[U-Boot] [PATCH 1/2] arm: dts: am3517_evm: Sync DTS files with Linux 4.13-RC5
To keep the DTS and DTSI files clean and in sync with Linux, new u-boot.dtsi files are added.
There are some spacing issues in the patch, but they appear to be present in the Linux source files. I'll try to get to fixing them there, and do a future re-sync at a later date.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/am3517-evm-u-boot.dtsi | 12 ++++ arch/arm/dts/am3517-evm.dts | 61 +++++++++++++++++ arch/arm/dts/am3517-u-boot.dtsi | 10 +++ arch/arm/dts/am3517.dtsi | 107 ++++++++++++++++++++++++++++++ arch/arm/dts/am35xx-clocks.dtsi | 128 ++++++++++++++++++++++++++++++++++++ 5 files changed, 318 insertions(+)
diff --git a/arch/arm/dts/am3517-evm-u-boot.dtsi b/arch/arm/dts/am3517-evm-u-boot.dtsi new file mode 100644 index 0000000..24a67db --- /dev/null +++ b/arch/arm/dts/am3517-evm-u-boot.dtsi @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2017 + * Logic PD - http://www.logicpd.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + chosen { + stdout-path = &uart3; + }; +}; diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts new file mode 100644 index 0000000..0e4a125 --- /dev/null +++ b/arch/arm/dts/am3517-evm.dts @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "am3517.dtsi" + +/ { + model = "TI AM3517 EVM (AM3517/05 TMDSEVM3517)"; + compatible = "ti,am3517-evm", "ti,am3517", "ti,omap3"; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256 MB */ + }; + + vmmc_fixed: vmmc { + compatible = "regulator-fixed"; + regulator-name = "vmmc_fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&davinci_emac { + status = "okay"; +}; + +&davinci_mdio { + status = "okay"; +}; + +&i2c1 { + clock-frequency = <400000>; +}; + +&i2c2 { + clock-frequency = <400000>; +}; + +&i2c3 { + clock-frequency = <400000>; +}; + +&mmc1 { + vmmc-supply = <&vmmc_fixed>; + bus-width = <4>; +}; + +&mmc2 { + status = "disabled"; +}; + +&mmc3 { + status = "disabled"; +}; + diff --git a/arch/arm/dts/am3517-u-boot.dtsi b/arch/arm/dts/am3517-u-boot.dtsi new file mode 100644 index 0000000..2190052 --- /dev/null +++ b/arch/arm/dts/am3517-u-boot.dtsi @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2017 + * Logic PD - http://www.logicpd.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +&uart4 { + reg-shift = <2>; +}; diff --git a/arch/arm/dts/am3517.dtsi b/arch/arm/dts/am3517.dtsi new file mode 100644 index 0000000..00da3f2 --- /dev/null +++ b/arch/arm/dts/am3517.dtsi @@ -0,0 +1,107 @@ +/* + * Device Tree Source for am3517 SoC + * + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include "omap3.dtsi" + +/ { + aliases { + serial3 = &uart4; + can = &hecc; + }; + + ocp@68000000 { + am35x_otg_hs: am35x_otg_hs@5c040000 { + compatible = "ti,omap3-musb"; + ti,hwmods = "am35x_otg_hs"; + status = "disabled"; + reg = <0x5c040000 0x1000>; + interrupts = <71>; + interrupt-names = "mc"; + }; + + davinci_emac: ethernet@0x5c000000 { + compatible = "ti,am3517-emac"; + ti,hwmods = "davinci_emac"; + status = "disabled"; + reg = <0x5c000000 0x30000>; + interrupts = <67 68 69 70>; + syscon = <&scm_conf>; + ti,davinci-ctrl-reg-offset = <0x10000>; + ti,davinci-ctrl-mod-reg-offset = <0>; + ti,davinci-ctrl-ram-offset = <0x20000>; + ti,davinci-ctrl-ram-size = <0x2000>; + ti,davinci-rmii-en = /bits/ 8 <1>; + local-mac-address = [ 00 00 00 00 00 00 ]; + }; + + davinci_mdio: ethernet@0x5c030000 { + compatible = "ti,davinci_mdio"; + ti,hwmods = "davinci_mdio"; + status = "disabled"; + reg = <0x5c030000 0x1000>; + bus_freq = <1000000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + uart4: serial@4809e000 { + compatible = "ti,omap3-uart"; + ti,hwmods = "uart4"; + status = "disabled"; + reg = <0x4809e000 0x400>; + interrupts = <84>; + dmas = <&sdma 55 &sdma 54>; + dma-names = "tx", "rx"; + clock-frequency = <48000000>; + }; + + omap3_pmx_core2: pinmux@480025d8 { + compatible = "ti,omap3-padconf", "pinctrl-single"; + reg = <0x480025d8 0x24>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xff1f>; + }; + + hecc: can@5c050000 { + compatible = "ti,am3517-hecc"; + status = "disabled"; + reg = <0x5c050000 0x80>, + <0x5c053000 0x180>, + <0x5c052000 0x200>; + reg-names = "hecc", "hecc-ram", "mbx"; + interrupts = <24>; + clocks = <&hecc_ck>; + }; + }; +}; + +&iva { + status = "disabled"; +}; + +&mailbox { + status = "disabled"; +}; + +&mmu_isp { + status = "disabled"; +}; + +&smartreflex_mpu_iva { + status = "disabled"; +}; + +/include/ "am35xx-clocks.dtsi" +/include/ "omap36xx-am35xx-omap3430es2plus-clocks.dtsi" diff --git a/arch/arm/dts/am35xx-clocks.dtsi b/arch/arm/dts/am35xx-clocks.dtsi new file mode 100644 index 0000000..00dd1f0 --- /dev/null +++ b/arch/arm/dts/am35xx-clocks.dtsi @@ -0,0 +1,128 @@ +/* + * Device Tree Source for OMAP3 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +&scm_clocks { + emac_ick: emac_ick@32c { + #clock-cells = <0>; + compatible = "ti,am35xx-gate-clock"; + clocks = <&ipss_ick>; + reg = <0x032c>; + ti,bit-shift = <1>; + }; + + emac_fck: emac_fck@32c { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&rmii_ck>; + reg = <0x032c>; + ti,bit-shift = <9>; + }; + + vpfe_ick: vpfe_ick@32c { + #clock-cells = <0>; + compatible = "ti,am35xx-gate-clock"; + clocks = <&ipss_ick>; + reg = <0x032c>; + ti,bit-shift = <2>; + }; + + vpfe_fck: vpfe_fck@32c { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&pclk_ck>; + reg = <0x032c>; + ti,bit-shift = <10>; + }; + + hsotgusb_ick_am35xx: hsotgusb_ick_am35xx@32c { + #clock-cells = <0>; + compatible = "ti,am35xx-gate-clock"; + clocks = <&ipss_ick>; + reg = <0x032c>; + ti,bit-shift = <0>; + }; + + hsotgusb_fck_am35xx: hsotgusb_fck_am35xx@32c { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_ck>; + reg = <0x032c>; + ti,bit-shift = <8>; + }; + + hecc_ck: hecc_ck@32c { + #clock-cells = <0>; + compatible = "ti,am35xx-gate-clock"; + clocks = <&sys_ck>; + reg = <0x032c>; + ti,bit-shift = <3>; + }; +}; +&cm_clocks { + ipss_ick: ipss_ick@a10 { + #clock-cells = <0>; + compatible = "ti,am35xx-interface-clock"; + clocks = <&core_l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <4>; + }; + + rmii_ck: rmii_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + + pclk_ck: pclk_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <27000000>; + }; + + uart4_ick_am35xx: uart4_ick_am35xx@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <23>; + }; + + uart4_fck_am35xx: uart4_fck_am35xx@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <23>; + }; +}; + +&cm_clockdomains { + core_l3_clkdm: core_l3_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sdrc_ick>, <&ipss_ick>, <&emac_ick>, <&vpfe_ick>, + <&hsotgusb_ick_am35xx>, <&hsotgusb_fck_am35xx>, + <&hecc_ck>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, + <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>, + <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, + <&uart4_ick_am35xx>, <&uart4_fck_am35xx>; + }; +};
With the device tree ported from Linux 4.13, this enables Driver Model and Device Tree support for the am3517-evm
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/mach-omap2/omap3/Kconfig | 5 +++ board/logicpd/am3517evm/am3517evm.c | 71 ++++++++++++++++++++++++------------- configs/am3517_evm_defconfig | 6 ++-- include/configs/am3517_evm.h | 14 +------- 4 files changed, 57 insertions(+), 39 deletions(-)
diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 11f5f05..4dbf9a2 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -22,6 +22,11 @@ choice
config TARGET_AM3517_EVM bool "AM3517 EVM" + select DM + select DM_SERIAL + select DM_GPIO + select DM_I2C + select DM_MMC
config TARGET_MT_VENTOUX bool "TeeJet Mt.Ventoux" diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index c18a5a3..29f136a 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -12,6 +12,8 @@ */
