Please pull u-boot-marvell/master
Hi Tom,
please pull this next batch of Marvell MVEBU related patches:
---------------------------------------------------------------- - mvebu: Fix usage of BIN header arguments (Pali) - mvebu: turris_omnia: Fix MTD partitions order for Linux (Pali) - mvebu: nandpagesize support for kwbimage v1 (Pali) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=127&view=resu...
Thanks, Stefan
The following changes since commit 670d657dfb6ede2957043dd0ac868297ac093857:
Merge tag 'efi-2022-01-rc1-2' of https://source.denx.de/u-boot/custodians/u-boot-efi (2021-10-26 18:42:52 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 7af368f4717a2c4b118f8cae597e268dc88a726c:
arm: mvebu: Fix comments about kwbimage structures (2021-10-28 10:33:32 +0200)
---------------------------------------------------------------- Pali Rohár (9): tools: kwboot: Align UART baudrate change code in BIN header to 128-bit boundary tools: kwbimage: Align BIN header executable code to 128-bit boundary arm: mvebu: Add documentation for save_boot_params() function arm: mvebu: Remove dummy BIN header arguments for SPL binary arm: mvebu: turris_omnia: Fix MTD partitions order for Linux tools: kwbimage: Add support for NAND_PAGE_SIZE command also for v1 images tools: kwboot: Patch nandpagesize to zero also for v1 image arm: mvebu: Update name of kwbimage v1 field at offset 0x2-0x3 arm: mvebu: Fix comments about kwbimage structures
arch/arm/mach-mvebu/kwbimage.cfg.in | 2 +- arch/arm/mach-mvebu/lowlevel_spl.S | 9 ++++++ arch/arm/mach-mvebu/spl.c | 4 +-- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- cmd/mvebu/bubt.c | 4 +-- tools/kwbimage.c | 54 ++++++++++++++++++++++---------- tools/kwbimage.h | 2 +- tools/kwboot.c | 35 ++++++++++++++------- 8 files changed, 76 insertions(+), 36 deletions(-)
Stefan Roese
