[U-Boot] [PATCH v3 0/8] SATA support for omap5_uevm and dra7_evm
This series adds SATA support for OMAP5 uevm and DRA7 evm.
Patches are also availabe at git@github.com:rogerq/u-boot.git sata
v3: - get rid of custom perror() macro, use printf - Fixed coding sytle issues
v2: - Address review comments in the RFC series - Fix cache align error in the ahci driver - Added dra7 support
cheers, -roger
Roger Quadros (8): ahci: Error out with message on malloc() failure ahci: Fix cache align error messages ARM: OMAP5: Add Pipe3 PHY driver ARM: OMAP5: Add PRCM and Control information for SATA ARM: OMAP5: Add SATA platform glue ARM: omap5_uevm: Add SATA support ARM: DRA7xx: Add PRCM and Control information for SATA ARM: dra7_evm: Add SATA support
arch/arm/cpu/armv7/omap-common/Makefile | 5 + arch/arm/cpu/armv7/omap-common/pipe3-phy.c | 231 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/pipe3-phy.h | 36 +++++ arch/arm/cpu/armv7/omap-common/sata.c | 75 ++++++++++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 7 + arch/arm/include/asm/arch-omap5/clock.h | 3 + arch/arm/include/asm/arch-omap5/omap.h | 3 + arch/arm/include/asm/arch-omap5/sata.h | 48 ++++++ arch/arm/include/asm/omap_common.h | 2 + board/ti/dra7xx/evm.c | 7 + board/ti/omap5_uevm/evm.c | 7 + drivers/block/ahci.c | 18 ++- include/configs/dra7xx_evm.h | 11 ++ include/configs/omap5_uevm.h | 10 ++ 14 files changed, 457 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.c create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.h create mode 100644 arch/arm/cpu/armv7/omap-common/sata.c create mode 100644 arch/arm/include/asm/arch-omap5/sata.h
If malloc() fails, we don't want to continue in ahci_init() and ahci_init_one(). Also print a more informative error message on malloc() failures.
CC: Rob Herring rob.herring@calxeda.com Signed-off-by: Roger Quadros rogerq@ti.com --- drivers/block/ahci.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 0daad36..e24d634 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -379,6 +379,11 @@ static int ahci_init_one(pci_dev_t pdev) int rc;
probe_ent = malloc(sizeof(struct ahci_probe_ent)); + if (!probe_ent) { + printf("%s: No memory for probe_ent\n", __func__); + return -ENOMEM; + } + memset(probe_ent, 0, sizeof(struct ahci_probe_ent)); probe_ent->dev = pdev;
@@ -503,7 +508,7 @@ static int ahci_port_start(u8 port) mem = (u32) malloc(AHCI_PORT_PRIV_DMA_SZ + 2048); if (!mem) { free(pp); - printf("No mem for table!\n"); + printf("%s: No mem for table!\n", __func__); return -ENOMEM; }
@@ -638,8 +643,10 @@ static int ata_scsiop_inquiry(ccb *pccb) /* Read id from sata */ port = pccb->target; tmpid = malloc(ATA_ID_WORDS * 2); - if (!tmpid) + if (!tmpid) { + printf("%s: No memory for tmpid\n", __func__); return -ENOMEM; + }
if (ahci_device_data_io(port, (u8 *) &fis, sizeof(fis), (u8 *)tmpid, ATA_ID_WORDS * 2, 0)) { @@ -889,6 +896,11 @@ int ahci_init(u32 base) u32 linkmap;
probe_ent->host_flags = ATA_FLAG_SATA
Align the ATA ID buffer to the cache-line boundary. This gets rid of the below error mesages on ARM v7 platforms.
