[PATCH] board: rockchip: Add support for Rock Pi S
Add support for the Radxa Rock Pi S RK3308 SBC.
Signed-off-by: Angelo Compagnucci angelo@amarulasolutions.com --- arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi | 21 ++++ arch/arm/dts/rk3308-rock-pi-s.dts | 115 ++++++++++++++++++++++ arch/arm/mach-rockchip/rk3308/Kconfig | 5 + board/radxa/rock-pi-s/Kconfig | 15 +++ board/radxa/rock-pi-s/MAINTAINERS | 8 ++ board/radxa/rock-pi-s/Makefile | 7 ++ board/radxa/rock-pi-s/rock-pi-s.c | 6 ++ configs/rock-pi-s-rk3308_defconfig | 88 +++++++++++++++++ doc/README.rockchip | 7 ++ include/configs/rock-pi-s.h | 15 +++ include/configs/rock-pi-s_rk3308.h | 15 +++ 11 files changed, 302 insertions(+) create mode 100644 arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts create mode 100644 board/radxa/rock-pi-s/Kconfig create mode 100644 board/radxa/rock-pi-s/MAINTAINERS create mode 100644 board/radxa/rock-pi-s/Makefile create mode 100644 board/radxa/rock-pi-s/rock-pi-s.c create mode 100644 configs/rock-pi-s-rk3308_defconfig create mode 100644 include/configs/rock-pi-s.h create mode 100644 include/configs/rock-pi-s_rk3308.h
diff --git a/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi b/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi new file mode 100644 index 0000000000..b6f18824ba --- /dev/null +++ b/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 Angelo Compagnucci angelo@amarulasolutions.com + */ +#include "rk3308-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; + clock-frequency = <24000000>; + status = "okay"; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3308-rock-pi-s.dts b/arch/arm/dts/rk3308-rock-pi-s.dts new file mode 100644 index 0000000000..5880fec8fe --- /dev/null +++ b/arch/arm/dts/rk3308-rock-pi-s.dts @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Angelo Compagnucci angelo@amarulasolutions.com + */ + +/dts-v1/; +#include "rk3308.dtsi" + +/ { + model = "Radxa ROCK Pi S"; + compatible = "radxa,rockpis", "rockchip,rk3308"; + + aliases { + mmc0 = &emmc; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial0:1500000n8"; + }; + + vcc_1v8: vcc-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_io: vcc-io { + compatible = "regulator-fixed"; + regulator-name = "vcc_io"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc_ddr: vcc-ddr { + compatible = "regulator-fixed"; + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vdd_core: vdd-core { + compatible = "pwm-regulator"; + pwms = <&pwm0 0 5000 1>; + pwm-supply = <&vcc5v0_sys>; + regulator-name = "vdd_core"; + regulator-min-microvolt = <827000>; + regulator-max-microvolt = <1340000>; + regulator-init-microvolt = <1015000>; + regulator-settling-time-up-us = <250>; + regulator-always-on; + regulator-boot-on; + }; + +}; + +&cpu0 { + cpu-supply = <&vdd_core>; +}; + +&emmc { + bus-width = <4>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + non-removable; + vmmc-supply = <&vcc_io>; + status = "okay"; +}; + +&mac { + clock_in_out = "output"; + phy-supply = <&vcc_io>; + snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 50000 50000>; + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&pwm0 { + status = "okay"; + pinctrl-0 = <&pwm0_pin_pull_down>; +}; + +&saradc { + vref-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdmmc { + cap-sd-highspeed; + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3308/Kconfig b/arch/arm/mach-rockchip/rk3308/Kconfig index 194353e4cd..8ca696181b 100644 --- a/arch/arm/mach-rockchip/rk3308/Kconfig +++ b/arch/arm/mach-rockchip/rk3308/Kconfig @@ -8,6 +8,10 @@ config TARGET_ROC_RK3308_CC bool "Firefly roc-rk3308-cc" select BOARD_LATE_INIT
+config TARGET_ROCK_PI_S + bool "Radxa Rock PI S" + select BOARD_LATE_INIT + config ROCKCHIP_BOOT_MODE_REG default 0xff000500
@@ -25,5 +29,6 @@ config SPL_SERIAL
source "board/rockchip/evb_rk3308/Kconfig" source "board/firefly/firefly-rk3308/Kconfig" +source "board/radxa/rock-pi-s/Kconfig"
endif diff --git a/board/radxa/rock-pi-s/Kconfig b/board/radxa/rock-pi-s/Kconfig new file mode 100644 index 0000000000..de5b71a66b --- /dev/null +++ b/board/radxa/rock-pi-s/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK_PI_S + +config SYS_BOARD + default "rock-pi-s" + +config SYS_VENDOR + default "radxa" + +config SYS_CONFIG_NAME + default "rock-pi-s" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/radxa/rock-pi-s/MAINTAINERS b/board/radxa/rock-pi-s/MAINTAINERS new file mode 100644 index 0000000000..f139dbceaf --- /dev/null +++ b/board/radxa/rock-pi-s/MAINTAINERS @@ -0,0 +1,8 @@ +FIREFLY +M: Angelo Compagnucci angelo@amarulasolutions.com +S: Maintained +F: arch/arm/dts/rk3288-rock-pi-s.dts +F: arch/arm/dts/rk3288-rock-pi-s-u-boot.dtsi +F: board/radxa/rock-pi-s +F: include/configs/rock-pi-s_rk3308.h +F: configs/rock-pi-s-rk3308_defconfig diff --git a/board/radxa/rock-pi-s/Makefile b/board/radxa/rock-pi-s/Makefile new file mode 100644 index 0000000000..8d2b5ad36e --- /dev/null +++ b/board/radxa/rock-pi-s/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2022 Angelo Compagnucci angelo@amarulasolutions.