[PATCH v4 1/4] Add reserved-memory
Bring in this file from Linux v6.5
Changes in v4: - New patch
.../reserved-memory/reserved-memory.yaml | 181 ++++++++++++++++++ 1 file changed, 181 insertions(+) create mode 100644 dtschema/schemas/reserved-memory/reserved-memory.yaml
diff --git a/dtschema/schemas/reserved-memory/reserved-memory.yaml b/dtschema/schemas/reserved-memory/reserved-memory.yaml new file mode 100644 index 0000000..c680e39 --- /dev/null +++ b/dtschema/schemas/reserved-memory/reserved-memory.yaml @@ -0,0 +1,181 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/reserved-memory.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: /reserved-memory Child Node Common + +maintainers: + - devicetree-spec@vger.kernel.org + +description: > + Reserved memory is specified as a node under the /reserved-memory node. The + operating system shall exclude reserved memory from normal usage one can + create child nodes describing particular reserved (excluded from normal use) + memory regions. Such memory regions are usually designed for the special + usage by various device drivers. + + Each child of the reserved-memory node specifies one or more regions + of reserved memory. Each child node may either use a 'reg' property to + specify a specific range of reserved memory, or a 'size' property with + optional constraints to request a dynamically allocated block of + memory. + + Following the generic-names recommended practice, node names should + reflect the purpose of the node (ie. "framebuffer" or "dma-pool"). + Unit address (@<address>) should be appended to the name if the node + is a static allocation. + +properties: + reg: true + + size: + oneOf: + - $ref: /schemas/types.yaml#/definitions/uint32 + - $ref: /schemas/types.yaml#/definitions/uint64 + description: > + Length based on parent's #size-cells. Size in bytes of memory to + reserve. + + alignment: + oneOf: + - $ref: /schemas/types.yaml#/definitions/uint32 + - $ref: /schemas/types.yaml#/definitions/uint64 + description: > + Length based on parent's #size-cells. Address boundary for + alignment of allocation. + + alloc-ranges: + $ref: /schemas/types.yaml#/definitions/uint32-array + description: > + Address and Length pairs. Specifies regions of memory that are + acceptable to allocate from. + + iommu-addresses: + $ref: /schemas/types.yaml#/definitions/phandle-array + description: > + A list of phandle and specifier pairs that describe static IO virtual + address space mappings and carveouts associated with a given reserved + memory region. The phandle in the first cell refers to the device for + which the mapping or carveout is to be created. + + The specifier consists of an address/size pair and denotes the IO + virtual address range of the region for the given device. The exact + format depends on the values of the "#address-cells" and "#size-cells" + properties of the device referenced via the phandle. + + When used in combination with a "reg" property, an IOVA mapping is to + be established for this memory region. One example where this can be + useful is to create an identity mapping for physical memory that the + firmware has configured some hardware to access (such as a bootsplash + framebuffer). + + If no "reg" property is specified, the "iommu-addresses" property + defines carveout regions in the IOVA space for the given device. This + can be useful if a certain memory region should not be mapped through + the IOMMU. + + no-map: + type: boolean + description: > + Indicates the operating system must not create a virtual mapping + of the region as part of its standard mapping of system memory, + nor permit speculative access to it under any circumstances other + than under the control of the device driver using the region. + + reusable: + type: boolean + description: > + The operating system can use the memory in this region with the + limitation that the device driver(s) owning the region need to be + able to reclaim it back. Typically that means that the operating + system can use that region to store volatile or cached data that + can be otherwise regenerated or migrated elsewhere. + +allOf: + - if: + required: + - no-map + + then: + not: + required: + - reusable + + - if: + required: + - reusable + + then: + not: + required: + - no-map + +oneOf: + - oneOf: + - required: + - reg + + - required: + - size + + - oneOf: + # IOMMU reservations + - required: + - iommu-addresses + + # IOMMU mappings + - required: + - reg + - iommu-addresses + +additionalProperties: true + +examples: + - | + / { + compatible = "foo"; + model = "foo"; + + #address-cells = <2>; + #size-cells = <2>; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + adsp_resv: reservation-adsp { + /* + * Restrict IOVA mappings for ADSP buffers to the 512 MiB region + * from 0x40000000 - 0x5fffffff. Anything outside is reserved by + * the ADSP for I/O memory and private memory allocations. + */ + iommu-addresses = <&adsp 0x0 0x00000000 0x00 0x40000000>, + <&adsp 0x0 0x60000000 0xff 0xa0000000>; + }; + + fb: framebuffer@90000000 { + reg = <0x0 0x90000000 0x0 0x00800000>; + iommu-addresses = <&dc0 0x0 0x90000000 0x0 0x00800000>; + }; + }; + + bus@0 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x0 0x40000000>; + + adsp: adsp@2990000 { + reg = <0x2990000 0x2000>; + memory-region = <&adsp_resv>; + }; + + dc0: display@15200000 { + reg = <0x15200000 0x10000>; + memory-region = <&fb>; + }; + }; + }; +...
