[U-Boot] [RFC] cmd: add bootslot command to select/boot slot based on boot counts
The existing bootcount feature is targeted systems with a primary, and a rescue boot setup, where the number of boot tries to the primary boot is tracked. If the number exceeds the limit, the alternative/rescue is booted.
This patch adds support for a more sophisticated setup, where more than two boot slots can exist, and the order of slots can be configured.
The 'bootcommand' command reads the configured slots (and their priority/order) from a configured environment variable ("bootslots" by default). For each conifgured slot, a remaining boot count is maintained in an evnironment variable ("bootcount_<slot>" by default). If the first boot slot has positive boot count, it is booted using the slot specific boot command ("bootcmd_<slot>" by default). Otherwise the next slot is checked.
An example environment when using the bootslot command with two slots ("a" and "b"):
bootslots=a b bootcount_a=3 bootcount_b=3 bootcmd_a=setenv bootargs $bootargs root=/dev/mmcblk0p1; booti $loadaddr bootcmd_b=setenv bootargs $bootargs root=/dev/mmcblk0p2; booti $loadaddr
Once linux is booted, it resets the bootcount variable for the booted slot using "fw_setenv":
fw_setenv bootcount_a 3
When the non-booted slot is updated, the order is updated by setting the bootslots variable with "fw_setenv":
fw_setenv bootslots=b a
Signed-off-by: Martin Hundebøll martin@geanix.com --- cmd/Kconfig | 42 +++++++++ cmd/Makefile | 1 + cmd/bootslot.c | 225 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 268 insertions(+) create mode 100644 cmd/bootslot.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index aec209006d..3919606e74 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1277,6 +1277,48 @@ config CMD_BOOTCOUNT Enable the bootcount command, which allows interrogation and reset of the bootcounter.
+config CMD_BOOTSLOT + bool "Enable support for multiple boot slots" + help + Parses an ordered list of configured boot slot names (e.g. "a b") + and selects a corresponding boot command based on the current + boot counter for each slot. + +config CMD_BOOTSLOT_ENV_SLOTS + string "Environment variable to read bootslots from" + depends on CMD_BOOTSLOT + default "bootslots" + help + Configures the environment variable to read out when looking for a + list of available boot sloots. + +config CMD_BOOTSLOT_ENV_COUNT + string "Environment variable format string to read/write slot boot count from/to" + depends on CMD_BOOTSLOT + default "bootcount_%s" + help + Configures the prefix to use when reading the boot count for a + specific slot. The prefix is concatenated with the slot name, so + that the boot count for slot "a" is read and saved to "<prefix>a". + +config CMD_BOOTSLOT_ENV_CMD + string "Environment variable format string to read slot boot command from" + depends on CMD_BOOTSLOT + default "bootcmd_%s" + help + Configures the prefix to use when reading the boot command for + specific slot. The prefix is concatenated with the slot name, so + that the boot command for slot "a" is read from "<prefix>a". + +config CMD_BOOTSLOT_DEFAULT_COUNT + int "Default boot count for each configured slot" + depends on CMD_BOOTSLOT + default 3 + help + The default number of times a slot is tried before proceeding to the + slot. The default is used when a slot has no count yet, or when it + is reset with the "bootslot reset" command. + config CMD_BSP bool "Enable board-specific commands" help diff --git a/cmd/Makefile b/cmd/Makefile index 323f1fd2c7..68c8e50c91 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -26,6 +26,7 @@ obj-$(CONFIG_CMD_BOOTCOUNT) += bootcount.o obj-$(CONFIG_CMD_BOOTEFI) += bootefi.o obj-$(CONFIG_CMD_BOOTMENU) += bootmenu.o obj-$(CONFIG_CMD_BOOTSTAGE) += bootstage.o +obj-$(CONFIG_CMD_BOOTSLOT) += bootslot.o obj-$(CONFIG_CMD_BOOTZ) += bootz.o obj-$(CONFIG_CMD_BOOTI) += booti.o obj-$(CONFIG_CMD_BTRFS) += btrfs.o diff --git a/cmd/bootslot.c b/cmd/bootslot.c new file mode 100644 index 0000000000..03897b1f60 --- /dev/null +++ b/cmd/bootslot.c @@ -0,0 +1,225 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018, Geanix, All rights reserved. + */ + +#include <common.h> +#include <environment.h> +#include <stdlib.h> +#include <linux/kernel.h> +#include <linux/string.h> +#include <linux/compat.h> +#include <vsprintf.h> + +static char *bootslot_envname(const char *fmt, const char *slot) +{ + int len = strlen(fmt) + strlen(slot); + char *envname = malloc(len + 1); + + sprintf(envname, fmt, slot); + + return envname; +} + +static unsigned long bootslot_get_count(const char *slot) +{ + char *envname; + unsigned long count; + + envname = bootslot_envname(CONFIG_CMD_BOOTSLOT_ENV_COUNT, slot); + count = env_get_ulong(envname, 10, CONFIG_CMD_BOOTSLOT_DEFAULT_COUNT); + free(envname); + + return count; +} + +static void bootslot_set_count(const char *slot, unsigned long count) +{ + char *envname; + + envname = bootslot_envname(CONFIG_CMD_BOOTSLOT_ENV_COUNT, slot); + env_set_ulong(envname, count); + free(envname); +} + +static const char *bootslot_get_cmd(const char *slot) +{ + char *envname; + char *cmd; + + envname = bootslot_envname(CONFIG_CMD_BOOTSLOT_ENV_CMD, slot); + cmd = env_get(envname); + free(envname); + + return cmd; +} + +static char *bootslot_get_slots(int argc, char * const argv[]) +{ + char *slots = NULL; + int len = 1; /* make room for terminating \0 */ + int i; + + /* read boot slots from environment if no args are given, or + * duplicate the argument if a single argument is given */ + if (argc == 1) + return strdup(env_get(CONFIG_CMD_BOOTSLOT_ENV_SLOTS)); + else if (argc == 2) + return strdup(argv[1]); + + /* compute the string length of the list of slots */ + for (i = 1; i < argc; i++) + len += strlen(argv[i]) + 1; /* add room for space separator */ + + /* allocate the string buffer and copy each slot argument to it */ + slots = kzalloc(len, 0); + strcpy(slots, argv[1]); + + for (i = 2; i < argc; i++) { + strcat(slots, " "); + strcat(slots, argv[i]); + } + + return slots; +} + +static int do_bootslot_list(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + char *mem = bootslot_get_slots(argc, argv); + char *slots = mem; + char *slot; + + if (slots == NULL) + return CMD_RET_USAGE; + + printf("slot\tcount\tbootcmd\n"); + while ((slot = strsep(&slots, " ")) != NULL) { + unsigned long count; + const char *bootcmd; + + if (strlen(slot) == 0) + continue; + + count = bootslot_get_count(slot); + bootcmd = bootslot_get_cmd(slot); + + if (bootcmd) + printf("%s\t%lu\t%s\n", slot, count, bootcmd); + else + printf("%s\t%lu\t<not defined>\n", slot, count); + } + + free(mem); + + return CMD_RET_SUCCESS; +} + +static int do_bootslot_reset(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + char *mem = bootslot_get_slots(argc, argv); + char *slots = mem; + char *slot; + + if (slots == NULL) + return CMD_RET_USAGE; + + while ((slot = strsep(&slots, " ")) != NULL) { + if (strlen(slot) == 0) + continue; + bootslot_set_count(slot, CONFIG_CMD_BOOTSLOT_DEFAULT_COUNT); + } + + free(mem); + + return CMD_RET_SUCCESS; +} + +static int do_bootslot_boot(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + char *mem = bootslot_get_slots(argc, argv); + char *slots = mem; + char *slot; + bool found_valid = false; + + if (slots == NULL) + return CMD_RET_USAGE; + + while ((slot = strsep(&slots, " ")) != NULL) { + const char *bootcmd; + unsigned long count; + + if (strlen(slot) == 0) + continue; + + count = bootslot_get_count(slot); + if (count == 0) { + printf("slot %s bootcount is zero; trying next...