scanning bus for devices... ERROR: v7_dcache_inval_range - start address is not aligned - 0xfee48618 ERROR: v7_dcache_inval_range - stop address is not aligned - 0xfee48818
CC: Aneesh V aneesh@ti.com Signed-off-by: Roger Quadros rogerq@ti.com --- drivers/block/ahci.c | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index e24d634..e64df4f 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -623,7 +623,7 @@ static int ata_scsiop_inquiry(ccb *pccb) 95 - 4, }; u8 fis[20]; - u16 *tmpid; + ALLOC_CACHE_ALIGN_BUFFER(u16, tmpid, ATA_ID_WORDS); u8 port;
/* Clean ccb data buffer */ @@ -642,16 +642,10 @@ static int ata_scsiop_inquiry(ccb *pccb)
/* Read id from sata */ port = pccb->target; - tmpid = malloc(ATA_ID_WORDS * 2); - if (!tmpid) { - printf("%s: No memory for tmpid\n", __func__); - return -ENOMEM; - }
if (ahci_device_data_io(port, (u8 *) &fis, sizeof(fis), (u8 *)tmpid, ATA_ID_WORDS * 2, 0)) { debug("scsi_ahci: SCSI inquiry command failure.\n"); - free(tmpid); return -EIO; }
Pipe3 PHY is used by SATA, USB3 and PCIe modules. This is a driver for the Pipe3 PHY.
Signed-off-by: Roger Quadros rogerq@ti.com --- arch/arm/cpu/armv7/omap-common/Makefile | 4 + arch/arm/cpu/armv7/omap-common/pipe3-phy.c | 231 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/pipe3-phy.h | 36 +++++ 3 files changed, 271 insertions(+) create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.c create mode 100644 arch/arm/cpu/armv7/omap-common/pipe3-phy.h
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 4d3a165..bfaf814 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -17,6 +17,10 @@ obj-y += vc.o obj-y += abb.o endif
+ifneq ($(CONFIG_OMAP54XX),) +COBJS += pipe3-phy.o +endif + ifeq ($(CONFIG_OMAP34XX),) obj-y += boot-common.o obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/armv7/omap-common/pipe3-phy.c b/arch/arm/cpu/armv7/omap-common/pipe3-phy.c new file mode 100644 index 0000000..b71d769 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/pipe3-phy.c @@ -0,0 +1,231 @@ +/* + * TI PIPE3 PHY + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <sata.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/errno.h> +#include "pipe3-phy.h" + +/* PLLCTRL Registers */ +#define PLL_STATUS 0x00000004 +#define PLL_GO 0x00000008 +#define PLL_CONFIGURATION1 0x0000000C +#define PLL_CONFIGURATION2 0x00000010 +#define PLL_CONFIGURATION3 0x00000014 +#define PLL_CONFIGURATION4 0x00000020 + +#define PLL_REGM_MASK 0x001FFE00 +#define PLL_REGM_SHIFT 9 +#define PLL_REGM_F_MASK 0x0003FFFF +#define PLL_REGM_F_SHIFT 0 +#define PLL_REGN_MASK 0x000001FE +#define PLL_REGN_SHIFT 1 +#define PLL_SELFREQDCO_MASK 0x0000000E +#define PLL_SELFREQDCO_SHIFT 1 +#define PLL_SD_MASK 0x0003FC00 +#define PLL_SD_SHIFT 10 +#define SET_PLL_GO 0x1 +#define PLL_TICOPWDN BIT(16) +#define PLL_LDOPWDN BIT(15) +#define PLL_LOCK 0x2 +#define PLL_IDLE 0x1 + +/* PHY POWER CONTROL Register */ +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK 0x003FC000 +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT 0xE + +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK 0xFFC00000 +#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT 0x16 + +#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON 0x3 +#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF 0x0 + + +#define PLL_IDLE_TIME 100 /* in milliseconds */ +#define PLL_LOCK_TIME 100 /* in milliseconds */ + +static inline u32 omap_pipe3_readl(void __iomem *addr, unsigned offset) +{ + return __raw_readl(addr + offset); +} + +static inline void omap_pipe3_writel(void __iomem *addr, unsigned offset, + u32 data) +{ + __raw_writel(data, addr + offset); +} + +static struct pipe3_dpll_params *omap_pipe3_get_dpll_params(struct omap_pipe3 + *pipe3) +{ + u32 rate; + struct pipe3_dpll_map *dpll_map = pipe3->dpll_map; + + rate = get_sys_clk_freq(); + + for (; dpll_map->rate; dpll_map++) { + if (rate == dpll_map->rate) + return &dpll_map->params; + } + + printf("%s: No DPLL configuration for %u Hz SYS CLK\n", + __func__, rate); + return NULL; +} + + +static int omap_pipe3_wait_lock(struct omap_pipe3 *phy) +{ + u32 val; + int timeout = PLL_LOCK_TIME; + + do { + mdelay(1); + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); + if (val & PLL_LOCK) + break; + } while (--timeout); + + if (!