 51 ++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/macro.h | 20 +++++++++++++++++ 2 files changed, 71 insertions(+)
diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 4b11aa4..df532f9 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -67,6 +67,9 @@ reset: msr cpacr_el1, x0 /* Enable FP/SIMD */ 0:
+ /* Apply ARM core specific erratas */ + bl apply_core_errata + /* * Cache/BPB/TLB Invalidate * i-cache is invalidated before enabled in icache_enable() @@ -97,6 +100,54 @@ master_cpu:
+WEAK(apply_core_errata) + + /* For now, we support Cortex-A57 specific errata only */ + + /* Check if we are running on a Cortex-A57 core */ + branch_if_a57_core x0, 1f + b 2f +1: + bl apply_a57_core_errata + +2: + ret +ENDPROC(apply_core_errata) + +/*-----------------------------------------------------------------------*/ + +WEAK(apply_a57_core_errata) + +#ifdef CONFIG_ARM_ERRATA_828024 + mrs x0, S3_1_c15_c2_0 /* cpuactlr_el1 */ + /* Disable non-allocate hint of w-b-n-a memory type */ + mov x0, #0x1 << 49 + /* Disable write streaming no L1-allocate threshold */ + mov x0, #0x3 << 25 + /* Disable write streaming no-allocate threshold */ + mov x0, #0x3 << 27 + msr S3_1_c15_c2_0, x0 /* cpuactlr_el1 */ +#endif + +#ifdef CONFIG_ARM_ERRATA_826974 + mrs x0, S3_1_c15_c2_0 /* cpuactlr_el1 */ + /* Disable speculative load execution ahead of a DMB */ + mov x0, #0x1 << 59 + msr S3_1_c15_c2_0, x0 /* cpuactlr_el1 */ +#endif + +#ifdef CONFIG_ARM_ERRATA_833069 + mrs x0, S3_1_c15_c2_0 /* cpuactlr_el1 */ + /* Disable Enable Invalidates of BTB bit */ + and x0, x0, #0xE + msr S3_1_c15_c2_0, x0 /* cpuactlr_el1 */ +#endif + + ret +ENDPROC(apply_a57_core_errata) + +/*-----------------------------------------------------------------------*/ + WEAK(lowlevel_init) mov x29, lr /* Save LR */
diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index 1c8c425..13bae37 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -74,6 +74,26 @@ lr .req x30 .endm
/* + * Branch if current processor is a Cortex-A57 core. + */ +.macro branch_if_a57_core, xreg, a57_label + mrs \xreg, midr_el1 + lsr \xreg, \xreg, #4 + cmp \xreg, #0xD07 /* Cortex-A57 MPCore processor. */ + b.eq \a57_label +.endm + +/* + * Branch if current processor is a Cortex-A53 core. + */ +.macro branch_if_a53_core, xreg, a53_label + mrs \xreg, midr_el1 + lsr \xreg, \xreg, #4 + cmp \xreg, #0xD03 /* Cortex-A53 MPCore processor. */ + b.eq \a53_label +.endm + +/* * Branch if current processor is a slave, * choose processor with all zero affinity value as the master. */
This patch adds support for handling 828024 and 826974 erratas for Cortex-A57 cores present on LS2085A SoC.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com --- include/configs/ls2085a_common.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 6fe032c..01c8566 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -14,6 +14,10 @@ #define CONFIG_LS2085A #define CONFIG_GICV3
+/* Errata fixes */ +#define CONFIG_ARM_ERRATA_828024 +#define CONFIG_ARM_ERRATA_826974 + /* Link Definitions */ #define CONFIG_SYS_TEXT_BASE 0x30001000
Changes from v1:
- /* Apply ARM core specific erratas */
- bl apply_core_errata
- Cache/BPB/TLB Invalidate
- i-cache is invalidated before enabled in icache_enable()
- /* For now, we support Cortex-A57 specific errata only */
- /* Check if we are running on a Cortex-A57 core */
- branch_if_a57_core x0, 1f
- b 2f
+1:
- bl apply_a57_core_errata
+2:
- ret
Bhupesh,
Have you tested the new code? I don't think it handles LR correctly. Your code will be stuck.
York
Hi York,
-----Original Message----- From: Sun York-R58495 Sent: Wednesday, January 14, 2015 9:44 PM On 01/14/2015 05:46 AM, Bhupesh Sharma wrote:
Changes from v1:
- i-cache is invalidated before enabled in icache_enable() @@ -
97,6
- b 2f
+1:
+2:
- ret
Bhupesh,
Yes, I have tested this on both the LS2085A simulator and emulator platforms. On emulator I tried u-boot boot-to-prompt and on simulator I tried linux boot-to-prompt. Both seem to be working fine.
Regards, Bhupesh
On Thu, Jan 15, 2015 at 06:10:57AM +0000, bhupesh.sharma@freescale.com wrote:
Hi York,
Changes from v1:
97,6
- b 2f
+1:
+2:
- ret
Bhupesh,
Has the apply_a57_core_errata function definitely been called in your tests?
If so the lr should point immediately after it (i.e. at the ret), and so the ret should branch to itself, repeatedly.
Mark.
Hi Mark,
-----Original Message----- From: Mark Rutland [mailto:mark.rutland@arm.com] Sent: Friday, January 16, 2015 12:35 AM To: Sharma Bhupesh-B45370 Cc: Sun York-R58495; u-boot@lists.denx.de; albert.u.boot@aribaud.net; Wood Scott-B07421; Yoder Stuart-B08248 Subject: Re: [U-Boot] [PATCH v2 1/2] Errata/ARM57: Add basic constructs to handle and apply A57 specific erratas
Hi York,
Changes from v1:
97,6
- b 2f
+1:
+2:
- ret
Bhupesh,
platforms.
Thanks for the pointers. Let me connect a debugger and see the step-by-step flow through the apply_a57_core_errata.
I will revert with the findings soon.
Regards, Bhupesh
Hi York,
Changes from v1:
97,6
- b 2f
+1:
+2:
- ret
Bhupesh,
That's what I thought. I wonder how Bhupesh tested on the simulator.
York
Changes from v1:
- b 2f
+1:
+2:
This is awkward. How often are you expecting to use this macro? Why not just open-code it? Or at least make it "branch_if_not_a57_core". Or fix your lr problem by doing "branch_if_a57_core apply_a57_core_errata" and having it branch back rather than "ret".
But I think opencoding would be best. Just define symbols for the actual core IDs.
Why is this weak?
-Scott
b 2f
+1:
+2:
How about implementing a table mapping core IDs to entry points (of the "apply_*_core_errata" fns) and iterating over that table here? That will make it easy to add new cores in future too.
Thanks Arnab
Why is this weak?
-Scott
participants (6)
Arnab Basu
Bhupesh Sharma
bhupesh.sharmaï¼ freescale.com
Mark Rutland
Scott Wood
York Sun
