[PATCH] board: ti: j722s: Update Resource Management configs
Update J722S Resource Management configs to the latest output generated by K3 Resource Partitioning tool. Main change includes allocating more BCDMA channels to A53 for CSI2RX to support 4 x CSIRX capture instance simultaneously.
Signed-off-by: Vaishnav Achath vaishnav.a@ti.com ---
Test logs (CSI capture + RM config dump): https://gist.github.com/vachath/7b37cd288ef16ad8a2ac6ff5710d1e9a
board/ti/j722s/rm-cfg.yaml | 48 ++++++++++++++++++++++----------- board/ti/j722s/tifs-rm-cfg.yaml | 28 +++++++++++++------ 2 files changed, 53 insertions(+), 23 deletions(-)
diff --git a/board/ti/j722s/rm-cfg.yaml b/board/ti/j722s/rm-cfg.yaml index 21ca30104c..e32beb8479 100644 --- a/board/ti/j722s/rm-cfg.yaml +++ b/board/ti/j722s/rm-cfg.yaml @@ -244,7 +244,7 @@ rm-cfg: subhdr: magic: 0x7B25 size: 8 - resasg_entries_size: 1160 + resasg_entries_size: 1184 reserved: 0 resasg_entries: - @@ -1017,13 +1017,13 @@ rm-cfg: reserved: 0 - start_resource: 8 - num_resource: 12 + num_resource: 32 type: 12750 host_id: 12 reserved: 0 - - start_resource: 20 - num_resource: 20 + start_resource: 8 + num_resource: 32 type: 12750 host_id: 38 reserved: 0 @@ -1035,13 +1035,13 @@ rm-cfg: reserved: 0 - start_resource: 0 - num_resource: 12 + num_resource: 32 type: 12769 host_id: 12 reserved: 0 - - start_resource: 12 - num_resource: 20 + start_resource: 0 + num_resource: 32 type: 12769 host_id: 38 reserved: 0 @@ -1053,10 +1053,22 @@ rm-cfg: reserved: 0 - start_resource: 0 - num_resource: 8 + num_resource: 2 type: 12810 host_id: 12 reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 12810 + host_id: 20 + reserved: 0 + - + start_resource: 4 + num_resource: 2 + type: 12810 + host_id: 22 + reserved: 0 - start_resource: 22 num_resource: 18 @@ -1065,21 +1077,27 @@ rm-cfg: reserved: 0 - start_resource: 12288 - num_resource: 64 + num_resource: 56 type: 12813 host_id: 12 reserved: 0 - - start_resource: 12352 - num_resource: 64 + start_resource: 12344 + num_resource: 48 type: 12813 - host_id: 38 + host_id: 20 reserved: 0 - - start_resource: 12416 - num_resource: 88 + start_resource: 12392 + num_resource: 48 type: 12813 - host_id: 128 + host_id: 22 + reserved: 0 + - + start_resource: 12440 + num_resource: 64 + type: 12813 + host_id: 38 reserved: 0 - start_resource: 1536 diff --git a/board/ti/j722s/tifs-rm-cfg.yaml b/board/ti/j722s/tifs-rm-cfg.yaml index 5e8d7e0444..4a2af0ebca 100644 --- a/board/ti/j722s/tifs-rm-cfg.yaml +++ b/board/ti/j722s/tifs-rm-cfg.yaml @@ -244,7 +244,7 @@ tifs-rm-cfg: subhdr: magic: 0x7B25 size: 8 - resasg_entries_size: 976 + resasg_entries_size: 992 reserved: 0 resasg_entries: - @@ -897,13 +897,13 @@ tifs-rm-cfg: reserved: 0 - start_resource: 8 - num_resource: 12 + num_resource: 32 type: 12750 host_id: 12 reserved: 0 - - start_resource: 20 - num_resource: 20 + start_resource: 8 + num_resource: 32 type: 12750 host_id: 38 reserved: 0 @@ -915,13 +915,13 @@ tifs-rm-cfg: reserved: 0 - start_resource: 0 - num_resource: 12 + num_resource: 32 type: 12769 host_id: 12 reserved: 0 - - start_resource: 12 - num_resource: 20 + start_resource: 0 + num_resource: 32 type: 12769 host_id: 38 reserved: 0 @@ -933,10 +933,22 @@ tifs-rm-cfg: reserved: 0 - start_resource: 0 - num_resource: 8 + num_resource: 2 type: 12810 host_id: 12 reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 12810 + host_id: 20 + reserved: 0 + - + start_resource: 4 + num_resource: 2 + type: 12810 + host_id: 22 + reserved: 0 - start_resource: 22 num_resource: 18
Hello Vaishnav,
Reviewed-by: Jayesh Choudhary j-choudhary@ti.com
num_resource: 12
start_resource: 20
num_resource: 20
start_resource: 8
num_resource: 12
start_resource: 12
num_resource: 20
start_resource: 0
num_resource: 8
start_resource: 2
num_resource: 2
type: 12810
host_id: 20
reserved: 0
start_resource: 4
num_resource: 2
type: 12810
host_id: 22
num_resource: 64
num_resource: 64
host_id: 38
num_resource: 88
host_id: 128
host_id: 22
reserved: 0
num_resource: 64
type: 12813
num_resource: 12
start_resource: 20
num_resource: 20
start_resource: 8
num_resource: 12
start_resource: 12
num_resource: 20
start_resource: 0
num_resource: 8
start_resource: 2
num_resource: 2
type: 12810
host_id: 20
reserved: 0
start_resource: 4
num_resource: 2
type: 12810
host_id: 22
Jayesh Choudhary
Vaishnav Achath
