[U-Boot] [PATCH 2/5] add TI da8xx support: new arch directory
Create initial contents of the include/asm-arm/arch-da8xx directory:
General hardware definitions.
Signed-off-by: Nick Thompson nick.thompson@gefanuc.com --- Applies to u-boot-ti
include/asm-arm/arch-da8xx/clock.h | 24 +++ include/asm-arm/arch-da8xx/emac_defs.h | 328 ++++++++++++++++++++++++++++++++ include/asm-arm/arch-da8xx/emif_defs.h | 71 +++++++ include/asm-arm/arch-da8xx/hardware.h | 206 ++++++++++++++++++++ include/asm-arm/arch-da8xx/i2c_defs.h | 95 +++++++++ 5 files changed, 724 insertions(+), 0 deletions(-)
diff --git a/include/asm-arm/arch-da8xx/clock.h b/include/asm-arm/arch-da8xx/clock.h new file mode 100644 index 0000000..a9b74f4 --- /dev/null +++ b/include/asm-arm/arch-da8xx/clock.h @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2009 Nick Thompson, GE Fanuc, Ltd. nick.thompson@gefanuc.com + * + * DA8xx clock include header + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ------------------------------------------------------------------------ ---- + */ + +#ifndef __ASSEMBLER__ +int clk_get(unsigned int id); +#endif diff --git a/include/asm-arm/arch-da8xx/emac_defs.h b/include/asm-arm/arch-da8xx/emac_defs.h new file mode 100644 index 0000000..2da0c41 --- /dev/null +++ b/include/asm-arm/arch-da8xx/emac_defs.h @@ -0,0 +1,328 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ------------------------------------------------------------------------ ---- + * + * dm644x_emac.h + * + * TI DaVinci (DM644X) EMAC peripheral driver header for DV-EVM + * + * Copyright (C) 2005 Texas Instruments. + * + * ------------------------------------------------------------------------ ---- + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ------------------------------------------------------------------------ ---- + + * Modifications: + * ver. 1.0: Sep 2005, TI PSP Team - Created EMAC version for uBoot. + * + */ + +#ifndef _DA8XX_EMAC_H_ +#define _DA8XX_EMAC_H_ + +#include <asm/arch/hardware.h> + +#define EMAC_BASE_ADDR DAVINCI_EMAC_CNTRL_REGS_BASE +#define EMAC_WRAPPER_BASE_ADDR DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE +#define EMAC_WRAPPER_RAM_ADDR DAVINCI_EMAC_WRAPPER_RAM_BASE +#define EMAC_MDIO_BASE_ADDR DAVINCI_MDIO_CNTRL_REGS_BASE + +/* MDIO module input frequency */ +#define EMAC_MDIO_BUS_FREQ clk_get(DAVINCI_MDIO_CLKID) + +/* MDIO clock output frequency */ +#define EMAC_MDIO_CLOCK_FREQ 2000000 /* 2.0 MHz */ + +/* Ethernet Min/Max packet size */ +#define EMAC_MIN_ETHERNET_PKT_SIZE 60 +#define EMAC_MAX_ETHERNET_PKT_SIZE 1518 +#define EMAC_PKT_ALIGN 18 /* 1518 + 18 = 1536 (packet aligned on 32 byte boundry) */ + +/* Number of RX packet buffers + * NOTE: Only 1 buffer supported as of now + */ +#define EMAC_MAX_RX_BUFFERS 10 + + +/*********************************************** + ******** Internally used macros *************** + ***********************************************/ + +#define EMAC_CH_TX 1 +#define EMAC_CH_RX 0 + +/* Each descriptor occupies 4 words, lets start RX desc's at 0 and + * reserve space for 64 descriptors max + */ +#define EMAC_RX_DESC_BASE 0x0 +#define EMAC_TX_DESC_BASE 0x1000 + +/* EMAC Teardown value */ +#define EMAC_TEARDOWN_VALUE 0xfffffffc + +/* MII Status Register */ +#define MII_STATUS_REG 1 + +/* Number of statistics registers */ +#define EMAC_NUM_STATS 36 + + +/* EMAC Descriptor */ +typedef volatile struct _emac_desc +{ + u_int32_t next; /* Pointer to next descriptor in chain */ + u_int8_t *buffer; /* Pointer to data buffer */ + u_int32_t buff_off_len; /* Buffer Offset(MSW) and Length(LSW) */ + u_int32_t pkt_flag_len; /* Packet Flags(MSW) and Length(LSW) */ +} emac_desc; + +/* CPPI bit positions */ +#define EMAC_CPPI_SOP_BIT (0x80000000) +#define EMAC_CPPI_EOP_BIT (0x40000000) +#define EMAC_CPPI_OWNERSHIP_BIT (0x20000000) +#define EMAC_CPPI_EOQ_BIT (0x10000000) +#define EMAC_CPPI_TEARDOWN_COMPLETE_BIT (0x08000000) +#define EMAC_CPPI_PASS_CRC_BIT (0x04000000) + +#define EMAC_CPPI_RX_ERROR_FRAME (0x03fc0000) + +#define EMAC_MACCONTROL_RMIISPEED_100 (1 << 15) +#define EMAC_MACCONTROL_MIIEN_ENABLE (0x20) +#define EMAC_MACCONTROL_FULLDUPLEX_ENABLE (0x1) + +#define EMAC_RXMBPENABLE_RXCAFEN_ENABLE (0x200000) +#define EMAC_RXMBPENABLE_RXBROADEN (0x2000) + + +#define MDIO_CONTROL_IDLE (0x80000000) +#define MDIO_CONTROL_ENABLE (0x40000000) +#define MDIO_CONTROL_FAULT_ENABLE (0x40000) +#define MDIO_CONTROL_FAULT (0x80000) +#define MDIO_USERACCESS0_GO (0x80000000) +#define MDIO_USERACCESS0_WRITE_READ (0x0) +#define MDIO_USERACCESS0_WRITE_WRITE (0x40000000) +#define MDIO_USERACCESS0_ACK (0x20000000) + +/* Ethernet MAC Registers Structure */ +typedef struct { + dv_reg TXIDVER; + dv_reg TXCONTROL; + dv_reg TXTEARDOWN; + u_int8_t RSVD0[4]; + dv_reg RXIDVER; + dv_reg RXCONTROL; + dv_reg RXTEARDOWN; + u_int8_t RSVD1[100]; + dv_reg TXINTSTATRAW; + dv_reg TXINTSTATMASKED; + dv_reg TXINTMASKSET; + dv_reg TXINTMASKCLEAR; + dv_reg MACINVECTOR; + u_int8_t RSVD2[12]; + dv_reg RXINTSTATRAW; + dv_reg RXINTSTATMASKED; + dv_reg RXINTMASKSET; + dv_reg RXINTMASKCLEAR; + dv_reg MACINTSTATRAW; + dv_reg MACINTSTATMASKED; + dv_reg MACINTMASKSET; + dv_reg MACINTMASKCLEAR; + u_int8_t RSVD3[64]; + dv_reg RXMBPENABLE; + dv_reg RXUNICASTSET; + dv_reg RXUNICASTCLEAR; + dv_reg RXMAXLEN; + dv_reg RXBUFFEROFFSET; + dv_reg RXFILTERLOWTHRESH; + u_int8_t RSVD4[8]; + dv_reg RX0FLOWTHRESH; + dv_reg RX1FLOWTHRESH; + dv_reg RX2FLOWTHRESH; + dv_reg RX3FLOWTHRESH; + dv_reg RX4FLOWTHRESH; + dv_reg RX5FLOWTHRESH; + dv_reg RX6FLOWTHRESH; + dv_reg RX7FLOWTHRESH; + dv_reg RX0FREEBUFFER; + dv_reg RX1FREEBUFFER; + dv_reg RX2FREEBUFFER; + dv_reg RX3FREEBUFFER; + dv_reg RX4FREEBUFFER; + dv_reg RX5FREEBUFFER; + dv_reg RX6FREEBUFFER; + dv_reg RX7FREEBUFFER; + dv_reg MACCONTROL; + dv_reg MACSTATUS; + dv_reg EMCONTROL; + dv_reg FIFOCONTROL; + dv_reg MACCONFIG; + dv_reg