Re: [PATCH v1] mtd: parsers: ofpart: Fix parsing when size-cells is 0
+ u-boot list
On Fri, Dec 02, 2022 at 11:53:27AM +0100, Miquel Raynal wrote:
francesco@dolcini.it wrote on Fri, 2 Dec 2022 11:24:29 +0100:
On Fri, Dec 02, 2022 at 11:12:43AM +0100, Francesco Dolcini wrote:
On Fri, Dec 02, 2022 at 10:14:18AM +0100, Miquel Raynal wrote:
francesco@dolcini.it wrote on Fri, 2 Dec 2022 08:19:00 +0100:
From: Francesco Dolcini francesco.dolcini@toradex.com
Add a fallback mechanism to handle the case in which #size-cells is set to <0>. According to the DT binding the nand controller node should have set it to 0 and this is not compatible with the legacy way of specifying partitions directly as child nodes of the nand-controller node.
I understand the problem, I understand the fix, but I have to say, I strongly dislike it :) Touching an mtd core driver to fix a single broken use case like that is... problematic, for the least.
I just noticed it 2 days after this patch was backported to a stable kernel, I am just the first one to notice, we are not talking about a single use case.
I am sorry but if a 6.0 kernel breaks because:
Not only kernel 6.0 is currently broken. This patch is going to be backported to any stable kernel given the fixes tag it has.
If you really want to workaround U-Boot, either you revert that patch or you just fix the DT description instead. The parent/child/partitions scheme has been enforced for maybe 5 years now and for a good reason: a NAND controller with partitions does not make _any_ sense. There are plenty of examples out there, imx7-colibri.dtsi has received many updates since its introduction (for the best), so why not this one?
I can and I will update imx7-colibri.dtsi (patch coming),
:thumb_up:
but is this good enough given the kind of boot failure regression this introduce? We are going to have old u-boot around that will not work with it, and the
Just another piece of information, support for the partitions node in U-Boot was added in version v2022.04 [1], we are not talking about ancient old legacy stuff.
If it is so recent, then this is what needs to be fixed, and it should not bother "many" people because 2022.04 is not so old.
So I am a bit lost, IIUC what is currently broken is:
- U-Boot > 2022.04 and any version of Linux with the backport?
If I add the partitions node as a child of my nand controller, as I was planning to do and I wrote 10 lines above, I will create a new flavor of non-booting system with U-Boot older than v2022.04 :-/
I think there is a little confusion here. You are referring to the NAND
I guess I have not explained myself well enough :-)
U-Boot is creating the partitions in the dtb, they are not defined in the source dts file (this is common practice with multiple boards).
Before v2022.04 it was always updating the nand-controller node, starting from v2022.04 if there is a dedicated `partitions` node it uses it. This is just the reverse of what ofpart_core.c is doing (if the partitions node is there it assumes the partitions should go into it, otherwise it proceeds with the legacy way).
Let's have a concrete example with colibri-imx7.
Current status: - The nand-controller node does not include any partitions child, any U-Boot version will just add the partition directly as child of the nand controller. This is where I am hitting this boot regression now.
Potential change I envisioned here: - I add the partitions node to the nand-controller, e.g.
--- a/arch/arm/boot/dts/imx7-colibri.dtsi +++ b/arch/arm/boot/dts/imx7-colibri.dtsi @@ -380,6 +380,12 @@ &gpmi { nand-on-flash-bbt; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpmi_nand>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + }; };
- U-Boot >= v2022.04 will just work fine creating the partitions as currently described in the bindings. - U-Boot < v2022.04 will still create the partitions as child of the nand-controller node. Linux will see that a `partitions` node exists but it will be empty, leading to a boot failure in case mtd is used as boot device.
controller node, the commit refers to the NAND chip node. What this commit does looks fine because it just tries to use the partitions {} node rather than the NAND chip node and if the partitions {} node already exist, I expect #address-cells and #size-cells to be defined and be != 0 already.
yes, this commit is perfectly fine I agree.
The reality is that people is using newer kernel with older U-Boot, and I do not think that deliberately breaking this use case is what the Linux kernel should do.
I do not think that I can push a change in the DTS that will break booting any board using an older U-Boot.
Francesco
Hi Francesco,
francesco@dolcini.it wrote on Fri, 2 Dec 2022 12:23:37 +0100:
- u-boot list
:thumb_up:
Ok, there is still a confusion. Even though I think your logic still applies, I want to emphasis on how wrong it is to define partitions in the NAND _controller_ node rather than the NAND _chip_ node. And I think this might have an impact on our final choice.
That fdt_fixup_mtdparts() thing is a mistake. The original idea is:
1. Define wrong nodes in your DT 2. Fix your DT at run time in U-Boot 3. Provide the "fixed" DT to Linux
Now step #2 now produces wrong FDT. So what, we should darken even more the of partition driver in Linux to workaround it? At most what we can do is warn the user so that people don't loose time understanding what happens, but I am against supporting this, ever.
