[U-Boot-Users] PCI stopped working on MPC8343
Last week my PCI bus has been running fine showing all devices. Right now no devices are shown on the bus.
I'm using CONFIG_83XX_GENERIC_PCI with common setup code for PCI.
Nothing changed from my side during the last 2 weeks.
Did I miss any changes in u-boot ?
regards, Andre Schwarz Matrix Vision
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Hi Andre and everyone,
I was just about to post on I problem I belatedly found with PCI on our Korat PPC400EPx board. (I believe the same problem exists on the Sequoia board, but have not proved it.) What appears to have broken it was the following patch (I got to use "git bisect" for the first time):
<patch> commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2 Author: Nobuhiro Iwamatsu iwamatsu@nigauri.org Date: Fri Mar 7 16:04:25 2008 +0900
pci: Add CONFIG_PCI_SKIP_HOST_BRIDGE config option
In current source code, when the device number of PCI is 0, process PCI bridge without fail. However, when the device number is 0, it is not PCI always bridge. There are times when device of PCI allocates.
When CONFIG_PCI_SKIP_HOST_BRIDGE is enable, this problem is solved when use this patch.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org Acked-by: Stefan Roese sr@denx.de
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 50ca6b0..7944b66 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -425,6 +425,9 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) dev < PCI_BDF(bus,PCI_MAX_PCI_DEVICES-1,PCI_MAX_PCI_FUNCTIONS-1); dev += PCI_BDF(0,0,1)) { + + /* Bus 0 is not necessarily PCI bridge. */ +#if defined(CONFIG_PCI_SKIP_HOST_BRIDGE) /* Skip our host bridge */ if ( dev == PCI_BDF(hose->first_busno,0,0) ) { #if defined(CONFIG_PCI_CONFIG_HOST_BRIDGE) /* don't skip host bridge */ @@ -434,10 +437,11 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) if (getenv("pciconfighost") == NULL) { continue; /* Skip our host bridge */ } -#else +#else /* CONFIG_PCI_CONFIG_HOST_BRIDGE */ continue; /* Skip our host bridge */ -#endif +#endif /* CONFIG_PCI_CONFIG_HOST_BRIDGE */ } +#endif /* CONFIG_PCI_SKIP_HOST_BRIDGE */
if (PCI_FUNC(dev) && !found_multi) continue; @@ -473,8 +477,11 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) hose->fixup_irq(hose, dev);
#ifdef CONFIG_PCI_SCAN_SHOW +#if defined(CONFIG_PCI_SKIP_HOST_BRIDGE) /* Skip our host bridge */ - if ( dev != PCI_BDF(hose->first_busno,0,0) ) { + if ( dev != PCI_BDF(hose->first_busno,0,0) ) +#endif + { unsigned char int_line;
pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_LINE,
</patch>
The patch changes the behavior of the code _unless_ CONFIG_PCI_SKIP_HOST_BRIDGE is defined. Defining that switch in the Korat configuration fixes the problem. The MPC8323ERDB configuration has also been patched to add the switch, so maybe this is is the cause of your problem as well.
I was going to submit the patch for Korat, but then decided I'd first like to ask Nobuhiro and the group whether it might not be better to change the occurrences of
in "drivers/pci/pci.c" to
#if !defined(CONFIG_PCI_NO_SKIP_HOST_BRIDGE)
That would allow those boards that need to patch to specify it explicity, while leaving the default functionality unchanged.
Comments?
Best regards, Larry
Larry,
you're right - but it doesn't fix my problem.
Thanks, André
<patch> commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2 Author: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Date: Fri Mar 7 16:04:25 2008 +0900
pci: Add CONFIG_PCI_SKIP_HOST_BRIDGE config option In current source code, when the device number of PCI is 0, process PCI bridge without fail. However, when the device number is 0, it is not PCI always bridge. There are times when device of PCI allocates. When CONFIG_PCI_SKIP_HOST_BRIDGE is enable, this problem is solved when use this patch. Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org Acked-by: Stefan Roese sr@denx.de
- /* Bus 0 is not necessarily PCI bridge. */
{ unsigned char int_line; pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_LINE,
</patch>
Comments?
