[U-Boot] ARM Pull request
Hi Wolfgang,
please pull he following changes since commit 7c84fe6a06dad9f793ed85b39b1e6c11a7882f5c: Bartlomiej Sieka (1): Fix to the auto-update feature documentation (CONFIG_UPDATE_TFTP_MSEC_MAX)
git://git.denx.de/u-boot-arm.git master
Jean-Christophe PLAGNIOL-VILLARD (4): move README.nios_CONFIG_SYS_NIOS_CPU to doc FPGA: move fpga drivers to drivers/fpga common/Makefile: create others group for non core, environment and command files Makefile/at91sam9: move some at91sam9 to the correct subsection for arm926ejs
Roman Mashak (2): ARM/Versatile port: Removed unused functions ARM926EJ-S: relocate OMAP specific 'cpuinfo.c' into OMAP directory
Sergey Lapin (1): Custom AFEB9260 board support
Tomohiro Masubuchi (1): Change to use "do_div" macro
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 22 +- board/afeb9260/Makefile | 56 +++++ board/afeb9260/afeb9260.c | 243 ++++++++++++++++++++ board/afeb9260/config.mk | 1 + board/afeb9260/nand.c | 78 +++++++ board/afeb9260/partition.c | 37 +++ board/versatile/versatile.c | 22 -- common/Makefile | 18 +- cpu/arm1136/mx31/interrupts.c | 58 ++++- cpu/arm926ejs/Makefile | 2 +- cpu/arm926ejs/omap/Makefile | 2 +- cpu/arm926ejs/{ => omap}/cpuinfo.c | 0 .../README.nios_CONFIG_SYS_NIOS_CPU | 0 {common => drivers/fpga}/ACEX1K.c | 0 drivers/fpga/Makefile | 58 +++++ {common => drivers/fpga}/altera.c | 0 {common => drivers/fpga}/cyclon2.c | 0 {common => drivers/fpga}/fpga.c | 0 {common => drivers/fpga}/spartan2.c | 0 {common => drivers/fpga}/spartan3.c | 0 {common => drivers/fpga}/stratixII.c | 0 {common => drivers/fpga}/virtex2.c | 0 {common => drivers/fpga}/xilinx.c | 0 include/configs/afeb9260.h | 169 ++++++++++++++ 26 files changed, 712 insertions(+), 59 deletions(-) create mode 100644 board/afeb9260/Makefile create mode 100644 board/afeb9260/afeb9260.c create mode 100644 board/afeb9260/config.mk create mode 100644 board/afeb9260/nand.c create mode 100644 board/afeb9260/partition.c rename cpu/arm926ejs/{ => omap}/cpuinfo.c (100%) rename README.nios_CONFIG_SYS_NIOS_CPU => doc/README.nios_CONFIG_SYS_NIOS_CPU (100%) rename {common => drivers/fpga}/ACEX1K.c (100%) create mode 100644 drivers/fpga/Makefile rename {common => drivers/fpga}/altera.c (100%) rename {common => drivers/fpga}/cyclon2.c (100%) rename {common => drivers/fpga}/fpga.c (100%) rename {common => drivers/fpga}/spartan2.c (100%) rename {common => drivers/fpga}/spartan3.c (100%) rename {common => drivers/fpga}/stratixII.c (100%) rename {common => drivers/fpga}/virtex2.c (100%) rename {common => drivers/fpga}/xilinx.c (100%) create mode 100644 include/configs/afeb9260.h
Dear Jean-Christophe PLAGNIOL-VILLARD,
I will merge your tree, but I'm not happy about it.
None of these patches should be present in the ARM repository.
Makefile/at91sam9 should be in the AT91 repo.
The other patches were not your responsibility. You should not have applied these at all.
Please do NOT do this again.
Applied, thanks.
Any feedback about the nomadik 8815 patch? It's not in the pull request
thanks /alessandro
Alessandro Rubini