Sounds reasonable.
Yes, that's how we handle legacy bindings.
Current status:
Not exactly. It worked until now because your original DT already included #size-cells = <1> I believe. It does not do that anymore and that is why you get your boot regression: because the DT was modified.
The reason why the DT got modified however is interesting. The commit log says the goal is to comply with modern bindings, which is great. But if you break how your board boots, then you should probably not do that. And if we really care about complying with the bindings, there is something much more interesting than fixing a single property: distinguishing the NAND controller vs. the NAND chip(s), which has been enforced since 2016 (which probably predates the imx7-colibri.dtsi, but whatever): 2d472aba15ff ("mtd: nand: document the NAND controller/NAND chip DT representation")
partitions {
#size-cells = <1>;
Agreed.
That's however the initial cause of this discovery. A DT change broke your boot flow. I'm saying "your" boot flow because I am not sure it affects "any" board.
For now it only affects the imx7 colibri boards because of: 753395ea1e45 ("ARM: dts: imx7: Fix NAND controller size-cells")
But all these boards could be affected in the same way because of some machine code playing with fdt_fixup_mtdparts(): * arch/arm/mach-uniphier/fdt-fixup.c * board/compulab/cm_fx6/cm_fx6.c * board/gateworks/gw_ventana/gw_ventana.c * board/isee/igep003x/board.c * board/isee/igep00x0/igep00x0.c * board/phytec/phycore_am335x_r2/board.c * board/st/stm32mp1/stm32mp1.c * board/toradex/colibri-imx6ull/colibri-imx6ull.c * board/toradex/colibri_imx7/colibri_imx7.c * board/toradex/colibri_vf/colibri_vf.c That's of course way too much possible failures.
I still strongly disagree with the initial proposal but what I think we can do is:
1. To prevent future breakages: Fix fdt_fixup_mtdparts() in u-boot. This way newer U-Boot + any kernel should work.
2. To help tracking down situations like that: Keep the warning in ofpart.c but continue to fail.
3. To fix the current situation: Immediately revert commit (and prevent it from being backported): 753395ea1e45 ("ARM: dts: imx7: Fix NAND controller size-cells") This way your own boot flow is fixed in the short term.
4. There is no reason to partially fix a DT like what the above did besides trying to avoid warnings emitted by the DT check tools. If complying with modern bindings is a goal (and I think it should be), then we can modernize this DT without breaking the boot flow: Instead of only setting #size-cell = <0>, you can as well define in your DT a subnode to define the NAND chip. NAND chips are not supposed to have #size-cells properties, but in the past they did, which means #address-cells and #size-cells are allowed (and marked deprecated in the schema). So in practice, the dt-schema will not warn you if they are there, which means you can still set #size-cell = <1>.
Please mind, the tools have been updated very recently to match what I am describing above, so they will likely still report errors until v6.2-rc1, see: https://lore.kernel.org/linux-mtd/20221114090315.848208-1-miquel.raynal@boot...
Does this sound reasonable?
Thanks, Miquèl
On 12/2/22 15:05, Miquel Raynal wrote:
Hi Francesco,
Here I disagree, the fix is correct and I think we shouldn't proliferate incorrect DTs which don't match the binding document. Rather, if a bootloader generates incorrect (new) DT entries, I believe the driver should implement a fixup and warn user about this. PC does that as well with broken ACPI tables as far as I can tell.
I'm not convinced making a DT non-compliant with bindings again, only to work around a problem induced by bootloader, is the right approach here.
This would be setting a dangerous example, where anyone could request a DT fix to be reverted because their random bootloader does the wrong thing and with valid DT clean up, something broke.
- There is no reason to partially fix a DT like what the above did besides trying to avoid warnings emitted by the DT check tools.
Note that the 3. does not partially fix the DT, it fixes the node fully.
I am really not convinced we should hack around this on the DT end and try to push some sort of convoluted workaround there, instead of fixing it on the driver side (and bootloader side, in the long run).
Please mind, the tools have been updated very recently to match what I am describing above, so they will likely still report errors until v6.2-rc1, see: https://lore.kernel.org/linux-mtd/20221114090315.848208-1-miquel.raynal@bootlin.com/
Hi Marek,
marex@denx.de wrote on Fri, 2 Dec 2022 15:31:40 +0100:
Hi Francesco,
I agree we should not proliferate incorrect DTs, so let's use a modern description then, with a controller and a child node which defines the chip.
I am sorry to say so, but while warnings reported by the tools should be fixed, it's not because the tool does not scream at you that the description is valid. We are actively working on enhancing the schema so that "all" improper descriptions get warnings (see the series pointed earlier), but in no way this change makes the node compliant with modern bindings.