(val & PLL_LOCK)) { + printf("%s: DPLL failed to lock\n", __func__); + return -EBUSY; + } + + return 0; +} + +static int omap_pipe3_dpll_program(struct omap_pipe3 *phy) +{ + u32 val; + struct pipe3_dpll_params *dpll_params; + + dpll_params = omap_pipe3_get_dpll_params(phy); + if (!dpll_params) { + printf("%s: Invalid DPLL parameters\n", __func__); + return -EINVAL; + } + + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION1); + val &= ~PLL_REGN_MASK; + val |= dpll_params->n << PLL_REGN_SHIFT; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION1, val); + + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); + val &= ~PLL_SELFREQDCO_MASK; + val |= dpll_params->freq << PLL_SELFREQDCO_SHIFT; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION2, val); + + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION1); + val &= ~PLL_REGM_MASK; + val |= dpll_params->m << PLL_REGM_SHIFT; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION1, val); + + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION4); + val &= ~PLL_REGM_F_MASK; + val |= dpll_params->mf << PLL_REGM_F_SHIFT; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION4, val); + + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION3); + val &= ~PLL_SD_MASK; + val |= dpll_params->sd << PLL_SD_SHIFT; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION3, val); + + omap_pipe3_writel(phy->pll_ctrl_base, PLL_GO, SET_PLL_GO); + + return omap_pipe3_wait_lock(phy); +} + +static void omap_control_phy_power(struct omap_pipe3 *phy, int on) +{ + u32 val, rate; + + val = readl(phy->power_reg); + + rate = get_sys_clk_freq(); + rate = rate/1000000; + + if (on) { + val &= ~(OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK | + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK); + val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; + val |= rate << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT; + } else { + val &= ~OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK; + val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF << + OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; + } + + writel(val, phy->power_reg); +} + +int phy_pipe3_power_on(struct omap_pipe3 *phy) +{ + int ret; + u32 val; + + /* Program the DPLL only if not locked */ + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); + if (!(val & PLL_LOCK)) { + ret = omap_pipe3_dpll_program(phy); + if (ret) + return ret; + } else { + /* else just bring it out of IDLE mode */ + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); + if (val & PLL_IDLE) { + val &= ~PLL_IDLE; + omap_pipe3_writel(phy->pll_ctrl_base, + PLL_CONFIGURATION2, val); + ret = omap_pipe3_wait_lock(phy); + if (ret) + return ret; + } + } + + /* Power up the PHY */ + omap_control_phy_power(phy, 1); + + return 0; +} + +int phy_pipe3_power_off(struct omap_pipe3 *phy) +{ + u32 val; + int timeout = PLL_IDLE_TIME; + + /* Power down the PHY */ + omap_control_phy_power(phy, 0); + + /* Put DPLL in IDLE mode */ + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); + val |= PLL_IDLE; + omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION2, val); + + /* wait for LDO and Oscillator to power down */ + do { + mdelay(1); + val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); + if ((val & PLL_TICOPWDN) && (val & PLL_LDOPWDN)) + break; + } while (--timeout); + + if (!(val & PLL_TICOPWDN) || !(val & PLL_LDOPWDN)) { + printf("%s: Failed to power down DPLL: PLL_STATUS 0x%x\n", + __func__, val); + return -EBUSY; + } + + return 0; +} + diff --git a/arch/arm/cpu/armv7/omap-common/pipe3-phy.h b/arch/arm/cpu/armv7/omap-common/pipe3-phy.h new file mode 100644 index 0000000..441f49a --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/pipe3-phy.h @@ -0,0 +1,36 @@ +/* + * TI PIPE3 PHY + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __OMAP_PIPE3_PHY_H +#define __OMAP_PIPE3_PHY_H + +struct pipe3_dpll_params { + u16 m; + u8 n; + u8 freq:3; + u8 sd; + u32 mf; +}; + +struct pipe3_dpll_map { + unsigned long rate; + struct pipe3_dpll_params params; +}; + +struct omap_pipe3 { + void __iomem *pll_ctrl_base; + void __iomem *power_reg; + struct pipe3_dpll_map *dpll_map; +}; + + +int phy_pipe3_power_on(struct omap_pipe3 *phy); +int phy_pipe3_power_off(struct omap_pipe3 *pipe3); + +#endif /* __OMAP_PIPE3_PHY_H */
Adds the necessary PRCM and Control register information for SATA on OMAP5.
