[PATCH v2] imx8m: Select BINMAN via SoC level
Since all imx8m boards have been converted to use binman, select binman via SoC level rather than making the selection for each board.
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v1: - Rebased against u-boot-imx tree. - Collected Peng Fan's Reviewed-by tag.
arch/arm/mach-imx/imx8m/Kconfig | 35 +-------------------------------- 1 file changed, 1 insertion(+), 34 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 5e4836b02f..9845644ad6 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -2,6 +2,7 @@ if ARCH_IMX8M
config IMX8M bool + select BINMAN select GICV3 if ARMV8_PSCI select HAS_CAAM select ROM_UNIFIED_SECTIONS @@ -41,13 +42,11 @@ choice
config TARGET_IMX8MQ_CM bool "Ronetix iMX8MQ-CM SoM" - select BINMAN select IMX8MQ select IMX8M_LPDDR4
config TARGET_IMX8MQ_EVK bool "imx8mq_evk" - select BINMAN select IMX8MQ select IMX8M_LPDDR4 select FSL_CAAM @@ -56,20 +55,17 @@ config TARGET_IMX8MQ_EVK
config TARGET_IMX8MQ_PHANBELL bool "imx8mq_phanbell" - select BINMAN select IMX8MQ select IMX8M_LPDDR4
config TARGET_IMX8MM_DATA_MODUL_EDM_SBC bool "Data Modul eDM SBC i.MX8M Mini" - select BINMAN select IMX8MM select IMX8M_LPDDR4 select SUPPORT_SPL
config TARGET_IMX8MM_EVK bool "imx8mm LPDDR4 EVK board" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -79,7 +75,6 @@ config TARGET_IMX8MM_EVK
config TARGET_IMX8MM_ICORE_MX8MM bool "Engicam i.Core MX8M Mini SOM" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -98,21 +93,18 @@ config TARGET_IMX8MM_ICORE_MX8MM
config TARGET_IMX8MM_MX8MENLO bool "Support i.MX8M Mini MX8Menlo board based on Toradex Verdin SoM" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_IMX8MM_PHG bool "i.MX8MM PHG board" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_IMX8MM_VENICE bool "Support Gateworks Venice iMX8M Mini module" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -121,7 +113,6 @@ config TARGET_IMX8MM_VENICE
config TARGET_KONTRON_MX8MM bool "Kontron Electronics N80xx" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -131,21 +122,18 @@ config TARGET_KONTRON_MX8MM
config TARGET_IMX8MN_BSH_SMM_S2 bool "imx8mn-bsh-smm-s2" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_DDR3L
config TARGET_IMX8MN_BSH_SMM_S2PRO bool "imx8mn-bsh-smm-s2pro" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_DDR3L
config TARGET_IMX8MN_EVK bool "imx8mn LPDDR4 EVK board" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 @@ -154,7 +142,6 @@ config TARGET_IMX8MN_EVK
config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_DDR4 @@ -163,7 +150,6 @@ config TARGET_IMX8MN_DDR4_EVK
config TARGET_IMX8MN_VENICE bool "Support Gateworks Venice iMX8M Nano module" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 @@ -172,14 +158,12 @@ config TARGET_IMX8MN_VENICE
config TARGET_IMX8MP_DH_DHCOM_PDK2 bool "DH electronics DHCOM Premium Developer Kit (2) i.MX8M Plus" - select BINMAN select IMX8MP select IMX8M_LPDDR4 select SUPPORT_SPL
config TARGET_IMX8MP_ICORE_MX8MP bool "Engicam i.Core MX8M Plus SOM" - select BINMAN select IMX8MP select IMX8M_LPDDR4 select SUPPORT_SPL @@ -193,7 +177,6 @@ config TARGET_IMX8MP_ICORE_MX8MP
config TARGET_IMX8MP_EVK bool "imx8mp LPDDR4 EVK board" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4 @@ -203,7 +186,6 @@ config TARGET_IMX8MP_EVK
config TARGET_IMX8MP_VENICE bool "Support Gateworks Venice iMX8M Plus module" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4 @@ -212,40 +194,34 @@ config TARGET_IMX8MP_VENICE
config TARGET_PICO_IMX8MQ bool "Support Technexion Pico iMX8MQ" - select BINMAN select IMX8MQ select IMX8M_LPDDR4
config TARGET_IMX8MN_VAR_SOM bool "imx8mn_var_som" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_DDR4
config TARGET_KONTRON_PITX_IMX8M bool "Support Kontron pITX-imx8m" - select BINMAN select IMX8MQ select IMX8M_LPDDR4
config TARGET_VERDIN_IMX8MM bool "Support Toradex Verdin iMX8M Mini module" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_VERDIN_IMX8MP bool "Support Toradex Verdin iMX8M Plus module" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_IMX8MM_BEACON bool "imx8mm Beacon Embedded devkit" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -255,7 +231,6 @@ config TARGET_IMX8MM_BEACON
config TARGET_IMX8MN_BEACON bool "imx8mn Beacon Embedded devkit" - select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 @@ -265,21 +240,18 @@ config TARGET_IMX8MN_BEACON
config TARGET_PHYCORE_IMX8MM bool "PHYTEC PHYCORE i.MX8MM" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_PHYCORE_IMX8MP bool "PHYTEC PHYCORE i.MX8MP" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_IMX8MM_CL_IOT_GATE bool "CompuLab iot-gate-imx8" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -287,7 +259,6 @@ config TARGET_IMX8MM_CL_IOT_GATE
config TARGET_IMX8MM_CL_IOT_GATE_OPTEE bool "CompuLab iot-gate-imx8 with optee support" - select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 @@ -295,28 +266,24 @@ config TARGET_IMX8MM_CL_IOT_GATE_OPTEE
config TARGET_IMX8MP_RSB3720A1_4G bool "Support i.MX8MP RSB3720A1 4G" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_IMX8MP_RSB3720A1_6G bool "Support i.MX8MP RSB3720A1 6G" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_MSC_SM2S_IMX8MP bool "MSC SMARC2 i.MX8MPLUS" - select BINMAN select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
config TARGET_LIBREM5 bool "Purism Librem5 Phone" - select BINMAN select IMX8MQ select SUPPORT_SPL select IMX8M_LPDDR4
Fabio Estevam
