[PATCH] imx: ventana: enable ONFI detection to fix NAND chip configuration
Enable ONFI detection to fix NAND chip configuration. Without this the NAND oobsize will be wrong which leads to invalid ECC strength and incompatibility with the previous configuration.
Fixes: 777f333c375a ("imx: ventana: enable dm for MTD and NAND")
Signed-off-by: Tim Harvey tharvey@gateworks.com --- configs/gwventana_nand_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 9fadc014a2c6..42e4f98b13b0 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -106,6 +106,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0xe00000 CONFIG_PHYLIB=y
Hi Tim,
Reviewed-by: Fabio Estevam festevam@denx.de
On Tue, Mar 22, 2022 at 5:32 PM Fabio Estevam festevam@gmail.com wrote:
Hi Tim,
Tom and Stefano,
With commit ed48490f8d3f ("mtd: gpmi: fix the bch setting backward compatible issue") now applied could this be applied for v2022.04 as well to fix NAND on the gw_ventana boards?
Best Regards,
Tim
Hi Tim,
Tom and Stefano,
Yes, thanks.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Tim Harvey
