Dear Tom,
The following changes since commit 5dcfc99b2b17fa1497adea47a50bf7c7a6ba5709:
Merge tag 'fsl-qoriq-2023-7-13' of https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq (2023-07-19 07:59:34 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2023-10-rc1-2
for you to fetch changes up to e07368ea57d224557570a6715dcffdbc883a8079:
efi_loader: support all uclasses in device path (2023-07-20 09:12:50 +0200)
Gitlab showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16959
---------------------------------------------------------------- Pull request efi-2023-10-rc1-2
UEFI:
* test: avoid function name 'setup' in capsule tests to not treat it as a fixture * ensure that device paths for USB block devices are unique * enable having multiple EFI_LOADER block devices * use InstallMultipleProtocolInterfaces() in TCG protocol implementation to increase UEFI compliance
---------------------------------------------------------------- Heinrich Schuchardt (4): efi_loader: simplify efi_uninstall_protocol() test: avoid function name 'setup' efi_loader: fix dp_fill() for BLKMAP, HOST, VIRTIO efi_loader: support all uclasses in device path
Ilias Apalodimas (2): efi_loader: use efi_install_multiple_protocol_interfaces() efi_loader: make efi_remove_protocol() static
Masahisa Kojima (1): efi_driver: fix duplicate efiblk#0 issue
include/efi_api.h | 7 +++ include/efi_loader.h | 4 -- lib/efi_driver/efi_block_device.c | 6 +- lib/efi_loader/efi_boottime.c | 15 ++--- lib/efi_loader/efi_device_path.c | 68 +++++++++------------- lib/efi_loader/efi_tcg2.c | 8 +-- test/py/tests/test_efi_capsule/capsule_common.py | 2 +- .../test_efi_capsule/test_capsule_firmware_fit.py | 10 ++-- .../test_efi_capsule/test_capsule_firmware_raw.py | 12 ++-- .../test_capsule_firmware_signed_fit.py | 12 ++-- .../test_capsule_firmware_signed_raw.py | 12 ++-- 11 files changed, 69 insertions(+), 87 deletions(-)
On Thu, Jul 20, 2023 at 01:04:21PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