Add those files from v6.5 which are already converted to yaml.
.../schemas/reserved-memory/framebuffer.yaml | 52 +++++++ .../reserved-memory/google,open-dice.yaml | 46 ++++++ .../reserved-memory/memory-region.yaml | 40 +++++ .../nvidia,tegra210-emc-table.yaml | 31 ++++ .../nvidia,tegra264-bpmp-shmem.yaml | 47 ++++++ dtschema/schemas/reserved-memory/phram.yaml | 47 ++++++ .../schemas/reserved-memory/qcom,cmd-db.yaml | 46 ++++++ .../reserved-memory/qcom,rmtfs-mem.yaml | 55 +++++++ dtschema/schemas/reserved-memory/ramoops.yaml | 144 ++++++++++++++++++ .../reserved-memory/shared-dma-pool.yaml | 97 ++++++++++++ 10 files changed, 605 insertions(+) create mode 100644 dtschema/schemas/reserved-memory/framebuffer.yaml create mode 100644 dtschema/schemas/reserved-memory/google,open-dice.yaml create mode 100644 dtschema/schemas/reserved-memory/memory-region.yaml create mode 100644 dtschema/schemas/reserved-memory/nvidia,tegra210-emc-table.yaml create mode 100644 dtschema/schemas/reserved-memory/nvidia,tegra264-bpmp-shmem.yaml create mode 100644 dtschema/schemas/reserved-memory/phram.yaml create mode 100644 dtschema/schemas/reserved-memory/qcom,cmd-db.yaml create mode 100644 dtschema/schemas/reserved-memory/qcom,rmtfs-mem.yaml create mode 100644 dtschema/schemas/reserved-memory/ramoops.yaml create mode 100644 dtschema/schemas/reserved-memory/shared-dma-pool.yaml
diff --git a/dtschema/schemas/reserved-memory/framebuffer.yaml b/dtschema/schemas/reserved-memory/framebuffer.yaml new file mode 100644 index 0000000..851ec24 --- /dev/null +++ b/dtschema/schemas/reserved-memory/framebuffer.yaml @@ -0,0 +1,52 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/framebuffer.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: /reserved-memory framebuffer node + +maintainers: + - devicetree-spec@vger.kernel.org + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: framebuffer + description: > + This indicates a region of memory meant to be used as a framebuffer for + a set of display devices. It can be used by an operating system to keep + the framebuffer from being overwritten and use it as the backing memory + for a display device (such as simple-framebuffer). + +unevaluatedProperties: false + +examples: + - | + / { + compatible = "foo"; + model = "foo"; + #address-cells = <1>; + #size-cells = <1>; + + chosen { + framebuffer { + compatible = "simple-framebuffer"; + memory-region = <&fb>; + }; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + fb: framebuffer@80000000 { + compatible = "framebuffer"; + reg = <0x80000000 0x007e9000>; + }; + }; + }; +... diff --git a/dtschema/schemas/reserved-memory/google,open-dice.yaml b/dtschema/schemas/reserved-memory/google,open-dice.yaml new file mode 100644 index 0000000..c591ec3 --- /dev/null +++ b/dtschema/schemas/reserved-memory/google,open-dice.yaml @@ -0,0 +1,46 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/google,open-dice.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Open Profile for DICE + +description: | + This binding represents a reserved memory region containing data + generated by the Open Profile for DICE protocol. + + See https://pigweed.googlesource.com/open-dice/ + +maintainers: + - David Brazdil dbrazdil@google.com + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: google,open-dice + + reg: + description: page-aligned region of memory containing DICE data + +required: + - compatible + - reg + - no-map + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <2>; + #size-cells = <1>; + + dice: dice@12340000 { + compatible = "google,open-dice"; + reg = <0x00 0x12340000 0x2000>; + no-map; + }; + }; diff --git a/dtschema/schemas/reserved-memory/memory-region.yaml b/dtschema/schemas/reserved-memory/memory-region.yaml new file mode 100644 index 0000000..592f180 --- /dev/null +++ b/dtschema/schemas/reserved-memory/memory-region.yaml @@ -0,0 +1,40 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/memory-region.