[U-Boot] nios: Move README.nios_CONFIG_SYS_NIOS_CPU to doc/ dir
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
Hi Jean,
in the commit 6d0f6bcf (rename CFG_ macros to CONFIG_SYS), this README file was added into ${TOPDIR} dir. Was this intended?
Thanks,
Shinya
README.nios_CONFIG_SYS_NIOS_CPU | 140 ----------------------------------- doc/README.nios_CONFIG_SYS_NIOS_CPU | 140 +++++++++++++++++++++++++++++++++++ 2 files changed, 140 insertions(+), 140 deletions(-) delete mode 100644 README.nios_CONFIG_SYS_NIOS_CPU create mode 100644 doc/README.nios_CONFIG_SYS_NIOS_CPU
diff --git a/README.nios_CONFIG_SYS_NIOS_CPU b/README.nios_CONFIG_SYS_NIOS_CPU deleted file mode 100644 index 3547c34..0000000 --- a/README.nios_CONFIG_SYS_NIOS_CPU +++ /dev/null @@ -1,140 +0,0 @@ - -=============================================================================== - C F G _ N I O S _ C P U _ * v s . N I O S S D K -=============================================================================== - -When ever you have to make a new NIOS CPU configuration you can use this table -as a reference list to the original NIOS SDK symbols made by Alteras SOPC -Builder. Look into excalibur.h and excalibur.s in your SDK path cpu_sdk/inc. -Symbols beginning with a '[ptf]:' are coming from your SOPC sytem description -(PTF file) in sections WIZARD_SCRIPT_ARGUMENTS or SYSTEM_BUILDER_INFO. - -C O R E N I O S S D K [1],[7] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_CLK nasys_clock_freq -CONFIG_SYS_NIOS_CPU_ICACHE nasys_icache_size -CONFIG_SYS_NIOS_CPU_DCACHE nasys_dcache_size -CONFIG_SYS_NIOS_CPU_REG_NUMS nasys_nios_num_regs -CONFIG_SYS_NIOS_CPU_MUL __nios_use_multiply__ -CONFIG_SYS_NIOS_CPU_MSTEP __nios_use_mstep__ -CONFIG_SYS_NIOS_CPU_STACK nasys_stack_top -CONFIG_SYS_NIOS_CPU_VEC_BASE nasys_vector_table -CONFIG_SYS_NIOS_CPU_VEC_SIZE nasys_vector_table_size -CONFIG_SYS_NIOS_CPU_VEC_NUMS -CONFIG_SYS_NIOS_CPU_RST_VECT nasys_reset_address -CONFIG_SYS_NIOS_CPU_DBG_CORE nasys_debug_core -CONFIG_SYS_NIOS_CPU_RAM_BASE na_onchip_ram_64_kbytes -CONFIG_SYS_NIOS_CPU_RAM_SIZE na_onchip_ram_64_kbytes_size -CONFIG_SYS_NIOS_CPU_ROM_BASE na_boot_monitor_rom -CONFIG_SYS_NIOS_CPU_ROM_SIZE na_boot_monitor_rom_size -CONFIG_SYS_NIOS_CPU_OCI_BASE nasys_oci_core -CONFIG_SYS_NIOS_CPU_OCI_SIZE -CONFIG_SYS_NIOS_CPU_SRAM_BASE na_ext_ram nasys_program_mem - nasys_data_mem -CONFIG_SYS_NIOS_CPU_SRAM_SIZE na_ext_ram_size nasys_program_mem_size - nasys_data_mem_size -CONFIG_SYS_NIOS_CPU_SDRAM_BASE na_sdram -CONFIG_SYS_NIOS_CPU_SDRAM_SIZE na_sdram_size -CONFIG_SYS_NIOS_CPU_FLASH_BASE na_ext_flash nasys_main_flash - nasys_am29lv065d_flash_0 - nasys_flash_0 -CONFIG_SYS_NIOS_CPU_FLASH_SIZE