[PATCH 0/3] arm64: Add a build target for Flat Image Tree
Flat Image Tree (FIT) is a widely used file format for packaging a kernel and associated devicetree files. This series adds support for building a FIT as part of the kernel build. This makes it easy to try out the kernel - just load the FIT onto your tftp server and it will run automatically on any supported arm64 board.
The script is written in Python, since it is easy to build a FIT using the Python libfdt bindings. For now, no attempt is made to compress files in parallel, so build the 900-odd files takes a while, about 6 seconds with my testing.
The series also includes a few minor clean-up patches.
Simon Glass (3): kbuild: Correct missing architecture-specific hyphens kbuild: arm64: Add BOOT_TARGETS variable arm64: boot: Support Flat Image Tree
MAINTAINERS | 7 + Makefile | 10 +- arch/arm64/Makefile | 7 +- arch/arm64/boot/Makefile | 8 +- scripts/Makefile.lib | 16 ++- scripts/make_fit.py | 285 +++++++++++++++++++++++++++++++++++++++ 6 files changed, 324 insertions(+), 9 deletions(-) create mode 100755 scripts/make_fit.py
These should add a hyphen to indicate that it makes a adjective. Fix them.
Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index 690cde550acd..b63796e6f94a 100644 --- a/Makefile +++ b/Makefile @@ -675,7 +675,7 @@ ifdef config-build # *config targets only - make sure prerequisites are updated, and descend # in scripts/kconfig to make the *config target
-# Read arch specific Makefile to set KBUILD_DEFCONFIG as needed. +# Read arch-specific Makefile to set KBUILD_DEFCONFIG as needed. # KBUILD_DEFCONFIG may point out an alternative default configuration # used for 'make defconfig' include $(srctree)/arch/$(SRCARCH)/Makefile @@ -689,7 +689,7 @@ config: outputmakefile scripts_basic FORCE
else #!config-build # =========================================================================== -# Build targets only - this includes vmlinux, arch specific targets, clean +# Build targets only - this includes vmlinux, arch-specific targets, clean # targets and others. In general all targets except *config targets.
# If building an external module we do not care about the all: rule @@ -1637,9 +1637,9 @@ help: @echo 'Documentation targets:' @$(MAKE) -f $(srctree)/Documentation/Makefile dochelp @echo '' - @echo 'Architecture specific targets ($(SRCARCH)):' + @echo 'Architecture-specific targets ($(SRCARCH)):' @$(or $(archhelp),\ - echo ' No architecture specific help defined for $(SRCARCH)') + echo ' No architecture-specific help defined for $(SRCARCH)') @echo '' @$(if $(boards), \ $(foreach b, $(boards), \ @@ -1681,7 +1681,7 @@ help-boards: $(help-board-dirs) boards-per-dir = $(sort $(notdir $(wildcard $(srctree)/arch/$(SRCARCH)/configs/$*/*_defconfig)))
$(help-board-dirs): help-%: - @echo 'Architecture specific targets ($(SRCARCH) $*):' + @echo 'Architecture-specific targets ($(SRCARCH) $*):' @$(if $(boards-per-dir), \ $(foreach b, $(boards-per-dir), \ printf " %-24s - Build for %s\n" $*/$(b) $(subst _defconfig,,$(b));) \
This is trivial. Applied to linux-kbuild. Thanks.
git grep -i 'arch specific'
or
git grep -i 'architecture specific'
finds similar patterns, but presumably we are not keen on fixing them tree-wide.
or
or '32 bit', '64 bit', but I agree with "not keen on fixing them tree-wide."
Add a new variable containing a list of possible targets. Mark them as phony. This matches the approach taken for arch/arm
arch/arm64/Makefile | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm64/Makefile b/arch/arm64/Makefile index 4bd85cc0d32b..7b77b63e978f 100644 --- a/arch/arm64/Makefile +++ b/arch/arm64/Makefile @@ -150,6 +150,10 @@ libs-$(CONFIG_EFI_STUB) += $(objtree)/drivers/firmware/efi/libstub/lib.a # Default target when executing plain make boot := arch/arm64/boot
+BOOT_TARGETS := Image.gz vmlinuz.efi + +PHONY += $(BOOT_TARGETS) + ifeq ($(CONFIG_EFI_ZBOOT),) KBUILD_IMAGE := $(boot)/Image.gz else @@ -159,7 +163,7 @@ endif all: $(notdir $(KBUILD_IMAGE))
-Image vmlinuz.efi: vmlinux +$(BOOT_TARGETS): vmlinux $(Q)$(MAKE) $(build)=$(boot) $(boot)/$@
Image.%: Image
Add a script which produces a Flat Image Tree (FIT), a single file containing the built kernel and associated devicetree files. Compression defaults to gzip which gives a good balance of size and performance.