I'm not saying the fix is wrong, but let's be pragmatic, it currently leads to boot failures.
When a patch breaks a board and there is no straight fix, you revert it, then you think harder. That's what I am saying. This is a temporary solution.
Please, you know this is not valid DT clean up. We've been decoupling controller and chip description since 2016. What I am proposing is a valid DT cleanup, not to the latest standard, but way closer than the current solution.
"convoluted workaround" :-)
s/tools/schema/
Thanks, Miquèl
On 12/2/22 16:00, Miquel Raynal wrote:
Hi Marek,
Hi Francesco,
Yes please !
But what if there is no chip connected to the controller node ?
If I understand the proposal here right (please correct me if I'm wrong), then:
1) This is the original, old, wrong binding: &gpmi { #size-cells = <1>; ... partition@N { ... }; };
2) This is the newer, but still wrong binding: &gpmi { #size-cells = <0>; ... partitions { partition@N { ... }; }; };
3) This is the newest binding, what we want: &gpmi { #size-cells = <0>; ... nand-chip { partitions { partition@N { ... }; }; }; };
But if there is no physical nand chip connected to the controller, would we end up with empty nand-chip node in DT, like this? &gpmi { #size-cells = <X>; ... nand-chip { /* empty */ }; }; What would be the gpmi controller size cells (X) in that case, still 0, right ? So how does that help solve this problem, wouldn't U-Boot still populate the partitions directly under the gpmi node or into partitions sub-node ?
I fully agree that we do have a problem, and that it trickled into stable makes it even worse. Maybe I don't fully understand the thing with nand-chip proposal, see my question above, esp. the last part.
Isn't this patch the straight fix, at least until the bootloader can be updated to generate the nand-chip node correctly ?
I think I really need one more explanation of the nand-chip part above.
Hi Marek,
marex@denx.de wrote on Fri, 2 Dec 2022 16:23:29 +0100:
Hi Marek,
Hi Francesco,
Yes please !
Good idea to summarize.
- This is the original, old, wrong binding:
Yes.
- This is the newer, but still wrong binding:
Well, this is wrong description, but it would work (for compat reasons, even though I don't think this is considered valid DT by the schemas).
- This is the newest binding, what we want:
Yes
Is this really a concern? If there is no NAND chip, the controller should be disabled, no? I guess technically you could even use the status property in the nand-chip node...
However, it should not be empty, at the very least a reg property should indicate on which CS it is wired, as expected there: https://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux.git/tree/Documenta...
But, as nand-chip.yaml references mtd.yaml, you can as well use whatever is described here: https://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux.git/tree/Documenta...
The commit that was pointed in the original fix clearly stated that the NAND chip node was targeted, not the NAND controller node. I hope this is correctly supported in U-Boot though. So if there is a NAND chip subnode, I suppose U-Boot would try to create the partitions that are inside, or even in the sub "partitions" container.
I hope things are clearer now.
Thanks, Miquèl
miquel.raynal@bootlin.com wrote on Fri, 2 Dec 2022 16:49:04 +0100:
Hi Marek,
Hi Marek,
Hi Francesco,
Yes please !
Yes.
Yes
Perhaps I should also mention that #size-cells expected to be 0 has nothing to do with the "partitions" container (otherwise #address-cells would be 0 as well). This value is however asking for an address-only reg property describing which NAND chip should be addressed and how, basically the NAND controller CS because you can wire your NAND to any CS.
Thanks, Miquèl
On 12/2/22 16:49, Miquel Raynal wrote:
Hi Marek,
Hi Marek,
Hi Francesco,
Yes please !
Yes.
Yes
I don't know, maybe it is not.
Sure.
OK, I see your point. So basically this?
&gpmi { #size-cells = <1>; ... nand-chip@0 { reg = <0>; }; };
btw. the GPMI NAND controller supports only one chipselect, so the reg in nand-chip node makes little sense.
I think this is another miscommunication here. The commit
modifies the size-cells of the NAND controller. The nand-chip is not involved in this at all . In the examples above, it's the "&gpmi" node size-cells that is modified.
My understanding is that U-Boot checks the nand-controller node size-cells, not the nand-chip{} or partitions{} subnode size-cells .
Francesco, can you please share the DT, including the U-Boot generated partitions, which is passed to Linux on Colibri MX7 ? I think that should make all confusion go away.
(or am I the only one who's still confused here?)
Hi Marek,
marex@denx.de wrote on Fri, 2 Dec 2022 17:17:59 +0100:
Hi Marek,
Hi Marek,
>> On 12/2/22 15:05, Miquel Raynal wrote: Hi Francesco,
Yes please !
Yes.
Yes
Sure.
I randomly opened a reference manual (IMX6DQL.pdf), they say:
"Up to four NAND devices, supported by four chip-selects and one ganged ready/ busy."