SOFTRESET; + u_int8_t RSVD5[88]; + dv_reg MACSRCADDRLO; + dv_reg MACSRCADDRHI; + dv_reg MACHASH1; + dv_reg MACHASH2; + dv_reg BOFFTEST; + dv_reg TPACETEST; + dv_reg RXPAUSE; + dv_reg TXPAUSE; + u_int8_t RSVD6[16]; + dv_reg RXGOODFRAMES; + dv_reg RXBCASTFRAMES; + dv_reg RXMCASTFRAMES; + dv_reg RXPAUSEFRAMES; + dv_reg RXCRCERRORS; + dv_reg RXALIGNCODEERRORS; + dv_reg RXOVERSIZED; + dv_reg RXJABBER; + dv_reg RXUNDERSIZED; + dv_reg RXFRAGMENTS; + dv_reg RXFILTERED; + dv_reg RXQOSFILTERED; + dv_reg RXOCTETS; + dv_reg TXGOODFRAMES; + dv_reg TXBCASTFRAMES; + dv_reg TXMCASTFRAMES; + dv_reg TXPAUSEFRAMES; + dv_reg TXDEFERRED; + dv_reg TXCOLLISION; + dv_reg TXSINGLECOLL; + dv_reg TXMULTICOLL; + dv_reg TXEXCESSIVECOLL; + dv_reg TXLATECOLL; + dv_reg TXUNDERRUN; + dv_reg TXCARRIERSENSE; + dv_reg TXOCTETS; + dv_reg FRAME64; + dv_reg FRAME65T127; + dv_reg FRAME128T255; + dv_reg FRAME256T511; + dv_reg FRAME512T1023; + dv_reg FRAME1024TUP; + dv_reg NETOCTETS; + dv_reg RXSOFOVERRUNS; + dv_reg RXMOFOVERRUNS; + dv_reg RXDMAOVERRUNS; + u_int8_t RSVD7[624]; + dv_reg MACADDRLO; + dv_reg MACADDRHI; + dv_reg MACINDEX; + u_int8_t RSVD8[244]; + dv_reg TX0HDP; + dv_reg TX1HDP; + dv_reg TX2HDP; + dv_reg TX3HDP; + dv_reg TX4HDP; + dv_reg TX5HDP; + dv_reg TX6HDP; + dv_reg TX7HDP; + dv_reg RX0HDP; + dv_reg RX1HDP; + dv_reg RX2HDP; + dv_reg RX3HDP; + dv_reg RX4HDP; + dv_reg RX5HDP; + dv_reg RX6HDP; + dv_reg RX7HDP; + dv_reg TX0CP; + dv_reg TX1CP; + dv_reg TX2CP; + dv_reg TX3CP; + dv_reg TX4CP; + dv_reg TX5CP; + dv_reg TX6CP; + dv_reg TX7CP; + dv_reg RX0CP; + dv_reg RX1CP; + dv_reg RX2CP; + dv_reg RX3CP; + dv_reg RX4CP; + dv_reg RX5CP; + dv_reg RX6CP; + dv_reg RX7CP; +} emac_regs; + +/* EMAC Wrapper Registers Structure */ +typedef struct { + dv_reg REV; + dv_reg SOFTRESET; + dv_reg INTCONTROL; + dv_reg C0RXTHRESHEN; + dv_reg C0RXEN; + dv_reg C0TXEN; + dv_reg C0MISCEN; + dv_reg C1RXTHRESHEN; + dv_reg C1RXEN; + dv_reg C1TXEN; + dv_reg C1MISCEN; + dv_reg C2RXTHRESHEN; + dv_reg C2RXEN; + dv_reg C2TXEN; + dv_reg C2MISCEN; + dv_reg C0RXTHRESHSTAT; + dv_reg C0RXSTAT; + dv_reg C0TXSTAT; + dv_reg C0MISCSTAT; + dv_reg C1RXTHRESHSTAT; + dv_reg C1RXSTAT; + dv_reg C1TXSTAT; + dv_reg C1MISCSTAT; + dv_reg C2RXTHRESHSTAT; + dv_reg C2RXSTAT; + dv_reg C2TXSTAT; + dv_reg C2MISCSTAT; + dv_reg C0RXIMAX; + dv_reg C0TXIMAX; + dv_reg C1RXIMAX; + dv_reg C1TXIMAX; + dv_reg C2RXIMAX; + dv_reg C2TXIMAX; +} ewrap_regs; + + +/* EMAC MDIO Registers Structure */ +typedef struct { + dv_reg VERSION; + dv_reg CONTROL; + dv_reg ALIVE; + dv_reg LINK; + dv_reg LINKINTRAW; + dv_reg LINKINTMASKED; + u_int8_t RSVD0[8]; + dv_reg USERINTRAW; + dv_reg USERINTMASKED; + dv_reg USERINTMASKSET; + dv_reg USERINTMASKCLEAR; + u_int8_t RSVD1[80]; + dv_reg USERACCESS0; + dv_reg USERPHYSEL0; + dv_reg USERACCESS1; + dv_reg USERPHYSEL1; +} mdio_regs; + +typedef struct +{ + char name[64]; + int (*init)(int phy_addr); + int (*is_phy_connected)(int phy_addr); + int (*get_link_speed)(int phy_addr); + int (*auto_negotiate)(int phy_addr); +} phy_t; + +#endif /* _DA8XX_EMAC_H_ */ diff --git a/include/asm-arm/arch-da8xx/emif_defs.h b/include/asm-arm/arch-da8xx/emif_defs.h new file mode 100644 index 0000000..c91e30c --- /dev/null +++ b/include/asm-arm/arch-da8xx/emif_defs.h @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _EMIF_DEFS_H_ +#define _EMIF_DEFS_H_ + +#include <asm/arch/hardware.h> + +typedef struct { + dv_reg ERCSR; + dv_reg AWCCR; + dv_reg SDBCR; + dv_reg SDRCR; + dv_reg AB1CR; + dv_reg AB2CR; + dv_reg AB3CR; + dv_reg AB4CR; + dv_reg SDTIMR; + dv_reg DDRSR; + dv_reg DDRPHYCR; + dv_reg DDRPHYSR; + dv_reg TOTAR; + dv_reg TOTACTR; + dv_reg DDRPHYID_REV; + dv_reg SDSRETR; + dv_reg EIRR; + dv_reg EIMR; + dv_reg EIMSR; + dv_reg EIMCR; + dv_reg IOCTRLR; + dv_reg IOSTATR; + u_int8_t RSVD0[8]; + dv_reg NANDFCR; + dv_reg NANDFSR; + u_int8_t RSVD1[8]; + dv_reg NANDF1ECC; + dv_reg NANDF2ECC; + dv_reg NANDF3ECC; + dv_reg NANDF4ECC; + u_int8_t RSVD2[60]; + dv_reg NAND4BITECCLOAD; + dv_reg NAND4BITECC1; + dv_reg NAND4BITECC2; + dv_reg NAND4BITECC3; + dv_reg NAND4BITECC4; + dv_reg NANDERRADD1; + dv_reg NANDERRADD2; + dv_reg NANDERRVAL1; + dv_reg NANDERRVAL2; +} emif_registers; + +typedef emif_registers *emifregs; +#endif diff --git a/include/asm-arm/arch-da8xx/hardware.h b/include/asm-arm/arch-da8xx/hardware.h new file mode 100644 index 0000000..ec2176d --- /dev/null +++ b/include/asm-arm/arch-da8xx/hardware.h @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc + * + * Based on hardware.h for DaVinci. Original Copyrights follow. + * + * Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ------------------------------------------------------------------------ - + * + * linux/include/asm-arm/arch-davinci/hardware.h + * + * Copyright (C) 2006 Texas Instruments. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#include <config.h> + +#ifndef __ASSEMBLY__ + +#include <asm/sizes.h> + +#define REG(addr) (*(volatile unsigned int *)(addr)) +#define REG_P(addr) ((volatile unsigned int *)(addr)) + +typedef volatile unsigned int dv_reg; +typedef volatile unsigned int * dv_reg_p; + +#endif + +/* + * Base register addresses + */ +#define DAVINCI_UART0_BASE (0x01c42000) +#define DAVINCI_UART1_BASE (0x01d0c000) +#define DAVINCI_UART2_BASE (0x01d0d000) +#define DAVINCI_I2C0_BASE (0x01c22000) +#define DAVINCI_I2C1_BASE (0x01e28000) +#define DAVINCI_TIMER0_BASE (0x01c20000) +#define DAVINCI_TIMER1_BASE (0x01c21000) +#define DAVINCI_WDOG_BASE (0x01c21000) +#define DAVINCI_PLL_CNTRL0_BASE (0x01c11000) +#define DAVINCI_PSC0_BASE (0x01c10000) +#define DAVINCI_PSC1_BASE (0x01e27000) +#define DAVINCI_SPI0_BASE (0x01c41000) +#define DAVINCI_USB_OTG_BASE (0x01e00000) +#define DAVINCI_SPI1_BASE (0x01e12000) +#define DAVINCI_GPIO_BASE (0x01e26000) +#define DAVINCI_EMAC_CNTRL_REGS_BASE (0x01e23000) +#define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE (0x01e22000) +#define DAVINCI_EMAC_WRAPPER_RAM_BASE (0x01e20000) +#define DAVINCI_MDIO_CNTRL_REGS_BASE (0x01e24000) +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE (0x68000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE (0x40000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE (0x60000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE3_BASE (0x62000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE4_BASE (0x64000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE5_BASE (0x66000000) +#define DAVINCI_DDR_EMIF_CTRL_BASE (0xb0000000) +#define DAVINCI_DDR_EMIF_DATA_BASE (0xc0000000) +#define DAVINCI_INTC_BASE (0xfffee000) +#define DAVINCI_BOOTCFG_BASE (0x01c14000) + +/* Clock IDs */ +#define DAVINCI_PLLM_CLKID (0xFF + 0) +#define DAVINCI_PLLC_CLKID (0xFF + 1) +#define DAVINCI_AUXCLK_CLKID (0xFF + 2) +#define DAVINCI_MDIO_CLKID 4 +#define DAVINCI_SPI0_CLKID 2 +#define DAVINCI_UART2_CLKID 2 +#define DAVINCI_ARM_CLKID 6 + +/* Power and Sleep Controller (PSC) Domains */ +#define DAVINCI_GPSC_ARMDOMAIN 0 +#define DAVINCI_GPSC_DSPDOMAIN 1 + +/* LPSCs in PSC0 */ +#define DAVINCI_LPSC_TPCC 0 +#define DAVINCI_LPSC_TPTC0 1 +#define DAVINCI_LPSC_TPTC1 2 +#define DAVINCI_LPSC_AEMIF 3 +#define DAVINCI_LPSC_SPI0 4 +#define DAVINCI_LPSC_MMC_SD 5 +#define DAVINCI_LPSC_AINTC 6 +#define DAVINCI_LPSC_ARM_RAM_ROM 7 +#define DAVINCI_LPSC_SECCTL_KEYMGR 8 +#define DAVINCI_LPSC_UART0 9 +#define DAVINCI_LPSC_SCR0 10 +#define DAVINCI_LPSC_SCR1 11 +#define DAVINCI_LPSC_SCR2 12 +#define DAVINCI_LPSC_DMAX 13 +#define DAVINCI_LPSC_ARM 14 +#define DAVINCI_LPSC_GEM 15 + +/* for LPSCs in PSC1, 32 + actual id is being used for differentiation */ +#define DAVINCI_LPSC_USB11 (32 + 1) +#define DAVINCI_LPSC_USB20 (32 + 2) +#define DAVINCI_LPSC_GPIO (32 + 3) +#define DAVINCI_LPSC_UHPI (32 + 4) +#define DAVINCI_LPSC_EMAC (32 + 5) +#define DAVINCI_LPSC_DDR_EMIF (32 + 6) +#define DAVINCI_LPSC_McASP0 (32 + 7) +#define DAVINCI_LPSC_McASP1 (32 + 8) +#define DAVINCI_LPSC_McASP2 (32 + 9) +#define DAVINCI_LPSC_SPI1 (32 + 10) +#define DAVINCI_LPSC_I2C1 (32 + 11) +#define DAVINCI_LPSC_UART1 (32 + 12) +#define DAVINCI_LPSC_UART2 (32 + 13) +#define DAVINCI_LPSC_LCDC (32 + 16) +#define DAVINCI_LPSC_ePWM (32 + 17) +#define DAVINCI_LPSC_eCAP (32 + 20) +#define DAVINCI_LPSC_eQEP (32 + 21) +#define DAVINCI_LPSC_SCR_P0 (32 + 22) +#define DAVINCI_LPSC_SCR_P1 (32 + 23) +#define DAVINCI_LPSC_CR_P3 (32 + 26) +#define DAVINCI_LPSC_L3_CBA_RAM (32 + 31) + +/* Some PSC defines */ + +#define PSC0_MDCTL (DAVINCI_PSC0_BASE + 0xa00) +#define PSC0_MDSTAT (DAVINCI_PSC0_BASE + 0x800) +#define PSC0_PTCMD (DAVINCI_PSC0_BASE + 0x120) +#define PSC0_PTSTAT (DAVINCI_PSC0_BASE + 0x128) + +#define PSC1_MDCTL (DAVINCI_PSC1_BASE + 0xa00) +#define PSC1_MDSTAT (DAVINCI_PSC1_BASE + 0x800) +#define PSC1_PTCMD (DAVINCI_PSC1_BASE + 0x120) +#define PSC1_PTSTAT (DAVINCI_PSC1_BASE + 0x128) + +/* Some PLL defines */ +#define PLL0_PLLCTL (DAVINCI_PLL_CNTRL0_BASE + 0x100) +#define PLL0_PLLM (DAVINCI_PLL_CNTRL0_BASE + 0x110) +#define PLL0_PREDIV (DAVINCI_PLL_CNTRL0_BASE + 0x114) +#define PLL0_POSTDIV (DAVINCI_PLL_CNTRL0_BASE + 0x128) +#define PLL0_DIV1 (DAVINCI_PLL_CNTRL0_BASE + 0x118) +#define PLL0_DIV2 (DAVINCI_PLL_CNTRL0_BASE + 0x11c) +#define PLL0_DIV3 (DAVINCI_PLL_CNTRL0_BASE + 0x120) +#define PLL0_DIV4 (DAVINCI_PLL_CNTRL0_BASE + 0x160) +#define PLL0_DIV5 (DAVINCI_PLL_CNTRL0_BASE + 0x164) +#define PLL0_DIV6 (DAVINCI_PLL_CNTRL0_BASE + 0x168) +#define PLL0_DIV7 (DAVINCI_PLL_CNTRL0_BASE + 0x16c) +#define PLL0_DIV8 (DAVINCI_PLL_CNTRL0_BASE + 0x170) +#define PLL0_DIV9 (DAVINCI_PLL_CNTRL0_BASE + 0x114) + +/* Boot config */ +#define PINMUX0 (DAVINCI_BOOTCFG_BASE + 0x120) +#define PINMUX1 (DAVINCI_BOOTCFG_BASE + 0x124) +#define PINMUX2 (DAVINCI_BOOTCFG_BASE + 0x128) +#define PINMUX3 (DAVINCI_BOOTCFG_BASE + 0x12c) +#define PINMUX4 (DAVINCI_BOOTCFG_BASE + 0x130) +#define PINMUX5 (DAVINCI_BOOTCFG_BASE + 0x134) +#define PINMUX6 (DAVINCI_BOOTCFG_BASE + 0x138) +#define PINMUX7 (DAVINCI_BOOTCFG_BASE + 0x13c) +#define PINMUX8 (DAVINCI_BOOTCFG_BASE + 0x140) +#define PINMUX9 (DAVINCI_BOOTCFG_BASE + 0x144) +#define PINMUX10 (DAVINCI_BOOTCFG_BASE + 0x148) +#define PINMUX11 (DAVINCI_BOOTCFG_BASE + 0x14c) +#define PINMUX12 (DAVINCI_BOOTCFG_BASE + 0x150) +#define PINMUX13 (DAVINCI_BOOTCFG_BASE + 0x154) +#define PINMUX14 (DAVINCI_BOOTCFG_BASE + 0x158) +#define PINMUX15 (DAVINCI_BOOTCFG_BASE + 0x15C) +#define PINMUX16 (DAVINCI_BOOTCFG_BASE + 0x160) +#define PINMUX17 (DAVINCI_BOOTCFG_BASE + 0x164) +#define PINMUX18 (DAVINCI_BOOTCFG_BASE + 0x168) +#define PINMUX19 (DAVINCI_BOOTCFG_BASE + 0x16c) +#define SUSPSRC (DAVINCI_BOOTCFG_BASE + 0x170) +#define CFGCHIP0 (DAVINCI_BOOTCFG_BASE + 0x17c) +#define CFGCHIP2 (DAVINCI_BOOTCFG_BASE + 0x184) + +/* Interrupt controller */ +#define INTC_GLB_EN (DAVINCI_INTC_BASE + 0x10) +#define INTC_HINT_EN (DAVINCI_INTC_BASE + 0x1500) +#define INTC_EN_CLR0 (DAVINCI_INTC_BASE + 0x380) + +/* GPIO */ +#define GPIO_BANK4_ADDR 0x01E26000 +#define GPIO_BANK4_REG_DIR_ADDR ( GPIO_BANK4_ADDR + 0x60 ) +#define GPIO_BANK4_REG_OPDATA_ADDR ( GPIO_BANK4_ADDR + 0x64 ) +#define GPIO_BANK4_REG_SET_ADDR ( GPIO_BANK4_ADDR + 0x68 ) +#define GPIO_BANK4_REG_CLR_ADDR ( GPIO_BANK4_ADDR + 0x6C ) + +#endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/include/asm-arm/arch-da8xx/i2c_defs.h b/include/asm-arm/arch-da8xx/i2c_defs.h new file mode 100644 index 0000000..714211f --- /dev/null +++ b/include/asm-arm/arch-da8xx/i2c_defs.h @@ -0,0 +1,95 @@ +/* + * (C) Copyright 2004 + * Texas Instruments, <www.ti.com> + * + * Some changes copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DAVINCI_I2C_H_ +#define _DAVINCI_I2C_H_ + +#define I2C_WRITE 0 +#define I2C_READ 1 + +#define I2C_BASE 0x01c22000 + +#define I2C_OA (I2C_BASE + 0x00) +#define I2C_IE (I2C_BASE + 0x04) +#define I2C_STAT (I2C_BASE + 0x08) +#define