[U-Boot] Please pull u-boot-dm
Hi Tom,
This includes SCSI DM conversion, livetree updates for tegra (although many patches will come later due to testing problems), ofnode tidy-up patches, dtoc and moveconfig improvements.
I am having trouble with timeouts with travis-ci but buildman is clean.
The following changes since commit 6b26aaef083957b75bcd69aa65bd6ffcf9245bb3:
pipe3: Fix broken dependency (2017-07-10 14:26:05 -0400)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to 8c9eaadaaad888e0cd77512553d0d02d476b4dde:
dm: ofnode: use fdt32_t for DT property value to fix sparse warning (2017-07-11 10:08:20 -0600)
---------------------------------------------------------------- Alison Chaiken (2): sandbox: README: fix partition command invocation cmd gpt: test in sandbox
Kever Yang (1): rockchip: dts: rk3328: add aliases for mmc controller
Masahiro Yamada (7): dm: include <dm/util.h> from drivers/core/util.c dm: ofnode: use ofnode_read_bool() to check property existence dm: ofnode: simplify ofnode_read_prop() dm: ofnode: rename ofnode_read_prop() to ofnode_get_property() dm: ofnode: simplify ofnode_read_bool() dm: include <dm/util.h> from driver/core/dump.c dm: ofnode: use fdt32_t for DT property value to fix sparse warning
Simon Glass (76): dm: core: Clarify uclass_first/next_device() comments dm: core: Test uclass_first/next_device() on probe failure dm: core: Add uclass_first/next_device_check() moveconfig: Support providing a path to the defconfig files moveconfig: Allow reading the defconfig list from stdin moveconfig: Tidy up the documentation and add hints moveconfig: Add a constant for auto.conf moveconfig: Support building a simple config database moveconfig: Support looking for implied CONFIG options dtoc: Support multiple compatible strings in a node Convert CONFIG_SCSI to Kconfig scsi: Drop sym53c8xx driver scsi: Drop scsi_print_error() Convert CONFIG_CMD_SATA to Kconfig Kconfig: Add CONFIG_SATA to enable SATA sata: Move drivers into new drivers/ata directory scsi: Move drivers into new drivers/scsi directory dm: scsi: Rearrange header file for driver model dm: scsi: Rename struct SCSI_cmd_block to struct scsi_cmd dm: scsi: Drop the ccb typedef dm: scsi: Use the uclass platform data dm: ahci: Rename struct ahci_probe_ent dm: sata: Move ataid into struct ahci_uc_priv dm: ahci: Refactor to avoid static variables dm: scsi: Indent the confusing #ifdefs dm: ahci: Move common code for starting ports into a function dm: ahci: Unwind the confusing init code dm: ahci: Drop use of probe_ent dm: scsi: Add operations dm: scsi: Add a device pointer to scan_exec(), scsi_bus_reset() dm: scsi: Document and rename the scsi_scan() parameter dm: ahci: Create a local version of two SCSI functions dm: scsi: Add operations for SCSI devices dm: scsi: Adjust return value of scsi_exec() dm: scsi: Split out the bus scanning code dm: ahci: Add a driver for SCSI on AHCI dm: scsi: Drop scsi_init() when driver model is used x86: Move link to use driver model for SCSI display_options: Refactor to allow obtaining the banner Allow displaying the U-Boot banner on a video display test: Add a test for snprintf() and the banner/version console: Use map_sysmem() for the pre-relocation console sandbox: Enable more console options sandbox: Drop special case console code for sandbox moveconfig: Allow piping in 'git show --stat' output moveconfig: Allow control of which implying configs are shown moveconfig: Allow automatic location and adding of 'imply' dtoc: