[U-Boot] USB doesn't work on Rockpro64 in u-boot
Hi Akash, Jagan,
Looks like USB is not functional in u-boot on Rockpro64. u-boot is from git, commit 680023c5fab6b1777c0c6f2e76e5d2effb7903a0.
I'm using u-boot SPL and mainline ATF (19adcb415c313d656324d54e7608cdc7d7a5c414 is ATF commit)
'usb start' doesn't detect anything but hubs and looks like there's no power on USB ports:
=> usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found
=> usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
Regulators were probed correctly according to 'dm tree':
regulator 14 [ + ] fixed regulator |-- vcc12v-dcin regulator 15 [ + ] fixed regulator |-- vcc1v8-s3 regulator 16 [ + ] fixed regulator |-- vcc3v3-pcie-regulator regulator 17 [ + ] fixed regulator |-- vcc3v3-sys regulator 18 [ + ] fixed regulator |-- vcc5v0-host-regulator regulator 19 [ + ] fixed regulator |-- vcc5v0-typec-regulator regulator 20 [ + ] fixed regulator |-- vcc5v0-sys regulator 21 [ + ] fixed regulator |-- vcc5v0-usb regulator 22 [ + ] pwm_regulator `-- vdd-log
Any ideas what can be wrong? Have it worked before?
Regards, Vasily
Hi Vasily,
On Wed, Nov 6, 2019 at 9:17 AM Vasily Khoruzhick anarsoul@gmail.com wrote:
Hi Akash, Jagan,
I remember my last checking, give me sometime will check it on master and update you.
Jagan.
On Wed, Nov 6, 2019 at 8:50 AM Jagan Teki jagan@amarulasolutions.com wrote:
Hi Vasily,
Hi Akash, Jagan,
Looks like gpio clock is not enabled anywhere in u-boot for rk3399, so gpios just don't work.
rk3399 clock driver is very rudimentary and doesn't touch clock gates at all.
Can anyone explain how it's supposed to work?
Jagan.
Hi Vasily,
Hi Akash, Jagan,
I was wrong about clock, it appears that set bin in CRU is disabled clock. Yet GPIOs don't work in u-boot, e.g.
=> gpio set 154 gpio: pin 154 (gpio 154) value is 1 Warning: value of pin is still 0
154 is vcc5v0-host-regulator.gpio.
Jagan.
I checked voltage on regulator enable pin and it's 1.5v in u-boot (and it's not enough to enable regulator!) and in linux it's 3v. That's why USB ports have no power in u-boot.
Looks like u-boot doesn't switch GPIO voltage from 1.8v to 3.3v. Any ideas how to fix this?
Hi Vasily,
Hi Akash, Jagan,
Jagan.
Hi Vasily,
I think I need to clock look of this, will look into it next week. I'm travelling till that time.
On Thu, Nov 7, 2019 at 10:33 PM Jagan Teki jagan@amarulasolutions.com wrote:
Hi Vasily,
I figured it out, rockpro64 needs I/O domains to be configured in order for USB to work.
See "rockchip: rk3399: split rockpro64 out of evb_rk3399" patch on ML.
Jagan Teki
Vasily Khoruzhick