Signed-off-by: Roger Quadros rogerq@ti.com --- arch/arm/cpu/armv7/omap5/prcm-regs.c | 4 ++++ arch/arm/include/asm/arch-omap5/clock.h | 3 +++ arch/arm/include/asm/arch-omap5/omap.h | 3 +++ arch/arm/include/asm/omap_common.h | 2 ++ 4 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index 304ac1c..5c60d74 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -203,8 +203,10 @@ struct prcm_regs const omap5_es1_prcm = { .cm_l3init_hsusbotg_clkctrl = 0x4a009360, .cm_l3init_hsusbtll_clkctrl = 0x4a009368, .cm_l3init_p1500_clkctrl = 0x4a009378, + .cm_l3init_sata_clkctrl = 0x4a009388, .cm_l3init_fsusb_clkctrl = 0x4a0093d0, .cm_l3init_ocp2scp1_clkctrl = 0x4a0093e0, + .cm_l3init_ocp2scp3_clkctrl = 0x4a0093e8,
/* cm2.l4per */ .cm_l4per_clkstctrl = 0x4a009400, @@ -296,6 +298,7 @@ struct omap_sys_ctrl_regs const omap5_ctrl = { .control_status = 0x4A002134, .control_std_fuse_opp_vdd_mpu_2 = 0x4A0021B4, .control_phy_power_usb = 0x4A002370, + .control_phy_power_sata = 0x4A002374, .control_padconf_core_base = 0x4A002800, .control_paconf_global = 0x4A002DA0, .control_paconf_mode = 0x4A002DA4, @@ -698,6 +701,7 @@ struct prcm_regs const omap5_es2_prcm = { .cm_l3init_hsusbotg_clkctrl = 0x4a009660, .cm_l3init_hsusbtll_clkctrl = 0x4a009668, .cm_l3init_p1500_clkctrl = 0x4a009678, + .cm_l3init_sata_clkctrl = 0x4a009688, .cm_l3init_fsusb_clkctrl = 0x4a0096d0, .cm_l3init_ocp2scp1_clkctrl = 0x4a0096e0, .cm_l3init_ocp2scp3_clkctrl = 0x4a0096e8, diff --git a/arch/arm/include/asm/arch-omap5/clock.h b/arch/arm/include/asm/arch-omap5/clock.h index 8869b50..2dfe4ef 100644 --- a/arch/arm/include/asm/arch-omap5/clock.h +++ b/arch/arm/include/asm/arch-omap5/clock.h @@ -137,6 +137,9 @@ #define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) #define HSMMC_CLKCTRL_CLKSEL_DIV_MASK (1 << 25)
+/* CM_L3INIT_SATA_CLKCTRL */ +#define SATA_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + /* CM_WKUP_GPTIMER1_CLKCTRL */ #define GPTIMER1_CLKCTRL_CLKSEL_MASK (1 << 24)
diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 414d37a..150db0f 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -64,6 +64,9 @@ /* QSPI */ #define QSPI_BASE 0x4B300000
+/* SATA */ +#define DWC_AHSATA_BASE 0x4A140000 + /* * Hardware Register Details */ diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 8a395e8..382da90 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -226,6 +226,7 @@ struct prcm_regs { u32 cm_l3init_hsusbotg_clkctrl; u32 cm_l3init_hsusbtll_clkctrl; u32 cm_l3init_p1500_clkctrl; + u32 cm_l3init_sata_clkctrl; u32 cm_l3init_fsusb_clkctrl; u32 cm_l3init_ocp2scp1_clkctrl; u32 cm_l3init_ocp2scp3_clkctrl; @@ -366,6 +367,7 @@ struct omap_sys_ctrl_regs { u32 control_ldosram_mpu_voltage_ctrl; u32 control_ldosram_core_voltage_ctrl; u32 control_usbotghs_ctrl; + u32 control_phy_power_sata; u32 control_padconf_core_base; u32 control_paconf_global; u32 control_paconf_mode;
Add platform glue logic for the SATA controller.
