[PATCH] doc: board: freescale: imx8mp_evk: update to newer versions and change ATF_LOAD_ADDR
Update imx-atf and firmware-imx to latest released versions.
Update address of ATF_LOAD_ADDR that has changed to 0x490000 in imx-atf commit 48733cb4e773a7584ced601de9d717efa3d73815.
Add 'O=' to make instructions as one issue has been noticed where it was trouble building directly inside u-boot source dir.
Signed-off-by: Peter Bergin peter@berginkonsult.se Cc: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com --- doc/board/freescale/imx8mp_evk.rst | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/doc/board/freescale/imx8mp_evk.rst b/doc/board/freescale/imx8mp_evk.rst index ccffcf7257..5ca3bb8199 100644 --- a/doc/board/freescale/imx8mp_evk.rst +++ b/doc/board/freescale/imx8mp_evk.rst @@ -18,7 +18,7 @@ Get and Build the ARM Trusted firmware
Note: $(srctree) is the U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf -branch: imx_5.4.47_2.2.0 +branch: imx_5.4.70_2.3.0
.. code-block:: bash
@@ -30,13 +30,13 @@ Get the ddr firmware
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin - $ chmod +x firmware-imx-8.9.bin - $ ./firmware-imx-8.9.bin - $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin - $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_201904.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin - $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin - $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_201904.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.10.bin + $ chmod +x firmware-imx-8.10.bin + $ ./firmware-imx-8.10.bin + $ cp firmware-imx-8.10/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_202006.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin + $ cp firmware-imx-8.10/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_202006.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin + $ cp firmware-imx-8.10/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_202006.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin + $ cp firmware-imx-8.10/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_202006.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
Build U-Boot ------------ @@ -44,15 +44,15 @@ Build U-Boot .. code-block:: bash
$ export CROSS_COMPILE=aarch64-poky-linux- - $ make imx8mp_evk_defconfig - $ export ATF_LOAD_ADDR=0x960000 - $ make flash.bin + $ make O=build imx8mp_evk_defconfig + $ export ATF_LOAD_ADDR=0x970000 + $ make O=build flash.bin
Burn the flash.bin to the MicroSD card at offset 32KB:
- $sudo dd if=flash.bin of=/dev/sd[x] bs=1K seek=32 conv=notrunc; sync + $sudo dd if=build/flash.bin of=/dev/sd[x] bs=1K seek=32 conv=notrunc; sync
Boot ----
Hello Peter,
-----Original Message----- From: Peter Bergin peter@berginkonsult.se Sent: Friday, February 12, 2021 2:57 PM To: u-boot@lists.denx.de Cc: Peter Bergin peter@berginkonsult.se; ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Subject: [PATCH] doc: board: freescale: imx8mp_evk: update to newer versions and change ATF_LOAD_ADDR
Commit message is incorrect, ATF_LOAD_ADDR is actually set to 0x970000
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.10.bin
- $ chmod +x firmware-imx-8.10.bin
- $ ./firmware-imx-8.10.bin
- $ cp
- firmware-imx-
- 6.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
Build U-Boot
- $ make flash.bin
- $ make O=build imx8mp_evk_defconfig
As a suggestion: maybe it is better to change the order here when `make O=build imx8mp_evk_defconfig` called first, followed by copy of DDR firmware and ATF binary.
This would make sure that the ./build folder would already exist at the time copy operations are executed, and should make step-by-step instructions more transparent.
- $ export ATF_LOAD_ADDR=0x970000
- $ make O=build flash.bin
- $sudo dd if=build/flash.bin of=/dev/sd[x] bs=1K seek=32
- conv=notrunc; sync
Boot
-- 2.25.1
Otherwise: Reviewed-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com
Cheers, Andrey
Hi Andrey,
thanks for the review!
On 2021-02-12 19:16, ZHIZHIKIN Andrey wrote:
Hello Peter,
Good catch and it is indeed wrong.
- $ cp
- firmware-imx-
- 6.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin Build U-Boot
- $ make flash.bin
Good suggestion.
conv=notrunc; sync
Boot
-- 2.25.1
Cheers, Andrey
Will update and send a v2 on this.
Best regards, /Peter
Peter Bergin
ZHIZHIKIN Andrey