\n", + slot); + continue; + } + + bootcmd = bootslot_get_cmd(slot); + if (bootcmd == NULL) { + printf("slot %s bootcmd not found; trying next...\n", + slot); + continue; + } + + printf("slot %s has %lu boot tries remaining; booting...\n", + slot, count); + found_valid = true; + bootslot_set_count(slot, --count); + env_save(); + run_command_list(bootcmd, -1, CMD_FLAG_ENV); + break; + } + + free(mem); + + if (found_valid == false) { + printf("no valid bootslot found; resetting counters\n"); + run_command("bootslot reset", 0); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static cmd_tbl_t cmd_bootslot_sub[] = { + U_BOOT_CMD_MKENT(boot, INT_MAX, 0, do_bootslot_boot, "", ""), + U_BOOT_CMD_MKENT(list, INT_MAX, 1, do_bootslot_list, "", ""), + U_BOOT_CMD_MKENT(reset, INT_MAX, 1, do_bootslot_reset, "", ""), +}; + +/* + * Process a bootslots sub-command + */ +static int do_bootslot(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + cmd_tbl_t *c; + + /* Strip off leading 'bootslot' command argument */ + argc--; + argv++; + + c = find_cmd_tbl(argv[0], cmd_bootslot_sub, + ARRAY_SIZE(cmd_bootslot_sub)); + + if (c) + return c->cmd(cmdtp, flag, argc, argv); + else + return CMD_RET_USAGE; +} + + +U_BOOT_CMD(bootslot, INT_MAX, 1, do_bootslot, + "Bootslot command", + " - select and boot slot based on counters\n" + "boot [<slot>] - Boot the passed or first valid slot in $bootslots\n" + "list [<slot>] - List remaining boot tries for passed or all slots in $bootslots\n" + "reset [<slot>] - Reset remaining boot tries for all or passed slot\n" +);
With RAUC bootslot's is specified with uppercase letters, uppercase is not preserved. We end up with BOOT_b_LEFT=2... botocmd_* is with lowercase, just to make things easier.
/Sean
Tested-by: Sean Nyekjaer sean.nyekjaer@prevas.dk
- bool "Enable support for multiple boot slots"
- help
- string "Environment variable to read bootslots from"
- depends on CMD_BOOTSLOT
- default "bootslots"
- help
- string "Environment variable format string to read/write slot boot count from/to"
- default "bootcount_%s"
- help
- string "Environment variable format string to read slot boot command from"
- default "bootcmd_%s"
- help
- int "Default boot count for each configured slot"
- default 3
- help
- config CMD_BSP bool "Enable board-specific commands" help
- Copyright (c) 2018, Geanix, All rights reserved.
- int len = strlen(fmt) + strlen(slot);
- char *envname = malloc(len + 1);
- sprintf(envname, fmt, slot);
- return envname;
- char *envname;
- unsigned long count;
- envname = bootslot_envname(CONFIG_CMD_BOOTSLOT_ENV_COUNT, slot);
- count = env_get_ulong(envname, 10, CONFIG_CMD_BOOTSLOT_DEFAULT_COUNT);
- free(envname);
- return count;
- char *envname;
- env_set_ulong(envname, count);
- free(envname);
- char *envname;
- char *cmd;
- envname = bootslot_envname(CONFIG_CMD_BOOTSLOT_ENV_CMD, slot);
- cmd = env_get(envname);
- free(envname);
- return cmd;
- char *slots = NULL;
- int len = 1; /* make room for terminating \0 */
- int i;
- /* read boot slots from environment if no args are given, or
- if (argc == 1)
- else if (argc == 2)
- /* compute the string length of the list of slots */
- for (i = 1; i < argc; i++)
- /* allocate the string buffer and copy each slot argument to it */
- slots = kzalloc(len, 0);