Signed-off-by: Roger Quadros rogerq@ti.com --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/sata.c | 75 +++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap5/sata.h | 48 +++++++++++++++++++++ 3 files changed, 124 insertions(+) create mode 100644 arch/arm/cpu/armv7/omap-common/sata.c create mode 100644 arch/arm/include/asm/arch-omap5/sata.h
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index bfaf814..679c1a1 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -19,6 +19,7 @@ endif
ifneq ($(CONFIG_OMAP54XX),) COBJS += pipe3-phy.o +obj-$(CONFIG_SCSI_AHCI_PLAT) += sata.o endif
ifeq ($(CONFIG_OMAP34XX),) diff --git a/arch/arm/cpu/armv7/omap-common/sata.c b/arch/arm/cpu/armv7/omap-common/sata.c new file mode 100644 index 0000000..f5468c4 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/sata.c @@ -0,0 +1,75 @@ +/* + * TI SATA platform driver + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <ahci.h> +#include <scsi.h> +#include <asm/arch/clock.h> +#include <asm/arch/sata.h> +#include <asm/io.h> +#include "pipe3-phy.h" + +static struct pipe3_dpll_map dpll_map_sata[] = { + {12000000, {1000, 7, 4, 6, 0} }, /* 12 MHz */ + {16800000, {714, 7, 4, 6, 0} }, /* 16.8 MHz */ + {19200000, {625, 7, 4, 6, 0} }, /* 19.2 MHz */ + {20000000, {600, 7, 4, 6, 0} }, /* 20 MHz */ + {26000000, {461, 7, 4, 6, 0} }, /* 26 MHz */ + {38400000, {312, 7, 4, 6, 0} }, /* 38.4 MHz */ + { }, /* Terminator */ +}; + +struct omap_pipe3 sata_phy = { + .pll_ctrl_base = (void __iomem *)TI_SATA_PLLCTRL_BASE, + /* .power_reg is updated at runtime */ + .dpll_map = dpll_map_sata, +}; + +int omap_sata_init(void) +{ + int ret; + u32 val; + + u32 const clk_domains_sata[] = { + 0 + }; + + u32 const clk_modules_hw_auto_sata[] = { + (*prcm)->cm_l3init_ocp2scp3_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_sata[] = { + (*prcm)->cm_l3init_sata_clkctrl, + 0 + }; + + do_enable_clocks(clk_domains_sata, + clk_modules_hw_auto_sata, + clk_modules_explicit_en_sata, + 0); + + /* Enable optional functional clock for SATA */ + setbits_le32((*prcm)->cm_l3init_sata_clkctrl, + SATA_CLKCTRL_OPTFCLKEN_MASK); + + sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata; + + /* Power up the PHY */ + phy_pipe3_power_on(&sata_phy); + + /* Enable SATA module, No Idle, No Standby */ + val = TI_SATA_IDLE_NO | TI_SATA_STANDBY_NO; + writel(val, TI_SATA_WRAPPER_BASE + TI_SATA_SYSCONFIG); + + ret = ahci_init(DWC_AHSATA_BASE); + scsi_scan(1); + + return ret; +} diff --git a/arch/arm/include/asm/arch-omap5/sata.h