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Reserved Memory Region + +maintainers: + - devicetree-spec@vger.kernel.org + +description: | + Regions in the /reserved-memory node may be referenced by other device + nodes by adding a memory-region property to the device node. + +select: true + +properties: + memory-region: + $ref: /schemas/types.yaml#/definitions/phandle-array + description: > + Phandle to a /reserved-memory child node assigned to the device. + + memory-region-names: + $ref: /schemas/types.yaml#/definitions/string-array + description: > + A list of names, one for each corresponding entry in the + memory-region property + +additionalProperties: true + +examples: + - | + fb0: video@12300000 { + /* ... */ + reg = <0x12300000 0x1000>; + memory-region = <&display_reserved>; + }; + +... diff --git a/dtschema/schemas/reserved-memory/nvidia,tegra210-emc-table.yaml b/dtschema/schemas/reserved-memory/nvidia,tegra210-emc-table.yaml new file mode 100644 index 0000000..e2ace3d --- /dev/null +++ b/dtschema/schemas/reserved-memory/nvidia,tegra210-emc-table.yaml @@ -0,0 +1,31 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/nvidia,tegra210-emc-table.yaml... +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: NVIDIA Tegra210 EMC Frequency Table + +maintainers: + - Thierry Reding thierry.reding@gmail.com + - Jon Hunter jonathanh@nvidia.com + +description: On Tegra210, firmware passes a binary representation of the + EMC frequency table via a reserved memory region. + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: nvidia,tegra210-emc-table + + reg: + description: region of memory reserved by firmware to pass the EMC + frequency table + +unevaluatedProperties: false + +required: + - compatible + - reg diff --git a/dtschema/schemas/reserved-memory/nvidia,tegra264-bpmp-shmem.yaml b/dtschema/schemas/reserved-memory/nvidia,tegra264-bpmp-shmem.yaml new file mode 100644 index 0000000..f9b2f0f --- /dev/null +++ b/dtschema/schemas/reserved-memory/nvidia,tegra264-bpmp-shmem.yaml @@ -0,0 +1,47 @@ +# SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/nvidia,tegra264-bpmp-shmem.yam... +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Tegra CPU-NS - BPMP IPC reserved memory + +maintainers: + - Peter De Schrijver pdeschrijver@nvidia.com + +description: | + Define a memory region used for communication between CPU-NS and BPMP. + Typically this node is created by the bootloader as the physical address + has to be known to both CPU-NS and BPMP for correct IPC operation. + The memory region is defined using a child node under /reserved-memory. + The sub-node is named shmem@<address>. + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: nvidia,tegra264-bpmp-shmem + + reg: + description: The physical address and size of the shared SDRAM region + +unevaluatedProperties: false + +required: + - compatible + - reg + - no-map + +examples: + - | + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + dram_cpu_bpmp_mail: shmem@f1be0000 { + compatible = "nvidia,tegra264-bpmp-shmem"; + reg = <0x0 0xf1be0000 0x0 0x2000>; + no-map; + }; + }; +... diff --git a/dtschema/schemas/reserved-memory/phram.yaml b/dtschema/schemas/reserved-memory/phram.yaml new file mode 100644 index 0000000..65c7cac --- /dev/null +++ b/dtschema/schemas/reserved-memory/phram.yaml @@ -0,0 +1,47 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/phram.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: MTD/block device in RAM + +description: | + Specifies that the reserved memory region can be used as an MTD or block + device. + + The "phram" node is named after the "MTD in PHysical RAM" driver which + provides an implementation of this functionality in Linux. + +maintainers: + - Vincent Whitchurch vincent.whitchurch@axis.com + +allOf: + - $ref: reserved-memory.yaml + - $ref: /schemas/mtd/mtd.yaml + +properties: + compatible: + const: phram + + reg: + description: region of memory that can be used as an MTD/block device + +required: + - compatible + - reg + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + + phram: flash@12340000 { + compatible = "phram"; + label = "rootfs"; + reg = <0x12340000 0x00800000>; + }; + }; diff --git a/dtschema/schemas/reserved-memory/qcom,cmd-db.yaml b/dtschema/schemas/reserved-memory/qcom,cmd-db.yaml new file mode 100644 index 0000000..610f8ef --- /dev/null +++ b/dtschema/schemas/reserved-memory/qcom,cmd-db.yaml @@ -0,0 +1,46 @@ +# SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/qcom,cmd-db.