Anyway, the NAND controller generic bindings which require this reg property, what the controller or the driver actually supports, or even how it is used on current designs is not relevant here.
Yes I know. I was referring to this commit, sorry: 36fee2f7621e ("common: fdt_support: add support for "partitions" subnode to fdt_fixup_mtdparts()")
The log says:
Listing MTD partitions directly in the flash mode has been deprecated for a while for kernel Device Trees. Look for a node "partitions" in the found flash nodes and use it instead of the flash node itself for the partition list when it exists, so Device Trees following the current best practices can be fixed up.
Which (I hope) means U-boot will equivalently try to play with the partitions container, either in the controller node or in the chip node.
I don't think U-Boot cares.
Please also do it with the NAND chip described. If, when the NAND chip is described U-Boot tries to create partitions in the controller node, then the situation is even worse than I thought. But I believe describing the node like a suggest in the DT should prevent the boot failure while still allowing a rather good description of the hardware.
BTW I still think the relevant action right now is to revert the DT patch.
Thanks, Miquèl
On 12/2/22 17:42, Miquel Raynal wrote:
Hi Marek,
Doh, and MX7D has the same controller, so size-cells = <1>; makes sense with nand-chip@N {} .
The log says:
I am starting to bank toward that variant as well (thanks for clarifying the rationale in the discussion, that helped a lot).
But then, the follow up fix would be what exactly, update the binding document to require #size-cells = <1>; ?
Hi Marek,
marex@denx.de wrote on Fri, 2 Dec 2022 17:52:05 +0100:
Hi Marek,
Actually #address-cells is here for that. You need to point at one CS, so in most cases this is:
controller { #address-cells = <1>; #size-cells = <0>; chip@N { reg = <N>; }; };
The log says:
Thanks, Miquèl
On 12/2/22 17:57, Miquel Raynal wrote:
Hi Marek,
Hi Marek,
Right ... thanks for spotting this.
But then the size-cells in the controller node should be zero. And 753395ea1e45 ("ARM: dts: imx7: Fix NAND controller size-cells") is therefore correct ?
But that correction in 753395ea1e45 breaks setup where old U-Boot injects partition@N directly into the nand-controller node, without updating the nand-controller node size-cells, i.e. this: nand-controller { #address-cells = <1>; #size-cells = <0>;
+ partition@0 { ... }; }; Because the size-cells is 0 in that case, and U-Boot does not update the size-cells .
It used to work before because Linux DT contained size-cells=<1> in the nand-controller node before 753395ea1e45 ("ARM: dts: imx7: Fix NAND controller size-cells").
But here I would say this is a firmware bug and it might have to be handled like a firmware bug, i.e. with fixup in the partition parser. I seem to be changing my opinion here again.
I was thinking at this over the weekend, and I came to the following ideas:
- we need some improvement on the fixup we already have in the partition parser. We cannot ignore the fdt produced by U-Boot - as bad as it is. - the proposed fixup is fine for the immediate need, but it is not going to be enough to cover the general issue with the U-Boot generated partitions. U-Boot might keep generating partitions as direct child of the nand controller even when a partitions{} node is available. In this case the current parser just fails since it looks only into it and it will find it empty. - the current U-Boot only handle partitions{} as a direct child of the nand-controller, the nand-chip is ignored. This is not the way it is supposed to work. U-Boot code would need to be improved.
With all of that said I think that Miquel is right
Francesco
Hi Francesco,
francesco@dolcini.it wrote on Mon, 5 Dec 2022 12:26:44 +0100:
I've been thinking about it this weekend as well and the current fix which "just set" s_cell to 1 seems risky for me, it is typically the type of quick & dirty fix that might even break other board (nobody knew that U-Boot current logic expected #size-cells to be set in the DT, what if another "broken" DT expects the opposite...), not mentioning potential issues with big storages (> 4GiB).
All in all, I really think we should revert the DT change now, reverting as little to no drawbacks besides a dt_binding_check warning and gives us time to deal with it properly (both in U-Boot and Linux).
Francesco
Thanks, Miquèl
On 12/5/22 14:49, Miquel Raynal wrote:
Hi Francesco,
Then with the current configuration, such broken DT would not work, since current DT does set #size-cells=<1> (wrongly).
I am really not happy with this, but if that's marked as intermediate fix, go for it.
How do we deal with this in the long run however? Parser-side fix like this one, maybe with better heuristics ?
Hi Marek & Francesco,
marex@denx.de wrote on Mon, 5 Dec 2022 17:25:11 +0100:
Hi Francesco,
Yesterday while talking about an ACPI mis-description which needed fixing, I realized fixing up what the firmware provides to Linux should preferably be handled as early as possible. So my first first idea was to avoid using the broken "fixup mtdparts" function in U-Boot and I am still convinced this is what we should do in priority. However, as rightly pointed in this thread, we need to take care about the case where someone would use a newer DT (let's say, with the reverted changed reverted again) with an old U-Boot. I am still against piggy hacks in the generic ofpart.c driver, but what we could do however is a DT fixup in the init_machine (or the dt_fixup) hook for imx7 Colibri, very much like this: https://elixir.bootlin.com/linux/latest/source/arch/arm/mach-mvebu/board-v7.... Plus a warning there saying "your dt is broken, update your firmware".