- strcpy(slots, argv[1]);
- for (i = 2; i < argc; i++) {
strcat(slots, " ");
- return slots;
- char *mem = bootslot_get_slots(argc, argv);
- char *slots = mem;
- char *slot;
- if (slots == NULL)
- printf("slot\tcount\tbootcmd\n");
- while ((slot = strsep(&slots, " ")) != NULL) {
continue;
if (bootcmd)
else
- free(mem);
- return CMD_RET_SUCCESS;
- char *slot;
continue;
- free(mem);
- char *slot;
- bool found_valid = false;
continue;
if (count == 0) {
slot);
continue;
slot);
continue;
slot, count);
found_valid = true;
env_save();
break;
- free(mem);
- if (found_valid == false) {
- U_BOOT_CMD_MKENT(boot, INT_MAX, 0, do_bootslot_boot, "", ""),
- U_BOOT_CMD_MKENT(list, INT_MAX, 1, do_bootslot_list, "", ""),
- U_BOOT_CMD_MKENT(reset, INT_MAX, 1, do_bootslot_reset, "", ""),
- Process a bootslots sub-command
- cmd_tbl_t *c;
- /* Strip off leading 'bootslot' command argument */
- argc--;
- argv++;
- c = find_cmd_tbl(argv[0], cmd_bootslot_sub,
- if (c)
- else
- "Bootslot command",
- " - select and boot slot based on counters\n"
- "boot [<slot>] - Boot the passed or first valid slot in $bootslots\n"
- "list [<slot>] - List remaining boot tries for passed or all slots in $bootslots\n"
- "reset [<slot>] - Reset remaining boot tries for all or passed slot\n"
I cannot reproduce the lowercase issue. Can you send me your (def)config and environment?
% grep BOOTSLOT .config CONFIG_CMD_BOOTSLOT=y CONFIG_CMD_BOOTSLOT_ENV_SLOTS="BOOTORDER" CONFIG_CMD_BOOTSLOT_ENV_COUNT="BOOT_%s_LEFT" CONFIG_CMD_BOOTSLOT_ENV_CMD="BOOTCMD_%s" CONFIG_CMD_BOOTSLOT_DEFAULT_COUNT=3
% grep -i boot board/raspberrypi/rpi/env.txt BOOTORDER=A B bootargs_all=console=ttyS0,115200n8 rootfstype=squashfs rootwait bootargs_a=root=/dev/mmcblk0p2 bootslot=A bootargs_b=root=/dev/mmcblk0p3 bootslot=B set_bootargs_a=setenv bootargs $bootargs_all $bootargs_a set_bootargs_b=setenv bootargs $bootargs_all $bootargs_b bootcmd_common=run load_kernel; booti $loadaddr - $fdtcontroladdr BOOTCMD_A=run set_bootargs_a bootcmd_common BOOTCMD_B=run set_bootargs_b bootcmd_common bootcmd=bootslot boot
// Martin
/Sean
diff --git a/cmd/Kconfig b/cmd/Kconfig index aec209006d..3919606e74 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1277,6 +1277,48 @@ config CMD_BOOTCOUNT Enable the bootcount command, which allows interrogation and reset of the bootcounter. +config CMD_BOOTSLOT + bool "Enable support for multiple boot slots" + help + Parses an ordered list of configured boot slot names (e.g. "a b") + and selects a corresponding boot command based on the current + boot counter for each slot.
+ return count; +}
+ return cmd; +}
+ return slots; +}
+ free(mem);
+ free(mem);
+ free(mem);
I'm not able to reproduce the lowercase issue, I must have got the config wrong :-)
Please submit a [PATCH] for this as it could be very useful.
/Sean
Signed-off-by: Martin Hundebøll martin@geanix.com Tested-by: Sean Nyekjaer sean.nyekjaer@prevas.dk
We have used this for the past 1.5 years. Will you post this as a patch?
/Sean
Dear Martin,
This is not a correct summary of the current implementation. If the boot count exceeds the limit, some _alternative_boot_command_ is executed.
The trivial case is to boot another image / partion or such.
Butt nothing prevents you to run any more sophisticated scripts here.
This can easily implemented with a few lines of shell code as well.
I think it makes no sense to add a lot of code that can be implemented as a few lines of shell scripts as well, especially as this code is neither time critical nor has the potential of becoming widely used.
NAKed-by: Wolfgang Denk wd@denx.de
Martin Hundebøll
Sean Nyekjaer
Sean Nyekjær
