[PATCH] riscv: ae350: Fix xip config boot failure
It will fail to boot with ae350_rv[32|64]_spl_xip_defconfig. It need to add OONFIG_XIP to get the specific HW address for DTB. Also drop OF_SEPARATE in board_fdt_blob_setup() because it will never reach here anyway.It only allow OF_BOARD to call board_fdt_blob_setup() in fdtdec_setup().
Fixes: 2e8d2f88439d ("riscv: Remove OF_PRIOR_STAGE from RISC-V boards") Signed-off-by: Rick Chen rick@andestech.com --- board/AndesTech/ax25-ae350/ax25-ae350.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/board/AndesTech/ax25-ae350/ax25-ae350.c b/board/AndesTech/ax25-ae350/ax25-ae350.c index d6a4291..9ca7fdf 100644 --- a/board/AndesTech/ax25-ae350/ax25-ae350.c +++ b/board/AndesTech/ax25-ae350/ax25-ae350.c @@ -54,13 +54,20 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) return 0; }
+#define ANDES_HW_DTB_ADDRESS 0xF2000000 void *board_fdt_blob_setup(int *err) { *err = 0; + #if defined(CONFIG_OF_BOARD) - return (void *)(ulong)gd->arch.firmware_fdt_addr; -#elif defined(CONFIG_OF_SEPARATE) +#if (defined(CONFIG_XIP) && CONFIG_IS_ENABLED(RISCV_MMODE)) + if (fdt_magic(CONFIG_SYS_FDT_BASE) == FDT_MAGIC) return (void *)CONFIG_SYS_FDT_BASE; + return (void *)ANDES_HW_DTB_ADDRESS; +#else + + return (void *)(ulong)gd->arch.firmware_fdt_addr; +#endif #else *err = -EINVAL; return NULL;
Andes