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Qualcomm Command DB + +description: | + Command DB is a database that provides a mapping between resource key and the + resource address for a system resource managed by a remote processor. The data + is stored in a shared memory region and is loaded by the remote processor. + + Some of the Qualcomm Technologies Inc SoC's have hardware accelerators for + controlling shared resources. Depending on the board configuration the shared + resource properties may change. These properties are dynamically probed by the + remote processor and made available in the shared memory. + +maintainers: + - Bjorn Andersson bjorn.andersson@linaro.org + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: qcom,cmd-db + +required: + - reg + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + reserved-memory@85fe0000 { + reg = <0x85fe0000 0x20000>; + compatible = "qcom,cmd-db"; + no-map; + }; + }; diff --git a/dtschema/schemas/reserved-memory/qcom,rmtfs-mem.yaml b/dtschema/schemas/reserved-memory/qcom,rmtfs-mem.yaml new file mode 100644 index 0000000..bab982f --- /dev/null +++ b/dtschema/schemas/reserved-memory/qcom,rmtfs-mem.yaml @@ -0,0 +1,55 @@ +# SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/qcom,rmtfs-mem.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Qualcomm Remote File System Memory + +description: | + This binding describes the Qualcomm remote filesystem memory, which serves the + purpose of describing the shared memory region used for remote processors to + access block device data using the Remote Filesystem protocol. + +maintainers: + - Bjorn Andersson bjorn.andersson@linaro.org + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: qcom,rmtfs-mem + + qcom,client-id: + $ref: /schemas/types.yaml#/definitions/uint32 + description: > + identifier of the client to use this region for buffers + + qcom,vmid: + $ref: /schemas/types.yaml#/definitions/uint32-array + description: > + Array of vmids of the remote processors, to set up memory protection + minItems: 1 + maxItems: 2 + +required: + - qcom,client-id + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + rmtfs@86700000 { + compatible = "qcom,rmtfs-mem"; + reg = <0x86700000 0xe0000>; + no-map; + + qcom,client-id = <1>; + }; + }; diff --git a/dtschema/schemas/reserved-memory/ramoops.yaml b/dtschema/schemas/reserved-memory/ramoops.yaml new file mode 100644 index 0000000..45cc39e --- /dev/null +++ b/dtschema/schemas/reserved-memory/ramoops.yaml @@ -0,0 +1,144 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/ramoops.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Ramoops oops/panic logger + +description: | + ramoops provides persistent RAM storage for oops and panics, so they can be + recovered after a reboot. This is a child-node of "/reserved-memory", and + is named "ramoops" after the backend, rather than "pstore" which is the + subsystem. + + Parts of this storage may be set aside for other persistent log buffers, such + as kernel log messages, or for optional ECC error-correction data. The total + size of these optional buffers must fit in the reserved region. + + Any remaining space will be used for a circular buffer of oops and panic + records. These records have a configurable size, with a size of 0 indicating + that they should be disabled. + + At least one of "record-size", "console-size", "ftrace-size", or "pmsg-size" + must be set non-zero, but are otherwise optional as listed below. + +maintainers: + - Kees Cook keescook@chromium.org + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + const: ramoops + + reg: + description: region of memory that is preserved between reboots + + ecc-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: enables ECC support and specifies ECC buffer size in bytes + default: 0 # no ECC + + record-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: maximum size in bytes of each kmsg dump + default: 0 + + console-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: size in bytes of log buffer reserved for kernel messages + default: 0 + + ftrace-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: size in bytes of log buffer reserved for function tracing and profiling + default: 0 + + pmsg-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: size in bytes of log buffer reserved for userspace messages + default: 0 + + mem-type: + $ref: /schemas/types.yaml#/definitions/uint32 + description: if present, sets the type of mapping is to be used to map the reserved region. + default: 0 + oneOf: + - const: 0 + description: write-combined + - const: 1 + description: unbuffered + - const: 2 + description: cached + + max-reason: + $ref: /schemas/types.yaml#/definitions/uint32 + default: 2 # log oopses and panics + maximum: 0x7fffffff + description: | + If present, sets maximum type of kmsg dump reasons to store. + This can be set to INT_MAX to store all kmsg dumps. + See include/linux/kmsg_dump.h