So next time someone stumbles upon this issue, we can tell them "fix your bootloader", and apply the same hack in their board family (there are three or four IIRC which might be concerned some day).
That would fix all cases and only have an impact on the affected boards.
Thanks, Miquèl
Hi Francesco,
This does not work, because the old U-Boot fixup_mtdparts() may be applied on any machine, it is not colibri mx7 specific. Also, new arch-side workaround are really not welcome by the architecture maintainers as far as I can tell.
There are also those machines we do not even know about which might be generating bogus DT using old U-Boot and fixup_mtdparts(), so, unless there is some all-arch fixup implementation, we wouldn't be able to fix them all on arch side. I think the all-arch fixup implementation would be the driver one, i.e. this patch as it is (or maybe with some improvement).
Sadly, it does only fix the known cases, not the unknown cases like downstream forks which never get any bootloader updates ever, and which you can't find in upstream U-Boot, and which you therefore cannot easily catch in the arch side fixup.
Hi Marek,
marex@denx.de wrote on Thu, 15 Dec 2022 08:45:33 +0100:
Hi Francesco,
>> On Fri, Dec 02, 2022 at 06:08:22PM +0100, Marek Vasut wrote: But here I would say this is a firmware bug and it might have to be handled like a firmware bug, i.e. with fixup in the partition parser. I seem to be changing my opinion here again.
No: https://elixir.bootlin.com/u-boot/latest/A/ident/fdt_fixup_mtdparts And we should make our best so its use does not proliferate. It's not like there is half a dozen of good ways to describe and forward partitions today.
So what? Let's propose the change and see what the maintainers have to say. I am open to discussion.
As I said, it is not colibri mx7 specific, there are a few boards which might be affected, they are all clearly identifiable with a compatible. It's not the entire planet either.
If we don't know about them, as you say, I don't feel concerned.
If something is buggy, people will report it, we will point them in the right direction so they can fix their firmware and propose a similar fix in their case which will involve adding a new machine compatible to the list of boards that should tweak the #size-cell property.
And ?
Thanks, Miquèl
On 12/15/22 09:04, Miquel Raynal wrote:
Hi Marek,
These are the boards from vendors who upstreamed their properly.
This does NOT take into account either boards which are using downstream U-Boot, or older U-Boot e.g. because they can not easily update.
I am not disputing that, but that's a separate U-Boot side fix which I hope Francesco would submit soon, AND, more importantly, the code is already in at least two U-Boot releases, so it's done, it's not going away any time soon.
That's really not what I am disputing here, the approach to describing partitions is crystal clear as far as I can tell.
Why is there such strong opposition toward generic fix in the OF partition parser ?
... that you know about ...
Neither of us can make this statement with certainty, because neither of us knows what hardware is running the affected version of U-Boot.
Why is a potentially lengthy list of compatible strings in arch code, which every single user has to find _after_ their system completely fails to boot and forces them to perform potentially difficult recovery, potentially after an update to new linux-stable release no less -- over -- 4 liner generic fix in OF partition parser, which covers all the systems, does not cause systems to fail to boot completely, does not force users to suffer through recovery, does not require a list of compatibles in arch code, and rather only gracefully prints a warning ?
I very much prefer the second solution over the first.
And one more thing, the list of compatibles in arch code does not really work anyway, since once user updates their bootloader, the compatible won't change and the arch-side workaround would still be applied, which is not desired at that point anymore.
And ?
I was under the impression Linux was supposed to deliver the best possible experience to its users even on not-perfect hardware, and if there are any quirks, the kernel should try to fix them up or work around them as best as it can, not dismiss them as broken hardware and fail to boot outright.
And ?
I would say something more on this.
We are not talking about Linux not working well on some hardware, we are talking about breaking hardware that was working fine since ever. I believe that the Linux has a quite strong point of view on such kind of regression.
Quoting Linus
If the kernel used to work for you, the rule is that it continues to work for you.
Francesco
Hello Marek and Miquel,
This is something that was already discussed, but I was not really thinking much on it till now. Do you think that the whole idea of editing the MTD partitions from the firmware is wrong and we should just pass the partition on the command line OR that the current implementation is broken and can/should be fixed?
I have a couple of concerns/question with this approach: - do we have a single point to handle this? Different architectures are affected by these issue. Duplicating the fixup code in multiple place does not seems a great idea - If we believe that the device tree is wrong, in the i.MX7 case because of #size-cells should be set to 0 and not 1, we should not alter the FDT. Other part of the code could rely on this being correctly set to 0 moving forward.