The files compress from about 85MB to 24MB using this approach.
The FIT can be used by bootloaders which support it, such as U-Boot and Linuxboot. It permits automatic selection of the correct devicetree, matching the compatible string of the running board with the closest compatible string in the FIT. There is no need for filenames or other workarounds.
Add a 'make image.fit' build target for arm64, as well.
The FIT can be examined using 'dumpimage -l'.
This features requires pylibfdt (use 'pip install libfdt'). It also requires compression utilities for the algorithm being used. Supported compression options are the same as the Image.xxx files. For now there is no way to change the compression other than by editing the rule for $(obj)/image.fit
While FIT supports a ramdisk / initrd, no attempt is made to support this here, since it must be built separately from the Linux build.
MAINTAINERS | 7 + arch/arm64/Makefile | 3 +- arch/arm64/boot/Makefile | 8 +- scripts/Makefile.lib | 16 ++- scripts/make_fit.py | 285 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 315 insertions(+), 4 deletions(-) create mode 100755 scripts/make_fit.py
diff --git a/MAINTAINERS b/MAINTAINERS index 2d13bbd69adb..d6955ebc3c24 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1575,6 +1575,13 @@ F: Documentation/process/maintainer-soc*.rst F: arch/arm/boot/dts/Makefile F: arch/arm64/boot/dts/Makefile
+ARM64 FIT SUPPORT +M: Simon Glass sjg@chromium.org +L: linux-arm-kernel@lists.infradead.org (moderated for non-subscribers) +S: Maintained +F: arch/arm64/boot/Makefile +F: scripts/make_fit.py + ARM ARCHITECTED TIMER DRIVER M: Mark Rutland mark.rutland@arm.com M: Marc Zyngier maz@kernel.org diff --git a/arch/arm64/Makefile b/arch/arm64/Makefile index 7b77b63e978f..d8290dcab6b6 100644 --- a/arch/arm64/Makefile +++ b/arch/arm64/Makefile @@ -150,7 +150,7 @@ libs-$(CONFIG_EFI_STUB) += $(objtree)/drivers/firmware/efi/libstub/lib.a # Default target when executing plain make boot := arch/arm64/boot
-BOOT_TARGETS := Image.gz vmlinuz.efi +BOOT_TARGETS := Image.gz vmlinuz.efi image.fit
@@ -215,6 +215,7 @@ virtconfig: define archhelp echo '* Image.gz - Compressed kernel image (arch/$(ARCH)/boot/Image.gz)' echo ' Image - Uncompressed kernel image (arch/$(ARCH)/boot/Image)' +$(if $(CONFIG_EFI_ZBOOT),,echo ' image.fit - Flat Image Tree (arch/$(ARCH)/boot/image.fit)') echo ' install - Install uncompressed kernel' echo ' zinstall - Install compressed kernel' echo ' Install using (your) ~/bin/installkernel or' diff --git a/arch/arm64/boot/Makefile b/arch/arm64/boot/Makefile index 1761f5972443..a6e5b20b22bd 100644 --- a/arch/arm64/boot/Makefile +++ b/arch/arm64/boot/Makefile @@ -16,7 +16,8 @@
OBJCOPYFLAGS_Image :=-O binary -R .note -R .note.gnu.build-id -R .comment -S
-targets := Image Image.bz2 Image.gz Image.lz4 Image.lzma Image.lzo Image.zst +targets := Image Image.bz2 Image.gz Image.lz4 Image.lzma Image.lzo \ + Image.zst image.fit
$(obj)/Image: vmlinux FORCE $(call if_changed,objcopy) @@ -39,6 +40,11 @@ $(obj)/Image.lzo: $(obj)/Image FORCE $(obj)/Image.zst: $(obj)/Image FORCE $(call if_changed,zstd)
+ifndef CONFIG_EFI_ZBOOT +$(obj)/image.fit: $(obj)/Image $(obj)/dts FORCE + $(call if_changed,fit,gzip) +endif + EFI_ZBOOT_PAYLOAD := Image EFI_ZBOOT_BFD_TARGET := elf64-littleaarch64 EFI_ZBOOT_MACH_TYPE := ARM64 diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 68d0134bdbf9..4e4364ad641a 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -487,14 +487,26 @@ UIMAGE_OPTS-y ?= UIMAGE_TYPE ?= kernel UIMAGE_LOADADDR ?= arch_must_set_this UIMAGE_ENTRYADDR ?= $(UIMAGE_LOADADDR) -UIMAGE_NAME ?= 'Linux-$(KERNELRELEASE)' +UIMAGE_NAME ?= "Linux-$(KERNELRELEASE)"
