[U-Boot] [PATCH 0/1] Davinci: Make MAC address offset in EEPROM configurable
Like subjects say, offset of MAC adress in EEPROM changed from hardcoded value to a per board configurable value
The following changes since commit 79af5f82d78b8bbc5fe81302b8a4b7fb5d880f25:
Davinci: Fix, console output confusing while setting MAC address (2013-02-01 07:04:12 +0000)
git://gitorious.org/~kibo/u-boot-shr/kibos-u-boot kibo-master http://gitorious.org/~kibo/u-boot-shr/kibos-u-boot/commits/kibo-master
Kim Bøndergaard (1): Davinci: Make MAC address offset in EEPROM configurable CONFIG_SYS_I2C_EEPROM_MAC_OFFSET
arch/arm/cpu/arm926ejs/davinci/misc.c | 2 +- include/configs/da830evm.h | 1 + include/configs/davinci_dm365evm.h | 1 + include/configs/davinci_dm6467evm.h | 1 + include/configs/davinci_dvevm.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + 7 files changed, 7 insertions(+), 1 deletion(-)
--- arch/arm/cpu/arm926ejs/davinci/misc.c | 2 +- include/configs/da830evm.h | 1 + include/configs/davinci_dm365evm.h | 1 + include/configs/davinci_dm6467evm.h | 1 + include/configs/davinci_dvevm.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + 7 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/misc.c b/arch/arm/cpu/arm926ejs/davinci/misc.c index 7e5728c..3e82d9a 100644 --- a/arch/arm/cpu/arm926ejs/davinci/misc.c +++ b/arch/arm/cpu/arm926ejs/davinci/misc.c @@ -59,7 +59,7 @@ int dvevm_read_mac_address(uint8_t *buf) { #ifdef CONFIG_SYS_I2C_EEPROM_ADDR /* Read MAC address. */ - if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0x7F00, + if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_MAC_OFFSET, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, (uint8_t *) &buf[0], 6)) goto i2cerr;
diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index f7ac256..2fa4a79 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -80,6 +80,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00
/* * Network & Ethernet Configuration diff --git a/include/configs/davinci_dm365evm.h b/include/configs/davinci_dm365evm.h index 6a331aa..72ec862 100644 --- a/include/configs/davinci_dm365evm.h +++ b/include/configs/davinci_dm365evm.h @@ -53,6 +53,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00
/* Network Configuration */ #define CONFIG_DRIVER_TI_EMAC diff --git a/include/configs/davinci_dm6467evm.h b/include/configs/davinci_dm6467evm.h index 366c77f..93da788 100644 --- a/include/configs/davinci_dm6467evm.h +++ b/include/configs/davinci_dm6467evm.h @@ -48,6 +48,7 @@ extern unsigned int davinci_arm_clk_get(void); #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00
/* Memory Info */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index ab9cedd..c7917b4 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -67,6 +67,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00 /*=============*/ /* Memory Info */ /*=============*/ diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index 958b19a..d150f9e 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -39,6 +39,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00 /* Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 256*1024) /* malloc() len */ #define CONFIG_SYS_MEMTEST_START 0x80000000 /* memtest start address */ diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 3d8d392..fdec085 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -69,6 +69,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x7F00 /*=============*/ /* Memory Info */ /*=============*/
With the following addition to fix da850_am18xxevm:
diff --git a/boards.cfg b/boards.cfg index b1319aa..e89762b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -137,7 +137,7 @@ portuxg20 arm arm926ejs stamp9g20 taskit stamp9g20 arm arm926ejs stamp9g20 taskit at91 stamp9g20:AT91SAM9G20 cam_enc_4xx arm arm926ejs cam_enc_4xx ait davinci cam_enc_4xx da830evm arm arm926ejs da8xxevm davinci davinci -da850_am18xxevm arm arm926ejs da8xxevm davinci davinci da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 +da850_am18xxevm arm arm926ejs da8xxevm davinci davinci da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50,SYS_I2C_EEPROM_MAC_OFFSET=0x7F00 da850evm arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH da850evm_direct_nor arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT davinci_dm355evm arm arm926ejs dm355evm davinci davinci
Applied to u-boot-ti/master, thanks!
Blarg, I take it back. It's not applied as I see you didn't include a Signed-off-by line. Please incorporate the above change which is: Signed-off-by: Tom Rini trini@ti.com and submit a v3, assuming the rules for a Signed-off-by-line are true.
Kim Bøndergaard
