[U-Boot] [PATCH] board: AXS10x - update SDIO clock value
With the most recent board firmware correct SDIO clock is 50MHz as opposed to 25 MHz before.
Also set max frequency of MMC data exchange equal to SDIO clock - because there's no way to transfer data faster than interface clock.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- board/synopsys/axs101/axs101.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/synopsys/axs101/axs101.c b/board/synopsys/axs101/axs101.c index d1271ff..7742049 100644 --- a/board/synopsys/axs101/axs101.c +++ b/board/synopsys/axs101/axs101.c @@ -27,9 +27,9 @@ int board_mmc_init(bd_t *bis) host->ioaddr = (void *)ARC_DWMMC_BASE; host->buswidth = 4; host->dev_index = 0; - host->bus_hz = 25000000; + host->bus_hz = 50000000;
- add_dwmci(host, 52000000, 400000); + add_dwmci(host, host->bus_hz, 400000);
return 0; }
Alexey Brodkin
