[U-Boot] [PATCH] time: fix gcc warnings on MIPS64
Commit 8dfafdde88eb3e71d5569846396ae67a91017232 introduced new gcc warnings on MIPS64:
time.c: In function 'tick_to_time': time.c:59:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:59:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' time.c: In function 'usec_to_tick': time.c:76:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:76:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *'
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- lib/time.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/time.c b/lib/time.c index 111b493..09bb05a 100644 --- a/lib/time.c +++ b/lib/time.c @@ -51,7 +51,7 @@ unsigned long long __weak notrace get_ticks(void) return ((unsigned long long)gd->timebase_h << 32) | gd->timebase_l; }
-static unsigned long long notrace tick_to_time(unsigned long long tick) +static unsigned long long notrace tick_to_time(uint64_t tick) { unsigned int div = get_tbclk();
@@ -71,7 +71,7 @@ unsigned long __weak notrace timer_get_us(void) } static unsigned long long usec_to_tick(unsigned long usec) { - unsigned long long tick = usec * get_tbclk(); + uint64_t tick = usec * get_tbclk(); usec *= get_tbclk(); do_div(tick, 1000000); return tick;
Daniel Schwierzeck