quiet_cmd_uimage = UIMAGE $@ cmd_uimage = $(BASH) $(MKIMAGE) -A $(UIMAGE_ARCH) -O linux \ -C $(UIMAGE_COMPRESSION) $(UIMAGE_OPTS-y) \ -T $(UIMAGE_TYPE) \ -a $(UIMAGE_LOADADDR) -e $(UIMAGE_ENTRYADDR) \ - -n $(UIMAGE_NAME) -d $< $@ + -n "$(UIMAGE_NAME)" -d $< $@ + +# Flat Image Tree (FIT) +# This allows for packaging of a kernel and all devicetrees files, using +# compression. +# --------------------------------------------------------------------------- + +MAKE_FIT := $(srctree)/scripts/make_fit.py + +quiet_cmd_fit = FIT $@ + cmd_fit = $(MAKE_FIT) -f $@ --arch $(UIMAGE_ARCH) --os linux \ + --name "$(UIMAGE_NAME)" \ + --compress $(UIMAGE_COMPRESSION) $^
# XZ # --------------------------------------------------------------------------- diff --git a/scripts/make_fit.py b/scripts/make_fit.py new file mode 100755 index 000000000000..07500d8638e9 --- /dev/null +++ b/scripts/make_fit.py @@ -0,0 +1,285 @@ +#!/usr/bin/env python3 +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2023 Google LLC +# Written by Simon Glass sjg@chromium.org +# + +"""Build a FIT containing a lot of devicetree files + +Usage: + make_fit.py -A arm64 -n 'Linux-6.6' -O linux + -f arch/arm64/boot/image.fit /tmp/kern/arch/arm64/boot/Image + /tmp/kern/arch/arm64/boot/dts/ -E -c gzip + +Creates a FIT containing the supplied list of files. The kernel must +be specified first. The DTB files are specified by way of a directory +tree containing them. + +Use -E to generate an external FIT (where the data is placed after the +FIT data structure). This allows parsing of the data without loading +the entire FIT. + +Use -c to compress the data, using bzip2, gzip, lz4, lzma, lzo and +zstd + +The resulting FIT can be booted by bootloaders which support FIT, such +as U-Boot, Linuxboot, Tianocore, etc. + +Note that this tool does not yet support adding a ramdisk / initrd. +""" + +import argparse +import collections +import os +import subprocess +import sys +import tempfile +import time + +import libfdt + + +# Tool extension and the name of the command-line tools +CompTool = collections.namedtuple('CompTool', 'ext,tools') + +COMP_TOOLS = { + 'bzip2': CompTool('.bz2', 'bzip2'), + 'gzip': CompTool('.gz', 'pigz,gzip'), + 'lz4': CompTool('.lz4', 'lz4'), + 'lzma': CompTool('.lzma', 'lzma'), + 'lzo': CompTool('.lzo', 'lzop'), + 'zstd': CompTool('.zstd', 'zstd'), +} + +def parse_args(): + """Parse the program ArgumentParser + + Returns: + Namespace object containing the arguments + """ + epilog = 'Build a FIT from a directory tree containing .dtb files' + parser = argparse.ArgumentParser(epilog=epilog) + parser.add_argument('-A', '--arch', type=str, required=True, + help='Specifies the architecture') + parser.add_argument('-c', '--compress', type=str, default='none', + help='Specifies the compression') + parser.add_argument('-E', '--external', action='store_true', + help='Convert the FIT to use external data') + parser.add_argument('-n', '--name', type=str, required=True, + help='Specifies the name') + parser.add_argument('-O', '--os', type=str, required=True, + help='Specifies the operating system') + parser.add_argument('-f', '--fit', type=str, required=True, + help='Specifies the output file (.fit)') + parser.add_argument('srcdir', type=str, nargs='*', + help='Specifies the directory tree that contains .dtb files') + + return parser.parse_args() + +def setup_fit(fsw): + """Make a start on writing the FIT + + Outputs the root properties and the 'images' node + + Args: + fsw (libfdt.FdtSw): Object to use for writing + """ + fsw.INC_SIZE = 65536 + fsw.finish_reservemap() + fsw.begin_node('') + fsw.property_string('description', 'DTB set') + fsw.property_u32('#address-cells', 1) + + fsw.property_u32('timestamp', int(time.time())) + fsw.begin_node('images') + + +def write_kernel(fsw, data, arch, fit_os, name, compress): + """Write out the kernel image + + Writes a kernel node along with the required properties + + Args: + fsw (libfdt.FdtSw): Object to use for writing + data (bytes): Data to write (possibly compressed) + arch (str): FIT architecture, e.g. 