I2C_SCLL (I2C_BASE + 0x0c) +#define I2C_SCLH (I2C_BASE + 0x10) +#define I2C_CNT (I2C_BASE + 0x14) +#define I2C_DRR (I2C_BASE + 0x18) +#define I2C_SA (I2C_BASE + 0x1c) +#define I2C_DXR (I2C_BASE + 0x20) +#define I2C_CON (I2C_BASE + 0x24) +#define I2C_IV (I2C_BASE + 0x28) +#define I2C_PSC (I2C_BASE + 0x30) + +/* I2C masks */ + +/* I2C Interrupt Enable Register (I2C_IE): */ +#define I2C_IE_SCD_IE (1 << 5) /* Stop condition detect interrupt enable */ +#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ +#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ +#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ +#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Status Register (I2C_STAT): */ + +#define I2C_STAT_BB (1 << 12) /* Bus busy */ +#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ +#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ +#define I2C_STAT_AAS (1 << 9) /* Address as slave */ +#define I2C_STAT_SCD (1 << 5) /* Stop condition detect */ +#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ +#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ +#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ +#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ + + +/* I2C Interrupt Code Register (I2C_INTCODE): */ + +#define I2C_INTCODE_MASK 7 +#define I2C_INTCODE_NONE 0 +#define I2C_INTCODE_AL 1 /* Arbitration lost */ +#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ +#define I2C_INTCODE_ARDY 3 /* Register access ready */ +#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ +#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ +#define I2C_INTCODE_SCD 6 /* Stop condition detect */ + + +/* I2C Configuration Register (I2C_CON): */ + +#define I2C_CON_EN (1 << 5) /* I2C module enable */ +#define I2C_CON_STB (1 << 4) /* Start byte mode (master mode only) */ +#define I2C_CON_MST (1 << 10) /* Master/slave mode */ +#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode (master mode only) */ +#define I2C_CON_XA (1 << 8) /* Expand address */ +#define I2C_CON_STP (1 << 11) /* Stop condition (master mode only) */ +#define I2C_CON_STT (1 << 13) /* Start condition (master mode only) */ +#define I2C_CON_FREE (1 << 14) /* Free run on emulation */ + +#define I2C_TIMEOUT 0xffff0000 /* Timeout mask for poll_i2c_irq() */ + +#endif
Resent due to wrapping in patch 2 (unwrapped patch 1 resent, 3, 4 and 5 seem okay)
diff --git a/include/asm-arm/arch-da8xx/clock.h b/include/asm-arm/arch-da8xx/clock.h new file mode 100644 index 0000000..a9b74f4 --- /dev/null +++ b/include/asm-arm/arch-da8xx/clock.h @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2009 Nick Thompson, GE Fanuc, Ltd. nick.thompson@gefanuc.com + * + * DA8xx clock include header + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#ifndef __ASSEMBLER__ +int clk_get(unsigned int id); +#endif diff --git a/include/asm-arm/arch-da8xx/emac_defs.h b/include/asm-arm/arch-da8xx/emac_defs.h new file mode 100644 index 0000000..2da0c41 --- /dev/null +++ b/include/asm-arm/arch-da8xx/emac_defs.h @@ -0,0 +1,328 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ---------------------------------------------------------------------------- + * + * dm644x_emac.h + * + * TI DaVinci (DM644X) EMAC peripheral driver header for DV-EVM + * + * Copyright (C) 2005 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + + * Modifications: + * ver. 1.0: Sep 2005, TI PSP Team - Created EMAC version for uBoot. + * + */ + +#ifndef _DA8XX_EMAC_H_ +#define _DA8XX_EMAC_H_ + +#include <asm/arch/hardware.h> + +#define EMAC_BASE_ADDR DAVINCI_EMAC_CNTRL_REGS_BASE +#define EMAC_WRAPPER_BASE_ADDR DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE +#define EMAC_WRAPPER_RAM_ADDR DAVINCI_EMAC_WRAPPER_RAM_BASE +#define EMAC_MDIO_BASE_ADDR DAVINCI_MDIO_CNTRL_REGS_BASE + +/* MDIO module input frequency */ +#define EMAC_MDIO_BUS_FREQ clk_get(DAVINCI_MDIO_CLKID) + +/* MDIO clock output frequency */ +#define EMAC_MDIO_CLOCK_FREQ 2000000 /* 2.0 MHz */ + +/* Ethernet Min/Max packet size */ +#define EMAC_MIN_ETHERNET_PKT_SIZE 60 +#define EMAC_MAX_ETHERNET_PKT_SIZE 1518 +#define EMAC_PKT_ALIGN 18 /* 1518 + 18 = 1536 (packet aligned on 32 byte boundry) */ + +/* Number of RX packet buffers + * NOTE: Only 1 buffer supported as of now + */ +#define EMAC_MAX_RX_BUFFERS 10 + + +/*********************************************** + ******** Internally used macros *************** + ***********************************************/ + +#define EMAC_CH_TX 1 +#define EMAC_CH_RX 0 + +/* Each descriptor occupies 4 words, lets start RX desc's at 0 and + * reserve space for 64 descriptors max + */ +#define EMAC_RX_DESC_BASE 0x0 +#define EMAC_TX_DESC_BASE 0x1000 + +/* EMAC Teardown value */ +#define EMAC_TEARDOWN_VALUE 0xfffffffc + +/* MII Status Register */ +#define MII_STATUS_REG 1 + +/* Number of statistics registers */ +#define EMAC_NUM_STATS 36 + + +/* EMAC Descriptor */ +typedef volatile struct _emac_desc +{ + u_int32_t next; /* Pointer to next descriptor in chain */ + u_int8_t *buffer; /* Pointer to data buffer */ + u_int32_t buff_off_len; /* Buffer Offset(MSW) and Length(LSW) */ + u_int32_t pkt_flag_len; /* Packet Flags(MSW) and Length(LSW) */ +} emac_desc; + +/* CPPI bit positions */ +#define EMAC_CPPI_SOP_BIT (0x80000000) +#define EMAC_CPPI_EOP_BIT (0x40000000) +#define EMAC_CPPI_OWNERSHIP_BIT (0x20000000) +#define EMAC_CPPI_EOQ_BIT (0x10000000) +#define EMAC_CPPI_TEARDOWN_COMPLETE_BIT (0x08000000) +#define EMAC_CPPI_PASS_CRC_BIT (0x04000000) + +#define EMAC_CPPI_RX_ERROR_FRAME (0x03fc0000) + +#define EMAC_MACCONTROL_RMIISPEED_100 (1 << 15) +#define EMAC_MACCONTROL_MIIEN_ENABLE (0x20) +#define EMAC_MACCONTROL_FULLDUPLEX_ENABLE (0x1) + +#define EMAC_RXMBPENABLE_RXCAFEN_ENABLE (0x200000) +#define EMAC_RXMBPENABLE_RXBROADEN (0x2000) + + +#define MDIO_CONTROL_IDLE (0x80000000) +#define MDIO_CONTROL_ENABLE (0x40000000) +#define MDIO_CONTROL_FAULT_ENABLE (0x40000) +#define MDIO_CONTROL_FAULT (0x80000) +#define MDIO_USERACCESS0_GO (0x80000000) +#define MDIO_USERACCESS0_WRITE_READ (0x0) +#define MDIO_USERACCESS0_WRITE_WRITE (0x40000000) +#define MDIO_USERACCESS0_ACK (0x20000000) + +/* Ethernet MAC Registers Structure */ +typedef struct { + dv_reg TXIDVER; + dv_reg TXCONTROL; + dv_reg TXTEARDOWN; + u_int8_t RSVD0[4]; + dv_reg RXIDVER; + dv_reg RXCONTROL; + dv_reg RXTEARDOWN; + u_int8_t RSVD1[100]; + dv_reg TXINTSTATRAW; + dv_reg TXINTSTATMASKED; + dv_reg TXINTMASKSET; + dv_reg TXINTMASKCLEAR; + dv_reg MACINVECTOR; + u_int8_t RSVD2[12]; + dv_reg RXINTSTATRAW; + dv_reg RXINTSTATMASKED; + dv_reg RXINTMASKSET; + dv_reg RXINTMASKCLEAR; + dv_reg MACINTSTATRAW; + dv_reg MACINTSTATMASKED; + dv_reg MACINTMASKSET; + dv_reg MACINTMASKCLEAR; + u_int8_t RSVD3[64]; + dv_reg RXMBPENABLE; + dv_reg RXUNICASTSET; + dv_reg RXUNICASTCLEAR; + dv_reg RXMAXLEN; + dv_reg RXBUFFEROFFSET; + dv_reg RXFILTERLOWTHRESH; + u_int8_t RSVD4[8]; + dv_reg RX0FLOWTHRESH; + dv_reg RX1FLOWTHRESH; + dv_reg RX2FLOWTHRESH; + dv_reg RX3FLOWTHRESH; + dv_reg RX4FLOWTHRESH; + dv_reg RX5FLOWTHRESH; + dv_reg RX6FLOWTHRESH; + dv_reg RX7FLOWTHRESH; + dv_reg RX0FREEBUFFER; + dv_reg RX1FREEBUFFER; + dv_reg RX2FREEBUFFER; + dv_reg RX3FREEBUFFER; + dv_reg RX4FREEBUFFER; + dv_reg RX5FREEBUFFER; + dv_reg RX6FREEBUFFER; + dv_reg RX7FREEBUFFER; + dv_reg MACCONTROL; + dv_reg MACSTATUS; + dv_reg EMCONTROL; + dv_reg FIFOCONTROL; + dv_reg MACCONFIG; + dv_reg SOFTRESET; + u_int8_t RSVD5[88]; + dv_reg MACSRCADDRLO; + dv_reg MACSRCADDRHI; + dv_reg MACHASH1; + dv_reg MACHASH2; + dv_reg BOFFTEST; + dv_reg TPACETEST; + dv_reg RXPAUSE; + dv_reg TXPAUSE; + u_int8_t RSVD6[16]; + dv_reg RXGOODFRAMES; + dv_reg RXBCASTFRAMES; + dv_reg RXMCASTFRAMES; + dv_reg RXPAUSEFRAMES; + dv_reg RXCRCERRORS; + dv_reg RXALIGNCODEERRORS; + dv_reg RXOVERSIZED; + dv_reg RXJABBER; + dv_reg RXUNDERSIZED; + dv_reg RXFRAGMENTS; + dv_reg RXFILTERED; + dv_reg RXQOSFILTERED; + dv_reg RXOCTETS; + dv_reg TXGOODFRAMES; + dv_reg TXBCASTFRAMES; + dv_reg TXMCASTFRAMES; + dv_reg TXPAUSEFRAMES; + dv_reg TXDEFERRED; + dv_reg TXCOLLISION; + dv_reg TXSINGLECOLL; + dv_reg TXMULTICOLL; + dv_reg TXEXCESSIVECOLL; + dv_reg TXLATECOLL; + dv_reg TXUNDERRUN; + dv_reg TXCARRIERSENSE; + dv_reg TXOCTETS; + dv_reg FRAME64; + dv_reg FRAME65T127; + dv_reg FRAME128T255; + dv_reg FRAME256T511; + dv_reg FRAME512T1023; + dv_reg FRAME1024TUP; + dv_reg NETOCTETS; + dv_reg RXSOFOVERRUNS; + dv_reg RXMOFOVERRUNS; + dv_reg RXDMAOVERRUNS; + u_int8_t RSVD7[624]; + dv_reg MACADDRLO; + dv_reg MACADDRHI; + dv_reg MACINDEX; + u_int8_t RSVD8[244]; + dv_reg TX0HDP; + dv_reg TX1HDP; + dv_reg TX2HDP; + dv_reg TX3HDP; + dv_reg TX4HDP; + dv_reg TX5HDP; + dv_reg TX6HDP; + dv_reg TX7HDP; + dv_reg RX0HDP; + dv_reg RX1HDP; + dv_reg RX2HDP; + dv_reg RX3HDP; + dv_reg RX4HDP; + dv_reg RX5HDP; + dv_reg RX6HDP; + dv_reg RX7HDP; + dv_reg TX0CP; + dv_reg TX1CP; + dv_reg TX2CP; + dv_reg TX3CP; + dv_reg TX4CP; + dv_reg TX5CP; + dv_reg TX6CP; + dv_reg TX7CP; + dv_reg RX0CP; + dv_reg RX1CP; + dv_reg RX2CP; + dv_reg RX3CP; + dv_reg RX4CP; + dv_reg RX5CP; + dv_reg RX6CP; + dv_reg RX7CP; +} emac_regs; + +/* EMAC Wrapper Registers Structure */ +typedef struct { + dv_reg REV; + dv_reg SOFTRESET; + dv_reg INTCONTROL; + dv_reg C0RXTHRESHEN; + dv_reg C0RXEN; + dv_reg C0TXEN; + dv_reg C0MISCEN; + dv_reg C1RXTHRESHEN; + dv_reg C1RXEN; + dv_reg C1TXEN; + dv_reg C1MISCEN; + dv_reg C2RXTHRESHEN; + dv_reg C2RXEN; + dv_reg C2TXEN; + dv_reg C2MISCEN; + dv_reg C0RXTHRESHSTAT; + dv_reg C0RXSTAT; + dv_reg C0TXSTAT; + dv_reg C0MISCSTAT; + dv_reg C1RXTHRESHSTAT; + dv_reg C1RXSTAT; + dv_reg C1TXSTAT; + dv_reg C1MISCSTAT; + dv_reg C2RXTHRESHSTAT; + dv_reg C2RXSTAT; + dv_reg C2TXSTAT; + dv_reg C2MISCSTAT; + dv_reg C0RXIMAX; + dv_reg C0TXIMAX; + dv_reg C1RXIMAX; + dv_reg C1TXIMAX; + dv_reg C2RXIMAX; + dv_reg C2TXIMAX; +} ewrap_regs; + + +/* EMAC MDIO Registers Structure */ +typedef struct { + dv_reg VERSION; + dv_reg CONTROL; + dv_reg ALIVE; + dv_reg LINK; + dv_reg LINKINTRAW; + dv_reg LINKINTMASKED; + u_int8_t RSVD0[8]; + dv_reg USERINTRAW; + dv_reg USERINTMASKED; + dv_reg USERINTMASKSET; + dv_reg USERINTMASKCLEAR; + u_int8_t RSVD1[80]; + dv_reg USERACCESS0; + dv_reg USERPHYSEL0; + dv_reg USERACCESS1; + dv_reg USERPHYSEL1; +} mdio_regs; + +typedef struct +{ + char name[64]; + int (*init)(int phy_addr); + int (*is_phy_connected)(int phy_addr); + int (*get_link_speed)(int phy_addr); + int (*auto_negotiate)(int phy_addr); +} phy_t; + +#endif /* _DA8XX_EMAC_H_ */ diff --git a/include/asm-arm/arch-da8xx/emif_defs.h b/include/asm-arm/arch-da8xx/emif_defs.h new file mode 100644 index 0000000..c91e30c --- /dev/null +++ b/include/asm-arm/arch-da8xx/emif_defs.h @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _EMIF_DEFS_H_ +#define _EMIF_DEFS_H_ + +#include <asm/arch/hardware.h> + +typedef struct { + dv_reg ERCSR; + dv_reg AWCCR; + dv_reg SDBCR; + dv_reg SDRCR; + dv_reg AB1CR; + dv_reg AB2CR; + dv_reg AB3CR; + dv_reg AB4CR; + dv_reg SDTIMR; + dv_reg DDRSR; + dv_reg DDRPHYCR; + dv_reg DDRPHYSR; + dv_reg TOTAR; + dv_reg TOTACTR; + dv_reg DDRPHYID_REV; + dv_reg SDSRETR; + dv_reg EIRR; + dv_reg EIMR; + dv_reg EIMSR; + dv_reg EIMCR; + dv_reg IOCTRLR; + dv_reg IOSTATR; + u_int8_t RSVD0[8]; + dv_reg NANDFCR; + dv_reg NANDFSR; + u_int8_t RSVD1[8]; + dv_reg NANDF1ECC; + dv_reg NANDF2ECC; + dv_reg NANDF3ECC; + dv_reg NANDF4ECC; + u_int8_t RSVD2[60]; + dv_reg NAND4BITECCLOAD; + dv_reg NAND4BITECC1; + dv_reg NAND4BITECC2; + dv_reg NAND4BITECC3; + dv_reg NAND4BITECC4; + dv_reg NANDERRADD1; + dv_reg NANDERRADD2; + dv_reg NANDERRVAL1; + dv_reg NANDERRVAL2; +} emif_registers; + +typedef emif_registers *emifregs; +#endif diff --git a/include/asm-arm/arch-da8xx/hardware.h b/include/asm-arm/arch-da8xx/hardware.h new file mode 100644 index 0000000..ec2176d --- /dev/null +++ b/include/asm-arm/arch-da8xx/hardware.h @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc + * + * Based on hardware.h for DaVinci. Original Copyrights follow. + * + * Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ------------------------------------------------------------------------- + * + * linux/include/asm-arm/arch-davinci/hardware.h + * + * Copyright (C) 2006 Texas Instruments. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#include <config.h> + +#ifndef __ASSEMBLY__ + +#include <asm/sizes.h> + +#define REG(addr) (*(volatile unsigned int *)(addr)) +#define REG_P(addr) ((volatile unsigned int *)(addr)) + +typedef volatile unsigned int dv_reg; +typedef volatile unsigned int * dv_reg_p; + +#endif + +/* + * Base register addresses + */ +#define DAVINCI_UART0_BASE (0x01c42000) +#define DAVINCI_UART1_BASE (0x01d0c000) +#define DAVINCI_UART2_BASE (0x01d0d000) +#define DAVINCI_I2C0_BASE (0x01c22000) +#define DAVINCI_I2C1_BASE (0x01e28000) +#define DAVINCI_TIMER0_BASE (0x01c20000) +#define DAVINCI_TIMER1_BASE (0x01c21000) +#define DAVINCI_WDOG_BASE (0x01c21000) +#define DAVINCI_PLL_CNTRL0_BASE (0x01c11000) +#define DAVINCI_PSC0_BASE (0x01c10000) +#define DAVINCI_PSC1_BASE (0x01e27000) +#define DAVINCI_SPI0_BASE (0x01c41000) +#define DAVINCI_USB_OTG_BASE (0x01e00000) +#define DAVINCI_SPI1_BASE (0x01e12000) +#define DAVINCI_GPIO_BASE (0x01e26000) +#define DAVINCI_EMAC_CNTRL_REGS_BASE (0x01e23000) +#define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE (0x01e22000) +#define DAVINCI_EMAC_WRAPPER_RAM_BASE (0x01e20000) +#define DAVINCI_MDIO_CNTRL_REGS_BASE (0x01e24000) +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE (0x68000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE (0x40000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE (0x60000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE3_BASE (0x62000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE4_BASE (0x64000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE5_BASE (0x66000000) +#define DAVINCI_DDR_EMIF_CTRL_BASE (0xb0000000) +#define DAVINCI_DDR_EMIF_DATA_BASE (0xc0000000) +#define DAVINCI_INTC_BASE (0xfffee000) +#define DAVINCI_BOOTCFG_BASE (0x01c14000) + +/* Clock IDs */ +#define DAVINCI_PLLM_CLKID (0xFF + 0) +#define DAVINCI_PLLC_CLKID (0xFF + 1) +#define DAVINCI_AUXCLK_CLKID (0xFF + 2) +#define DAVINCI_MDIO_CLKID 4 +#define DAVINCI_SPI0_CLKID 2 +#define DAVINCI_UART2_CLKID 2 +#define DAVINCI_ARM_CLKID 6 + +/* Power and Sleep Controller (PSC) Domains */ +#define DAVINCI_GPSC_ARMDOMAIN 0 +#define DAVINCI_GPSC_DSPDOMAIN 1 + +/* LPSCs in PSC0 */ +#define DAVINCI_LPSC_TPCC 0 +#define DAVINCI_LPSC_TPTC0 1 +#define DAVINCI_LPSC_TPTC1 2 +#define DAVINCI_LPSC_AEMIF 3 +#define DAVINCI_LPSC_SPI0 4 +#define DAVINCI_LPSC_MMC_SD 5 +#define DAVINCI_LPSC_AINTC 6 +#define DAVINCI_LPSC_ARM_RAM_ROM 7 +#define DAVINCI_LPSC_SECCTL_KEYMGR 8 +#define DAVINCI_LPSC_UART0 9 +#define DAVINCI_LPSC_SCR0 10 +#define DAVINCI_LPSC_SCR1 11 +#define DAVINCI_LPSC_SCR2 12 +#define DAVINCI_LPSC_DMAX 13 +#define DAVINCI_LPSC_ARM 14 +#define DAVINCI_LPSC_GEM 15 + +/* for LPSCs in PSC1, 32 + actual id is being used for differentiation */ +#define DAVINCI_LPSC_USB11 (32 + 1) +#define DAVINCI_LPSC_USB20 (32 + 2) +#define DAVINCI_LPSC_GPIO (32 + 3) +#define DAVINCI_LPSC_UHPI (32 + 4) +#define DAVINCI_LPSC_EMAC (32 + 5) +#define DAVINCI_LPSC_DDR_EMIF (32 + 6) +#define DAVINCI_LPSC_McASP0 (32 + 7) +#define DAVINCI_LPSC_McASP1 (32 + 8) +#define DAVINCI_LPSC_McASP2 (32 + 9) +#define DAVINCI_LPSC_SPI1 (32 + 10) +#define DAVINCI_LPSC_I2C1 (32 + 11) +#define DAVINCI_LPSC_UART1 (32 + 12) +#define DAVINCI_LPSC_UART2 (32 + 13) +#define DAVINCI_LPSC_LCDC (32 + 16) +#define DAVINCI_LPSC_ePWM (32 + 17) +#define DAVINCI_LPSC_eCAP (32 + 20) +#define DAVINCI_LPSC_eQEP (32 + 21) +#define DAVINCI_LPSC_SCR_P0 (32 + 22) +#define DAVINCI_LPSC_SCR_P1 (32 + 23) +#define DAVINCI_LPSC_CR_P3 (32 + 26) +#define DAVINCI_LPSC_L3_CBA_RAM (32 + 31) + +/* Some PSC defines */ + +#define PSC0_MDCTL (DAVINCI_PSC0_BASE + 0xa00) +#define PSC0_MDSTAT (DAVINCI_PSC0_BASE + 0x800) +#define PSC0_PTCMD (DAVINCI_PSC0_BASE + 0x120) +#define PSC0_PTSTAT (DAVINCI_PSC0_BASE + 0x128) + +#define PSC1_MDCTL (DAVINCI_PSC1_BASE + 0xa00) +#define PSC1_MDSTAT (DAVINCI_PSC1_BASE + 0x800) +#define PSC1_PTCMD (DAVINCI_PSC1_BASE + 0x120) +#define PSC1_PTSTAT (DAVINCI_PSC1_BASE + 0x128) + +/* Some PLL defines */ +#define PLL0_PLLCTL (DAVINCI_PLL_CNTRL0_BASE + 0x100) +#define PLL0_PLLM (DAVINCI_PLL_CNTRL0_BASE + 0x110) +#define PLL0_PREDIV (DAVINCI_PLL_CNTRL0_BASE + 0x114) +#define PLL0_POSTDIV (DAVINCI_PLL_CNTRL0_BASE + 0x128) +#define PLL0_DIV1 (DAVINCI_PLL_CNTRL0_BASE + 0x118) +#define PLL0_DIV2 (DAVINCI_PLL_CNTRL0_BASE + 0x11c) +#define PLL0_DIV3 (DAVINCI_PLL_CNTRL0_BASE + 0x120) +#define PLL0_DIV4 (DAVINCI_PLL_CNTRL0_BASE + 0x160) +#define PLL0_DIV5 (DAVINCI_PLL_CNTRL0_BASE + 0x164) +#define PLL0_DIV6 (DAVINCI_PLL_CNTRL0_BASE + 0x168) +#define PLL0_DIV7 (DAVINCI_PLL_CNTRL0_BASE + 0x16c) +#define PLL0_DIV8 (DAVINCI_PLL_CNTRL0_BASE + 0x170) +#define PLL0_DIV9 (DAVINCI_PLL_CNTRL0_BASE + 0x114) + +/* Boot config */ +#define PINMUX0 (DAVINCI_BOOTCFG_BASE + 0x120) +#define PINMUX1 (DAVINCI_BOOTCFG_BASE + 0x124) +#define PINMUX2 (DAVINCI_BOOTCFG_BASE + 0x128) +#define PINMUX3 (DAVINCI_BOOTCFG_BASE + 0x12c) +#define PINMUX4 (DAVINCI_BOOTCFG_BASE + 0x130) +#define PINMUX5 (DAVINCI_BOOTCFG_BASE + 0x134) +#define PINMUX6 (DAVINCI_BOOTCFG_BASE + 0x138) +#define PINMUX7 (DAVINCI_BOOTCFG_BASE + 0x13c) +#define PINMUX8 (DAVINCI_BOOTCFG_BASE + 0x140) +#define PINMUX9 (DAVINCI_BOOTCFG_BASE + 0x144) +#define PINMUX10 (DAVINCI_BOOTCFG_BASE + 0x148) +#define PINMUX11 (DAVINCI_BOOTCFG_BASE + 0x14c) +#define PINMUX12 (DAVINCI_BOOTCFG_BASE + 0x150) +#define PINMUX13 (DAVINCI_BOOTCFG_BASE + 0x154) +#define PINMUX14 (DAVINCI_BOOTCFG_BASE + 0x158) +#define PINMUX15 (DAVINCI_BOOTCFG_BASE + 0x15C) +#define PINMUX16 (DAVINCI_BOOTCFG_BASE + 0x160) +#define PINMUX17 (DAVINCI_BOOTCFG_BASE + 0x164) +#define PINMUX18 (DAVINCI_BOOTCFG_BASE + 0x168) +#define PINMUX19 (DAVINCI_BOOTCFG_BASE + 0x16c) +#define SUSPSRC (DAVINCI_BOOTCFG_BASE + 0x170) +#define CFGCHIP0 (DAVINCI_BOOTCFG_BASE + 0x17c) +#define CFGCHIP2 (DAVINCI_BOOTCFG_BASE + 0x184) + +/* Interrupt controller */ +#define INTC_GLB_EN (DAVINCI_INTC_BASE + 0x10) +#define INTC_HINT_EN (DAVINCI_INTC_BASE + 0x1500) +#define INTC_EN_CLR0 (DAVINCI_INTC_BASE + 0x380) + +/* GPIO */ +#define GPIO_BANK4_ADDR 0x01E26000 +#define GPIO_BANK4_REG_DIR_ADDR ( GPIO_BANK4_ADDR + 0x60 ) +#define GPIO_BANK4_REG_OPDATA_ADDR ( GPIO_BANK4_ADDR + 0x64 ) +#define GPIO_BANK4_REG_SET_ADDR ( GPIO_BANK4_ADDR + 0x68 ) +#define GPIO_BANK4_REG_CLR_ADDR ( GPIO_BANK4_ADDR + 0x6C ) + +#endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/include/asm-arm/arch-da8xx/i2c_defs.h b/include/asm-arm/arch-da8xx/i2c_defs.h new file mode 100644 index 0000000..714211f --- /dev/null +++ b/include/asm-arm/arch-da8xx/i2c_defs.h @@ -0,0 +1,95 @@ +/* + * (C) Copyright 2004 + * Texas Instruments, <www.ti.com> + * + * Some changes copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DAVINCI_I2C_H_ +#define _DAVINCI_I2C_H_ + +#define I2C_WRITE 0 +#define I2C_READ 1 + +#define I2C_BASE 0x01c22000 + +#define I2C_OA (I2C_BASE + 0x00) +#define I2C_IE (I2C_BASE + 0x04) +#define I2C_STAT (I2C_BASE + 0x08) +#define I2C_SCLL (I2C_BASE + 0x0c) +#define I2C_SCLH (I2C_BASE + 0x10) +#define I2C_CNT (I2C_BASE + 0x14) +#define I2C_DRR (I2C_BASE + 0x18) +#define I2C_SA (I2C_BASE + 0x1c) +#define I2C_DXR (I2C_BASE + 0x20) +#define I2C_CON (I2C_BASE + 0x24) +#define I2C_IV (I2C_BASE + 0x28) +#define I2C_PSC (I2C_BASE + 0x30) + +/* I2C masks */ + +/* I2C Interrupt Enable Register (I2C_IE): */ +#define I2C_IE_SCD_IE (1 << 5) /* Stop condition detect interrupt enable */ +#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ +#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ +#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ +#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Status Register (I2C_STAT): */ + +#define I2C_STAT_BB (1 << 12) /* Bus busy */ +#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ +#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ +#define I2C_STAT_AAS (1 << 9) /* Address as slave */ +#define I2C_STAT_SCD (1 << 5) /* Stop condition detect */ +#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ +#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ +#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ +#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ + + +/* I2C Interrupt Code Register (I2C_INTCODE): */ + +#define I2C_INTCODE_MASK 7 +#define I2C_INTCODE_NONE 0 +#define I2C_INTCODE_AL 1 /* Arbitration lost */ +#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ +#define I2C_INTCODE_ARDY 3 /* Register access ready */ +#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ +#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ +#define I2C_INTCODE_SCD 6 /* Stop condition detect */ + + +/* I2C Configuration Register (I2C_CON): */ + +#define I2C_CON_EN (1 << 5) /* I2C module enable */ +#define I2C_CON_STB (1 << 4) /* Start byte mode (master mode only) */ +#define I2C_CON_MST (1 << 10) /* Master/slave mode */ +#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode (master mode only) */ +#define I2C_CON_XA (1 << 8) /* Expand address */ +#define I2C_CON_STP (1 << 11) /* Stop condition (master mode only) */ +#define I2C_CON_STT (1 << 13) /* Start condition (master mode only) */ +#define I2C_CON_FREE (1 << 14) /* Free run on emulation */ + +#define I2C_TIMEOUT 0xffff0000 /* Timeout mask for poll_i2c_irq() */ + +#endif
Sorry I missed your rev of patch #1. I prefer to see the whole patch set resubmitted instead of parts.
Please also list the version number of the patch set in the subject of at least the 0/n. You commenting on what changed from from version 1 to version 2 is good.
- Copyright (C) 2009 Nick Thompson, GE Fanuc, Ltd. nick.thompson@gefanuc.com
Trailing whitespace. Please check globally
- DA8xx clock include header
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
Extra spaces in the last 3 lines
The __ASSEMBLY__ (not __ASSEMBLER__) prefix is used when including headers in assembly files so #defines can be used. This is a mostly empty file. You can remove the __ASSEMBLER__
You should put the timer structure for the first patch here.
- Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net
- Based on:
- dm644x_emac.h
- TI DaVinci (DM644X) EMAC peripheral driver header for DV-EVM
- Copyright (C) 2005 Texas Instruments.
More extra spaces
- Modifications:
- ver. 1.0: Sep 2005, TI PSP Team - Created EMAC version for uBoot.
This is not needed for gpl 2. Please remove
This exceeds the 80 chars per line. checkpatch.pl will help you find the others. Please apply globally.
- NOTE: Only 1 buffer supported as of now
Extra line, remove
- ******** Internally used macros ***************
Convert to multi-line comment style mentioned in patch 1 If these are really internal macros, they should not be included here. Maybe you should move them to the 'C' file?
- reserve space for 64 descriptors max
Multi-line comment
The volatile is not needed. The read / write access is not direct but rather through the readl/writel (or appropriate datalength) function
- u_int32_t next; /* Pointer to next descriptor in chain */
- u_int8_t *buffer; /* Pointer to data buffer */
- u_int32_t buff_off_len; /* Buffer Offset(MSW) and Length(LSW) */
- u_int32_t pkt_flag_len; /* Packet Flags(MSW) and Length(LSW) */
+} emac_desc;
Extra line
Extra line
The '( ' .. ')' are not needed around the #define-ed immediates. They can be removed.