na_ext_flash_size nasys_main_flash_size - -T I M E R N I O S S D K [3] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_TIMER_NUMS nasys_timer_count -CONFIG_SYS_NIOS_CPU_TIMER[0-9] nasys_timer_[0-9] -CONFIG_SYS_NIOS_CPU_TIMER[0-9]_IRQ nasys_timer_[0-9]_irq -CONFIG_SYS_NIOS_CPU_TIMER[0-9]_PER [ptf]:period - [ptf]:period_units - [ptf]:mult -CONFIG_SYS_NIOS_CPU_TIMER[0-9]_AR [ptf]:always_run -CONFIG_SYS_NIOS_CPU_TIMER[0-9]_FP [ptf]:fixed_period -CONFIG_SYS_NIOS_CPU_TIMER[0-9]_SS [ptf]:snapshot - -U A R T N I O S S D K [2] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_UART_NUMS nasys_uart_count -CONFIG_SYS_NIOS_CPU_UART[0-9] nasys_uart_[0-9] -CONFIG_SYS_NIOS_CPU_UART[0-9]_IRQ nasys_uart_[0-9]_irq -CONFIG_SYS_NIOS_CPU_UART[0-9]_BR [ptf]:baud -CONFIG_SYS_NIOS_CPU_UART[0-9]_DB [ptf]:data_bits -CONFIG_SYS_NIOS_CPU_UART[0-9]_SB [ptf]:stop_bits -CONFIG_SYS_NIOS_CPU_UART[0-9]_PA [ptf]:parity -CONFIG_SYS_NIOS_CPU_UART[0-9]_HS [ptf]:use_cts_rts -CONFIG_SYS_NIOS_CPU_UART[0-9]_EOP [ptf]:use_eop_register - -P I O N I O S S D K [4] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_PIO_NUMS nasys_pio_count -CONFIG_SYS_NIOS_CPU_PIO[0-9] nasys_pio_[0-9] -CONFIG_SYS_NIOS_CPU_PIO[0-9]_IRQ nasys_pio_[0-9]_irq -CONFIG_SYS_NIOS_CPU_PIO[0-9]_BITS [ptf]:Data_Width -CONFIG_SYS_NIOS_CPU_PIO[0-9]_TYPE [ptf]:has_tri - [ptf]:has_out - [ptf]:has_in -CONFIG_SYS_NIOS_CPU_PIO[0-9]_CAP [ptf]:capture -CONFIG_SYS_NIOS_CPU_PIO[0-9]_EDGE [ptf]:edge_type -CONFIG_SYS_NIOS_CPU_PIO[0-9]_ITYPE [ptf]:irq_type - -S P I N I O S S D K [6] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_SPI_NUMS nasys_spi_count -CONFIG_SYS_NIOS_CPU_SPI[0-9] nasys_spi_[0-9] -CONFIG_SYS_NIOS_CPU_SPI[0-9]_IRQ nasys_spi_[0-9]_irq -CONFIG_SYS_NIOS_CPU_SPI[0-9]_BITS [ptf]:databits -CONFIG_SYS_NIOS_CPU_SPI[0-9]_MA [ptf]:ismaster -CONFIG_SYS_NIOS_CPU_SPI[0-9]_SLN [ptf]:numslaves -CONFIG_SYS_NIOS_CPU_SPI[0-9]_TCLK [ptf]:targetclock -CONFIG_SYS_NIOS_CPU_SPI[0-9]_TDELAY [ptf]:targetdelay -CONFIG_SYS_NIOS_CPU_SPI[0-9]_* [ptf]:* - -I D E N I O S S D K -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_IDE_NUMS nasys_usersocket_count -CONFIG_SYS_NIOS_CPU_IDE[0-9] nasys_usersocket_[0-9] - -A S M I N I O S S D K [5] -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_ASMI_NUMS nasys_asmi_count -CONFIG_SYS_NIOS_CPU_ASMI[0-9] nasys_asmi_[0-9] -CONFIG_SYS_NIOS_CPU_ASMI[0-9]_IRQ nasys_asmi_[0-9]_irq - -E t h e r n e t ( L A N ) N I O S S D K -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_LAN_NUMS -CONFIG_SYS_NIOS_CPU_LAN[0-9]_BASE na_lan91c111 -CONFIG_SYS_NIOS_CPU_LAN[0-9]_OFFS LAN91C111_REGISTERS_OFFSET -CONFIG_SYS_NIOS_CPU_LAN[0-9]_IRQ na_lan91c111_irq -CONFIG_SYS_NIOS_CPU_LAN[0-9]_BUSW LAN91C111_DATA_BUS_WIDTH -CONFIG_SYS_NIOS_CPU_LAN[0-9]_TYPE - -s y s t e m c o m p o s i n g N I O S S D K -------------------------------------------------------------------------------- -CONFIG_SYS_NIOS_CPU_TICK_TIMER (na_low_priority_timer2) -CONFIG_SYS_NIOS_CPU_USER_TIMER (na_timer1) -CONFIG_SYS_NIOS_CPU_BUTTON_PIO (na_button_pio) -CONFIG_SYS_NIOS_CPU_LCD_PIO (na_lcd_pio) -CONFIG_SYS_NIOS_CPU_LED_PIO (na_led_pio) -CONFIG_SYS_NIOS_CPU_SEVENSEG_PIO (na_seven_seg_pio) -CONFIG_SYS_NIOS_CPU_RECONF_PIO (na_reconfig_request_pio) -CONFIG_SYS_NIOS_CPU_CFPRESENT_PIO (na_cf_present_pio) -CONFIG_SYS_NIOS_CPU_CFPOWER_PIO (na_cf_power_pio) -CONFIG_SYS_NIOS_CPU_CFATASEL_PIO (na_cf_ata_select_pio) -CONFIG_SYS_NIOS_CPU_USER_SPI (na_spi) - - -=============================================================================== - R E F E R E N C E S -=============================================================================== -[1] http://www.altera.com/literature/ds/ds_nioscpu.pdf -[2] http://www.altera.com/literature/ds/ds_nios_uart.pdf -[3] http://www.altera.com/literature/ds/ds_nios_timer.pdf -[4] http://www.altera.com/literature/ds/ds_nios_pio.pdf -[5] http://www.altera.com/literature/ds/ds_nios_asmi.pdf -[6] http://www.altera.com/literature/ds/ds_nios_spi.pdf -[7] http://www.altera.com/literature/ds/ds_legacy_sdram_ctrl.pdf - - -=============================================================================== -Stephan Linz linz@li-pro.net diff --git a/doc/README.nios_CONFIG_SYS_NIOS_CPU b/doc/README.nios_CONFIG_SYS_NIOS_CPU new file mode 100644 index 0000000..3547c34 --- /dev/null +++ b/doc/README.nios_CONFIG_SYS_NIOS_CPU @@ -0,0 +1,140 @@ + +=============================================================================== + C F G _ N I O S _ C P U _ * v s . N I O S S D K +=============================================================================== + +When ever you have to make a new NIOS CPU configuration you can use this table +as a reference list to the original NIOS SDK symbols made by Alteras SOPC +Builder. Look into excalibur.h and excalibur.s in your SDK path cpu_sdk/inc. +Symbols beginning with a '[ptf]:' are coming from your SOPC sytem description +(PTF file) in sections WIZARD_SCRIPT_ARGUMENTS or SYSTEM_BUILDER_INFO. + +C O R E N I O S S D K [1],[7] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_CLK nasys_clock_freq +CONFIG_SYS_NIOS_CPU_ICACHE nasys_icache_size +CONFIG_SYS_NIOS_CPU_DCACHE nasys_dcache_size +CONFIG_SYS_NIOS_CPU_REG_NUMS nasys_nios_num_regs +CONFIG_SYS_NIOS_CPU_MUL __nios_use_multiply__ +CONFIG_SYS_NIOS_CPU_MSTEP __nios_use_mstep__ +CONFIG_SYS_NIOS_CPU_STACK