Best regards, Larry
André Schwarz wrote:
Larry,
Thanks, André
<snip>
I'm sorry to hear that. (And it was such a nice theory!)
Best regards, Larry
<snip>
Comments?
Yes, I totally agree. Patches should *not* change the default behavior. We should change it as you suggested. Sorry, I must have missed this.
Nobuhiro, could you please send a new patch to fix this problem?
Thanks.
Best regards, Stefan
Hi, all.
Sorry for the delay.
Comments?
Thank you for your check. It has troubled you with my patch.
I rewirte new patch . Could you please check this patch and confirming the work?
Best regards, Nobuhiro
Nobuhiro Iwamatsu wrote:
Hi, all.
Comments?
Hi Nobuhiro, Stefan, and everyone,
Sorry for the delay in getting back to you. My mail reader thinks your patch is part of your signature, so I missed it the first time around.
I did a quick check using the Sequoia board, and it looks like the patch isn't working there. U-Boot is reporting the class of the bridge as "0680", which I assume is why the patch doesn't skip it.
Nobuhiro and Stefan, do you think we can get a working fix for this into 1.3.3 (even if it is not the final fix)? If not, we should patch Sequoia and Korat to add CONFIG_PCI_SKIP_HOST_BRIDGE so they won't be broken in that release.
Best regards, Larry
Yes, I just gave the new patch a try and noticed (still) a problem on Sequoia. The PCI host bridge (PPC) is listed upon bootup which was not the case with the U-Boot version prior to the first patch.
I definitely hope so. Even though I will probably not find the time to submit a patch to really fix this problem till the scheduled release date. But I will gladly test a patch. :)
Or perhaps we should revert the first patch and give it another try in the next merge-window when/if a new patch is available.
Yes, please. That patch also broke probably all Freescale PowerPC boards. Particularly, without #define CONFIG_PCI_SKIP_HOST_BRIDGE I'm getting these errors from the Linux using PCI 3com driver:
eth4: Host error, FIFO diagnostic register 0000. eth4: PCI bus error, bus status 80000020 eth4: setting full-duplex. [infinite times]
This is MPC8315E-RDB.
At this point, I'm in favor of reverting the patch for this release and letting Nobuhiro put in a temporary board-specific patch for those boards that need the modified functionality.
The if we do a non-board-specific patch for the next window, we won't be rushed to make sure it doesn't break any boards.
Best regards, Larry
In message 20080507163121.GA15435@polina.dev.rtsoft.ru Anton Vorontsov wrote:
I now reverted that patch.
OK. I understood.
Yes, I do not want to release the one that I broke, too.
I made the patch that applied your comment. This patch skips PCI bridge ( Class code : 0x06XX).
Could you check this patch?
Thanks - but note that this will not make it in the v1.3.3 release in any case.
Hi, all.
2008/5/13 Wolfgang Denk wd@denx.de:
Does the developer and Board maintainer get a problem with this patch? Would you test this patch?
Hi, all.
Sorry , I forgot attached patch.
Best regards, Nobuhiro --- In current source code, when the device number of PCI is 0, process PCI bridge without fail. However, when the device number is 0, it is not PCI always bridge. There are times when device of PCI allocates.
This patch add check PCI bridge class.