- dv_reg TXIDVER;
- dv_reg TXCONTROL;
- dv_reg TXTEARDOWN;
- u_int8_t RSVD0[4];
- dv_reg RXIDVER;
- dv_reg RXCONTROL;
- dv_reg RXTEARDOWN;
- u_int8_t RSVD1[100];
- dv_reg TXINTSTATRAW;
- dv_reg TXINTSTATMASKED;
- dv_reg TXINTMASKSET;
- dv_reg TXINTMASKCLEAR;
- dv_reg MACINVECTOR;
- u_int8_t RSVD2[12];
- dv_reg RXINTSTATRAW;
- dv_reg RXINTSTATMASKED;
- dv_reg RXINTMASKSET;
- dv_reg RXINTMASKCLEAR;
- dv_reg MACINTSTATRAW;
- dv_reg MACINTSTATMASKED;
- dv_reg MACINTMASKSET;
- dv_reg MACINTMASKCLEAR;
- u_int8_t RSVD3[64];
- dv_reg RXMBPENABLE;
- dv_reg RXUNICASTSET;
- dv_reg RXUNICASTCLEAR;
- dv_reg RXMAXLEN;
- dv_reg RXBUFFEROFFSET;
- dv_reg RXFILTERLOWTHRESH;
- u_int8_t RSVD4[8];
- dv_reg RX0FLOWTHRESH;
- dv_reg RX1FLOWTHRESH;
- dv_reg RX2FLOWTHRESH;
- dv_reg RX3FLOWTHRESH;
- dv_reg RX4FLOWTHRESH;
- dv_reg RX5FLOWTHRESH;
- dv_reg RX6FLOWTHRESH;
- dv_reg RX7FLOWTHRESH;
- dv_reg RX0FREEBUFFER;
- dv_reg RX1FREEBUFFER;
- dv_reg RX2FREEBUFFER;
- dv_reg RX3FREEBUFFER;
- dv_reg RX4FREEBUFFER;
- dv_reg RX5FREEBUFFER;
- dv_reg RX6FREEBUFFER;
- dv_reg RX7FREEBUFFER;
- dv_reg MACCONTROL;
- dv_reg MACSTATUS;
- dv_reg EMCONTROL;
- dv_reg FIFOCONTROL;
- dv_reg MACCONFIG;
- dv_reg SOFTRESET;
- u_int8_t RSVD5[88];
- dv_reg MACSRCADDRLO;
- dv_reg MACSRCADDRHI;
- dv_reg MACHASH1;
- dv_reg MACHASH2;
- dv_reg BOFFTEST;
- dv_reg TPACETEST;
- dv_reg RXPAUSE;
- dv_reg TXPAUSE;
- u_int8_t RSVD6[16];
- dv_reg RXGOODFRAMES;
- dv_reg RXBCASTFRAMES;
- dv_reg RXMCASTFRAMES;
- dv_reg RXPAUSEFRAMES;
- dv_reg RXCRCERRORS;
- dv_reg RXALIGNCODEERRORS;
- dv_reg RXOVERSIZED;
- dv_reg RXJABBER;
- dv_reg RXUNDERSIZED;
- dv_reg RXFRAGMENTS;
- dv_reg RXFILTERED;
- dv_reg RXQOSFILTERED;
- dv_reg RXOCTETS;
- dv_reg TXGOODFRAMES;
- dv_reg TXBCASTFRAMES;
- dv_reg TXMCASTFRAMES;
- dv_reg TXPAUSEFRAMES;
- dv_reg TXDEFERRED;
- dv_reg TXCOLLISION;
- dv_reg TXSINGLECOLL;
- dv_reg TXMULTICOLL;
- dv_reg TXEXCESSIVECOLL;
- dv_reg TXLATECOLL;
- dv_reg TXUNDERRUN;
- dv_reg TXCARRIERSENSE;
- dv_reg TXOCTETS;
- dv_reg FRAME64;
- dv_reg FRAME65T127;
- dv_reg FRAME128T255;
- dv_reg FRAME256T511;
- dv_reg FRAME512T1023;
- dv_reg FRAME1024TUP;
- dv_reg NETOCTETS;
- dv_reg RXSOFOVERRUNS;
- dv_reg RXMOFOVERRUNS;
- dv_reg RXDMAOVERRUNS;
- u_int8_t RSVD7[624];
- dv_reg MACADDRLO;
- dv_reg MACADDRHI;
- dv_reg MACINDEX;
- u_int8_t RSVD8[244];
- dv_reg TX0HDP;
- dv_reg TX1HDP;
- dv_reg TX2HDP;
- dv_reg TX3HDP;
- dv_reg TX4HDP;
- dv_reg TX5HDP;
- dv_reg TX6HDP;
- dv_reg TX7HDP;
- dv_reg RX0HDP;
- dv_reg RX1HDP;
- dv_reg RX2HDP;
- dv_reg RX3HDP;
- dv_reg RX4HDP;
- dv_reg RX5HDP;
- dv_reg RX6HDP;
- dv_reg RX7HDP;
- dv_reg TX0CP;
- dv_reg TX1CP;
- dv_reg TX2CP;
- dv_reg TX3CP;
- dv_reg TX4CP;
- dv_reg TX5CP;
- dv_reg TX6CP;
- dv_reg TX7CP;
- dv_reg RX0CP;
- dv_reg RX1CP;
- dv_reg RX2CP;
- dv_reg RX3CP;
- dv_reg RX4CP;
- dv_reg RX5CP;
- dv_reg RX6CP;
- dv_reg RX7CP;
+} emac_regs;
Lowercase the elements Please apply this globally.
- dv_reg REV;
- dv_reg SOFTRESET;
- dv_reg INTCONTROL;
- dv_reg C0RXTHRESHEN;
- dv_reg C0RXEN;
- dv_reg C0TXEN;
- dv_reg C0MISCEN;
- dv_reg C1RXTHRESHEN;
- dv_reg C1RXEN;
- dv_reg C1TXEN;
- dv_reg C1MISCEN;
- dv_reg C2RXTHRESHEN;
- dv_reg C2RXEN;
- dv_reg C2TXEN;
- dv_reg C2MISCEN;
- dv_reg C0RXTHRESHSTAT;
- dv_reg C0RXSTAT;
- dv_reg C0TXSTAT;
- dv_reg C0MISCSTAT;
- dv_reg C1RXTHRESHSTAT;
- dv_reg C1RXSTAT;
- dv_reg C1TXSTAT;
- dv_reg C1MISCSTAT;
- dv_reg C2RXTHRESHSTAT;
- dv_reg C2RXSTAT;
- dv_reg C2TXSTAT;
- dv_reg C2MISCSTAT;
- dv_reg C0RXIMAX;
- dv_reg C0TXIMAX;
- dv_reg C1RXIMAX;
- dv_reg C1TXIMAX;
- dv_reg C2RXIMAX;
- dv_reg C2TXIMAX;
+} ewrap_regs;
Extra line
- dv_reg VERSION;
- dv_reg CONTROL;
- dv_reg ALIVE;
- dv_reg LINK;
- dv_reg LINKINTRAW;
- dv_reg LINKINTMASKED;
- u_int8_t RSVD0[8];
- dv_reg USERINTRAW;
- dv_reg USERINTMASKED;
- dv_reg USERINTMASKSET;
- dv_reg USERINTMASKCLEAR;
- u_int8_t RSVD1[80];
- dv_reg USERACCESS0;
- dv_reg USERPHYSEL0;
- dv_reg USERACCESS1;
- dv_reg USERPHYSEL1;
+} mdio_regs;
+typedef struct +{
- char name[64];
- int (*init)(int phy_addr);
- int (*is_phy_connected)(int phy_addr);
- int (*get_link_speed)(int phy_addr);
- int (*auto_negotiate)(int phy_addr);
+} phy_t;
- project.
- MA 02111-1307 USA
+typedef struct {
- dv_reg ERCSR;
- dv_reg AWCCR;
- dv_reg SDBCR;
- dv_reg SDRCR;
- dv_reg AB1CR;
- dv_reg AB2CR;
- dv_reg AB3CR;
- dv_reg AB4CR;
- dv_reg SDTIMR;
- dv_reg DDRSR;
- dv_reg DDRPHYCR;
- dv_reg DDRPHYSR;
- dv_reg TOTAR;
- dv_reg TOTACTR;
- dv_reg DDRPHYID_REV;
- dv_reg SDSRETR;
- dv_reg EIRR;
- dv_reg EIMR;
- dv_reg EIMSR;
- dv_reg EIMCR;
- dv_reg IOCTRLR;
- dv_reg IOSTATR;
- dv_reg NANDFCR;
- dv_reg NANDFSR;
- u_int8_t RSVD1[8];
- dv_reg NANDF1ECC;
- dv_reg NANDF2ECC;
- dv_reg NANDF3ECC;
- dv_reg NANDF4ECC;
- u_int8_t RSVD2[60];
- dv_reg NAND4BITECCLOAD;
- dv_reg NAND4BITECC1;
- dv_reg NAND4BITECC2;
- dv_reg NAND4BITECC3;
- dv_reg NAND4BITECC4;
- dv_reg NANDERRADD1;
- dv_reg NANDERRADD2;
- dv_reg NANDERRVAL1;
- dv_reg NANDERRVAL2;
+} emif_registers;
- Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc
The author usually goes on the next line. But if this was the original file, do not modify.
- Based on hardware.h for DaVinci. Original Copyrights follow.
- Sergey Kubushyn ksi@koi8.net
- Based on:
- linux/include/asm-arm/arch-davinci/hardware.h
- Copyright (C) 2006 Texas Instruments.
- This program is free software; you can redistribute it and/or modify it
- under the terms of the GNU General Public License as published by the
- Free Software Foundation; either version 2 of the License, or (at your
- option) any later version.
- THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
- WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
- NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
- INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
- ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
- THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- You should have received a copy of the GNU General Public License along
- with this program; if not, write to the Free Software Foundation, Inc.,
- 675 Mass Ave, Cambridge, MA 02139, USA.
If checkpatch complains about the line exceeding 80 chars, remove the leading tabs of the copyrite
Change this to a less generic name. Something like __DA8XX_HARDWARE__
This typedef and macros will go way when you convert to using readl/writel
- Base register addresses
The '(' .. ')' should be removed from the #define immediates.
space after ..BASE
space after ..BASE
space after ..BASE
spaces before 6
space after SD
Consider making the 32 a #define
space ater the last 3 lines 0,1,2
space after the last 2 lines This is a general problem. Please check that your #defines just have tab between the identifier and the value.
Extra spaces after '(' and before ')' should be removed
- (C) Copyright 2004
- Texas Instruments, <www.ti.com>
I believe TI copywrite have the these lines combined into 1. Please check.
- Some changes copyright (C) 2007 Sergey Kubushyn ksi@koi8.net
- project.
- MA 02111-1307 USA
+/* I2C masks */
These comment cause lines exceeding 80 chars. This is a general problem Please fix where appropriate
This value likely doesn't not align with the ones above it. Please fix if it doesn't.
Extra line
+#endif _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Tom
