[PATCH] global_data: remove unused mxc_i2c specific field
The srdata field is unused since commit 71204e95ce13228 ("i2c: mxc: refactor i2c driver and support dm").
Cc: Peng Fan peng.fan@nxp.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- include/asm-generic/global_data.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 7587ba2ee586..5d027329fe0f 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -89,9 +89,6 @@ typedef struct global_data { #endif #if defined(CONFIG_SYS_I2C) int cur_i2c_bus; /* current used i2c bus */ -#endif -#ifdef CONFIG_SYS_I2C_MXC - void *srdata[10]; #endif unsigned int timebase_h; unsigned int timebase_l;
Subject: [PATCH] global_data: remove unused mxc_i2c specific field
Reviewed-by: Peng Fan peng.fan@nxp.com
- void *srdata[10];
#endif unsigned int timebase_h; unsigned int timebase_l; -- 2.24.0
Hello Baruch,
Am 25.12.2019 um 16:57 schrieb Baruch Siach:
Cc: Peng Fan peng.fan@nxp.com Signed-off-by: Baruch Siach baruch@tkos.co.il Reviewed-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-i2c master.
Thanks!
bye, Heiko
Baruch Siach
Heiko Schocher
Peng Fan