nasys_stack_top +CONFIG_SYS_NIOS_CPU_VEC_BASE nasys_vector_table +CONFIG_SYS_NIOS_CPU_VEC_SIZE nasys_vector_table_size +CONFIG_SYS_NIOS_CPU_VEC_NUMS +CONFIG_SYS_NIOS_CPU_RST_VECT nasys_reset_address +CONFIG_SYS_NIOS_CPU_DBG_CORE nasys_debug_core +CONFIG_SYS_NIOS_CPU_RAM_BASE na_onchip_ram_64_kbytes +CONFIG_SYS_NIOS_CPU_RAM_SIZE na_onchip_ram_64_kbytes_size +CONFIG_SYS_NIOS_CPU_ROM_BASE na_boot_monitor_rom +CONFIG_SYS_NIOS_CPU_ROM_SIZE na_boot_monitor_rom_size +CONFIG_SYS_NIOS_CPU_OCI_BASE nasys_oci_core +CONFIG_SYS_NIOS_CPU_OCI_SIZE +CONFIG_SYS_NIOS_CPU_SRAM_BASE na_ext_ram nasys_program_mem + nasys_data_mem +CONFIG_SYS_NIOS_CPU_SRAM_SIZE na_ext_ram_size nasys_program_mem_size + nasys_data_mem_size +CONFIG_SYS_NIOS_CPU_SDRAM_BASE na_sdram +CONFIG_SYS_NIOS_CPU_SDRAM_SIZE na_sdram_size +CONFIG_SYS_NIOS_CPU_FLASH_BASE na_ext_flash nasys_main_flash + nasys_am29lv065d_flash_0 + nasys_flash_0 +CONFIG_SYS_NIOS_CPU_FLASH_SIZE na_ext_flash_size nasys_main_flash_size + +T I M E R N I O S S D K [3] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_TIMER_NUMS nasys_timer_count +CONFIG_SYS_NIOS_CPU_TIMER[0-9] nasys_timer_[0-9] +CONFIG_SYS_NIOS_CPU_TIMER[0-9]_IRQ nasys_timer_[0-9]_irq +CONFIG_SYS_NIOS_CPU_TIMER[0-9]_PER [ptf]:period + [ptf]:period_units + [ptf]:mult +CONFIG_SYS_NIOS_CPU_TIMER[0-9]_AR [ptf]:always_run +CONFIG_SYS_NIOS_CPU_TIMER[0-9]_FP [ptf]:fixed_period +CONFIG_SYS_NIOS_CPU_TIMER[0-9]_SS [ptf]:snapshot + +U A R T N I O S S D K [2] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_UART_NUMS nasys_uart_count +CONFIG_SYS_NIOS_CPU_UART[0-9] nasys_uart_[0-9] +CONFIG_SYS_NIOS_CPU_UART[0-9]_IRQ nasys_uart_[0-9]_irq +CONFIG_SYS_NIOS_CPU_UART[0-9]_BR [ptf]:baud +CONFIG_SYS_NIOS_CPU_UART[0-9]_DB [ptf]:data_bits +CONFIG_SYS_NIOS_CPU_UART[0-9]_SB [ptf]:stop_bits +CONFIG_SYS_NIOS_CPU_UART[0-9]_PA [ptf]:parity +CONFIG_SYS_NIOS_CPU_UART[0-9]_HS [ptf]:use_cts_rts +CONFIG_SYS_NIOS_CPU_UART[0-9]_EOP [ptf]:use_eop_register + +P I O N I O S S D K [4] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_PIO_NUMS nasys_pio_count +CONFIG_SYS_NIOS_CPU_PIO[0-9] nasys_pio_[0-9] +CONFIG_SYS_NIOS_CPU_PIO[0-9]_IRQ nasys_pio_[0-9]_irq +CONFIG_SYS_NIOS_CPU_PIO[0-9]_BITS [ptf]:Data_Width +CONFIG_SYS_NIOS_CPU_PIO[0-9]_TYPE [ptf]:has_tri + [ptf]:has_out + [ptf]:has_in +CONFIG_SYS_NIOS_CPU_PIO[0-9]_CAP [ptf]:capture +CONFIG_SYS_NIOS_CPU_PIO[0-9]_EDGE [ptf]:edge_type +CONFIG_SYS_NIOS_CPU_PIO[0-9]_ITYPE [ptf]:irq_type + +S P I N I O S S D K [6] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_SPI_NUMS nasys_spi_count +CONFIG_SYS_NIOS_CPU_SPI[0-9] nasys_spi_[0-9] +CONFIG_SYS_NIOS_CPU_SPI[0-9]_IRQ nasys_spi_[0-9]_irq +CONFIG_SYS_NIOS_CPU_SPI[0-9]_BITS [ptf]:databits +CONFIG_SYS_NIOS_CPU_SPI[0-9]_MA [ptf]:ismaster +CONFIG_SYS_NIOS_CPU_SPI[0-9]_SLN [ptf]:numslaves +CONFIG_SYS_NIOS_CPU_SPI[0-9]_TCLK [ptf]:targetclock +CONFIG_SYS_NIOS_CPU_SPI[0-9]_TDELAY [ptf]:targetdelay +CONFIG_SYS_NIOS_CPU_SPI[0-9]_* [ptf]:* + +I D E N I O S S D K +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_IDE_NUMS nasys_usersocket_count +CONFIG_SYS_NIOS_CPU_IDE[0-9] nasys_usersocket_[0-9] + +A S M I N I O S S D K [5] +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_ASMI_NUMS nasys_asmi_count +CONFIG_SYS_NIOS_CPU_ASMI[0-9] nasys_asmi_[0-9] +CONFIG_SYS_NIOS_CPU_ASMI[0-9]_IRQ nasys_asmi_[0-9]_irq + +E t h e r n e t ( L A N ) N I O S S D K +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_LAN_NUMS +CONFIG_SYS_NIOS_CPU_LAN[0-9]_BASE na_lan91c111 +CONFIG_SYS_NIOS_CPU_LAN[0-9]_OFFS LAN91C111_REGISTERS_OFFSET +CONFIG_SYS_NIOS_CPU_LAN[0-9]_IRQ na_lan91c111_irq +CONFIG_SYS_NIOS_CPU_LAN[0-9]_BUSW LAN91C111_DATA_BUS_WIDTH +CONFIG_SYS_NIOS_CPU_LAN[0-9]_TYPE + +s y s t e m c o m p o s i n g N I O S S D K +------------------------------------------------------------------------------- +CONFIG_SYS_NIOS_CPU_TICK_TIMER (na_low_priority_timer2) +CONFIG_SYS_NIOS_CPU_USER_TIMER (na_timer1) +CONFIG_SYS_NIOS_CPU_BUTTON_PIO (na_button_pio) +CONFIG_SYS_NIOS_CPU_LCD_PIO (na_lcd_pio) +CONFIG_SYS_NIOS_CPU_LED_PIO (na_led_pio) +CONFIG_SYS_NIOS_CPU_SEVENSEG_PIO (na_seven_seg_pio) +CONFIG_SYS_NIOS_CPU_RECONF_PIO (na_reconfig_request_pio) +CONFIG_SYS_NIOS_CPU_CFPRESENT_PIO (na_cf_present_pio) +CONFIG_SYS_NIOS_CPU_CFPOWER_PIO (na_cf_power_pio) +CONFIG_SYS_NIOS_CPU_CFATASEL_PIO (na_cf_ata_select_pio) +CONFIG_SYS_NIOS_CPU_USER_SPI (na_spi) + + +=============================================================================== + R E F E R E N C E S +=============================================================================== +[1] http://www.altera.com/literature/ds/ds_nioscpu.pdf +[2] http://www.altera.com/literature/ds/ds_nios_uart.pdf +[3] http://www.altera.com/literature/ds/ds_nios_timer.pdf +[4] http://www.altera.com/literature/ds/ds_nios_pio.pdf +[5] http://www.altera.com/literature/ds/ds_nios_asmi.pdf +[6] http://www.altera.com/literature/ds/ds_nios_spi.pdf +[7] http://www.altera.com/literature/ds/ds_legacy_sdram_ctrl.pdf + + +=============================================================================== +Stephan Linz linz@li-pro.net
Hi Jean,
Tks, I've seen it and also send a patch to fix
He must be somewhere on the ML
Best Regards, J.
Dear Shinya Kuribayashi,
Hi Jean,
Thanks,
Shinya
Applied, thanks.
You should have crated a rename patch, though.
Jean-Christophe PLAGNIOL-VILLARD
Shinya Kuribayashi