KMSG_DUMP_* for other kmsg dump reason values. + Setting this to 0 (KMSG_DUMP_UNDEF), means the reason filtering will be + controlled by the printk.always_kmsg_dump boot param. + If unset, it will be 2 (KMSG_DUMP_OOPS), otherwise 5 (KMSG_DUMP_MAX). + + flags: + $ref: /schemas/types.yaml#/definitions/uint32 + default: 0 + description: | + If present, pass ramoops behavioral flags + (see include/linux/pstore_ram.h RAMOOPS_FLAG_* for flag values). + + no-dump-oops: + deprecated: true + type: boolean + description: | + Use max_reason instead. If present, and max_reason is not specified, + it is equivalent to max_reason = 1 (KMSG_DUMP_PANIC). + + unbuffered: + deprecated: true + type: boolean + description: | + Use mem_type instead. If present, and mem_type is not specified, + it is equivalent to mem_type = 1 and uses unbuffered mappings to map + the reserved region (defaults to buffered mappings mem_type = 0). + If both are specified -- "mem_type" overrides "unbuffered". + +unevaluatedProperties: false + +required: + - compatible + - reg + +anyOf: + - required: [record-size] + - required: [console-size] + - required: [ftrace-size] + - required: [pmsg-size] + +examples: + - | + / { + compatible = "foo"; + model = "foo"; + #address-cells = <1>; + #size-cells = <1>; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + ramoops@bfdf0000 { + compatible = "ramoops"; + reg = <0xbfdf0000 0x10000>; /* 64kB */ + console-size = <0x8000>; /* 32kB */ + record-size = <0x400>; /* 1kB */ + ecc-size = <16>; + }; + }; + }; diff --git a/dtschema/schemas/reserved-memory/shared-dma-pool.yaml b/dtschema/schemas/reserved-memory/shared-dma-pool.yaml new file mode 100644 index 0000000..457de09 --- /dev/null +++ b/dtschema/schemas/reserved-memory/shared-dma-pool.yaml @@ -0,0 +1,97 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/shared-dma-pool.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: /reserved-memory DMA pool + +maintainers: + - devicetree-spec@vger.kernel.org + +allOf: + - $ref: reserved-memory.yaml + +properties: + compatible: + oneOf: + - const: shared-dma-pool + description: > + This indicates a region of memory meant to be used as a shared + pool of DMA buffers for a set of devices. It can be used by an + operating system to instantiate the necessary pool management + subsystem if necessary. + + - const: restricted-dma-pool + description: > + This indicates a region of memory meant to be used as a pool + of restricted DMA buffers for a set of devices. The memory + region would be the only region accessible to those devices. + When using this, the no-map and reusable properties must not + be set, so the operating system can create a virtual mapping + that will be used for synchronization. The main purpose for + restricted DMA is to mitigate the lack of DMA access control + on systems without an IOMMU, which could result in the DMA + accessing the system memory at unexpected times and/or + unexpected addresses, possibly leading to data leakage or + corruption. The feature on its own provides a basic level of + protection against the DMA overwriting buffer contents at + unexpected times. However, to protect against general data + leakage and system memory corruption, the system needs to + provide way to lock down the memory access, e.g., MPU. Note + that since coherent allocation needs remapping, one must set + up another device coherent pool by shared-dma-pool and use + dma_alloc_from_dev_coherent instead for atomic coherent + allocation. + + linux,cma-default: + type: boolean + description: > + If this property is present, then Linux will use the region for + the default pool of the contiguous memory allocator. + + linux,dma-default: + type: boolean + description: > + If this property is present, then Linux will use the region for + the default pool of the consistent DMA allocator. + +if: + properties: + compatible: + contains: + const: restricted-dma-pool +then: + properties: + no-map: false + reusable: false + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + /* global autoconfigured region for contiguous allocations */ + linux,cma { + compatible = "shared-dma-pool"; + reusable; + size = <0x4000000>; + alignment = <0x2000>; + linux,cma-default; + }; + + display_reserved: framebuffer@78000000 { + reg = <0x78000000 0x800000>; + }; + + restricted_dma_reserved: restricted-dma-pool@50000000 { + compatible = "restricted-dma-pool"; + reg = <0x50000000 0x4000000>; + }; + }; + +...
