[U-Boot] [PATCH 13/31] powerpc: mgcoge, mgsuvd: move IVM feature config to keymile-common.h
the IVM feature is enabled for all keymile boards therefore the configuration parameters are trans- ferred from the board specific config files to keymile-common.h.
Signed-off-by: Thomas Herzmann thomas.herzmann@keymile.com Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/keymile-common.h | 20 ++++++++++++++++++++ include/configs/mgcoge.h | 19 +------------------ include/configs/mgsuvd.h | 19 +------------------ 3 files changed, 22 insertions(+), 36 deletions(-)
diff --git a/include/configs/keymile-common.h b/include/configs/keymile-common.h index aaefdf1..2e324fe 100644 --- a/include/configs/keymile-common.h +++ b/include/configs/keymile-common.h @@ -106,6 +106,26 @@ #define CONFIG_SYS_SLOT_ID_OFF (0x07) /* register offset */ #define CONFIG_SYS_SLOT_ID_MASK (0x3f) /* mask for slot ID bits */
+#if defined(CONFIG_MGCOGE) || defined(CONFIG_MGSUVD) +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_I2C_CMD_TREE 1 +#define CONFIG_SYS_MAX_I2C_BUS 2 +#define CONFIG_SYS_I2C_INIT_BOARD 1 +#define CONFIG_I2C_MUX 1 + +/* EEprom support */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* Support the IVM EEprom */ +#define CONFIG_SYS_IVM_EEPROM_ADR 0x50 +#define CONFIG_SYS_IVM_EEPROM_MAX_LEN 0x400 +#define CONFIG_SYS_IVM_EEPROM_PAGE_LEN 0x100 +#endif + #define CONFIG_SYS_FLASH_PROTECTION 1
/* diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index f307382..070fe53 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -95,6 +95,7 @@ "10m(rootfs1),1m(var),5m(cfg) \0" \ "partition=nor1,5 \0" \ "new_env=prot off FE060000 FE09FFFF; era FE060000 FE09FFFF \0" \ + "EEprom_ivm=pca9544a:70:4 \0" \ ""
#define CONFIG_SYS_SDRAM_BASE 0x00000000 @@ -150,24 +151,6 @@ else iop->pdat &= ~0x00020000 #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
-#define CONFIG_I2C_MULTI_BUS 1 -#define CONFIG_I2C_CMD_TREE 1 -#define CONFIG_SYS_MAX_I2C_BUS 2 -#define CONFIG_SYS_I2C_INIT_BOARD 1 -#define CONFIG_I2C_MUX 1 - -/* EEprom support */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* Support the IVM EEprom */ -#define CONFIG_SYS_IVM_EEPROM_ADR 0x50 -#define CONFIG_SYS_IVM_EEPROM_MAX_LEN 0x400 -#define CONFIG_SYS_IVM_EEPROM_PAGE_LEN 0x100 - /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 7c97a21..700878f 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -69,6 +69,7 @@ "2432k(rootfs1),640k(var),768k(cfg)\0" \ "partition=nor0,9 \0" \ "new_env=prot off F0060000 F009FFFF; era F0060000 F009FFFF \0" \ + "EEprom_ivm=pca9544a:70:4 \0" \ ""
#undef CONFIG_RTC_MPC8xx /* MPC866 does not support RTC */ @@ -290,24 +291,6 @@ } #define I2C_DELAY udelay(50) /* 1/4 I2C clock duration */
-#define CONFIG_I2C_MULTI_BUS 1 -#define CONFIG_I2C_CMD_TREE 1 -#define CONFIG_SYS_MAX_I2C_BUS 2 -#define CONFIG_SYS_I2C_INIT_BOARD 1 -#define CONFIG_I2C_MUX 1 - -/* EEprom support */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* Support the IVM EEprom */ -#define CONFIG_SYS_IVM_EEPROM_ADR 0x50 -#define CONFIG_SYS_IVM_EEPROM_MAX_LEN 0x400 -#define CONFIG_SYS_IVM_EEPROM_PAGE_LEN 0x100 - /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_SENSORS {0, 2, 4, 6} /* Sensor addresses */
Heiko Schocher
