[U-Boot] newbie questions regarding some config options.
As per the README file:
Subscribe to u-boot mailing list;
if (clueless) email("Hi, I am new to U-Boot, how do I get started?");
I'm messing around with uboot and QEMU (qemu-system-arm -M realview-pbx-a9 -kernel u-boot.bin), things are going pretty well in the sense that I'm not having too much trouble reading most of the code and creating a new board. I have some questions that I can't figure out by reading the code. What is the CONFIG_SYS_TEXT_BASE variable and how can I figure out what it should be?
I randomly set it to 0x0...then tried to debug u-boot under qemu, but when stepping in the start.S file it was instantly clear that it wasn't really working because gdb said the code ran right though the _start: b reset instruction and qemu eventually crashed with the following output: qemu: fatal: Trying to execute code outside RAM or ROM at 0xfeb70cdc
R00=00000000 R01=ffff0000 R02=00000000 R03=000108ac R04=ffff0000 R05=ffbedf70 R06=ffff0000 R07=00000010 R08=00001000 R09=ffff0000 R10=000108ac R11=00000000 R12=00001078 R13=ffbedf60 R14=00000960 R15=feb70cdc PSR=600001d3 -ZC- A svc32 Aborted
Apart from that everything is pretty clear to me, but I want to make sure I'm getting this points right: Is the environment the set of variables that can be modified with setenv? How can I determine the "size of the environment"? Is it the number of characters including variable names?
Also, is there anything special I need to do with gdb to get it to follow relocating code?
thanks, -Chris
Hi Christopher,
U-boot is typically stored in flash and one of the first things it does when executed is relocate to ram. CONFIG_SYS_TEXT_BASE is the relocation address. Typically, u-boot global data, heap and then stack is stored just below this.
Since u-boot is used to load some other program like the kernel, you need the u-boot relocation address to be out of the way of this. So, for the boards I have seen (not arm), CONFIG_SYS_TEXT_BASE is set to the top of ram - 256KB, i.e. enough room for the u-boot image.
I am sure more experienced u-boot developers will correct me if I am wrong :)
Regards Phil
Am 13.06.2011 15:09, schrieb PHIL.EDWORTHY@renesas.com:
Hi Christopher,
the relocation
On ARM, CONFIG_SYS_TEXT_BASE is typically the base address of the image in flash. This is, on a system booting from NOR, the address of the first instruction which is fetched from the CPU.
The relocation address is dynamically calculated from a couple of (runtime) information and has nothing to do with CONFIG_SYS_TEXT_BASE. This is true for ARM and AFAIK for PPC.
Matthias
Hi Matthias,
the relocation
Thanks for the additional info - SH is a little different then!
Phil
On Mon, 13 Jun 2011 15:08:35 +0100, PHIL.EDWORTHY@renesas.com wrote:
Hi Matthias,
Phil
Thanks for the information. Since CONFIG_SYS_TEXT_BASE seems to be a critical value and isn't something that can be ignored, maybe it deserves an entry in the already helpful README. I'd write it myself but I'm not qualified.
-Chris
Dear Christopher Harvey,
Try it, and others will fill in and/or correct where necessary.
Dear PHIL.EDWORTHY@renesas.com,
In message OF0DAC137B.B5EC37B0-ONC12578AE.004D7395-802578AE.004D9320@eu.necel.com you wrote:
Several architectures copied the old ARM model of not performing proper relocation. They all should be fixed...
In message OF460D0558.A844A780-ONC12578AE.0047905C-802578AE.00482EFA@eu.necel.com you wrote:
This is completely wrong. The relocation address is determined dynamically, depending on RAM size and a number of coinfigured options.
CONFIG_SYS_TEXT_BASE is the start address of the text segment when execution starts - on ROM booting systems this is an address in ROM.
Indeed this was necessary.
Wolfgang Denk <wd <at> denx.de> writes:
Dear PHIL.EDWORTHY <at> renesas.com,
In message <OF460D0558.A844A780-ONC12578AE.0047905C-802578AE.00482EFA <at>
wrong :)
Hello Wolfgang,
is it safe to say that this is the base address of the flash memory, the CONFIG_SYS_TEXT_BASE? Of course if I boot from flash.. Say if my flash is in 0x10000000 for NCS0 of at91rm9200 as an example, CONFIG_SYS_TEXT_BASE = 0x10000000?
Thanks
Chris
participants (5)
Chris
Christopher Harvey
Matthias Weisser
