[U-Boot] [PATCH 1/4] i2c: rcar_iic: Allow IIC on RCar Gen2
The IIC on Gen2 is compatible with this driver as well, allow it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/i2c/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 7dbec775df..9d43690503 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -178,7 +178,7 @@ endif
config SYS_I2C_RCAR_IIC bool "Renesas RCar Gen3 IIC driver" - depends on RCAR_GEN3 && DM_I2C + depends on (RCAR_GEN3 || RCAR_GEN2) && DM_I2C help Support for Renesas RCar Gen3 IIC controller.
Enable I2C6 bus on Porter to access the PMIC , ie. to reset the board.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/r8a7791-porter.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/r8a7791-porter.dts b/arch/arm/dts/r8a7791-porter.dts index bc93bb24e4..0592aa7f49 100644 --- a/arch/arm/dts/r8a7791-porter.dts +++ b/arch/arm/dts/r8a7791-porter.dts @@ -351,6 +351,11 @@ }; };
+&i2c6 { + status = "okay"; + clock-frequency = <400000>; +}; + &sata0 { status = "okay"; };
Get rid of the SH I2C driver on Porter and enable the IIC driver instead . The old SH I2C is completely broken on Porter anyway and the DM/DT capable IIC driver allows access to the PMIC too. Use the DM/DT capable driver instead.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/porter_defconfig | 3 +++ include/configs/porter.h | 14 -------------- 2 files changed, 3 insertions(+), 14 deletions(-)
diff --git a/configs/porter_defconfig b/configs/porter_defconfig index c244a9c221..09776db003 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -50,6 +50,9 @@ CONFIG_SPL_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y CONFIG_RCAR_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_I2C_COMPAT=y +CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y CONFIG_MMC_UNIPHIER=y CONFIG_SPI_FLASH=y diff --git a/include/configs/porter.h b/include/configs/porter.h index 1816f2fd76..eb28d1afcc 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -49,20 +49,6 @@
#define CONFIG_SYS_TMU_CLK_DIV 4
-/* i2c */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SH -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_SH_NUM_CONTROLLERS 3 -#define CONFIG_SYS_I2C_SH_SPEED0 400000 -#define CONFIG_SYS_I2C_SH_SPEED1 400000 -#define CONFIG_SYS_I2C_SH_SPEED2 400000 -#define CONFIG_SH_I2C_DATA_HIGH 4 -#define CONFIG_SH_I2C_DATA_LOW 5 -#define CONFIG_SH_I2C_CLOCK 10000000 - -#define CONFIG_SYS_I2C_POWERIC_ADDR 0x58 /* da9063 */ - #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0"
The 'reset' command did not work on Porter because the reset code was accessing the wrong PMIC address over broken I2C bus driver. Replace the code with DM-aware code and fix up the PMIC address. This makes the 'reset' command work again.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/porter/porter.c | 23 ++++++++++++++++++----- 1 file changed, 18 insertions(+), 5 deletions(-)
diff --git a/board/renesas/porter/porter.c b/board/renesas/porter/porter.c index dfefd7fb71..320841f27b 100644 --- a/board/renesas/porter/porter.c +++ b/board/renesas/porter/porter.c @@ -116,12 +116,25 @@ const struct rmobile_sysinfo sysinfo = {
void reset_cpu(ulong addr) { - u8 val; + struct udevice *dev; + const u8 pmic_bus = 6; + const u8 pmic_addr = 0x5a; + u8 data; + int ret;
- i2c_set_bus_num(2); /* PowerIC connected to ch2 */ - i2c_read(CONFIG_SYS_I2C_POWERIC_ADDR, 0x13, 1, &val, 1); - val |= 0x02; - i2c_write(CONFIG_SYS_I2C_POWERIC_ADDR, 0x13, 1, &val, 1); + ret = i2c_get_chip_for_busnum(pmic_bus, pmic_addr, 1, &dev); + if (ret) + hang(); + + ret = dm_i2c_read(dev, 0x13, &data, 1); + if (ret) + hang(); + + data |= BIT(1); + + ret = dm_i2c_write(dev, 0x13, &data, 1); + if (ret) + hang(); }
#ifdef CONFIG_SPL_BUILD