If I understood you are proposing to have a fixup at the machine level that is converting a valid nand-controller node definition to a "broken" one. Unless I misunderstood you and you are thinking about rewriting the whole MTD partition from a broken definition to a proper one.
And ?
I'm not personally and directly concerned, since the machine I care are all available upstream and known, however this is a general problem with U-Boot code being at the same time widely used on a range of embedded products and producing a broken MTD partition list.
I think we will just silently break boards and just creating a lot of issues to people. We would just introduce regression to the users, being aware of it and deliberately decide to not care and move the problem to someone else. I do not think this is a good way to go.
Francesco
No, patching the partition layout into DT is fine. Firmwares of all kinds have been patching various parts of the DT before passing it to OS since forever, or more recently, merging multiple DT fragments and passing the composite DT to Linux.
As far as I recall, OF predates Linux and the OF tree has been usually assembled by the Forth firmware of that era from various chunks stored in different parts of the system. So this patching is fundamental part of the design since the beginning.
It is difficult to describe complex structure like the partition mapping on kernel command line, it should really be in DT or other such structure, so patching it into the DT is fine. The only detail here is, it should be patched into the DT correctly ... and ... if old firmwares do not do that, Linux should fix it up. You don't throw away your old PC just because it doesn't have perfect ACPI tables one would expect today, I don't see why we should do that with DT machines.
And ?
I agree.
marex@denx.de wrote on Fri, 16 Dec 2022 11:46:18 +0100:
I think describing it in the DT is fine and welcome. I think patching it in the DT is ugly. My 2cts.
No, quite the opposite.
Either size-cell is wrong which makes the description totally inconsistent (if size-cell is there, it must have a use, otherwise why do we keep it?) and we must fix it, or it is right and we should not touch it.
What I propose is to check very early whether the description is consistent on the board known to have this problem. If the description is wrong, we fix it and the generic parser can then do its work properly.
And ?
What? Since when my proposal is breaking boards? My proposal leads to a situation where: - If you have a board that has an inconsistent description but worked, it will still work. - If you have a board that has a consistent description and worked, it will still work. - If your have a board that has an inconsistent description and got broken *recently* by another change (typically you "fix" the DT in Linux to comply with the bindings), then you get a warning that leads you on the right path, you then update your bootloader if you can, but either way you add your machine compatible to the list of devices which need the early fix and your boot is fixed. - If you add support for a new board with an old kernel and have an inconsistent description it does not "just work because we have an automatic piggy hack in the driver". I am against it.
Whether or not it is acceptable by arch maintainer is something else, we won't know until we include them in the loop with a proper patch.
Thanks, Miquèl
What if we add `nand-chip{}` children in the future (the i.MX nand controller has nothing implemented not described in the schema so far, but it is something that is supported by the hw)? Will this idea still works?
And ?
What?
Let me rephrase, I was not clear enough.
This implies that we can proactively catch all the affected boards. I do not believe this is reasonable and because of that my comment before about creating regression to the users.
Francesco
Hi Francesco,
francesco@dolcini.it wrote on Fri, 16 Dec 2022 13:37:31 +0100:
I think yes. I mean, moving to a
nand-controller { nand-chip { partitions { part@x part@y } } }
scheme is what we should eventually find on all maintained boards, but I would say, at the very least, the description must be coherent.
But my previous answer was only focusing on the case where you change something in the kernel or in the DT that breaks the board because of the mess fdt_fixup_mtdparts() brings.
And ?
What?
I really don't understand the reasoning here.
What I say is: let's fix the boards known to be incorrectly described when we break them so they continue working with a broken firmware.
What regression could this possibly bring? I don't care about catching the 2k boards out there which work but wrongly describe their partitions. If they work, they will continue working.
You and Marek say: let's blindly always change a property in the DT, no matter if the board is broken, even if we don't know if this is the right thing to do, and apply this to the entire world.
But with this approach you're not worried about regressions.
I am sorry it does not stand.
Thanks, Miquèl
On 12/16/22 14:37, Miquel Raynal wrote:
What?
The second part of the message, as far as I understand it, is "ignore problems this will cause to users of boards we do not know about, let them run into unbootable systems after some linux kernel update, and once they suffer through system recovery, make them add compatible string to the arch-side workaround".
Those boards would start failing once the Linux-side DT size-cells is corrected.
Also, this got missed in the previous discussion. If you use only board compatible string in arch-side workaround, the workaround would be applied even on systems with updated bootloaders, which is likely not what we want.
As far as I can tell, if we have partitions in the NAND controller node and size-cells=0, then the right thing to do is to override size-cells to 1 , because partitions with size-cells=0 make no sense.
If the heuristics here needs to be improved somehow, let's discuss that.
Hi Marek,
marex@denx.de wrote on Fri, 16 Dec 2022 15:32:28 +0100:
What?
