[PATCH v2 0/1] arm: bcmbca: introduce the bcmbca architecture and 47622 SOC
This change introduces Broadcom's ARCH_BCMBCA architecture for armv7 and armv8 based Broadband SoCs. We expect to send additional patches for each SoC in the near future.
Changes in v2: - Updated dts and dtsi files which are accpeted in linux-next upstream - Changed CONFIG_SYS_TEXT_BASE to 0x01000000 from 0x10000000 to work on boards with 256MB or less memory
William Zhang (1): arm: bcmbca: introduce the bcmbca architecture and 47622 SOC
MAINTAINERS | 11 +++ arch/arm/Kconfig | 7 ++ arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 3 + arch/arm/dts/bcm47622.dtsi | 126 +++++++++++++++++++++++++ arch/arm/dts/bcm947622.dts | 30 ++++++ arch/arm/mach-bcmbca/Kconfig | 17 ++++ arch/arm/mach-bcmbca/Makefile | 6 ++ arch/arm/mach-bcmbca/bcm47622/Kconfig | 17 ++++ arch/arm/mach-bcmbca/bcm47622/Makefile | 5 + board/broadcom/bcmbca/Kconfig | 17 ++++ board/broadcom/bcmbca/Makefile | 5 + board/broadcom/bcmbca/board.c | 35 +++++++ configs/bcm947622_defconfig | 18 ++++ include/configs/bcm947622.h | 21 +++++ 15 files changed, 319 insertions(+) create mode 100644 arch/arm/dts/bcm47622.dtsi create mode 100644 arch/arm/dts/bcm947622.dts create mode 100644 arch/arm/mach-bcmbca/Kconfig create mode 100644 arch/arm/mach-bcmbca/Makefile create mode 100644 arch/arm/mach-bcmbca/bcm47622/Kconfig create mode 100644 arch/arm/mach-bcmbca/bcm47622/Makefile create mode 100644 board/broadcom/bcmbca/Kconfig create mode 100644 board/broadcom/bcmbca/Makefile create mode 100644 board/broadcom/bcmbca/board.c create mode 100644 configs/bcm947622_defconfig create mode 100644 include/configs/bcm947622.h
This is the initial support for Broadcom's ARM-based 47622 SOC.
In this change, our first SOC is an armv7 platform called 47622. The initial support includes a bare-bone implementation and dts with ARM PL011 uart.
The SOC-specific code resides in arch/arm/mach-bcmbca/<soc> and board related code is in board/broadcom/bcmba.
The u-boot image can be loaded from flash or network to the entry point address in the memory and boot from there.
Signed-off-by: William Zhang william.zhang@broadcom.com Signed-off-by: Kursad Oney kursad.oney@broadcom.com Signed-off-by: Anand Gore anand.gore@broadcom.com ---
diff --git a/MAINTAINERS b/MAINTAINERS index 56be0bfad00c..96cd85dd1c7a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -195,6 +195,17 @@ F: drivers/pinctrl/broadcom/ F: configs/rpi_* T: git https://source.denx.de/u-boot/custodians/u-boot-arm.git
+ARM BROADCOM BCMBCA +M: Anand Gore anand.gore@broadcom.com +M: William Zhang william.zhang@broadcom.com +M: Kursad Oney kursad.oney@broadcom.com +M: Joel Peshkin joel.peshkin@broadcom.com +S: Maintained +F: arch/arm/mach-bcmbca/ +F: board/broadcom/bcmbca/ +F: configs/bcm947622_defconfig +F: include/configs/bcm947622.h + ARM BROADCOM BCMSTB M: Thomas Fitzsimmons fitzsim@fitzsim.org S: Maintained diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 57946f61fabe..5e231fc72854 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -712,6 +712,11 @@ config ARCH_BCMSTB This enables support for Broadcom ARM-based set-top box chipsets, including the 7445 family of chips.
