[U-Boot] Pull request: u-boot-mmc 07022014
Hi Tom,
The following changes since commit dbf3de2dd26cae37d16b00b348828c883b658cc5:
include/usb/s3c_udc.h: Add <asm/sizes.h> (2014-02-06 14:26:05 -0500)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to b818d9ab8d96471c40ccbd4541a46dfa415eda73:
dra7xx_evm: Add CONFIG_SUPPORT_EMMC_BOOT, document usage (2014-02-07 18:17:49 +0200)
---------------------------------------------------------------- Rajeshwari S Shinde (1): MMC: DWMMC: Correct the CLKDIV register value
Siva Durga Prasad Paladugu (1): mmc: Enabled quirk SDHCI_QUIRK_BROKEN_R1B
Stephen Warren (1): mmc: set rca to 1 for MMC cards
Tom Rini (8): SPL: Add CONFIG_SUPPORT_EMMC_BOOT support to CONFIG_SPL_FRAMEWORK cmd_mmc.c: Change 'bootpart' code to match normal coding style cmd_mmc.c: Rename 'bootpart' to 'bootpart-resize' cmd_mmc.c: Add 'partconf' command to mmc cmd_mmc.c: Add bootbus mmc sub-command cmd_mmc.c: Drop open/close mmc sub-commands omap5_uevm: Add CONFIG_SUPPORT_EMMC_BOOT, document usage dra7xx_evm: Add CONFIG_SUPPORT_EMMC_BOOT, document usage
arch/arm/cpu/armv7/omap-common/boot-common.c | 13 ++++++++++- arch/arm/include/asm/arch-exynos/dwmmc.h | 4 ++++ board/ti/dra7xx/README | 25 +++++++++++++++++++++ board/ti/omap5_uevm/README | 25 +++++++++++++++++++++ common/cmd_mmc.c | 108 ++++++++++++++++++++++++++++++++++++++++++------------------------------------------------ common/spl/spl_mmc.c | 24 ++++++++++++++++++++ drivers/mmc/dw_mmc.c | 2 +- drivers/mmc/exynos_dw_mmc.c | 17 +++++++++++++-- drivers/mmc/mmc.c | 79 ++++++++++++++++++++++++------------------------------------------ drivers/mmc/zynq_sdhci.c | 3 ++- include/configs/dra7xx_evm.h | 2 ++ include/configs/omap5_uevm.h | 1 + include/dwmmc.h | 2 +- include/mmc.h | 9 ++++++-- include/spl.h | 1 + 15 files changed, 198 insertions(+), 117 deletions(-) create mode 100644 board/ti/dra7xx/README create mode 100644 board/ti/omap5_uevm/README
Regards
-- Pantelis
On Fri, Feb 07, 2014 at 06:37:13PM +0200, Pantelis Antoniou wrote:
Hi Tom,
Pantelis Antoniou