Changes in v4:
- New patch
I don't think I want all of these in dtschema. Certainly not vendor specific ones. Generally, if it's not something we'd put in the spec, then I don't want it in dtschema. The u-boot stuff so far has been an exception.
Probably a good rule is if it has a compatible, then it doesn't go into dtschema. Though there's some exceptions already.
Maybe
No
Yes
No
Depends on mtd.yaml in the kernel, so no.
No.
Probably not.
Maybe.
Rob
The Devicetree specification skips over handling of a logical view of the memory map, pointing users to the UEFI specification.
It is common to split firmware into 'Platform Init', which does the initial hardware setup and a "Payload" which selects the OS to be booted. Thus an handover interface is required between these two pieces.
Where UEFI boot-time services are not available, but UEFI firmware is present on either side of this interface, information about memory usage and attributes must be presented to the "Payload" in some form.
This aims to provide an initial schema for this mapping.
Note that this is separate from the existing /memory and /reserved-memory nodes, since it is mostly concerned with what the memory is used for. It may cover only a small fraction of available memory.
For now, no attempt is made to create an exhaustive binding, so there are some example types listed. This can be completed once this has passed initial review.
The compatible string is not included, since the node name is enough to indicate the purpose of a node, as per the existing reserved-memory schema.
This binding does not include a binding for the memory 'attribute' property, defined by EFI_BOOT_SERVICES.GetMemoryMap(). It may be useful to have that as well, but perhaps not as a bit mask.
Changes in v4: - Make use of the reserved-memory node instead of creating a new one
Changes in v3: - Reword commit message again - cc a lot more people, from the FFI patch - Split out the attributes into the /memory nodes
Changes in v2: - Reword commit message
dtschema/schemas/memory-map.yaml | 61 +++++++++++++++++++ .../reserved-memory/common-reserved.yaml | 53 ++++++++++++++++ 2 files changed, 114 insertions(+) create mode 100644 dtschema/schemas/memory-map.yaml create mode 100644 dtschema/schemas/reserved-memory/common-reserved.yaml
diff --git a/dtschema/schemas/memory-map.yaml b/dtschema/schemas/memory-map.yaml new file mode 100644 index 0000000..4b06583 --- /dev/null +++ b/dtschema/schemas/memory-map.yaml @@ -0,0 +1,61 @@ +# SPDX-License-Identifier: BSD-2-Clause +# Copyright 2023 Google LLC +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/memory-map.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: /memory-map nodes +description: | + Common properties always required in /memory-map nodes. These nodes are + intended to resolve the nonchalant clause 3.4.1 ("/memory node and UEFI") + in the Devicetree Specification. + +maintainers: + - Simon Glass sjg@chromium.org + +properties: + $nodename: + const: 'memory-map' + +patternProperties: + "^([a-z][a-z0-9\-]+@[0-9a-f]+)?$": + type: object + additionalProperties: false + + properties: + reg: + minItems: 1 + maxItems: 1024 + + usage: + $ref: /schemas/types.yaml#/definitions/string + description: | + Describes the usage of the memory region, e.g.: + + "acpi-reclaim", "acpi-nvs", "bootcode", "bootdata", "bootdata", + "runtime-code", "runtime-data". + + See enum EFI_MEMORY_TYPE in "Unified Extensible Firmware Interface + (UEFI) Specification" for all the types. For now there are not + listed here. + + required: + - reg + +additionalProperties: false + +examples: + - | + memory-map { + acpi@f0000 { + reg = <0xf0000 0x4000>; + usage = "acpi-reclaim"; + }; + + runtime@12300000 { + reg = <0x12300000 0x28000>; + usage = "runtime-code"; + }; + }; +... diff --git a/dtschema/schemas/reserved-memory/common-reserved.yaml b/dtschema/schemas/reserved-memory/common-reserved.yaml new file mode 100644 index 0000000..70cdead --- /dev/null +++ b/dtschema/schemas/reserved-memory/common-reserved.yaml @@ -0,0 +1,53 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/reserved-memory/common-reserved.yaml# +$schema: http://devicetree.org/meta-schemas/base.yaml# + +title: Common memory reservations + +description: | + Specifies that the reserved memory region can be used for the purpose + indicated by its node name. + + Clients may reuse this reserved memory if they understand what it is for. + +maintainers: + - Simon Glass sjg@chromium.org + +# always select the core schema +select: true + +properties: + $nodename: + oneOf: + - acpi-reclaim + - acpi-nvs + - boot-code + - boot-data + - runtime-code + - runtime-data + + reg: + description: region of memory that is reserved for the purpose indicated + by the node name. + +required: + - reg + +unevaluatedProperties: false + +examples: + - | + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + + boot-code@12340000 { + reg = <0x12340000 0x00800000>; + }; + + boot-data@43210000 { + reg = <0x43210000 0x00800000>; + }; + };
Some memories provides ECC correction. For software which wants to check memory, it is helpful to see which regions provide this feature.