+config ARCH_BCMBCA + bool "Broadcom broadband chip family" + select DM + select OF_CONTROL + config TARGET_VEXPRESS_CA9X4 bool "Support vexpress_ca9x4" select CPU_V7A @@ -2175,6 +2180,8 @@ source "arch/arm/mach-at91/Kconfig"
source "arch/arm/mach-bcm283x/Kconfig"
+source "arch/arm/mach-bcmbca/Kconfig" + source "arch/arm/mach-bcmstb/Kconfig"
source "arch/arm/mach-davinci/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index ad757e982e37..0fd127e0e7e4 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -59,6 +59,7 @@ machine-$(CONFIG_ARCH_APPLE) += apple machine-$(CONFIG_ARCH_ASPEED) += aspeed machine-$(CONFIG_ARCH_AT91) += at91 machine-$(CONFIG_ARCH_BCM283X) += bcm283x +machine-$(CONFIG_ARCH_BCMBCA) += bcmbca machine-$(CONFIG_ARCH_BCMSTB) += bcmstb machine-$(CONFIG_ARCH_DAVINCI) += davinci machine-$(CONFIG_ARCH_EXYNOS) += exynos diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ab2d0da192c6..db42475bba1c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1132,6 +1132,9 @@ dtb-$(CONFIG_TARGET_BCMNS3) += ns3-board.dtb
dtb-$(CONFIG_ARCH_BCMSTB) += bcm7xxx.dtb
+dtb-$(CONFIG_BCM47622) += \ + bcm947622.dtb + dtb-$(CONFIG_ASPEED_AST2500) += ast2500-evb.dtb dtb-$(CONFIG_ASPEED_AST2600) += ast2600-evb.dtb
diff --git a/arch/arm/dts/bcm47622.dtsi b/arch/arm/dts/bcm47622.dtsi new file mode 100644 index 000000000000..c016e12b7372 --- /dev/null +++ b/arch/arm/dts/bcm47622.dtsi @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2022 Broadcom Ltd. + */ + +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + compatible = "brcm,bcm47622", "brcm,bcmbca"; + #address-cells = <1>; + #size-cells = <1>; + + interrupt-parent = <&gic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + CA7_0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x0>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + }; + + CA7_1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x1>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + }; + CA7_2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x2>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + }; + CA7_3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0x3>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + }; + L2_0: l2-cache0 { + compatible = "cache"; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + arm,cpu-registers-not-fw-configured; + }; + + pmu: pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&CA7_0>, <&CA7_1>, + <&CA7_2>, <&CA7_3>; + }; + + clocks: clocks { + periph_clk: periph-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + }; + uart_clk: uart-clk { + compatible = "fixed-factor-clock"; + #clock-cells = <0>; + clocks = <&periph_clk>; + clock-div = <4>; + clock-mult = <1>; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + cpu_off = <1>; + cpu_on = <2>; + }; + + axi@81000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x81000000 0x818000>; + + gic: interrupt-controller@1000 { + compatible = "arm,cortex-a7-gic"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x1000 0x1000>, + <0x2000 0x2000>; + }; + }; + + bus@ff800000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xff800000 0x800000>; + + uart0: serial@12000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x12000 0x1000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&uart_clk>, <&uart_clk>; + clock-names = "uartclk", "apb_pclk"; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/bcm947622.dts b/arch/arm/dts/bcm947622.dts new file mode 100644 index 000000000000..6f083724ab8e --- /dev/null +++ b/arch/arm/dts/bcm947622.dts @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 Broadcom Ltd. + */ + +/dts-v1/; + +#include "bcm47622.dtsi" + +/ { + model = "Broadcom BCM947622 Reference Board"; + compatible = "brcm,bcm947622", "brcm,bcm47622", "brcm,bcmbca"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x08000000>; + }; +}; + +&uart0 { + status = "okay"; +}; diff --git a/arch/arm/mach-bcmbca/Kconfig b/arch/arm/mach-bcmbca/Kconfig new file mode 100644 