[U-Boot] [PATCH] OMAP3: omap3_logic: Remove LCD preboot info
The LCD isn't supported in U-Boot and the LCD is now configured in the device tree, so this code is pointless.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index a7649ca..ff7bf92 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -128,27 +128,8 @@
/* Environment information */
-/* - * PREBOOT assumes the 4.3" display is attached. User can interrupt - * and modify display variable to suit their needs. - */ #define CONFIG_PREBOOT \ - "echo ======================NOTICE============================;"\ - "echo "The u-boot environment is not set.";" \ - "echo "If using a display a valid display variable for your panel";" \ - "echo "needs to be set.";" \ - "echo "Valid display options are:";" \ - "echo " 2 == LQ121S1DG31 TFT SVGA (12.1) Sharp";" \ - "echo " 3 == LQ036Q1DA01 TFT QVGA (3.6) Sharp w/ASIC";" \ - "echo " 5 == LQ064D343 TFT VGA (6.4) Sharp";" \ - "echo " 7 == LQ10D368 TFT VGA (10.4) Sharp";" \ - "echo " 15 == LQ043T1DG01 TFT WQVGA (4.3) Sharp (DEFAULT)";" \ - "echo " vga[-dvi or -hdmi] LCD VGA 640x480";" \ - "echo " svga[-dvi or -hdmi] LCD SVGA 800x600";" \ - "echo " xga[-dvi or -hdmi] LCD XGA 1024x768";" \ - "echo " 720p[-dvi or -hdmi] LCD 720P 1280x720";" \ - "echo "Defaulting to 4.3 LCD panel (display=15).";" \ - "setenv display 15;" \ + "setenv preboot;" \ "nand unlock;" \ "saveenv;"
Adam Ford