b/arch/arm/include/asm/arch-omap5/sata.h new file mode 100644 index 0000000..2ca8947 --- /dev/null +++ b/arch/arm/include/asm/arch-omap5/sata.h @@ -0,0 +1,48 @@ +/* + * SATA Wrapper Register map + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _TI_SATA_H +#define _TI_SATA_H + +/* SATA Wrapper module */ +#define TI_SATA_WRAPPER_BASE (OMAP54XX_L4_CORE_BASE + 0x141100) +/* SATA PHY Module */ +#define TI_SATA_PLLCTRL_BASE (OMAP54XX_L4_CORE_BASE + 0x96800) + +/* SATA Wrapper register offsets */ +#define TI_SATA_SYSCONFIG 0x00 +#define TI_SATA_CDRLOCK 0x04 + +/* Register Set */ +#define TI_SATA_SYSCONFIG_OVERRIDE0 (1 << 16) +#define TI_SATA_SYSCONFIG_STANDBY_MASK (0x3 << 4) +#define TI_SATA_SYSCONFIG_IDLE_MASK (0x3 << 2) + +/* Standby modes */ +#define TI_SATA_STANDBY_FORCE 0x0 +#define TI_SATA_STANDBY_NO (0x1 << 4) +#define TI_SATA_STANDBY_SMART_WAKE (0x3 << 4) +#define TI_SATA_STANDBY_SMART (0x2 << 4) + +/* Idle modes */ +#define TI_SATA_IDLE_FORCE 0x0 +#define TI_SATA_IDLE_NO (0x1 << 2) +#define TI_SATA_IDLE_SMART_WAKE (0x3 << 2) +#define TI_SATA_IDLE_SMART (0x2 << 2) + +#ifdef CONFIG_SCSI_AHCI_PLAT +int omap_sata_init(void); +#else +static inline int omap_sata_init(void) +{ + return 0; +} +#endif /* CONFIG_SCSI_AHCI_PLAT */ + +#endif /* _TI_SATA_H */
The uevm has a SATA port. Inititialize the SATA controller.
Signed-off-by: Roger Quadros rogerq@ti.com --- board/ti/omap5_uevm/evm.c | 7 +++++++ include/configs/omap5_uevm.h | 10 ++++++++++ 2 files changed, 17 insertions(+)
diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index bb3a699..af854da 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -20,6 +20,7 @@ #include <asm/arch/clock.h> #include <asm/arch/ehci.h> #include <asm/ehci-omap.h> +#include <asm/arch/sata.h>
#define DIE_ID_REG_BASE (OMAP54XX_L4_CORE_BASE + 0x2000) #define DIE_ID_REG_OFFSET 0x200 @@ -67,6 +68,12 @@ int board_init(void) return 0; }
+int board_late_init(void) +{ + omap_sata_init(); + return 0; +} + int board_eth_init(bd_t *bis) { return 0; diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 4d3a800..2f128b8 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -69,4 +69,14 @@ /* Max time to hold reset on this board, see doc/README.omap-reset-time */ #define CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC 16296
+#define CONFIG_BOARD_LATE_INIT +#define CONFIG_CMD_SCSI +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + #endif /* __CONFIG_OMAP5_EVM_H */
Adds the necessary PRCM and Control register information for SATA on DRA7xx.