index 000000000000..2d49380f879b --- /dev/null +++ b/arch/arm/mach-bcmbca/Kconfig @@ -0,0 +1,17 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd +# + +if ARCH_BCMBCA + +config BCM47622 + bool "Support for Broadcom 47622 Family" + select SYS_ARCH_TIMER + select CPU_V7A + select DM_SERIAL + select PL01X_SERIAL + +endif + +source "arch/arm/mach-bcmbca/bcm47622/Kconfig" diff --git a/arch/arm/mach-bcmbca/Makefile b/arch/arm/mach-bcmbca/Makefile new file mode 100644 index 000000000000..072d4ea7b5e6 --- /dev/null +++ b/arch/arm/mach-bcmbca/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd +# + +obj-$(CONFIG_BCM47622) += bcm47622/ diff --git a/arch/arm/mach-bcmbca/bcm47622/Kconfig b/arch/arm/mach-bcmbca/bcm47622/Kconfig new file mode 100644 index 000000000000..bce30892e35d --- /dev/null +++ b/arch/arm/mach-bcmbca/bcm47622/Kconfig @@ -0,0 +1,17 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd +# + +if BCM47622 + +config TARGET_BCM947622 + bool "Broadcom 47622 Reference Board" + depends on ARCH_BCMBCA + +config SYS_SOC + default "bcm47622" + +source "board/broadcom/bcmbca/Kconfig" + +endif diff --git a/arch/arm/mach-bcmbca/bcm47622/Makefile b/arch/arm/mach-bcmbca/bcm47622/Makefile new file mode 100644 index 000000000000..beb979af7520 --- /dev/null +++ b/arch/arm/mach-bcmbca/bcm47622/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd +# +obj- += dummy.o diff --git a/board/broadcom/bcmbca/Kconfig b/board/broadcom/bcmbca/Kconfig new file mode 100644 index 000000000000..63d4252da620 --- /dev/null +++ b/board/broadcom/bcmbca/Kconfig @@ -0,0 +1,17 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd +# + +config SYS_BOARD + default "bcmbca" + +config SYS_VENDOR + default "broadcom" + +if TARGET_BCM947622 + +config SYS_CONFIG_NAME + default "bcm947622" + +endif diff --git a/board/broadcom/bcmbca/Makefile b/board/broadcom/bcmbca/Makefile new file mode 100644 index 000000000000..8f06c3111b9b --- /dev/null +++ b/board/broadcom/bcmbca/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Broadcom Ltd + +obj-y += board.o diff --git a/board/broadcom/bcmbca/board.c b/board/broadcom/bcmbca/board.c new file mode 100644 index 000000000000..4aa1d659d5c7 --- /dev/null +++ b/board/broadcom/bcmbca/board.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 Broadcom Ltd. + */ + +#include <common.h> +#include <fdtdec.h> + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + if (fdtdec_setup_mem_size_base() != 0) + puts("fdtdec_setup_mem_size_base() has failed\n"); + + return 0; +} + +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + return 0; +} + +int print_cpuinfo(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/configs/bcm947622_defconfig b/configs/bcm947622_defconfig new file mode 100644 index 000000000000..2cb17fb0ac2c --- /dev/null +++ b/configs/bcm947622_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_BCMBCA=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_BCM47622=y +CONFIG_TARGET_BCM947622=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="bcm947622" +CONFIG_IDENT_STRING=" Broadcom BCM47622" +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_SYS_LOAD_ADDR=0x01000000 +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CACHE=y +CONFIG_OF_EMBED=y +CONFIG_CLK=y diff --git a/include/configs/bcm947622.h b/include/configs/bcm947622.h new file mode 100644 index 000000000000..7c80e88be03d --- /dev/null +++ b/include/configs/bcm947622.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 Broadcom Ltd. + */ + +#ifndef __BCM947622_H +#define __BCM947622_H +#include <linux/sizes.h> + +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BOOTM_LEN (32 * 1024 * 1024) + +/* UART */ +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } + +#define CONFIG_SYS_SDRAM_BASE 0x00000000 + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) + +#define COUNTER_FREQUENCY 50000000 +#endif
Minor:
Please just use the default table.
Minor:
Will remove this line in v3
William Zhang
