[PATCH] tee: optee: rework TA bus scanning code
Late versions of OP-TEE support a pseudo bus. TAs that behave as hardware blocks (e.g TPM, RNG etc) present themselves on a bus which we can scan. Unfortunately U-Boot doesn't support that yet. It's worth noting that we already have a workaround for RNG. The details are in commit 70812bb83da6 ("tee: optee: bind rng optee driver")
So let's add a list of devices based on U-Boot Kconfig options that we will scan until we properly implement the tee-bus functionality.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tee/optee/core.c | 22 +++++++++++++++++++--- 1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/drivers/tee/optee/core.c b/drivers/tee/optee/core.c index a89d62aaf0b3..48a9b59171cb 100644 --- a/drivers/tee/optee/core.c +++ b/drivers/tee/optee/core.c @@ -31,6 +31,20 @@ struct optee_pdata { optee_invoke_fn *invoke_fn; };
+static const struct { + const char *drv_name; + const char *dev_name; +} optee_bus_probe[] = { +#ifdef CONFIG_RNG_OPTEE + { "optee-rng", "optee-rng" }, +#endif +#ifdef CONFIG_TPM2_FTPM_TEE + { "ftpm-tee", "ftpm-tee" }, +#endif +}; + +#define MAX_TEE_BUS_DEV_COUNT ARRAY_SIZE(optee_bus_probe) + struct rpc_param { u32 a0; u32 a1; @@ -643,7 +657,7 @@ static int optee_probe(struct udevice *dev) struct optee_pdata *pdata = dev_get_plat(dev); u32 sec_caps; struct udevice *child; - int ret; + int ret, i;
if (!is_optee_api(pdata->invoke_fn)) { dev_err(dev, "OP-TEE api uid mismatch\n"); @@ -672,8 +686,10 @@ static int optee_probe(struct udevice *dev) * in U-Boot, the discovery of TA on the TEE bus is not supported: * only bind the drivers associated to the supported OP-TEE TA */ - if (IS_ENABLED(CONFIG_RNG_OPTEE)) { - ret = device_bind_driver(dev, "optee-rng", "optee-rng", &child); + + for (i = 0; i < MAX_TEE_BUS_DEV_COUNT; i++) { + ret = device_bind_driver(dev, optee_bus_probe[i].drv_name, + optee_bus_probe[i].dev_name, &child); if (ret) return ret; }
On Tue, Aug 23, 2022 at 10:11 AM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
+#endif +};
int ret;
int ret, i; if (!is_optee_api(pdata->invoke_fn)) { dev_err(dev, "OP-TEE api uid mismatch\n");
I wonder which behaviour is most useful. Disable OP-TEE support completely if there's some error when binding dependent drivers or to just complain a bit but continue.
Cheers, Jens
-- 2.34.1
Hello Ilias, Jens,
On Fri, 26 Aug 2022 at 10:46, Jens Wiklander jens.wiklander@linaro.org wrote:
+#endif +};
int ret;
I would use ARRAY_SIZE(optee_bus_probe) straight here. Macro indirection is not really useful imho.
I agree with you, this should better print the status and proceed with the next driver. There are other occurrences of such behaviour in U-Boot.
Br, etienne
Cheers, Jens
-- 2.34.1
Hey Etienne, Jens
Sure
I also agree, however this changes the behaviour of *existing* code, which I tried to avoid. Since you both think it's better, I'll just add a log_err() on v2 and continue.
Thanks /Ilias
Br, etienne
Cheers, Jens
-- 2.34.1
Etienne Carriere
Ilias Apalodimas
Jens Wiklander