#include <common.h> +#include <dm.h> +#include <ns16550.h> #include <asm/io.h> #include <asm/omap_musb.h> #include <asm/arch/am35x_def.h> @@ -34,6 +36,22 @@ DECLARE_GLOBAL_DATA_PTR;
#define AM3517_IP_SW_RESET 0x48002598 #define CPGMACSS_SW_RST (1 << 1) +#define PHY_GPIO 30 + +/* This is only needed until SPL gets OF support */ +#ifdef CONFIG_SPL_BUILD +static const struct ns16550_platdata am3517_serial = { + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK, + .fcr = UART_FCR_DEFVAL, +}; + +U_BOOT_DEVICE(am3517_uart) = { + "ns16550_serial", + &am3517_serial +}; +#endif
/* * Routine: board_init @@ -113,30 +131,35 @@ int misc_init_r(void)
am3517_evm_musb_init();
- /* activate PHY reset */ - gpio_direction_output(30, 0); - gpio_set_value(30, 0); - - ctr = 0; - do { - udelay(1000); - ctr++; - } while (ctr < 300); - - /* deactivate PHY reset */ - gpio_set_value(30, 1); - - /* allow the PHY to stabilize and settle down */ - ctr = 0; - do { - udelay(1000); - ctr++; - } while (ctr < 300); - - /* ensure that the module is out of reset */ - reset = readl(AM3517_IP_SW_RESET); - reset &= (~CPGMACSS_SW_RST); - writel(reset,AM3517_IP_SW_RESET); + if (gpio_request(PHY_GPIO, "gpio_30") == 0) { + /* activate PHY reset */ + gpio_direction_output(PHY_GPIO, 0); + gpio_set_value(PHY_GPIO, 0); + + ctr = 0; + do { + udelay(1000); + ctr++; + } while (ctr < 300); + + /* deactivate PHY reset */ + gpio_set_value(PHY_GPIO, 1); + + /* allow the PHY to stabilize and settle down */ + ctr = 0; + do { + udelay(1000); + ctr++; + } while (ctr < 300); + + /* ensure that the module is out of reset */ + reset = readl(AM3517_IP_SW_RESET); + reset &= (~CPGMACSS_SW_RST); + writel(reset, AM3517_IP_SW_RESET); + + /* Free requested GPIO */ + gpio_free(PHY_GPIO); + }
return 0; } diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 920c61c..8ab0186 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -4,11 +4,14 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO_SUPPORT is not set +CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y +CONFIG_DEFAULT_DEVICE_TREE="am3517-evm" CONFIG_BOOTDELAY=10 CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_HUSH_PARSER=y @@ -27,13 +30,12 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_TIME is not set CONFIG_CMD_UBI=y CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y -CONFIG_USB_STORAGE=y # CONFIG_FAT_WRITE is not set CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 708a98f..adb33a9 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -21,6 +21,7 @@ * header. That is 0x800FFFC0--0x80100000 should not be used for any * other needs. */ + #define CONFIG_SYS_TEXT_BASE 0x80100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 @@ -33,16 +34,6 @@
/* Hardware drivers */
-/* NS16550 Configuration */ -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) - -/* select serial console configuration */ -#define CONFIG_CONS_INDEX 3 -#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 -#define CONFIG_SERIAL3 3 /* UART3 on AM3517 EVM */ - - /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
@@ -72,7 +63,6 @@ #endif /* CONFIG_USB_MUSB_AM35X */
/* I2C */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 #define CONFIG_SYS_OMAP24_I2C_SLAVE 1
@@ -250,8 +240,6 @@ #define CONFIG_SPL_FRAMEWORK #undef CONFIG_SPL_TEXT_BASE #define CONFIG_SPL_TEXT_BASE 0x40200000 -#define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ - CONFIG_SPL_TEXT_BASE)
#undef CONFIG_SPL_BSS_START_ADDR #define CONFIG_SPL_BSS_START_ADDR 0x80000000
Tested-by: Derald D. Woods woods.technical@gmail.com
- select DM
- select DM_SERIAL
- select DM_GPIO
- select DM_I2C
- select DM_MMC
- .base = OMAP34XX_UART3,
- .reg_shift = 2,
- .clock = V_NS16550_CLK,
- .fcr = UART_FCR_DEFVAL,
- "ns16550_serial",
- &am3517_serial
+}; +#endif
- Routine: board_init
- ctr = 0;
- do {
udelay(1000);
ctr++;
- ctr = 0;
- do {
udelay(1000);
ctr++;
ctr = 0;
do {
udelay(1000);
ctr++;
ctr = 0;
do {
udelay(1000);
ctr++;
- header. That is 0x800FFFC0--0x80100000 should not be used for any
- other needs.
