[U-Boot] [PATCH] ARM: rmobile: dts: Add XHCI USB node to r8a7796
The R8A7796 XHCI USB nodes are missing from r8a7796 dtsi, add them. These nodes don't come from mainline Linux, yet the DT binding is similar enough to R8A7795 which already has those in mainline and once the nodes hit mainline, this DT should be resynched.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/r8a7796.dtsi | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/r8a7796.dtsi b/arch/arm/dts/r8a7796.dtsi index 7e3b1d82a1..9e6a5f231e 100644 --- a/arch/arm/dts/r8a7796.dtsi +++ b/arch/arm/dts/r8a7796.dtsi @@ -1120,7 +1120,13 @@ };
xhci0: usb@ee000000 { - /* placeholder */ + compatible = "renesas,xhci-r8a7796", "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; };
ohci0: usb@ee080000 {
2017-09-13 6:02 GMT+09:00 Marek Vasut marek.vasut@gmail.com:
Applied to rmobile branch.
Thanks, Nobuhiro
/* placeholder */
status = "disabled"; }; ohci0: usb@ee080000 {
-- 2.11.0
Nobuhiro Iwamatsu
