[U-Boot] [PATCH 2/5][v2] powerpc/mpc85xx: new SPL support for IFC NAND
Linker script is not able find start.o binary. So add its absolute path in u-boot-spl.lds. This change is similar to u-boot-nand.lds
common/Makefile: Avoid compiling unnecssary files
fsl_ifc_spl.c : It is is responsible for reading u-boot binary from NAND flash and copying into DDR. It also transfer cotrol from NAND SPL to u-boot image present in DDR.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master
Changes for v2: Sending as it is
arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 2 +- board/freescale/common/Makefile | 10 ++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsl_ifc_spl.c | 258 +++++++++++++++++++++++++++++++ 4 files changed, 270 insertions(+), 1 deletion(-) create mode 100644 drivers/mtd/nand/fsl_ifc_spl.c
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index f2b7bff..cf6fa7c 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -60,7 +60,7 @@ SECTIONS #if defined(CONFIG_FSL_IFC) /* Restrict bootpg at 4K boundry for IFC */ .bootpg ADDR(.text) + 0x1000 : { - start.o (.bootpg) + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) } #define RESET_VECTOR_OFFSET 0x1ffc /* IFC has 8K sram */ #elif defined(CONFIG_FSL_ELBC) diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 75725b4..a4d521c 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -29,6 +29,15 @@ endif
LIB = $(obj)libfreescale.o
+MINIMAL= + +ifdef CONFIG_SPL_BUILD +ifdef CONFIG_SPL_INIT_MINIMAL +MINIMAL=y +endif +endif + +ifndef MINIMAL COBJS-$(CONFIG_FSL_CADMUS) += cadmus.o COBJS-$(CONFIG_FSL_VIA) += cds_via.o COBJS-$(CONFIG_FMAN_ENET) += fman.o @@ -62,6 +71,7 @@ SUBLIB-$(CONFIG_P3041DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P4080DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5020DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5040DS) += p_corenet/libp_corenet.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index c77c0c4..9d7deb8 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -82,6 +82,7 @@ COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o else # minimal SPL drivers
COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o
endif # drivers endif # nand diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c new file mode 100644 index 0000000..c4a9ba1 --- /dev/null +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -0,0 +1,258 @@ +/* + * NAND boot for Freescale Integrated Flash Controller, NAND FCM + * + * Copyright 2011 Freescale Semiconductor, Inc. + * Author: Dipen Dudhat dipen.dudhat@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/fsl_ifc.h> +#include <linux/mtd/nand.h> + +static inline int is_blank(uchar *addr, int page_size) +{ + int i; + + for (i = 0; i < page_size; i++) { + if (__raw_readb(&addr[i]) != 0xff) + return 0; + } + + /* + * For the SPL, don't worry about uncorrectable errors + * where the main area is all FFs but shouldn't be. + */ + return 1; +} + +/* returns nonzero if entire page is blank */ +static inline int check_read_ecc(uchar *buf, u32 *eccstat, + unsigned int bufnum, int page_size) +{ + u32 reg = eccstat[bufnum / 4]; + int errors = (reg >> ((3 - bufnum % 4) * 8)) & 15; + + if (errors == 15) { /* uncorrectable */ + /* Blank pages fail hw ECC checks */ + if (is_blank(buf, page_size)) + return 1; + + puts("ecc error\n"); + for (;;) + ; + } + + return 0; +} + +static inline void nand_wait(uchar *buf, int bufnum, int page_size) +{ + struct fsl_ifc *ifc = IFC_BASE_ADDR; + u32 status; + u32 eccstat[4]; + int bufperpage = page_size / 512; + int bufnum_end, i; + + bufnum *= bufperpage; + bufnum_end = bufnum + bufperpage - 1; + + do { + status = in_be32(&ifc->ifc_nand.nand_evter_stat); + } while (!