[U-Boot] [PATCH] board: tbs2910: add private imx config
Add board specific imx config file with recommended IPU Qos settings and adapted DDR configuration.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/Kconfig | 2 +- board/tbs/tbs2910/tbs2910.cfg | 115 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 116 insertions(+), 1 deletion(-) create mode 100644 board/tbs/tbs2910/tbs2910.cfg
diff --git a/board/tbs/tbs2910/Kconfig b/board/tbs/tbs2910/Kconfig index 55c475c..2e5e1d4 100644 --- a/board/tbs/tbs2910/Kconfig +++ b/board/tbs/tbs2910/Kconfig @@ -13,6 +13,6 @@ config MX6Q default y
config IMX_CONFIG - default "board/boundary/nitrogen6x/nitrogen6q2g.cfg" + default "board/tbs/tbs2910/tbs2910.cfg"
endif diff --git a/board/tbs/tbs2910/tbs2910.cfg b/board/tbs/tbs2910/tbs2910.cfg new file mode 100644 index 0000000..37fd4ba --- /dev/null +++ b/board/tbs/tbs2910/tbs2910.cfg @@ -0,0 +1,115 @@ +/* + * Copyright (C) 2017 Soeren Moch smoch@web.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define __ASSEMBLY__ +#include "asm/arch/crm_regs.h" +#include "asm/arch/iomux.h" +#include "asm/arch/mx6-ddr.h" + +/* image version 2 for imx6 */ +IMAGE_VERSION 2 +BOOT_FROM sd + +/* set the default clock gates to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF +/* set CKO1 (used as AUDIO_MCLK) to ahb_clk_root/8 = 16.5 MHz */ +DATA 4, CCM_CCOSR, 0x000000fb + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x77177717 +DATA 4, MX6_IOMUXC_GPR7, 0x77177717 + + +/* + * DDR3/DDR3L settings + * use default 40 Ohm pad drive strength, no odt + * 4x256Mx16 DDR3L-1066 7-7-7 + */ + +/* disable dq pullup */ +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +/* disable dqs pullup */ +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 +/* set ddr input mode for dq signals */ +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 +/* set ddr input mode for dqs signals */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 +/* set pad calibration type to DDR3 */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 +/* ZQ calibration */ +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +/* dqs write delay */ +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x001f001f +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x001f001f +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x001f001f +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x001f001f +/* dqs read delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 +/* dqs read gating control */ +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x43000300 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x03000300 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x43000300 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x03000300 +/* start delay line calibration */ +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +/* tRFC=0x89+1,tXS=0x8e+1,tXP=3+1,tXPDLL=0xc+1,tFAW=0x17+1,tCL=0x4+3 */ +DATA 4, MX6_MMDC_P0_MDCFG0, 0x898E7974 +/* tRCD=6+1,tRP=6+1,tRC=0x1a+1,tRAS=0x13+1,tRPA=tRP+1,tWR=7+1,tMRD=0xb+1,tCWL=4+2 */ +DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB538F64 +/* tDLLK=0x1ff+1,tRTP=3+1,tWTR=3+1,tRRD=3+1 */ +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +/* RTW_SAME=2,WTR_DIFF=3,WTW_DIFF=3,RTW_DIFF=2,RTR_DIFF=2 */ +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +/* tXPR=0x8e+1,SDE2RST=0x10-2,RST2CKE=0x23-2 */ +DATA 4, MX6_MMDC_P0_MDOR, 0x008E1023 +/* ODT timing */ +DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 +/* read odt settings, 120 Ohm */ +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00011117 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00011117 +/* cs0, 15-bit row, 10-bit column, BL 8, 64-bit bus */ +DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 +/* interleaved bank access (row/bank/col), 5 cycles additional read delay */ +DATA 4, MX6_MMDC_P0_MDMISC, 0x00001740 +/* 2GiByte RAM at cs0 */ +DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 +/* load mode registers of external ddr chips */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +/* externel chip ZQ calibration */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +/* configure and start refreshes, 8 refresh commands at 32 kHz */ +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +/* tCKE=2+1,tCKSRX=6,tCKSE=6, active power down after 256 cycles (setting 5) */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 +/* set automatic self refresh */ +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 +/* controller configuration finished */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000
Best regards, Stefano Babic
Soeren Moch
Stefano Babic