Now you know what kernel update will break them, so you can prevent it from happening.
For boards without even a dtsi in the kernel, should we care?
If the heuristics here needs to be improved somehow, let's discuss that ;)
How do you know the firmware did not set #size-cell=0 on purpose to avoid using the partitions? How would this be more stupid than updating partitions without setting #size-cell to the right value? Can you be so sure every board in the world will never do that? And how do you handle the 64-bit case as well? You _do_no_know_ what applies in all the cases, guessing is dangerous here, you'll just support new broken cases or even break existing setups! What you do know however is what applies for a number of cases your clearly identified. Applying this logic to *all* cases in simply _broken_ and utterly stupid (tm). I don't know how to express that so we stop bike-shedding.
Thanks, Miquèl
Would caring for those boards not be just exact the same as caring for some UEFI/ACPI mess for which no source code is normally available and nobody really known at which point the various vendors have forked their source code from some Intel or AMD or whatever reference code?
IMHO we should care for the multiple reason I have already written in my previous emails.
And honestly, just as a side comment, I would feel way more happy to know that the elevator control system in the elevator I use everyday or the chemical industrial plan HMI next to my home is running an up to date Linux system that is not affected by known security vulnerabilities and they did stop updating it just because there was some random bug preventing the updated kernel to boot and nobody had the time/skill to investigate and fix it. [1]
Francesco
[1] this is pure fictional, I have no elevator in my condo and no industrial plant next to my home :-), yet I know that this non upstream boards we are talking about are used every day in such environments ...
Hi Francesco,
francesco@dolcini.it wrote on Fri, 16 Dec 2022 17:30:18 +0100:
I am sorry I don't know UEFI/ACPI well enough to discuss it.
The issue comes from a very specific U-Boot function that should have never existed. I hope people working on chemical plants do not make use of these and will not disregard the "your DT is broken there [...]" warning we plan to add right before their updated board will fail. We are not living people in the dark, I agreed for a warning, but I don't think applying the proposed fix blindly is wise and future-proof.
Thanks, Miquèl
Hi Francesco,
miquel.raynal@bootlin.com wrote on Mon, 2 Jan 2023 10:40:04 +0100:
Hi Francesco,
Let's move forward with this. Let's assume my fears are baseless. We might consider the situation where someone tries to hide the partitions by setting #size-cell to 0 even wronger and too unlikely. Hopefully we will not break any other existing setups by applying an always-on fix.
I would still like to see U-Boot partitions handling evolve, at least: - fix #size-cells in fdt_fixup_mtd() - avoid the fdt_fixup_mtd() call from Collibri boards (ie. an example that can be followed by the other users)
On Linux side let's fix #size-cells like you proposed without filtering against a list of compatibles. We however need to improve the heuristics: - Do it only when there are partitions declared within a NAND controller node. - Change the warning to avoid mentioning backward compatibility, just mention this is utterly wrong and thus the value will be set to 1 instead of 0. - Mention in the comment above this only works on systems with <4GiB chips. If you think about other conditions please feel free to add them.
Do you concur?
Thanks, Miquèl
Hello Miquel,
Nice, good!
Fine, I can do it.
However I am just not 100% sure about your proposal, I wonder if we should just deprecate this function or we should fix it. The exact end result will depend on the discussion with the U-Boot folks, but I absolutely agree that the current situation needs to change. I'll keep you in CC on those patches.
Do you concur?
Yes, I do agree.
Side comment, I have been recently busy with other life AND work priorities and this task was just idling on the bottom of my backlog. I do not see the situation improving that much in the next few weeks.
Said that patches coming, I am committed to have this sorted out before the next Linux Kernel merge window, for U-Boot the merge window opens in 3 days and I am already late, let's see, this might be as well considered a fix that is fine for a late integration.
Francesco
On 1/5/23 13:47, Francesco Dolcini wrote:
Hello Miquel,
Nice, good!
Indeed
Fine, I can do it.
I would say fix it.
Do you concur?
Yes, I do agree.
Same here, agreed, thanks.
marex@denx.de wrote on Thu, 5 Jan 2023 15:51:10 +0100:
Hello Miquel,
Nice, good!
Indeed
Fine, I can do it.
I would say fix it.
Well, I think these are two orthogonal changes. The function should be deprecated *and* fixed for the existing users?
Do you concur?
Yes, I do agree.
Thanks, Miquèl
It's like that for U-Boot older than v2022.04 ... and IMO we cannot ignore it.
Said that from the code U-Boot looks into a `partition{}` node only as a direct child of the nand-controller, if there is a nand-chip in between the nand-controller{} and the partitions{} it will just ignore it.
I could try to see what it is doing exactly, but I would need a little bit more time, I just tried changing the DTS as wrote I got a non bootable system.