Use self._options instead of the global options dtoc: Add a comment at the top dtoc: Split out the main class into its own file dtoc: Fix pylint warnings dtoc: Don't handle properties with / in them dtoc: Pass include_disabled explicitly dtoc: Move static functions out of the class dtoc: Move the main logic into the dtb_platdata file dtoc: Add a comment about string replace in conv_name_to_c() sandbox: Stop printing platdata at the start of SPL dtoc: Add tests binman: Put our local modules ahead of system modules dm: core: Add ofnode_read_string_count() dm: core: Add dev_read_resource() to read device resources dm: core: Add dev_read_enabled() to check if a device is enabled dm: core: Add functions to obtain node's address/size cells tegra: video: Time the LCD init tegra: nyan-big: Enable the debug UART dm: Fix error handling when unflattening the DT tegra: nyan-big: Enable bootstage dm: video: Sync display on backspace dm: video: Update pwm_backlight to support livetree video: simple-panel: Add a little more debugging tegra: Fix up include file ordering dm: serial: ns16550: Convert to livetree dm: serial: Separate out the core serial-device finding code dm: serial: Add livetree support tegra: Show a debug message if the LCD PMIC fails to start tegra: fdt: Ensure that the console UART is enabled
Tom Rini (1): fdt: Check for NULL return from fdt_getprop in 'fdt set'
README | 6 - api/api_storage.c | 2 +- arch/Kconfig | 2 + arch/arm/Kconfig | 10 + arch/arm/cpu/armv7/ls102xa/Kconfig | 1 + arch/arm/cpu/armv7/ls102xa/ls102xa_sata.c | 2 +- arch/arm/cpu/armv7/mx6/Kconfig | 4 + arch/arm/cpu/armv7/mx6/clock.c | 6 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 2 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 +- arch/arm/dts/rk3328.dtsi | 3 + arch/arm/dts/tegra114-dalmore.dts | 4 + arch/arm/dts/tegra124-cei-tk1-som.dts | 4 + arch/arm/dts/tegra124-jetson-tk1.dts | 4 + arch/arm/dts/tegra124-venice2.dts | 4 + arch/arm/dts/tegra186-p2771-0000.dtsi | 4 + arch/arm/dts/tegra20-colibri.dts | 4 + arch/arm/dts/tegra20-harmony.dts | 4 + arch/arm/dts/tegra20-trimslice.dts | 4 + arch/arm/dts/tegra210-e2220-1170.dts | 4 + arch/arm/dts/tegra210-p2371-0000.dts | 4 + arch/arm/dts/tegra210-p2371-2180.dts | 4 + arch/arm/dts/tegra210-p2571.dts | 4 + arch/arm/dts/tegra30-apalis.dts | 4 + arch/arm/dts/tegra30-beaver.dts | 4 + arch/arm/dts/tegra30-cardhu.dts | 4 + arch/arm/dts/tegra30-colibri.dts | 4 + arch/arm/dts/tegra30-tec-ng.dts | 4 + arch/arm/imx-common/Makefile | 2 +- arch/arm/imx-common/cpu.c | 2 +- arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/mach-mvebu/Kconfig | 4 + arch/arm/mach-omap2/omap5/Kconfig | 2 + arch/arm/mach-omap2/sata.c | 4 +- arch/arm/mach-tegra/board2.c | 26 +- arch/arm/mach-tegra/clock.c | 4 +- arch/powerpc/cpu/mpc83xx/Kconfig | 1 + arch/powerpc/cpu/mpc85xx/Kconfig | 46 ++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 4 +- arch/powerpc/cpu/mpc86xx/Kconfig | 1 + arch/sandbox/cpu/spl.c | 11 - arch/sandbox/dts/sandbox.dts | 1 + arch/sandbox/dts/test.dts | 19 ++ arch/x86/cpu/ivybridge/sata.c | 22 +- board/advantech/dms-ba16/dms-ba16.c | 2 +- board/bachmann/ot1200/ot1200.c | 2 +- board/boundary/nitrogen6x/nitrogen6x.c | 2 +- board/congatec/Kconfig | 1 + board/congatec/cgtqmx6eval/cgtqmx6eval.c | 2 +- board/dfi/Kconfig | 1 + board/gateworks/gw_ventana/gw_ventana.c | 2 +- board/highbank/ahci.c | 2 +- board/highbank/highbank.c | 2 +- board/kosagi/novena/novena.c | 2 +- board/sandbox/README.sandbox | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 2 +- board/toradex/colibri_imx6/colibri_imx6.c | 2 +- board/udoo/udoo.c | 2 +- board/wandboard/wandboard.c | 2 +- cmd/Kconfig | 13 + cmd/fdt.c | 4 + cmd/scsi.c | 6 +- cmd/version.c | 4 +- common/Kconfig | 2 +- common/Makefile | 5 - common/board_r.c | 1 + common/console.c | 41 +-- common/spl/spl_sata.c | 2 +- common/splash_source.c | 2 +- common/usb_storage.c | 44 ++-- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebook_link64_defconfig | 3 + configs/chromebook_link_defconfig | 3 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 3 + configs/cm_fx6_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/highbank_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 9 + configs/omap5_uevm_defconfig | 1 + configs/sandbox_defconfig | 2 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/udoo_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + doc/README.gpt | 10 + doc/driver-model/of-plat.txt | 5 + drivers/Kconfig | 4 + drivers/Makefile | 4 +- drivers/ata/Kconfig | 62 +++++ drivers/ata/Makefile | 22 ++ drivers/{block => ata}/ahci-uclass.c | 0 drivers/{block => ata}/ahci.c | 395 ++++++++++++++++++----------- drivers/{block => ata}/dwc_ahci.c | 10 +- drivers/{block => ata}/dwc_ahsata.c | 74 +++--- drivers/{block => ata}/dwc_ahsata.h | 0 drivers/{block => ata}/fsl_sata.c | 0 drivers/{block => ata}/fsl_sata.h | 0 drivers/{block => ata}/libata.c | 0 drivers/{block => ata}/mvsata_ide.c | 0 drivers/{block => ata}/mxc_ata.c | 0 {common => drivers/ata}/sata.c | 0 drivers/{block => ata}/sata_ceva.c | 9 +- drivers/{block => ata}/sata_dwc.c | 0 drivers/{block => ata}/sata_dwc.h | 0 drivers/{block => ata}/sata_mv.c | 0 drivers/{block => ata}/sata_sandbox.c | 0 drivers/{block => ata}/sata_sil.c | 0 drivers/{block => ata}/sata_sil.h | 0 drivers/{block => ata}/sata_sil3114.c | 0 drivers/{block => ata}/sata_sil3114.h | 0 drivers/block/Kconfig | 41 --- drivers/block/Makefile | 17 +- drivers/block/scsi-uclass.c | 27 -- drivers/block/sym53c8xx.c | 851 --------------------------------------------------------------- drivers/core/Makefile | 2 +- drivers/core/dump.c | 1 + drivers/core/lists.c | 3 +- drivers/core/of_access.c | 24 ++ drivers/core/ofnode.c | 72 +++--- drivers/core/read.c | 23 +- drivers/core/read_extra.c | 37 +++ drivers/core/regmap.c | 4 +- drivers/core/uclass.c | 30 ++- drivers/core/util.c | 5 + drivers/misc/cros_ec_sandbox.c | 2 +- drivers/pci/pci-uclass.c | 8 +- drivers/pinctrl/pinctrl-uclass.c | 2 +- drivers/scsi/Kconfig | 17 ++ drivers/scsi/Makefile | 20 ++ drivers/{block => scsi}/sandbox_scsi.c | 9 +- drivers/scsi/scsi-uclass.c | 40 +++ {common => drivers/scsi}/scsi.c | 147 ++++++----- drivers/serial/ns16550.c | 15 +- drivers/serial/serial-uclass.c | 92 ++++--- drivers/usb/emul/sandbox_flash.c | 2 +- drivers/video/pwm_backlight.c | 22 +- drivers/video/simple_panel.c | 2 + drivers/video/tegra124/display.c | 2 + drivers/video/vidconsole-uclass.c | 1 + fs/fat/fat.c | 2 +- include/ahci.h | 57 ++++- include/config_cmd_all.h | 1 - include/config_distro_bootcmd.h | 6 +- include/config_fallbacks.h | 2 +- include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8349ITX.h | 4 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/P4080DS.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 2 - include/configs/UCP1020.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/apalis_imx6.h | 4 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t54.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/efi-x86.h | 1 - include/configs/galileo.