'arm64' + fit_os (str): Operating Systems, e.g. 'linux' + name (str): Name of OS, e.g. 'Linux-6.6.0-rc7' + compress (str): Compression algorithm to use, e.g. 'gzip' + """ + with fsw.add_node('kernel'): + fsw.property_string('description', name) + fsw.property_string('type', 'kernel_noload') + fsw.property_string('arch', arch) + fsw.property_string('os', fit_os) + fsw.property_string('compression', compress) + fsw.property('data', data) + fsw.property_u32('load', 0) + fsw.property_u32('entry', 0) + + +def finish_fit(fsw, entries): + """Finish the FIT ready for use + + Writes the /configurations node and subnodes + + Args: + fsw (libfdt.FdtSw): Object to use for writing + entries (list of tuple): List of configurations: + str: Description of model + str: Compatible stringlist + """ + fsw.end_node() + seq = 0 + with fsw.add_node('configurations'): + for model, compat in entries: + seq += 1 + with fsw.add_node(f'conf-{seq}'): + fsw.property('compatible', bytes(compat)) + fsw.property_string('description', model) + fsw.property_string('fdt', f'fdt-{seq}') + fsw.property_string('kernel', 'kernel') + fsw.end_node() + + +def compress_data(inf, compress): + """Compress data using a selected algorithm + + Args: + inf (IOBase): Filename containing the data to compress + compress (str): Compression algorithm, e.g. 'gzip' + + Return: + bytes: Compressed data + """ + if compress == 'none': + return inf.read() + + comp = COMP_TOOLS.get(compress) + if not comp: + raise ValueError(f"Unknown compression algorithm '{compress}'") + + with tempfile.NamedTemporaryFile() as comp_fname: + with open(comp_fname.name, 'wb') as outf: + done = False + for tool in comp.tools.split(','): + try: + subprocess.call([tool, '-c'], stdin=inf, stdout=outf) + done = True + break + except FileNotFoundError: + pass + if not done: + raise ValueError(f'Missing tool(s): {comp.tools}\n') + with open(comp_fname.name, 'rb') as compf: + comp_data = compf.read() + return comp_data + + +def output_dtb(fsw, seq, fname, compress): + """Write out a single devicetree to the FIT + + Args: + fsw (libfdt.FdtSw): Object to use for writing + seq (int): Sequence number (1 for first) + fmame (str): Filename containing the DTB + compress (str): Compressed algorithm, e.g. 'gzip' + + Returns: + tuple: + str: Model name + bytes: Compatible stringlist + """ + with fsw.add_node(f'fdt-{seq}'): + # Get the compatible / model information + with open(fname, 'rb') as inf: + data = inf.read() + fdt = libfdt.FdtRo(data) + model = fdt.getprop(0, 'model').as_str() + compat = fdt.getprop(0, 'compatible') + + fsw.property_string('description', model) + fsw.property_string('type', 'flat_dt') + fsw.property_string('arch', 'arm64') + fsw.property_string('compression', compress) + fsw.property('compatible', bytes(compat)) + + with open(fname, 'rb') as inf: + compressed = compress_data(inf, compress) + fsw.property('data', compressed) + return model, compat + + +def build_fit(args): + """Build the FIT from the provided files and arguments + + Args: + args: Namespace object containing program arguments + + Returns: + tuple: + bytes: FIT data + int: Number of configurations generated + size: Total uncompressed size of data + """ + fsw = libfdt.FdtSw() + setup_fit(fsw) + seq = 0 + size = 0 + entries = [] + for path in args.srcdir: + # Handle devicetree files + if os.path.isdir(path): + for dirpath, _, fnames in os.walk(path): + for fname in fnames: + if os.path.splitext(fname)[1] != '.dtb': + continue + pathname = os.path.join(dirpath, fname) + seq += 1 + size += os.path.getsize(pathname) + model, compat = output_dtb(fsw, seq, pathname, + args.compress) + entries.append([model, compat]) + + # Handle