Francesco
Hello Miquel
If I have a nand-chip { partitions {} } described in the dts U-Boot (even the latest one) ignores it and generates the partition as child of the nand controller, the linux parser however see that partitions{} exists, even if empty, and ignore the partition directly defined as child of the nand controller.
TL;DR: parser fails and boot fails according to that.
Francesco
Hi Francesco,
francesco@dolcini.it wrote on Mon, 5 Dec 2022 12:30:16 +0100:
Hello Miquel
Yeah I get that. For me the longterm goal should be to just kill that function. We have proper DT support today, Linux knows how to read the mtdparts cmdline variable, so there is no need for anything else. I guess in U-Boot we should just: - warn users of this function that the function is deprecated and they should update their machine support - just migrate to another solution on the colibri board
What do you think?
Thanks, Miquèl
Not 100% correct.
- U-Boot before v2022.04 updates the nand-controller{} node, no matter what. - U-Boot starting from v2022.04 looks for `partitions{}` into the nand-controller{} node, and creates the partition into it if found. If not found it behaves the same way as the previous versions. See commit 36fee2f7621e ("common: fdt_support: add support for "partitions" subnode to fdt_fixup_mtdparts()")
I'd like to stress once more the fact that we cannot expect old U-Boot to be updated in the field, and they will keep generating the partitions as child of the nand-controller node whatever we do with the dts file.
I think that this should be treated the same way as any other fixup we might have for broken firmware, especially considering that this used to "work" (yes, I can agree that it horrible, but I cannot change the past) without even a warning since the imx7 support was first introduced in the linux kernel years ago.
The device tree part is easy, just arch/arm/boot/dts/imx7d-colibri-eval-v3.dts.
and the nand-controller node is coming from
#include "imx7d.dtsi"
plus
&gpmi { fsl,use-minimum-ecc; nand-ecc-mode = "hw"; nand-on-flash-bbt; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpmi_nand>; };
The partitions nodes are generated 100% by U-Boot, nothing is present in the dts source files.
With this DTS file as input, whatever U-Boot version is used I have the following generated:
root@colibri-imx7-02844233:/# ls /proc/device-tree/soc/nand-controller@33002000/ #address-cells dma-names nand-on-flash-bbt pinctrl-0 #size-cells dmas partition@0 pinctrl-names assigned-clock-parents fsl,use-minimum-ecc partition@200000 reg assigned-clocks interrupt-names partition@380000 reg-names clock-names interrupts partition@400000 status clocks name partition@80000 compatible nand-ecc-mode phandle
root@colibri-imx7-02844233:/# ls /proc/device-tree/soc/nand-controller@33002000/partition@* /proc/device-tree/soc/nand-controller@33002000/partition@0: label name reg
/proc/device-tree/soc/nand-controller@33002000/partition@200000: label name read_only reg
/proc/device-tree/soc/nand-controller@33002000/partition@380000: label name reg
/proc/device-tree/soc/nand-controller@33002000/partition@400000: label name reg
/proc/device-tree/soc/nand-controller@33002000/partition@80000: label name read_only reg
Hi Francesco,
francesco@dolcini.it wrote on Fri, 2 Dec 2022 17:45:37 +0100:
Not 100% correct.
plus
I hope if you provide a NAND chip child node, the partitions are created at the right location, otherwise this is so, so wrong...
Thanks, Miquèl
On 02.12.22 15:31, Marek Vasut wrote:
On 12/2/22 15:05, Miquel Raynal wrote: [...]
- To fix the current situation:
Well, that might be the right solution in the long run, that's up for others to decide, but we need to fix this *quickly*. For two reasons actually: the 6.1 release is near and the change was backported to stable already.
For details wrt to the "quickly", see "Prioritize work on fixing regressions" here: https://docs.kernel.org/process/handling-regressions.html
IOW: Ideally it should be fixed by Sunday.
I'll hence likely soon will point Linus to this and suggest to revert this, unless there are strong reasons against that or some sort of agreement on a better solution.
Ciao, Thorsten (wearing his 'the Linux kernel's regression tracker' hat)
P.S.: As the Linux kernel's regression tracker I deal with a lot of reports and sometimes miss something important when writing mails like this. If that's the case here, don't hesitate to tell me in a public reply, it's in everyone's interest to set the public record straight.
You might want to wait until everyone is back on Monday, the discussion is still ongoing, but it seems to be getting to a conclusion.
Yeah, came to a similar conclusion, but want to mentioned it nevertheless and already have this prepared (together will appropriate links to the discussion):
``` A regression causing boot failures on iMX7 (due to a backport this is also affecting 6.0.y) could be fixed with a quick revert as well. But looks like there is no need for it, after some back and forth the developers that care are close to come to an agreement how to fix the problem properly soonish: ```
Ciao, Thorsten
ACK, thanks
Francesco Dolcini
Miquel Raynal
Thorsten Leemhuis