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += rock-pi-s.o diff --git a/board/radxa/rock-pi-s/rock-pi-s.c b/board/radxa/rock-pi-s/rock-pi-s.c new file mode 100644 index 0000000000..cbd4ab4f32 --- /dev/null +++ b/board/radxa/rock-pi-s/rock-pi-s.c @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* +# (C) Copyright 2022 Angelo Compagnucci angelo@amarulasolutions.com + */ + +#include <common.h> diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig new file mode 100644 index 0000000000..2cbcf90839 --- /dev/null +++ b/configs/rock-pi-s-rk3308_defconfig @@ -0,0 +1,88 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00600000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="rk3308-rock-pi-s" +CONFIG_ROCKCHIP_RK3308=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_TARGET_ROCK_PI_S=y +CONFIG_SPL_STACK_R_ADDR=0xc00000 +CONFIG_DEBUG_UART_BASE=0xFF0A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x800000 +CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_BOOTDELAY=0 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x400000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPT=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_SLEEP is not set +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set diff --git a/doc/README.rockchip b/doc/README.rockchip index 52b5140eca..b60eb80c39 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -46,7 +46,14 @@ Building => export BL31=/path/to/rkbin/bin/rk33/rk3308_bl31_v2.22.elf => make roc-cc-rk3308_defconfig => make CROSS_COMPILE=aarch64-linux-gnu- all + + - idbloader for roc-cc-rk3308 => ./tools/mkimage -n rk3308 -T rksd -d /path/to/rkbin/bin/rk33/rk3308_ddr_589MHz_uart2_m0_v1.26.bin idbloader.img + + - idbloader for rock-pi-s-rk3308 + => ./tools/mkimage -n rk3308 -T rksd -d /path/to/rkbin/bin/rk33/rk3308_ddr_589MHz_uart0_m0_v1.26.bin idbloader.img + + - Finalize idbloader => cat spl/u-boot-spl.bin >> idbloader.img
3. To build RK3399 board: diff --git a/include/configs/rock-pi-s.h b/include/configs/rock-pi-s.h new file mode 100644 index 0000000000..0273e751ce --- /dev/null +++ b/include/configs/rock-pi-s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef __EVB_RK3308_H +#define __EVB_RK3308_H + +#include <configs/rk3308_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif diff --git a/include/configs/rock-pi-s_rk3308.h b/include/configs/rock-pi-s_rk3308.h new file mode 100644 index 0000000000..0273e751ce --- /dev/null +++ b/include/configs/rock-pi-s_rk3308.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef __EVB_RK3308_H +#define __EVB_RK3308_H + +#include <configs/rk3308_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif
Hi Angelo,
1. please add simple description about this board like other new board add;
2. please add mainline kernel commit number or tag for dts;
3. please split tht dts change and board support change into two patches.
Thanks,
- Kever
- (C) Copyright 2022 Angelo Compagnucci angelo@amarulasolutions.com
- chosen {
+&uart0 {
- u-boot,dm-pre-reloc;
- clock-frequency = <24000000>;
- status = "okay";
+&sdmmc {
- Copyright (c) 2022 Angelo Compagnucci angelo@amarulasolutions.com
- model = "Radxa ROCK Pi S";
- compatible = "radxa,rockpis", "rockchip,rk3308";
- aliases {
mmc0 = &emmc;
mmc1 = &sdmmc;
- chosen {
- vcc_1v8: vcc-1v8 {
regulator-boot-on;
- vcc_io: vcc-io {
regulator-boot-on;
- vcc_ddr: vcc-ddr {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vdd_core: vdd-core {
regulator-boot-on;
+&cpu0 {
- cpu-supply = <&vdd_core>;
+&emmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
- non-removable;
- vmmc-supply = <&vcc_io>;
- status = "okay";
+&mac {
- clock_in_out = "output";
- phy-supply = <&vcc_io>;
- snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 50000 50000>;
- status = "okay";
+&i2c1 {
- status = "okay";
+&pwm0 {
- status = "okay";
- pinctrl-0 = <&pwm0_pin_pull_down>;
+&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
+&sdmmc {
- cap-sd-highspeed;
- status = "okay";
- select BOARD_LATE_INIT
- config ROCKCHIP_BOOT_MODE_REG default 0xff000500
+config SYS_BOARD
- default "rock-pi-s"
+config SYS_VENDOR
- default "radxa"
- def_bool y
- To build RK3399 board:
- (C) Copyright 2018 Rockchip Electronics Co., Ltd
Angelo Compagnucci
Kever Yang
