[PATCH 0/3] bootstage support for risc-v
This adds to support bootstage for risc-v. timer_get_boot_us function is required to record each boot stages with microsecond timestamp.
Chanho Park (3): riscv: bootstage: correct bootstage_report guard riscv: timer: add timer_get_boot_us for BOOTSTAGE timer: riscv_aclint_timer: add timer_get_boot_us for BOOTSTAGE
arch/riscv/lib/bootm.c | 2 +- drivers/timer/riscv_aclint_timer.c | 22 ++++++++++++++++++++++ drivers/timer/riscv_timer.c | 21 +++++++++++++++++++++ 3 files changed, 44 insertions(+), 1 deletion(-)
Below warning can be occurred when CONFIG_BOOTSTAGE and !CONFIG_SPL_BOOTSTAGE. It should be guarded by using CONFIG_IS_ENABLED for SPL build.
arch/riscv/lib/bootm.c:46:9: warning: implicit declaration of function 'bootstage_report' 46 | bootstage_report(); | ^~~~~~~~~~~~~~~~ | bootstage_error
Signed-off-by: Chanho Park chanho61.park@samsung.com --- arch/riscv/lib/bootm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index 276677a5e2f9..cc30efc90498 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -42,7 +42,7 @@ static void announce_and_cleanup(int fake) #ifdef CONFIG_BOOTSTAGE_FDT bootstage_fdt_add_report(); #endif -#ifdef CONFIG_BOOTSTAGE_REPORT +#if CONFIG_IS_ENABLED(BOOTSTAGE_REPORT) bootstage_report(); #endif
timer_get_boot_us function is required to record the boot stages as us-based timestamp.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- drivers/timer/riscv_timer.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/timer/riscv_timer.c b/drivers/timer/riscv_timer.c index 3627ed79b819..f9fc7dae37d0 100644 --- a/drivers/timer/riscv_timer.c +++ b/drivers/timer/riscv_timer.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <div64.h> #include <dm.h> #include <errno.h> #include <timer.h> @@ -50,6 +51,26 @@ u64 notrace timer_early_get_count(void) } #endif
+#if CONFIG_IS_ENABLED(BOOTSTAGE) +ulong timer_get_boot_us(void) +{ + int ret; + u64 ticks = 0; + u32 rate; + + ret = dm_timer_init(); + if (!ret) { + rate = timer_get_rate(gd->timer); + timer_get_count(gd->timer, &ticks); + } else { + rate = RISCV_SMODE_TIMER_FREQ; + ticks = riscv_timer_get_count(NULL); + } + + return lldiv(ticks * 1000, (rate / 1000)); +} +#endif + static int riscv_timer_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
Signed-off-by: Chanho Park chanho61.park@samsung.com --- drivers/timer/riscv_aclint_timer.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/drivers/timer/riscv_aclint_timer.c b/drivers/timer/riscv_aclint_timer.c index e29d527c8d77..442b48d55adf 100644 --- a/drivers/timer/riscv_aclint_timer.c +++ b/drivers/timer/riscv_aclint_timer.c @@ -6,6 +6,7 @@
#include <common.h> #include <clk.h> +#include <div64.h> #include <dm.h> #include <timer.h> #include <asm/io.h> @@ -44,6 +45,27 @@ u64 notrace timer_early_get_count(void) } #endif
+#if CONFIG_IS_ENABLED(BOOTSTAGE) +ulong timer_get_boot_us(void) +{ + int ret; + u64 ticks = 0; + u32 rate; + + ret = dm_timer_init(); + if (!ret) { + rate = timer_get_rate(gd->timer); + timer_get_count(gd->timer, &ticks); + } else { + rate = RISCV_MMODE_TIMER_FREQ; + ticks = readq((void __iomem *)MTIME_REG(RISCV_MMODE_TIMERBASE, + RISCV_MMODE_TIMEROFF)); + } + + return lldiv(ticks * 1001, (rate / 1000)); +} +#endif + static const struct timer_ops riscv_aclint_timer_ops = { .get_count = riscv_aclint_timer_get_count, };
Chanho Park
