[U-Boot] [PATCH v3 0/2] sunxi: add spi flash bootcmd
Changes since v2: - Rebase to current master - Added more information to Kconfig help text
Changes since v1: - Move bootcmd to config_distro_bootcmd - Add Kconfig options to enable and configure it
Oskari Lemmela (2): distro_bootcmd: add spi flash boot command sunxi: enable distro spi boot command
Kconfig | 32 ++++++++++++++++++++++++++++++++ include/config_distro_bootcmd.h | 16 ++++++++++++++++ include/configs/sunxi-common.h | 1 + 3 files changed, 49 insertions(+)
Add a boot command to distro boot to support load FIT image from SPI flash.
Tested with Pine A64-LTS board to load kernel and dtb.
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- Kconfig | 32 ++++++++++++++++++++++++++++++++ include/config_distro_bootcmd.h | 16 ++++++++++++++++ 2 files changed, 48 insertions(+)
diff --git a/Kconfig b/Kconfig index d2eb744e70..391ce58810 100644 --- a/Kconfig +++ b/Kconfig @@ -395,6 +395,38 @@ config FIT_IMAGE_POST_PROCESS injected into the FIT creation (i.e. the blobs would have been pre- processed before being added to the FIT image).
+config FIT_SPI_FLASH_BOOT + bool "Distro bootcmd from SPI Flash" + depends on DM_SPI_FLASH + imply CMD_SF + help + Enable SPI bootcmd to load FIT image from SPI flash. Command + probes for the SPI flash device. If device is found command + will try to load FIT image to memory and boot it. + +config FIT_FLASH_IMAGE_ADDR + hex "FIT image memory address" + depends on FIT_SPI_FLASH_BOOT + help + Memory address where to load FIT image. + +config FIT_FLASH_IMAGE_OFFSET + hex "FIT image flash offset" + depends on FIT_SPI_FLASH_BOOT + default 0x100000 + help + Flash offset of FIT image. Default 1MB offset leaves space for u-boot + itself. + +config FIT_FLASH_IMAGE_SIZE + hex "FIT image size" + depends on FIT_SPI_FLASH_BOOT + default 0x700000 + help + Maximum size of the FIT image. Default value of 7MB is enough for + small compressed kernel, dtb and ramdisk. Reducing offset and image + size allows to use smaller than 8MB flash devices. + if SPL
config SPL_FIT diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 3570a32dff..8c6376ccab 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -280,6 +280,22 @@ BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB #endif
+#ifdef CONFIG_FIT_SPI_FLASH_BOOT +#define BOOT_TARGET_DEVICES_SPI(func) func(SPI, spi, 0) +#define BOOTENV_DEV_SPI(devtypeu, devtypel, instance) \ + "image_addr_r=" __stringify(CONFIG_FIT_FLASH_IMAGE_ADDR) "\0" \ + "image_addr=" __stringify(CONFIG_FIT_FLASH_IMAGE_OFFSET) "\0" \ + "image_size=" __stringify(CONFIG_FIT_FLASH_IMAGE_SIZE) "\0" \ + "bootcmd_" #devtypel #instance "=" \ + "if sf probe " #instance "; then " \ + "sf read ${image_addr_r} ${image_addr} ${image_size}; " \ + "bootm ${image_addr_r}; " \ + "fi\0" +#define BOOTENV_DEV_NAME_SPI BOOTENV_DEV_NAME_BLKDEV +#else +#define BOOT_TARGET_DEVICES_SPI(func) +#endif + #ifdef CONFIG_CMD_VIRTIO #define BOOTENV_RUN_VIRTIO_INIT "run virtio_init; " #define BOOTENV_SET_VIRTIO_NEED_INIT "virtio_need_init=; "
I think I mentioned this before, but I have my reservations about introducing this to *distro_bootcmd*. IIUC, this feature is explicitly about providing easy support for generic distributions to point U-Boot to their kernel, without board-specific knowledge. Putting a FIT image with a specific .dtb and initrd into a certain address in some SPI flash does not fall into this category. Instead this sound like a valid, but quite specific embedded use case.
If you want to pull this off for your board(s), why not just set bootcmd to your specific instructions, then use "saveenv" to store this on the SPI flash env? This sounds easier and doesn't disturb the generic boot process.
If you are after easily creating an image file, I had some success lately with adding a board specific environment into an extra environment image file, which would save you from both tweaking the default environment in source, also avoiding to do the modification live on a board:
#!/bin/sh addr=$(readelf -s u-boot | grep default_environment | tr -s ' ' | cut -d\ -f3) size=$(readelf -s u-boot | grep default_environment | tr -s ' ' | cut -d\ -f4) offset=$((0x$addr - 0x4a000000)) (dd if=u-boot.bin bs=1 skip=$offset count=$size status=none | tr '\0' '\n' | grep -v '^$' | grep -v '^bootcmd='; cat myown_additions.env.txt) | tools/mkenvimage -p 0 -s 65536 -o - - (Opening the nerd competition to find an better combination of UNIX tools to achieve the same purpose ;-)
The resulting file can be dumped as the external environment into whatever place you configured U-Boot to look for that, next to u-boot-sunxi-with-spl.bin, for instance into SPI flash. So the distro_bootcmd stays clean in the source, yet you can automate the boot on your specific board by flashing just one image file.
- bool "Distro bootcmd from SPI Flash"
- depends on DM_SPI_FLASH
- imply CMD_SF
- help
- hex "FIT image memory address"
- depends on FIT_SPI_FLASH_BOOT
- help
- hex "FIT image flash offset"
- default 0x100000
- help
itself.
- hex "FIT image size"
- default 0x700000
- help
if SPL
- "image_addr_r=" __stringify(CONFIG_FIT_FLASH_IMAGE_ADDR) "\0" \
- "image_addr=" __stringify(CONFIG_FIT_FLASH_IMAGE_OFFSET) "\0" \
- "image_size=" __stringify(CONFIG_FIT_FLASH_IMAGE_SIZE) "\0" \
I think this part gives it away: Here you set board specific flash offset addresses in the generic config_distro_bootcmd.h file. IMHO this contradicts the whole effort of distro_bootcmd.
Cheers, Andre.
- "bootcmd_" #devtypel #instance "=" \
- "fi\0"
Hi Andre,
Thanks for comments.
Reason for having it in generic bootcmd is opportunity to have fail-safe image in spi flash.
So usually EFI is used to load normal linux distribution, but if sdcard EFI app is for some reason broken. Then we could have small spi flash recovery image with possibility remote recovery of EFI partition.
I'm planning to use small openwrt image for fail-safe recovery image.
Sure this is one option to modify boot_targets and add fail-safe spi bootcmd. If environment gets broken for some reason then fail-safe just stops working. I would rather have fail-safe method to be working without working environment.
- imply CMD_SF
- help
- help
- default 0x100000
- help
itself.
- default 0x700000
- help
if SPL
Agreed. Better solution would be reading flash offset and size from dtb. But that would need much complex implementation.
Oskari
Cheers, Andre.
- "fi\0"
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- include/configs/sunxi-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 7be94ee7d1..cb7b68cf72 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -414,6 +414,7 @@ extern int soft_i2c_gpio_scl; BOOT_TARGET_DEVICES_MMC(func) \ BOOT_TARGET_DEVICES_SCSI(func) \ BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SPI(func) \ BOOT_TARGET_DEVICES_PXE(func) \ BOOT_TARGET_DEVICES_DHCP(func)
André Przywara
Oskari Lemmela
Oskari Lemmelä