Signed-off-by: Roger Quadros rogerq@ti.com --- arch/arm/cpu/armv7/omap5/prcm-regs.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index 5c60d74..77c428b 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -376,6 +376,7 @@ struct omap_sys_ctrl_regs const omap5_ctrl = {
struct omap_sys_ctrl_regs const dra7xx_ctrl = { .control_status = 0x4A002134, + .control_phy_power_sata = 0x4A002374, .control_core_mac_id_0_lo = 0x4A002514, .control_core_mac_id_0_hi = 0x4A002518, .control_core_mac_id_1_lo = 0x4A00251C, @@ -895,9 +896,11 @@ struct prcm_regs const dra7xx_prcm = { .cm_l3init_hsusbhost_clkctrl = 0x4a009340, .cm_l3init_hsusbotg_clkctrl = 0x4a009348, .cm_l3init_hsusbtll_clkctrl = 0x4a009350, + .cm_l3init_sata_clkctrl = 0x4a009388, .cm_gmac_clkstctrl = 0x4a0093c0, .cm_gmac_gmac_clkctrl = 0x4a0093d0, .cm_l3init_ocp2scp1_clkctrl = 0x4a0093e0, + .cm_l3init_ocp2scp3_clkctrl = 0x4a0093e8,
/* cm2.l4per */ .cm_l4per_clkstctrl = 0x4a009700,
The evm has a SATA port. Enable SATA configuration and inititialize the SATA controller.
Signed-off-by: Roger Quadros rogerq@ti.com --- board/ti/dra7xx/evm.c | 7 +++++++ include/configs/dra7xx_evm.h | 11 +++++++++++ 2 files changed, 18 insertions(+)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 9657c75..9ae88c5 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -14,6 +14,7 @@ #include <palmas.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> +#include <asm/arch/sata.h>
#include "mux_data.h"
@@ -77,6 +78,12 @@ int board_init(void) return 0; }
+int board_late_init(void) +{ + omap_sata_init(); + return 0; +} + /** * @brief misc_init_r - Configure EVM board specific configurations * such as power configurations, ethernet initialization as phase2 of diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index a9f39f2..6fadffb 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -78,4 +78,15 @@ #define CONFIG_OMAP_USB_PHY #define CONFIG_OMAP_USB2PHY2_HOST
+/* SATA */ +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_CMD_SCSI +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + #endif /* __CONFIG_DRA7XX_EVM_H */
Hi Roger,
2013/11/11 Roger Quadros rogerq@ti.com:
v3:
v2:
cheers, -roger
-- 1.8.3.2
I've tested the patches in my board and worked for me.
Note, but, although the patches apply cleanly in current master branch the build is broken due this commit:
commit 4e1aa8437ae5baed2be79fff09aa70a293e61467 Author: Masahiro Yamada yamada.m@jp.panasonic.com Date: Thu Oct 17 17:34:48 2013 +0900
armv7: convert makefiles to Kbuild style
You should apply the following change in your patch number 3 (U-Boot-v3-3-8-ARM-OMAP5-Add-Pipe3-PHY-driver.patch)
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 679c1a1..59f5352 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -18,7 +18,7 @@ obj-y += abb.o endif
ifneq ($(CONFIG_OMAP54XX),) -COBJS += pipe3-phy.o +obj-y += pipe3-phy.o obj-$(CONFIG_SCSI_AHCI_PLAT) += sata.o endif
And rebase the patch number 5 (U-Boot-v3-5-8-ARM-OMAP5-Add-SATA-platform-glue.patch) as after the change doesn't apply.
Despite this:
Tested-by: Enric Balletbo i Serra eballetbo@iseebcn.com
Cheers, Enric
v3:
v2:
cheers, -roger
Applied to u-boot-ti/master, thanks!
Hi Roger,
2013/12/4 Tom Rini trini@ti.com:
v3:
v2:
cheers, -roger
Now that this will go to mainline, I wonder to know if there is any plan to add SPL support to boot from SATA ?
Thanks, Enric
-- Tom
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 12/18/2013 06:31 AM, Enric Balletbo Serra wrote:
Hi Roger,
v3:
v2:
cheers, -roger
I've talked ever so briefly with Dan Murphy about this because his series that adds USB host support gets us ever further towards SATA SPL support as both talk in block_dev_desc_t. I don't think anyone is working on this today, but my gut says it shouldn't be too hard to add on top.
- -- Tom
Roger Quadros
