[U-Boot] [PATCH v2 0/3] MXC: Add NAND support for i.MX31
Hi all,
This series adds NAND support for i.MX31 using the mxc_nand driver that was added for i.MX27. The same NAND flash controller is used in i.MX31.
Tested on i.MX31 Litekit. MAKEALL ARM11&ARM9 performed.
Changes since v1: Changed variable name in mxc_nand.c.
Regards, Magnus
Magnus Lilja (3): MX31: Add struct definition for clock control module in i.MX31. mxc_nand: Update driver to work with i.MX31. MX31: Activate NAND support for i.MX31 Litekit board.
drivers/mtd/nand/mxc_nand.c | 34 ++++++++++++++++++++++++++-- include/asm-arm/arch-mx31/mx31-regs.h | 39 +++++++++++++++++++++++++++++++++ include/configs/imx31_litekit.h | 10 ++++++++ 3 files changed, 80 insertions(+), 3 deletions(-)
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- include/asm-arm/arch-mx31/mx31-regs.h | 39 +++++++++++++++++++++++++++++++++ 1 files changed, 39 insertions(+), 0 deletions(-)
diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index 51b02a2..6f6e9a4 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -24,6 +24,45 @@ #ifndef __ASM_ARCH_MX31_REGS_H #define __ASM_ARCH_MX31_REGS_H
+#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/types.h> + +/* Clock control module registers */ +struct clock_control_regs { + u32 ccmr; + u32 pdr0; + u32 pdr1; + u32 rcsr; + u32 mpctl; + u32 upctl; + u32 spctl; + u32 cosr; + u32 cgr0; + u32 cgr1; + u32 cgr2; + u32 wimr0; + u32 ldc; + u32 dcvr0; + u32 dcvr1; + u32 dcvr2; + u32 dcvr3; + u32 ltr0; + u32 ltr1; + u32 ltr2; + u32 ltr3; + u32 ltbr0; + u32 ltbr1; + u32 pmcr0; + u32 pmcr1; + u32 pdr2; +}; + +/* Bit definitions for RCSR register in CCM */ +#define CCM_RCSR_NF16B (1 << 31) +#define CCM_RCSR_NFMS (1 << 30) + +#endif + #define __REG(x) (*((volatile u32 *)(x))) #define __REG16(x) (*((volatile u16 *)(x))) #define __REG8(x) (*((volatile u8 *)(x)))
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com Acked-by: Scott Wood scottwood@freescale.com ---
Change since v1: Renamed sc_regs variable for i.MX31 to cc_regs.
drivers/mtd/nand/mxc_nand.c | 34 +++++++++++++++++++++++++++++++--- 1 files changed, 31 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index eb0323f..3ce3adb 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -149,6 +149,36 @@ static struct nand_ecclayout nand_soft_eccoob = { }; #endif
+#ifdef CONFIG_MX27 +static int is_16bit_nand(void) +{ + struct system_control_regs *sc_regs = + (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; + + if (readl(&sc_regs->fmcr) & NF_16BIT_SEL) + return 1; + else + return 0; +} +#elif defined(CONFIG_MX31) +static int is_16bit_nand(void) +{ + struct clock_control_regs *cc_regs = + (struct clock_control_regs *)CCM_BASE; + + if (readl(&cc_regs->rcsr) & CCM_RCSR_NF16B) + return 1; + else + return 0; +} +#else +#warning "8/16 bit NAND autodetection not supported" +static int is_16bit_nand(void) +{ + return 0; +} +#endif + static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size) { uint32_t *d = dest; @@ -808,8 +838,6 @@ static void mxc_nand_command(struct mtd_info *mtd, unsigned command,
int board_nand_init(struct nand_chip *this) { - struct system_control_regs *sc_regs = - (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; struct mtd_info *mtd; uint16_t tmp; int err = 0; @@ -871,7 +899,7 @@ int board_nand_init(struct nand_chip *this) writew(0x4, &host->regs->nfc_wrprot);
/* NAND bus width determines access funtions used by upper layer */ - if (readl(&sc_regs->fmcr) & NF_16BIT_SEL) + if (is_16bit_nand()) this->options |= NAND_BUSWIDTH_16;
host->pagesize_2k = 0;
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- include/configs/imx31_litekit.h | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 6131008..f413994 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -89,6 +89,7 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_SPI #define CONFIG_CMD_DATE +#define CONFIG_CMD_NAND
#define CONFIG_BOOTDELAY 3
@@ -174,4 +175,13 @@ #undef CONFIG_CMD_MTDPARTS #define CONFIG_JFFS2_DEV "nor0"
+/* + * NAND + */ +#define CONFIG_NAND_MXC +#define CONFIG_MXC_NAND_REGS_BASE NFC_BASE_ADDR +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR +#define CONFIG_MXC_NAND_HWECC + #endif /* __CONFIG_H */
Hi
I received no further comments on these patches after posting v2 (the NAND part is ACK-ed by Scott Wood). Could someone pull these? I applied them to the current u-boot tip without any problems.
Regads, Magnus
Magnus Lilja skrev:
Hi all,
Regards, Magnus
Magnus Lilja