(status & IFC_NAND_EVTER_STAT_OPC)); + + if (status & IFC_NAND_EVTER_STAT_FTOER) { + puts("flash time out error\n"); + for (;;) + ; + } + + for (i = bufnum / 4; i <= bufnum_end / 4; i++) + eccstat[i] = in_be32(&ifc->ifc_nand.nand_eccstat[i]); + + for (i = bufnum; i <= bufnum_end; i++) { + if (check_read_ecc(buf, eccstat, i, page_size)) + break; + } + + out_be32(&ifc->ifc_nand.nand_evter_stat, status); +} + +static inline int bad_block(uchar *marker, int port_size) +{ + if (port_size == 8) + return __raw_readb(marker) != 0xff; + else + return __raw_readw((u16 *)marker) != 0xffff; +} + +static void nand_load(unsigned int offs, int uboot_size, uchar *dst) +{ + struct fsl_ifc *ifc = IFC_BASE_ADDR; + uchar *buf = (uchar *)CONFIG_SYS_NAND_BASE; + int page_size; + int port_size; + int pages_per_blk; + int blk_size; + int bad_marker = 0; + int bufnum_mask, bufnum; + + int csor, cspr; + int pos = 0; + int j = 0; + + int sram_addr; + int pg_no; + + /* Get NAND Flash configuration */ + csor = CONFIG_SYS_NAND_CSOR; + cspr = CONFIG_SYS_NAND_CSPR; + + port_size = (cspr & CSPR_PORT_SIZE_16) ? 16 : 8; + + if (csor & CSOR_NAND_PGS_4K) { + page_size = 4096; + bufnum_mask = 1; + } else if (csor & CSOR_NAND_PGS_2K) { + page_size = 2048; + bufnum_mask = 3; + } else { + page_size = 512; + bufnum_mask = 15; + + if (port_size == 8) + bad_marker = 5; + } + + pages_per_blk = + 32 << ((csor & CSOR_NAND_PB_MASK) >> CSOR_NAND_PB_SHIFT); + + blk_size = pages_per_blk * page_size; + + /* Open Full SRAM mapping for spare are access */ + out_be32(&ifc->ifc_nand.ncfgr, 0x0); + + /* Clear Boot events */ + out_be32(&ifc->ifc_nand.nand_evter_stat, 0xffffffff); + + /* Program FIR/FCR for Large/Small page */ + if (page_size > 512) { + out_be32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP4_SHIFT)); + out_be32(&ifc->ifc_nand.nand_fir1, 0x0); + + out_be32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | + (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); + } else { + out_be32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP3_SHIFT)); + out_be32(&ifc->ifc_nand.nand_fir1, 0x0); + + out_be32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); + } + + /* Program FBCR = 0 for full page read */ + out_be32(&ifc->ifc_nand.nand_fbcr, 0); + + /* Read and copy u-boot on SDRAM from NAND device, In parallel + * check for Bad block if found skip it and read continue to + * next Block + */ + while (pos < uboot_size) { + int i = 0; + do { + pg_no = offs / page_size; + bufnum = pg_no & bufnum_mask; + sram_addr = bufnum * page_size * 2; + + out_be32(&ifc->ifc_nand.row0, pg_no); + out_be32(&ifc->ifc_nand.col0, 0); + /* start read */ + out_be32(&ifc->ifc_nand.nandseq_strt, + IFC_NAND_SEQ_STRT_FIR_STRT); + + /* wait for read to complete */ + nand_wait(&buf[sram_addr], bufnum, page_size); + + /* + * If either of the first two pages are marked bad, + * continue to the next block. + */ + if (i++ < 2 && + bad_block(&buf[sram_addr + page_size + bad_marker], + port_size)) { + puts("skipping\n"); + offs = (offs + blk_size) & ~(blk_size - 1); + pos &= ~(blk_size - 1); + break; + } + + for (j = 0; j < page_size; j++) + dst[pos + j] = __raw_readb(&buf[sram_addr + j]); + + pos += page_size; + offs += page_size; + } while ((offs & (blk_size - 1)) && (pos < uboot_size)); + } +} + +/* + * Main entrypoint for NAND Boot. It's necessary that SDRAM is already + * configured and available since this code loads the main U-boot image + * from NAND into SDRAM and starts from there. + */ +void nand_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + /* + * Load U-Boot image from NAND into RAM + */ + nand_load(CONFIG_SYS_NAND_U_BOOT_OFFS, CONFIG_SYS_NAND_U_BOOT_SIZE, + (uchar *)CONFIG_SYS_NAND_U_BOOT_DST); + +#ifdef CONFIG_NAND_ENV_DST + nand_load(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_NAND_ENV_DST); + +#ifdef CONFIG_ENV_OFFSET_REDUND + nand_load(CONFIG_ENV_OFFSET_REDUND, CONFIG_ENV_SIZE, + (uchar *)CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE); +#endif +#endif + /* + * Jump to U-Boot image + */ +#ifdef CONFIG_SPL_FLUSH_IMAGE + /* + * Clean d-cache and invalidate i-cache, to + * make sure that no stale data is executed. + */ + flush_cache(CONFIG_SYS_NAND_U_BOOT_DST, CONFIG_SYS_NAND_U_BOOT_SIZE); +#endif + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; + uboot(); +}
+MINIMAL=
If this is needed to avoid pulling in any files from this directory, why did p1_p2_rdb_pc not need this? Is there a particular file that is failing to build or failing to get optimized away?