2.7.4
Signed-off-by: Adam Ford aford173@gmail.com Tested-by: Derald D. Woods woods.technical@gmail.com
- Copyright (C) 2017
- Logic PD - http://www.logicpd.com
- chosen {
- Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
+/dts-v1/;
- model = "TI AM3517 EVM (AM3517/05 TMDSEVM3517)";
- compatible = "ti,am3517-evm", "ti,am3517", "ti,omap3";
- memory@80000000 {
vmmc_fixed: vmmc {
+&davinci_emac {
status = "okay";
+&davinci_mdio {
status = "okay";
+&i2c1 {
- clock-frequency = <400000>;
+&i2c2 {
+&i2c3 {
+&mmc1 {
- vmmc-supply = <&vmmc_fixed>;
- bus-width = <4>;
+&mmc2 {
+&mmc3 {
+&uart4 {
- reg-shift = <2>;
- Device Tree Source for am3517 SoC
- Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
- This file is licensed under the terms of the GNU General Public License
- version 2. This program is licensed "as is" without any warranty of any
- kind, whether express or implied.
- aliases {
serial3 = &uart4;
can = &hecc;
- ocp@68000000 {
interrupts = <71>;
#size-cells = <0>;
interrupts = <84>;
#size-cells = <0>;
<0x5c053000 0x180>,
<0x5c052000 0x200>;
interrupts = <24>;
+&iva {
- status = "disabled";
+&mailbox {
+&mmu_isp {
- Device Tree Source for OMAP3 clock data
- Copyright (C) 2013 Texas Instruments, Inc.
+&scm_clocks {
- emac_ick: emac_ick@32c {
#clock-cells = <0>;
reg = <0x032c>;
ti,bit-shift = <1>;
- emac_fck: emac_fck@32c {
#clock-cells = <0>;
reg = <0x032c>;
ti,bit-shift = <9>;
- vpfe_ick: vpfe_ick@32c {
#clock-cells = <0>;
reg = <0x032c>;
ti,bit-shift = <2>;
- vpfe_fck: vpfe_fck@32c {
#clock-cells = <0>;
reg = <0x032c>;
- hsotgusb_ick_am35xx: hsotgusb_ick_am35xx@32c {
#clock-cells = <0>;
reg = <0x032c>;
ti,bit-shift = <0>;
- hsotgusb_fck_am35xx: hsotgusb_fck_am35xx@32c {
#clock-cells = <0>;
clocks = <&sys_ck>;
reg = <0x032c>;
ti,bit-shift = <8>;
- hecc_ck: hecc_ck@32c {
#clock-cells = <0>;
clocks = <&sys_ck>;
reg = <0x032c>;
ti,bit-shift = <3>;
+}; +&cm_clocks {
- ipss_ick: ipss_ick@a10 {
#clock-cells = <0>;
reg = <0x0a10>;
ti,bit-shift = <4>;
- rmii_ck: rmii_ck {
#clock-cells = <0>;
- pclk_ck: pclk_ck {
#clock-cells = <0>;
- uart4_ick_am35xx: uart4_ick_am35xx@a10 {
#clock-cells = <0>;
reg = <0x0a10>;
- uart4_fck_am35xx: uart4_fck_am35xx@a00 {
#clock-cells = <0>;
reg = <0x0a00>;
+&cm_clockdomains {
- core_l3_clkdm: core_l3_clkdm {
<&hecc_ck>;
- core_l4_clkdm: core_l4_clkdm {
2.7.4
Adam Ford
Derald D. Woods