the kernel + elif path != 'FORCE': + with open(path, 'rb') as inf: + comp_data = compress_data(inf, args.compress) + size += os.path.getsize(path) + write_kernel(fsw, comp_data, args.arch, args.os, + args.name, args.compress) + + finish_fit(fsw, entries) + + return fsw.as_fdt().as_bytearray(), seq, size + + +def run_make_fit(): + """Run the tool's main logic""" + args = parse_args() + + out_data, count, size = build_fit(args) + with open(args.fit, 'wb') as outf: + outf.write(out_data) + + ext_fit_size = None + if args.external: + mkimage = os.environ.get('MKIMAGE', 'mkimage') + subprocess.check_call([mkimage, '-E', '-F', args.fit], + stdout=subprocess.DEVNULL) + + with open(args.fit, 'rb') as inf: + data = inf.read() + ext_fit = libfdt.FdtRo(data) + ext_fit_size = ext_fit.totalsize() + + comp_size = len(out_data) + print(f'FIT size {comp_size:#x}/{comp_size / 1024 / 1024:.1f} MB', end='') + if ext_fit_size: + print(f', header {ext_fit_size:#x}/{ext_fit_size / 1024:.1f} KB', end='') + print(f', {count} files, uncompressed {size / 1024 / 1024:.1f} MB') + + +if __name__ == "__main__": + sys.exit(run_make_fit())
Is this useful? For arm64, initrd is likely used.
FIT should be created in unbrellea projects such as OpenEmbedded, Buildroot, etc.
Image.zst image.fit
This is wrong.
$(obj)/dts is a directory.
There is no point for comparing timestamps between $(obj)/image.fit and $(obj)/dts.
Updates of *.dtb do not result in the update of the $(obj)/dts timestamp.
if_changed never works correctly.
+endif
Unneeded noise change.
-- Best Regards
Masahiro Yamada
Hi Masahiro,
It depends on your kernel configuration, though. I have found it convenient to enable the drivers necessary to boot.
Sure, but that is a separate issue, isn't it? We already support various boot targets in arm64 but not one that includes the DTs, so far as I can see. The old arm 'uImage' target is pretty out-of-date now.
Image.zst image.fit
This is wrong.
Yes I am aware that this doesn't actually deal with changes. I'll see if I can figure out another way.
+endif
I'll move that to a separate patch. We don't want the single quotes in the name.
On Sun, Oct 29, 2023 at 05:46:12AM +1300, Simon Glass wrote:
Hi Masahiro,
Does that mean it can be removed? ;)
I've NAK'd FIT support on 32-bit Arm in the past, and I remain of the opinion that boot loader specific packaging of the kernel should not be in the kernel but should be external to it - even more so given the multi-platform nature of 32-bit Arm kernels.
Hi Masahiro,
I'll point it out here rather than Simon. As part of https://github.com/open-source-firmware FIT is a standard and not "boot loader specific". And one of the points of a FIT image is that you can easily support multi-platform kernels in a single file (without optimizing things further, at a cost in tens of milliseconds on a Pi 3 anyhow) and with user-controlled security.
Hi Masahiro,
-- Tom
It is a copy of the document in U-Boot.
The file was split into two, but the content is the same.
[original in U-Boot] https://github.com/u-boot/u-boot/blob/v2023.10/doc/usage/fit/source_file_for...
[flat-image-tree] https://github.com/open-source-firmware/flat-image-tree/blob/v0.8/source/cha... https://github.com/open-source-firmware/flat-image-tree/blob/v0.8/source/cha...
-- Best Regards Masahiro Yamada
Hi Masahiro,
-- Tom
Yes, it would have been a bad idea to change a 15 year old format as part of getting it included in some standards, and we'd also recently cleaned it up to rST. Similar comments would I expect be true of turning grub.cfg in to extlinux.conf and all of the organizations that has moved along, and anything else that wasn't developed by committee at some Standards organization.
participants (5)
Masahiro Yamada
Randy Dunlap