-Scott
+MINIMAL=
I cannot avoid this directory :(. because new SPL compile this directory even after undef QIXIS defines
#ifndef CONFIG_SPL_BUILD #define CONFIG_FSL_QIXIS #endif
make[3]: Leaving directory `/home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/board/freescale/bsc9132qds' make -C /home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/board/freescale/common/ make[3]: Entering directory `/home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/board/freescale/common' -- -- /opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/bin/powerpc-linux-gnu-gcc -g -Os -fpic -mrelocatable -ffunction-sections -fdata-sections -meabi -D__KERNEL__ -ffunction-sections -fdata-sections -DCONFIG_SYS_TEXT_BASE=0x00201000 -DCONFIG_SPL_TEXT_BASE=0xFFFFE000 -DCONFIG_SPL_BUILD -I/home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/freescale/usr/local/gcc-4.5.55-eglibc-2.11.55/powerpc-linux-gnu/lib/gcc/powerpc-linux-gnu/4.5.1/include -pipe -DCONFIG_PPC -D__powerpc__ -ffixed-r2 -Wa,-me500 -msoft-float -mno-string -mspe=yes -mno-spe -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -o /home/b32579/Workspace/MERGE/OPENSRC/U-BOOT/u-boot/spl/board/freescale/common/qixis.o qixis.c -c qixis.c: In function 'qixis_read': --- qixis.c:36:20: error: 'QIXIS_BASE' undeclared (first use in this function) qixis.c:36:20: note: each undeclared identifier is reported only once for each function it appears in make: *** [BSC9132QDS_NAND_DDRCLK133] Error 2
Regards, Prabhakar
+MINIMAL=
Yeah, the makefiles never see CONFIG_SPL_BUILD -- it only works for C code.
The P1022 SPL patch just does this in the makefile:
+ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_FSL_NGPIXIS) += ngpixis.o +endif
...which is less intrusive. We can revisit it if we end up actually needing pixis/qixis inside an SPL.
-Scott
+MINIMAL=
Only putting qixis.c in ifndef CONFIG_SPI_BUILD may not work for 9132QDS. following change is also required i.e. to put CONFIG_ID_EEPROM in ifndef CONFIG_SPI_BUILD
+ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_FSL_QIXIS) += qixis.o -COBJS-$(CONFIG_PQ_MDS_PIB) += pq-mds-pib.o COBJS-$(CONFIG_ID_EEPROM) += sys_eeprom.o +endif +COBJS-$(CONFIG_PQ_MDS_PIB) += pq-mds-pib.o
It will be good to have original patch which do not compile any file for SPL. if any file needs to be compiled for SPL, it can be added in ifdef MINIMAL.
If we follow "ifndef CONFIG_SPL_BUILD" way, one has to add required define one by one for required platforms supporting SPL. It eventually may become equal to my original patch. (just guessing, it may never happen)
Regards, Prabhakar
+MINIMAL=
OK.
-Scott
+MINIMAL=
I need to add config_mpc85xx.h here.
#define CONFIG_MPC85xx #define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_SYS_HAS_SERDES /* common SERDES init code */ +#include "../../arch/powerpc/include/asm/config_mpc85xx.h"
I tried just after CONFIG_P1010 but it is giving compilation error.
Just to mention, I need to provide relative path in order to compile. I will still suggest to keep original patch, As header file location may change over period of time then config file needs to be updated again.
Regards, Prabhakar
Prabhakar Kushwaha
Scott Wood