- 0x0604 PCI to AGP bridge / PCI to PCI bridge - 0x0605 PCI to PCMCIA bridge - 0x0606 Nu Bus bridge - 0x0607 PCMCIA CardBus controller - 0x0608 RACEWay bridge
Signed-off-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- drivers/pci/pci.c | 23 +++++++++++++++-------- 1 files changed, 15 insertions(+), 8 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index b3ae3b1..39ca130 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -425,14 +425,21 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) dev < PCI_BDF(bus,PCI_MAX_PCI_DEVICES-1,PCI_MAX_PCI_FUNCTIONS-1); dev += PCI_BDF(0,0,1)) { + /* Read class register */ + pci_hose_read_config_word(hose, dev, PCI_CLASS_DEVICE, &class); /* Skip our host bridge */ - if ( dev == PCI_BDF(hose->first_busno,0,0) ) { -#if defined(CONFIG_PCI_CONFIG_HOST_BRIDGE) /* don't skip host bridge */ - /* - * Only skip hostbridge configuration if "pciconfighost" is not set - */ - if (getenv("pciconfighost") == NULL) { - continue; /* Skip our host bridge */ + if (dev == PCI_BDF(hose->first_busno,0,0)) { + /* CPU to PCI bridge check */ + if (((class & 0xFF00) == 0x0600) && (class != 0x0680)) +#if defined(CONFIG_PCI_CONFIG_HOST_BRIDGE) /* don't skip host bridge */ + { + /* + * Only skip hostbridge configuration if + * "pciconfighost" is not set + */ + if (getenv("pciconfighost") == NULL) { + continue; /* Skip our host bridge */ + } } #else continue; /* Skip our host bridge */ @@ -474,7 +481,7 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus)
#ifdef CONFIG_PCI_SCAN_SHOW /* Skip our host bridge */ - if ( dev != PCI_BDF(hose->first_busno,0,0) ) { + if (((class & 0xFF00) != 0x0600) || (class == 0x0680)) { unsigned char int_line;
pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_LINE, -- 1.5.5.1
Hi Nobuhiro,
sorry about the late reply.
I now finally took the time to take a closer look at this issue. Your approach doesn't look "clean" to me. To be honsest, the original code isn't "clean" either. But with your addition it really get confusing. At least for me.
So let me summarize what the current code (without your patch) does and perhaps you could write again what exactly you want to fix/change. And please correct me if I am wrong.
Currently, the configuration of the PCI device at BDF == 0,0,0 will be skipped if:
a) CONFIG_PCI_CONFIG_HOST_BRIDGE is not defined
or
b) CONFIG_PCI_CONFIG_HOST_BRIDGE is defined but the env variable "pciconfighost" is not defined
So this PCI device will get configured if:
c) CONFIG_PCI_CONFIG_HOST_BRIDGE is defined and the env variable "pciconfighost" is defined too
If I understand you correctly, then you have some PCI devices at BDF == 0,0,0 that need to be configured (and not skipped). Correct? If this is correct, wouldn't it be enough for you to use "solution" c) from above?
If this is not the case, then please explain again exactly what you need to achieve.
Thanks.
Hi, Stefan.
2008/7/7 Stefan Roese sr@denx.de: - 引用テキストを表示しない -
Hi Nobuhiro,
or
Yes, Your indication is right. And there was the part which I did not understand. But, I think that there is still a problem only by these measures.
For example, BDF == 0,0,0 are not displayed when I validated CONFIG_PCI_SCAN_SHOW.
475 #ifdef CONFIG_PCI_SCAN_SHOW 476 /* Skip our host bridge */ 477 if ( dev != PCI_BDF(hose->first_busno,0,0) ) { 478 unsigned char int_line; 479 480 pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_LINE, 481 &int_line); 482 printf(" %02x %02x %04x %04x %04x %02x\n", 483 PCI_BUS(dev), PCI_DEV(dev), vendor, device, class, 484 int_line); 485 } 486 #endif
I think that it is a problem to handle only "BDF == 0,0,0". I think that I had better check it in Class ID. (Of cource, I understand that my implementation is mean.)
Hi Nobuhiro,
Right, this is a problem.
Yes, switching to this class-ID check would be probably "cleaner". The main problem I see with this is, that we could break backward compatibility. I really don't know if all boards currently using this "Host-Bridge-Skipping" implementation have the class-ID set to 0x0680 (Other bridge type).
So I suggest the following solution: I'll prepare a patch to move this "Skip-device-check" into a separate weak function with the current behavior. You (and others) can then define a custom "Skip-device-check" function in your platform code that overrides this default function.
I'll send this patch to the list in a short while. Please try it out and let me know if this works for you.
Hi Stefan,
in message bc6f41e00806162159hc396149sf11ac0e2497a6b13@mail.gmail.com Nobuhiro Iwamatsu wrote:
Do you have any comments on this? Does it now work on Sequoia et al?
participants (8)
Andre Schwarz
André Schwarz
Anton Vorontsov
Larry Johnson
Nobuhiro Iwamatsu
Nobuhiro Iwamatsu
Stefan Roese