Add this as a property of the /memory nodes, since it presumably follows the hardware-level memory system.
(no changes since v3)
Changes in v3: - Add new patch to update the /memory nodes
dtschema/schemas/memory.yaml | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/dtschema/schemas/memory.yaml b/dtschema/schemas/memory.yaml index 1d74410..981af04 100644 --- a/dtschema/schemas/memory.yaml +++ b/dtschema/schemas/memory.yaml @@ -34,7 +34,14 @@ patternProperties: description: For the purpose of identification, each NUMA node is associated with a unique token known as a node id. - + attr: + $ref: /schemas/types.yaml#/definitions/string-array + description: | + Attributes possessed by this memory region: + + "single-bit-ecc" - supports single-bit ECC + "multi-bit-ecc" - supports multiple-bit ECC + "no-ecc" - non-ECC memory
required: - device_type
Changes in v3:
attr:
Kind of vague.
description: |
"supports" means corrects or reports? Most h/w supports both, but only reports multi-bit errors.
Don't define values in free form text.
This form is difficult to validate especially when non-ECC related attr's are added to the mix as we can't really define which combinations are valid. For example how do we prevent:
attr = "single-bit-ecc", "multi-bit-ecc";
Or maybe that's valid? If so, how would we express that?
Why do we need "no-ecc"? Is that the same as no "attr" property?
I think it's better if we have 'ecc-type' or something? Or generally, a property per class/type of attribute.
Rob
Hi Rob, Sorry for missing this: regarding your question on whether if the memory can support both single-bit and multi-bit ECC, i think the answer is yes. @Dong, Guo guo.dong@intel.com or @Chiu, Chasel chasel.chiu@intel.com could you help to confirm on this?
Thanks.
Best Regards, *Lean Sheng Tan*
9elements GmbH, Kortumstraße 19-21, 44787 Bochum, Germany Email: sheng.tan@9elements.com Phone: *+49 234 68 94 188 <+492346894188>* Mobile: *+49 176 76 113842 <+4917676113842>*
Registered office: Bochum Commercial register: Amtsgericht Bochum, HRB 17519 Management: Sebastian German, Eray Bazaar
Data protection information according to Art. 13 GDPR https://9elements.com/privacy
Changes in v3:
associated with
attr:
Kind of vague.
description: |
Rob
Hi Sheng,
On Wed, 6 Sept 2023 at 08:47, Lean Sheng Tan sheng.tan@9elements.com wrote:
Hi Rob, Sorry for missing this: regarding your question on whether if the memory can support both single-bit and multi-bit ECC, i think the answer is yes. @Dong, Guo or @Chiu, Chasel could you help to confirm on this?
I sent a v5 series which breaks these out into separate properties.
Thanks.
Best Regards, Lean Sheng Tan
9elements GmbH, Kortumstraße 19-21, 44787 Bochum, Germany Email: sheng.tan@9elements.com Phone: +49 234 68 94 188 Mobile: +49 176 76 113842
Changes in v3:
attr:
Kind of vague.
description: |
Rob
Lean Sheng Tan
Rob Herring