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/highbank.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/m53evk.h | 1 - include/configs/mvebu_armada-37xx.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mx53loco.h | 1 - include/configs/nitrogen6x.h | 4 - include/configs/novena.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/ot1200.h | 4 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/qemu-x86.h | 1 - include/configs/sandbox.h | 3 +- include/configs/sunxi-common.h | 1 - include/configs/t4qds.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/udoo.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/console.h | 12 + include/display_options.h | 19 ++ include/dm/of_access.h | 38 +++ include/dm/ofnode.h | 36 ++- include/dm/read.h | 64 ++++- include/dm/uclass-id.h | 1 + include/dm/uclass.h | 44 +++- include/scsi.h | 85 +++++-- lib/display_options.c | 36 ++- lib/of_live.c | 7 +- scripts/config_whitelist.txt | 4 - test/Makefile | 1 + test/dm/test-fdt.c | 152 ++++++++++++ test/print_ut.c | 83 +++++++ test/py/tests/test_ofplatdata.py | 30 +-- tools/binman/binman.py | 9 +- tools/dtoc/dtb_platdata.py | 456 ++++++++++++++++++++++++++++++++++ tools/dtoc/dtoc.py | 452 ++++----------------------------- tools/dtoc/dtoc_test.dts | 12 + tools/dtoc/dtoc_test_aliases.dts | 18 ++ tools/dtoc/dtoc_test_empty.dts | 12 + tools/dtoc/dtoc_test_phandle.dts | 23 ++ tools/dtoc/dtoc_test_simple.dts | 48 ++++ tools/dtoc/test_dtoc.py | 271 ++++++++++++++++++++ tools/moveconfig.py | 604 +++++++++++++++++++++++++++++++++++++++++++-- 282 files changed, 3281 insertions(+), 1986 deletions(-) create mode 100644 drivers/ata/Kconfig create mode 100644 drivers/ata/Makefile rename drivers/{block => ata}/ahci-uclass.c (100%) rename drivers/{block => ata}/ahci.c (74%) rename drivers/{block => ata}/dwc_ahci.c (92%) rename drivers/{block => ata}/dwc_ahsata.c (92%) rename drivers/{block => ata}/dwc_ahsata.h (100%) rename drivers/{block => ata}/fsl_sata.c (100%) rename drivers/{block => ata}/fsl_sata.h (100%) rename drivers/{block => ata}/libata.c (100%) rename drivers/{block => ata}/mvsata_ide.c (100%) rename drivers/{block => ata}/mxc_ata.c (100%) rename {common => drivers/ata}/sata.c (100%) rename drivers/{block => ata}/sata_ceva.c (95%) rename drivers/{block => ata}/sata_dwc.c (100%) rename drivers/{block => ata}/sata_dwc.h (100%) rename drivers/{block => ata}/sata_mv.c (100%) rename drivers/{block => ata}/sata_sandbox.c (100%) rename drivers/{block => ata}/sata_sil.c (100%) rename drivers/{block => ata}/sata_sil.h (100%) rename drivers/{block => ata}/sata_sil3114.c (100%) rename drivers/{block => ata}/sata_sil3114.h (100%) delete mode 100644 drivers/block/scsi-uclass.c delete mode 100644 drivers/block/sym53c8xx.c create mode 100644 drivers/core/read_extra.c create mode 100644 drivers/scsi/Kconfig create mode 100644 drivers/scsi/Makefile rename drivers/{block => scsi}/sandbox_scsi.c (75%) create mode 100644 drivers/scsi/scsi-uclass.c rename {common => drivers/scsi}/scsi.c (86%) create mode 100644 test/print_ut.c create mode 100644 tools/dtoc/dtb_platdata.py create mode 100644 tools/dtoc/dtoc_test.dts create mode 100644 tools/dtoc/dtoc_test_aliases.dts create mode 100644 tools/dtoc/dtoc_test_empty.dts create mode 100644 tools/dtoc/dtoc_test_phandle.dts create mode 100644 tools/dtoc/dtoc_test_simple.dts create mode 100644 tools/dtoc/test_dtoc.py
On Tue, Jul 11, 2017 at 12:42:31PM -0600, Simon Glass wrote:
Hi Tom,
