[U-Boot] [PATCH 1/1] compiler_gcc: do not redefine __gnu_attributes
gcc allows extensions to be non compiler specific by defining __* macros for the attributes supported by gcc. Having a different definition causes many warnings during the build (cdefs.h on FreeBSD uses __attribute((__pure__)) where u-boot uses __attribute__((pure)) for example). Do not redefine these macros to suppress these warnings.
This patch ignores the checkpatch warning: WARNING: __packed is preferred over __attribute__((packed))
Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- include/linux/compiler-gcc.h | 12 +++++++++--- include/linux/compiler-gcc4.h | 4 +++- 2 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/include/linux/compiler-gcc.h b/include/linux/compiler-gcc.h index 73dcf80..9896e54 100644 --- a/include/linux/compiler-gcc.h +++ b/include/linux/compiler-gcc.h @@ -50,7 +50,9 @@ #endif
#define __deprecated __attribute__((deprecated)) -#define __packed __attribute__((packed)) +#ifndef __packed +# define __packed __attribute__((packed)) +#endif #define __weak __attribute__((weak))
/* @@ -73,8 +75,12 @@ * would be. * [...] */ -#define __pure __attribute__((pure)) -#define __aligned(x) __attribute__((aligned(x))) +#ifndef __pure +# define __pure __attribute__((pure)) +#endif +#ifndef __aligned +# define __aligned(x) __attribute__((aligned(x))) +#endif #define __printf(a,b) __attribute__((format(printf,a,b))) #define noinline __attribute__((noinline)) #define __attribute_const__ __attribute__((__const__)) diff --git a/include/linux/compiler-gcc4.h b/include/linux/compiler-gcc4.h index 94dea3f..27d11ca 100644 --- a/include/linux/compiler-gcc4.h +++ b/include/linux/compiler-gcc4.h @@ -12,7 +12,9 @@ #define __used __attribute__((__used__)) #define __must_check __attribute__((warn_unused_result)) #define __compiler_offsetof(a,b) __builtin_offsetof(a,b) -#define __always_inline inline __attribute__((always_inline)) +#ifndef __always_inline +# define __always_inline inline __attribute__((always_inline)) +#endif
/* * A trick to suppress uninitialized variable warning without generating any
Jeroen Hofstee
