Pull request for tpm-next-22112023
Hi Tom,
The following changes since commit dca7a8958f8d0dbd53072caa4353353e062d80ca:
Merge tag 'v2024.01-rc3' into next (2023-11-20 09:19:50 -0500)
https://source.denx.de/u-boot/custodians/u-boot-tpm/ tags/tpm-next-22112023
for you to fetch changes up to 9086e8f04d268a989193470de7cc14e4a577e6f5:
tpm: remove superfluous check in tpm_tis_send() (2023-11-22 10:03:55 +0200)
Minor changes from Heinrich removing a ptr check that is not needed, since by the time we get to that function the device is up and running. Since we are late in the cycle for 2024.01 release I prefer this going into -next since it doesn't fix any bugs.
As expected the CI had no issues https://source.denx.de/u-boot/custodians/u-boot-tpm/-/pipelines/18689
Please consider pulling Thanks /Ilias
---------------------------------------------------------------- tpm_tis_send-cleanup ---------------------------------------------------------------- Heinrich Schuchardt (1): tpm: remove superfluous check in tpm_tis_send()
drivers/tpm/tpm2_tis_core.c | 3 --- 1 file changed, 3 deletions(-)
On Wed, Nov 22, 2023 at 12:21:27PM +0200, Ilias Apalodimas wrote:
Hi Tom,
Ilias Apalodimas
